root/radiance/ray/src/rt/rpaint.h
Revision: 2.6
Committed: Mon Jul 14 22:24:00 2003 UTC (21 years, 10 months ago) by schorsch
1 /* RCSid $Id: rpaint.h,v 2.5 2003/06/27 06:53:23 greg Exp $ */
2 /*
3 * rpaint.h - header file for image painting.
4 */
5 #ifndef _RAD_RPAINT_H_
6 #define _RAD_RPAINT_H_
7
8 #include "driver.h"
9 #include "view.h"
10
11 #ifdef __cplusplus
12 extern "C" {
13 #endif
14
15 typedef short COORD; /* an image coordinate */
16
17 typedef struct pnode {
18 struct pnode *kid; /* children */
19 COORD x, y; /* position */
20 COLOR v; /* value */
21 } PNODE; /* a paint node */
22
23 /* child ordering */
24 #define DL 0 /* down left */
25 #define DR 1 /* down right */
26 #define UL 2 /* up left */
27 #define UR 3 /* up right */
28
29 #define newptree() (PNODE *)calloc(4, sizeof(PNODE))
30
31 typedef struct {
32 COORD l, d, r, u; /* left, down, right, up */
33 } RECT; /* a rectangle */
34
35 extern PNODE ptrunk; /* the base of the image tree */
36
37 extern VIEW ourview; /* current view parameters */
38 extern VIEW oldview; /* previous view parameters */
39 extern int hresolu, vresolu; /* image resolution */
40
41 extern int greyscale; /* map colors to brightness? */
42
43 extern int pdepth; /* image depth in current frame */
44 extern RECT pframe; /* current frame rectangle */
45
46 extern double exposure; /* exposure for scene */
47
48 extern struct driver *dev; /* driver functions */
49
50 /* defined in rview.c */
51 extern void devopen(char *dname);
52 extern void devclose(void);
53 extern void printdevices(void);
54 extern void fillreserves(void);
55 extern void freereserves(void);
56 extern void command(char *prompt);
57 extern void rsample(void);
58 extern int refine(PNODE *p, int xmin, int ymin,
59 int xmax, int ymax, int pd);
60 /* defined in rv2.c */
61 extern void getframe(char *s);
62 extern void getrepaint(char *s);
63 extern void getview(char *s);
64 extern void lastview(char *s);
65 extern void saveview(char *s);
66 extern void loadview(char *s);
67 extern void getaim(char *s);
68 extern void getmove(char *s);
69 extern void getrotate(char *s);
70 extern void getpivot(char *s);
71 extern void getexposure(char *s);
72 extern int getparam(char *str, char *dsc, int typ, void *p);
73 extern void setparam(char *s);
74 extern void traceray(char *s);
75 extern void writepict(char *s);
76 /* defined in rv3.c */
77 extern int getrect(char *s, RECT *r);
78 extern int getinterest(char *s, int direc, FVECT vec, double *mp);
79 extern float *greyof(COLOR col);
80 extern void paint(PNODE *p, int xmin, int ymin, int xmax, int ymax);
81 extern void newimage(void);
82 extern void redraw(void);
83 extern void repaint(int xmin, int ymin, int xmax, int ymax);
84 extern void paintrect(PNODE *p, int xmin, int ymin,
85 int xmax, int ymax, RECT *r);
86 extern PNODE *findrect(int x, int y, PNODE *p, RECT *r, int pd);
87 extern void scalepict(PNODE *p, double sf);
88 extern void getpictcolrs(int yoff, COLR *scan, PNODE *p,
89 int xsiz, int ysiz);
90 extern void freepkids(PNODE *p);
91 extern void newview(VIEW *vp);
92 extern void moveview(double angle, double elev, double mag, FVECT vc);
93 extern void pcopy(PNODE *p1, PNODE *p2);
94 extern void zoomview(VIEW *vp, double zf);
95
96
97 #ifdef __cplusplus
98 }
99 #endif
100 #endif /* _RAD_RPAINT_H_ */
101
