root/radiance/ray/src/rt/rpaint.h
Revision: 2.12
Committed: Sun Mar 6 01:13:18 2016 UTC (9 years, 3 months ago) by schorsch
CVS Tags: rad5R4, rad5R2, rad5R1, rad5R3, HEAD
Changes since 2.11: +7 -6 lines
Error occurred while calculating annotation data.
1 /* RCSid $Id: rpaint.h,v 2.11 2013/11/13 23:45:54 greg Exp $ */
2 /*
3 * rpaint.h - header file for image painting.
4 */
5 #ifndef _RAD_RPAINT_H_
6 #define _RAD_RPAINT_H_
7
8 #include "driver.h"
9 #include "view.h"
10
11 #ifdef __cplusplus
12 extern "C" {
13 #endif
14
15 #if defined(_WIN32) || defined(_WIN64)
16 /* stupid Windows name collisions */
17 #undef COORD
18 #define COORD radCOORD
19 #undef RECT
20 #define RECT radRECT
21 #endif
22
23 typedef short COORD; /* an image coordinate */
24
25 typedef struct pnode {
26 struct pnode *kid; /* children */
27 COORD x, y; /* position */
28 COORD xmin, ymin, xmax, ymax; /* rectangle */
29 COLOR v; /* value */
30 } PNODE; /* a paint node */
31
32 /* child ordering */
33 #define DL 0 /* down left */
34 #define DR 1 /* down right */
35 #define UL 2 /* up left */
36 #define UR 3 /* up right */
37
38 #define newptree() (PNODE *)calloc(4, sizeof(PNODE))
39
40 typedef struct {
41 COORD l, d, r, u; /* left, down, right, up */
42 } RECT; /* a rectangle */
43
44 extern PNODE ptrunk; /* the base of the image tree */
45
46 extern VIEW ourview; /* current view parameters */
47 extern VIEW oldview; /* previous view parameters */
48 extern int hresolu, vresolu; /* image resolution */
49
50 extern int newparam; /* parameter setting changed */
51
52 extern char *dvcname; /* output device name */
53
54 extern char rifname[]; /* rad input file name */
55
56 extern int psample; /* pixel sample size */
57 extern double maxdiff; /* max. sample difference */
58
59 extern int greyscale; /* map colors to brightness? */
60
61 extern int pdepth; /* image depth in current frame */
62 extern RECT pframe; /* current frame rectangle */
63
64 extern double exposure; /* exposure for scene */
65
66 extern struct driver *dev; /* driver functions */
67
68 extern int nproc; /* number of processes */
69
70 /* defined in rview.c */
71 extern void devopen(char *dname);
72 extern void devclose(void);
73 extern void printdevices(void);
74 extern void command(char *prompt);
75 extern void rsample(void);
76 extern int refine(PNODE *p, int pd);
77 /* defined in rv2.c */
78 extern void getframe(char *s);
79 extern void getrepaint(char *s);
80 extern void getview(char *s);
81 extern void lastview(char *s);
82 extern void saveview(char *s);
83 extern void loadview(char *s);
84 extern void getfocus(char *s);
85 extern void getaim(char *s);
86 extern void getmove(char *s);
87 extern void getrotate(char *s);
88 extern void getpivot(char *s);
89 extern void getorigin(char *s);
90 extern void getexposure(char *s);
91 extern int getparam(char *str, char *dsc, int typ, void *p);
92 extern void setparam(char *s);
93 extern void traceray(char *s);
94 extern void writepict(char *s);
95 /* defined in rv3.c */
96 extern int getrect(char *s, RECT *r);
97 extern int getinterest(char *s, int direc, FVECT vec, double *mp);
98 extern float *greyof(COLOR col);
99 extern int paint(PNODE *p);
100 extern int waitrays(void);
101 extern void newimage(char *s);
102 extern void redraw(void);
103 extern void repaint(int xmin, int ymin, int xmax, int ymax);
104 extern void paintrect(PNODE *p, RECT *r);
105 extern PNODE *findrect(int x, int y, PNODE *p, int pd);
106 extern void compavg(PNODE *p);
107 extern void scalepict(PNODE *p, double sf);
108 extern void getpictcolrs(int yoff, COLR *scan, PNODE *p,
109 int xsiz, int ysiz);
110 extern void freepkids(PNODE *p);
111 extern void newview(VIEW *vp);
112 extern void moveview(double angle, double elev, double mag, FVECT vc);
113 extern void pcopy(PNODE *p1, PNODE *p2);
114 extern void zoomview(VIEW *vp, double zf);
115
116
117 #ifdef __cplusplus
118 }
119 #endif
120 #endif /* _RAD_RPAINT_H_ */
121
