root/Development/ray/src/rt/rpaint.h
Revision: 2.2
Committed: Sat Feb 22 02:07:29 2003 UTC (22 years, 8 months ago) by greg
Changes since 2.1: +147 -6 lines
1 /* RCSid: $Id$ */
2 /*
3 * rpaint.h - header file for image painting.
4 */
5
6 /* ====================================================================
7 * The Radiance Software License, Version 1.0
8 *
9 * Copyright (c) 1990 - 2002 The Regents of the University of California,
10 * through Lawrence Berkeley National Laboratory. All rights reserved.
11 *
12 * Redistribution and use in source and binary forms, with or without
13 * modification, are permitted provided that the following conditions
14 * are met:
15 *
16 * 1. Redistributions of source code must retain the above copyright
17 * notice, this list of conditions and the following disclaimer.
18 *
19 * 2. Redistributions in binary form must reproduce the above copyright
20 * notice, this list of conditions and the following disclaimer in
21 * the documentation and/or other materials provided with the
22 * distribution.
23 *
24 * 3. The end-user documentation included with the redistribution,
25 * if any, must include the following acknowledgment:
26 * "This product includes Radiance software
27 * (http://radsite.lbl.gov/)
28 * developed by the Lawrence Berkeley National Laboratory
29 * (http://www.lbl.gov/)."
30 * Alternately, this acknowledgment may appear in the software itself,
31 * if and wherever such third-party acknowledgments normally appear.
32 *
33 * 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
34 * and "The Regents of the University of California" must
35 * not be used to endorse or promote products derived from this
36 * software without prior written permission. For written
37 * permission, please contact [email protected].
38 *
39 * 5. Products derived from this software may not be called "Radiance",
40 * nor may "Radiance" appear in their name, without prior written
41 * permission of Lawrence Berkeley National Laboratory.
42 *
43 * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
44 * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
45 * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
46 * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
47 * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
48 * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
49 * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
50 * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
51 * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
52 * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
53 * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
54 * SUCH DAMAGE.
55 * ====================================================================
56 *
57 * This software consists of voluntary contributions made by many
58 * individuals on behalf of Lawrence Berkeley National Laboratory. For more
59 * information on Lawrence Berkeley National Laboratory, please see
60 * <http://www.lbl.gov/>.
61 */
62
63 #include "driver.h"
64
65 #include "view.h"
66
67 typedef short COORD; /* an image coordinate */
68
69 typedef struct pnode {
70 struct pnode *kid; /* children */
71 COORD x, y; /* position */
72 COLOR v; /* value */
73 } PNODE; /* a paint node */
74
75 /* child ordering */
76 #define DL 0 /* down left */
77 #define DR 1 /* down right */
78 #define UL 2 /* up left */
79 #define UR 3 /* up right */
80
81 #define newptree() (PNODE *)calloc(4, sizeof(PNODE))
82
83 typedef struct {
84 COORD l, d, r, u; /* left, down, right, up */
85 } RECT; /* a rectangle */
86
87 extern PNODE ptrunk; /* the base of the image tree */
88
89 extern VIEW ourview; /* current view parameters */
90 extern VIEW oldview; /* previous view parameters */
91 extern int hresolu, vresolu; /* image resolution */
92
93 extern int greyscale; /* map colors to brightness? */
94
95 extern int pdepth; /* image depth in current frame */
96 extern RECT pframe; /* current frame rectangle */
97
98 extern double exposure; /* exposure for scene */
99
100 extern struct driver *dev; /* driver functions */
101
102 #ifdef NOPROTO
103
104 extern void devopen();
105 extern void devclose();
106 extern void printdevices();
107 extern void fillreserves();
108 extern void freereserves();
109 extern void command();
110 extern void rsample();
111 extern int refine();
112 extern void getframe();
113 extern void getrepaint();
114 extern void getview();
115 extern void lastview();
116 extern void saveview();
117 extern void loadview();
118 extern void getaim();
119 extern void getmove();
120 extern void getrotate();
121 extern void getpivot();
122 extern void getexposure();
123 extern int getparam();
124 extern void setparam();
125 extern void traceray();
126 extern void writepict();
127 extern int getrect();
128 extern int getinterest();
129 extern float *greyof();
130 extern void paint();
131 extern void newimage();
132 extern void redraw();
133 extern void repaint();
134 extern void paintrec();
135 extern PNODE *findrect();
136 extern void scalepict();
137 extern void getpictcolrs();
138 extern void freepkids();
139 extern void newview();
140 extern void moveview();
141 extern void pcopy();
142 extern void zoomview();
143
144 #else
145 /* defined in rview.c */
146 extern void devopen(char *dname);
147 extern void devclose(void);
148 extern void printdevices(void);
149 extern void fillreserves(void);
150 extern void freereserves(void);
151 extern void command(char *prompt);
152 extern void rsample(void);
153 extern int refine(PNODE *p, int xmin, int ymin,
154 int xmax, int ymax, int pd);
155 /* defined in rv2.c */
156 extern void getframe(char *s);
157 extern void getrepaint(char *s);
158 extern void getview(char *s);
159 extern void lastview(char *s);
160 extern void saveview(char *s);
161 extern void loadview(char *s);
162 extern void getaim(char *s);
163 extern void getmove(char *s);
164 extern void getrotate(char *s);
165 extern void getpivot(char *s);
166 extern void getexposure(char *s);
167 extern int getparam(char *str, char *dsc, int typ, void *p);
168 extern void setparam(char *s);
169 extern void traceray(char *s);
170 extern void writepict(char *s);
171 /* defined in rv3.c */
172 extern int getrect(char *s, RECT *r);
173 extern int getinterest(char *s, int direc, FVECT vec, double *mp);
174 extern float *greyof(COLOR col);
175 extern void paint(PNODE *p, int xmin, int ymin, int xmax, int ymax);
176 extern void newimage(void);
177 extern void redraw(void);
178 extern void repaint(int xmin, int ymin, int xmax, int ymax);
179 extern void paintrect(PNODE *p, int xmin, int ymin,
180 int xmax, int ymax, RECT *r);
181 extern PNODE *findrect(int x, int y, PNODE *p, RECT *r, int pd);
182 extern void scalepict(PNODE *p, double sf);
183 extern void getpictcolrs(int yoff, COLR *scan, PNODE *p,
184 int xsiz, int ysiz);
185 extern void freepkids(PNODE *p);
186 extern void newview(VIEW *vp);
187 extern void moveview(double angle, double elev, double mag, FVECT vc);
188 extern void pcopy(PNODE *p1, PNODE *p2);
189 extern void zoomview(VIEW *vp, double zf);
190
191 #endif
