root/radiance/ray/src/rt/rpaint.h
Revision: 2.7
Committed: Fri Jan 21 00:52:59 2005 UTC (20 years, 4 months ago) by greg
CVS Tags: rad3R7P2, rad3R7P1, rad3R8, rad3R9
# User Rev Content
1 greg 2.7 /* RCSid $Id: rpaint.h,v 2.6 2003/07/14 22:24:00 schorsch Exp $ */
2 greg 1.1 /*
3     * rpaint.h - header file for image painting.
4 greg 2.2 */
5 schorsch 2.4 #ifndef _RAD_RPAINT_H_
6     #define _RAD_RPAINT_H_
7 schorsch 2.6
8     #include "driver.h"
9     #include "view.h"
10
11 schorsch 2.4 #ifdef __cplusplus
12     extern "C" {
13     #endif
14 greg 1.1
15     typedef short COORD; /* an image coordinate */
16
17     typedef struct pnode {
18     struct pnode *kid; /* children */
19     COORD x, y; /* position */
20     COLOR v; /* value */
21     } PNODE; /* a paint node */
22
23     /* child ordering */
24     #define DL 0 /* down left */
25     #define DR 1 /* down right */
26     #define UL 2 /* up left */
27     #define UR 3 /* up right */
28
29     #define newptree() (PNODE *)calloc(4, sizeof(PNODE))
30
31     typedef struct {
32     COORD l, d, r, u; /* left, down, right, up */
33     } RECT; /* a rectangle */
34
35     extern PNODE ptrunk; /* the base of the image tree */
36
37     extern VIEW ourview; /* current view parameters */
38     extern VIEW oldview; /* previous view parameters */
39 greg 1.2 extern int hresolu, vresolu; /* image resolution */
40 greg 1.1
41     extern int greyscale; /* map colors to brightness? */
42
43     extern int pdepth; /* image depth in current frame */
44     extern RECT pframe; /* current frame rectangle */
45
46     extern double exposure; /* exposure for scene */
47
48     extern struct driver *dev; /* driver functions */
49
50 greg 2.2 /* defined in rview.c */
51     extern void devopen(char *dname);
52     extern void devclose(void);
53     extern void printdevices(void);
54     extern void fillreserves(void);
55     extern void freereserves(void);
56     extern void command(char *prompt);
57     extern void rsample(void);
58     extern int refine(PNODE *p, int xmin, int ymin,
59     int xmax, int ymax, int pd);
60     /* defined in rv2.c */
61     extern void getframe(char *s);
62     extern void getrepaint(char *s);
63     extern void getview(char *s);
64     extern void lastview(char *s);
65     extern void saveview(char *s);
66     extern void loadview(char *s);
67 greg 2.7 extern void getfocus(char *s);
68 greg 2.2 extern void getaim(char *s);
69     extern void getmove(char *s);
70     extern void getrotate(char *s);
71     extern void getpivot(char *s);
72     extern void getexposure(char *s);
73     extern int getparam(char *str, char *dsc, int typ, void *p);
74     extern void setparam(char *s);
75     extern void traceray(char *s);
76     extern void writepict(char *s);
77     /* defined in rv3.c */
78     extern int getrect(char *s, RECT *r);
79     extern int getinterest(char *s, int direc, FVECT vec, double *mp);
80     extern float *greyof(COLOR col);
81     extern void paint(PNODE *p, int xmin, int ymin, int xmax, int ymax);
82     extern void newimage(void);
83     extern void redraw(void);
84     extern void repaint(int xmin, int ymin, int xmax, int ymax);
85     extern void paintrect(PNODE *p, int xmin, int ymin,
86     int xmax, int ymax, RECT *r);
87     extern PNODE *findrect(int x, int y, PNODE *p, RECT *r, int pd);
88     extern void scalepict(PNODE *p, double sf);
89     extern void getpictcolrs(int yoff, COLR *scan, PNODE *p,
90     int xsiz, int ysiz);
91     extern void freepkids(PNODE *p);
92     extern void newview(VIEW *vp);
93     extern void moveview(double angle, double elev, double mag, FVECT vc);
94     extern void pcopy(PNODE *p1, PNODE *p2);
95     extern void zoomview(VIEW *vp, double zf);
96
97 schorsch 2.4
98     #ifdef __cplusplus
99     }
100 greg 2.2 #endif
101 schorsch 2.4 #endif /* _RAD_RPAINT_H_ */
102
