root/radiance/ray/src/rt/rpaint.h
Revision: 2.3
Committed: Tue Feb 25 02:47:23 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.2: +2 -57 lines
# User Rev Content
1 greg 2.3 /* RCSid $Id$ */
2 greg 1.1 /*
3     * rpaint.h - header file for image painting.
4 greg 2.2 */
5
6 greg 2.3 #include "copyright.h"
7 greg 1.1
8     #include "driver.h"
9
10     #include "view.h"
11
12     typedef short COORD; /* an image coordinate */
13
14     typedef struct pnode {
15     struct pnode *kid; /* children */
16     COORD x, y; /* position */
17     COLOR v; /* value */
18     } PNODE; /* a paint node */
19
20     /* child ordering */
21     #define DL 0 /* down left */
22     #define DR 1 /* down right */
23     #define UL 2 /* up left */
24     #define UR 3 /* up right */
25
26     #define newptree() (PNODE *)calloc(4, sizeof(PNODE))
27
28     typedef struct {
29     COORD l, d, r, u; /* left, down, right, up */
30     } RECT; /* a rectangle */
31
32     extern PNODE ptrunk; /* the base of the image tree */
33
34     extern VIEW ourview; /* current view parameters */
35     extern VIEW oldview; /* previous view parameters */
36 greg 1.2 extern int hresolu, vresolu; /* image resolution */
37 greg 1.1
38     extern int greyscale; /* map colors to brightness? */
39
40     extern int pdepth; /* image depth in current frame */
41     extern RECT pframe; /* current frame rectangle */
42
43     extern double exposure; /* exposure for scene */
44
45     extern struct driver *dev; /* driver functions */
46
47 greg 2.2 #ifdef NOPROTO
48
49     extern void devopen();
50     extern void devclose();
51     extern void printdevices();
52     extern void fillreserves();
53     extern void freereserves();
54     extern void command();
55     extern void rsample();
56     extern int refine();
57     extern void getframe();
58     extern void getrepaint();
59     extern void getview();
60     extern void lastview();
61     extern void saveview();
62     extern void loadview();
63     extern void getaim();
64     extern void getmove();
65     extern void getrotate();
66     extern void getpivot();
67     extern void getexposure();
68     extern int getparam();
69     extern void setparam();
70     extern void traceray();
71     extern void writepict();
72     extern int getrect();
73     extern int getinterest();
74     extern float *greyof();
75     extern void paint();
76     extern void newimage();
77     extern void redraw();
78     extern void repaint();
79     extern void paintrec();
80     extern PNODE *findrect();
81     extern void scalepict();
82     extern void getpictcolrs();
83     extern void freepkids();
84     extern void newview();
85     extern void moveview();
86     extern void pcopy();
87     extern void zoomview();
88
89     #else
90     /* defined in rview.c */
91     extern void devopen(char *dname);
92     extern void devclose(void);
93     extern void printdevices(void);
94     extern void fillreserves(void);
95     extern void freereserves(void);
96     extern void command(char *prompt);
97     extern void rsample(void);
98     extern int refine(PNODE *p, int xmin, int ymin,
99     int xmax, int ymax, int pd);
100     /* defined in rv2.c */
101     extern void getframe(char *s);
102     extern void getrepaint(char *s);
103     extern void getview(char *s);
104     extern void lastview(char *s);
105     extern void saveview(char *s);
106     extern void loadview(char *s);
107     extern void getaim(char *s);
108     extern void getmove(char *s);
109     extern void getrotate(char *s);
110     extern void getpivot(char *s);
111     extern void getexposure(char *s);
112     extern int getparam(char *str, char *dsc, int typ, void *p);
113     extern void setparam(char *s);
114     extern void traceray(char *s);
115     extern void writepict(char *s);
116     /* defined in rv3.c */
117     extern int getrect(char *s, RECT *r);
118     extern int getinterest(char *s, int direc, FVECT vec, double *mp);
119     extern float *greyof(COLOR col);
120     extern void paint(PNODE *p, int xmin, int ymin, int xmax, int ymax);
121     extern void newimage(void);
122     extern void redraw(void);
123     extern void repaint(int xmin, int ymin, int xmax, int ymax);
124     extern void paintrect(PNODE *p, int xmin, int ymin,
125     int xmax, int ymax, RECT *r);
126     extern PNODE *findrect(int x, int y, PNODE *p, RECT *r, int pd);
127     extern void scalepict(PNODE *p, double sf);
128     extern void getpictcolrs(int yoff, COLR *scan, PNODE *p,
129     int xsiz, int ysiz);
130     extern void freepkids(PNODE *p);
131     extern void newview(VIEW *vp);
132     extern void moveview(double angle, double elev, double mag, FVECT vc);
133     extern void pcopy(PNODE *p1, PNODE *p2);
134     extern void zoomview(VIEW *vp, double zf);
135
136     #endif
