/* Copyright (c) 1993 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; #endif /* * rmain.c - main for ray tracing programs * * 3/24/87 */ /* for flaky pre-processors */ #ifndef RPICT #define RPICT 0 #endif #ifndef RTRACE #define RTRACE 0 #endif #ifndef RVIEW #define RVIEW 0 #endif #include "ray.h" #include "resolu.h" #include "octree.h" #include #include "view.h" #include "paths.h" /* persistent processes define */ #ifdef F_SETLKW #if RPICT|RTRACE #define PERSIST 1 /* normal persist */ #define PARALLEL 2 /* parallel persist */ #define PCHILD 3 /* child of normal persist */ #endif #endif char *progname; /* argv[0] */ char *octname; /* octree name */ char *libpath; /* library directory list */ char *sigerr[NSIG]; /* signal error messages */ extern char VersionID[]; /* version ID string */ extern int stderr_v(); /* standard error output */ int (*errvec)() = stderr_v; /* error output vector */ int (*wrnvec)() = stderr_v; /* warning output vector */ int (*cmdvec)() = NULL; /* command error vector */ int (*trace)() = NULL; /* trace call */ int do_irrad = 0; /* compute irradiance? */ extern unsigned long time(); unsigned long tstart; /* start time */ extern int ambnotify(); /* new object notify functions */ #if RTRACE extern int tranotify(); int (*addobjnotify[])() = {ambnotify, tranotify, NULL}; extern char *tralist[]; /* trace include/exclude list */ extern int traincl; /* include == 1, exclude == 0 */ #else int (*addobjnotify[])() = {ambnotify, NULL}; #endif CUBE thescene; /* our scene */ OBJECT nsceneobjs; /* number of objects in our scene */ extern unsigned long raynum, nrays; /* ray counts */ extern int imm_irrad; /* calculate immediate irradiance? */ extern int ralrm; /* seconds between reports */ extern int greyscale; /* map colors to brightness? */ extern char *devname; /* output device name */ extern double exposure; /* exposure compensation */ extern char *formstr(); /* string from format */ extern int inform; /* input format */ extern int outform; /* output format */ extern char *outvals; /* output values */ extern VIEW ourview; /* viewing parameters */ extern char rifname[]; /* rad input file name */ extern int hresolu; /* horizontal resolution */ extern int vresolu; /* vertical resolution */ extern double pixaspect; /* pixel aspect ratio */ extern int psample; /* pixel sample size */ extern double maxdiff; /* max. sample difference */ extern double dstrpix; /* square pixel distribution */ extern double dstrsrc; /* square source distribution */ extern double shadthresh; /* shadow threshold */ extern double shadcert; /* shadow testing certainty */ extern int directrelay; /* number of source relays */ extern int vspretest; /* virtual source pretest density */ extern int directvis; /* light sources visible to eye? */ extern double srcsizerat; /* maximum source size/dist. ratio */ extern double specthresh; /* specular sampling threshold */ extern double specjitter; /* specular sampling jitter */ extern int maxdepth; /* maximum recursion depth */ extern double minweight; /* minimum ray weight */ extern COLOR ambval; /* ambient value */ extern double ambacc; /* ambient accuracy */ extern int ambres; /* ambient resolution */ extern int ambdiv; /* ambient divisions */ extern int ambssamp; /* ambient super-samples */ extern int ambounce; /* ambient bounces */ extern char *amblist[]; /* ambient include/exclude list */ extern int ambincl; /* include == 1, exclude == 0 */ main(argc, argv) int argc; char *argv[]; { #define check(ol,al) if (argv[i][ol] || \ badarg(argc-i-1,argv+i+1,al)) \ goto badopt #define bool(olen,var) switch (argv[i][olen]) { \ case '\0': var = !var; break; \ case 'y': case 'Y': case 't': case 'T': \ case '+': case '1': var = 1; break; \ case 'n': case 'N': case 'f': case 'F': \ case '-': case '0': var = 0; break; \ default: goto badopt; } char *err; char *recover = NULL; char *outfile = NULL; char *zfile = NULL; char *errfile = NULL; char *ambfile = NULL; int loadflags = ~IO_FILES; int seqstart = 0; int persist = 0; char **amblp; char **tralp; int duped1; int rval; int i; /* record start time */ tstart = time((unsigned long *)NULL); /* global program name */ progname = argv[0] = fixargv0(argv[0]); /* get library path */ if ((libpath = getenv(ULIBVAR)) == NULL) libpath = DEFPATH; /* initialize object types */ initotypes(); /* initialize urand */ initurand(2048); /* option city */ for (i = 1; i < argc; i++) { /* expand arguments */ while (rval = expandarg(&argc, &argv, i)) if (rval < 0) { sprintf(errmsg, "cannot expand '%s'", argv[i]); error(SYSTEM, errmsg); } if (argv[i] == NULL || argv[i][0] != '-') break; /* break from options */ if (!strcmp(argv[i], "-version")) { puts(VersionID); quit(0); } if (!strcmp(argv[i], "-defaults") || !strcmp(argv[i], "-help")) { printdefaults(); quit(0); } #if RVIEW if (!strcmp(argv[i], "-devices")) { printdevices(); quit(0); } #endif #if RPICT|RVIEW rval = getviewopt(&ourview, argc-i, argv+i); if (rval >= 0) { i += rval; continue; } #endif switch (argv[i][1]) { #if RPICT|RVIEW case 'v': /* view file */ if (argv[i][2] != 'f') goto badopt; check(3,"s"); rval = viewfile(argv[++i], &ourview, NULL); if (rval < 0) { sprintf(errmsg, "cannot open view file \"%s\"", argv[i]); error(SYSTEM, errmsg); } else if (rval == 0) { sprintf(errmsg, "bad view file \"%s\"", argv[i]); error(USER, errmsg); } break; #endif case 'd': /* direct */ switch (argv[i][2]) { case 't': /* threshold */ check(3,"f"); shadthresh = atof(argv[++i]); break; case 'c': /* certainty */ check(3,"f"); shadcert = atof(argv[++i]); break; case 'j': /* jitter */ check(3,"f"); dstrsrc = atof(argv[++i]); break; case 'r': /* relays */ check(3,"i"); directrelay = atoi(argv[++i]); break; case 'p': /* pretest */ check(3,"i"); vspretest = atoi(argv[++i]); break; case 'v': /* visibility */ bool(3,directvis); break; case 's': /* size */ check(3,"f"); srcsizerat = atof(argv[++i]); break; default: goto badopt; } break; case 's': /* specular */ switch (argv[i][2]) { case 't': /* threshold */ check(3,"f"); specthresh = atof(argv[++i]); break; case 'j': /* jitter */ check(3,"f"); specjitter = atof(argv[++i]); break; default: goto badopt; } break; #if RPICT|RVIEW case 'p': /* pixel */ switch (argv[i][2]) { case 's': /* sample */ check(3,"i"); psample = atoi(argv[++i]); break; case 't': /* threshold */ check(3,"f"); maxdiff = atof(argv[++i]); break; #if RPICT case 'j': /* jitter */ check(3,"f"); dstrpix = atof(argv[++i]); break; case 'a': /* aspect */ check(3,"f"); pixaspect = atof(argv[++i]); break; #endif #if RVIEW case 'e': /* exposure */ check(3,"f"); exposure = atof(argv[++i]); if (argv[i][0] == '+' || argv[i][0] == '-') exposure = pow(2.0, exposure); break; #endif default: goto badopt; } break; #endif #if RPICT|RTRACE case 'x': /* x resolution */ check(2,"i"); hresolu = atoi(argv[++i]); break; case 'y': /* y resolution */ check(2,"i"); vresolu = atoi(argv[++i]); break; #endif case 'w': /* warnings */ rval = wrnvec != NULL; bool(2,rval); if (rval) wrnvec = stderr_v; else wrnvec = NULL; break; case 'e': /* error file */ check(2,"s"); errfile = argv[++i]; break; case 'l': /* limit */ switch (argv[i][2]) { case 'r': /* recursion */ check(3,"i"); maxdepth = atoi(argv[++i]); break; case 'w': /* weight */ check(3,"f"); minweight = atof(argv[++i]); break; default: goto badopt; } break; case 'i': /* irradiance */ bool(2,do_irrad); break; #if RPICT case 'S': /* slave index */ check(2,"i"); seqstart = atoi(argv[++i]); break; case 'o': /* output file */ check(2,"s"); outfile = argv[++i]; break; case 'z': /* z file */ check(2,"s"); zfile = argv[++i]; break; case 'r': /* recover file */ if (argv[i][2] == 'o') { /* +output */ check(3,"s"); outfile = argv[i+1]; } else check(2,"s"); recover = argv[++i]; break; case 't': /* timer */ check(2,"i"); ralrm = atoi(argv[++i]); break; #endif case 'a': /* ambient */ switch (argv[i][2]) { case 'v': /* value */ check(3,"fff"); setcolor(ambval, atof(argv[i+1]), atof(argv[i+2]), atof(argv[i+3])); i += 3; break; case 'a': /* accuracy */ check(3,"f"); ambacc = atof(argv[++i]); break; case 'r': /* resolution */ check(3,"i"); ambres = atoi(argv[++i]); break; case 'd': /* divisions */ check(3,"i"); ambdiv = atoi(argv[++i]); break; case 's': /* super-samp */ check(3,"i"); ambssamp = atoi(argv[++i]); break; case 'b': /* bounces */ check(3,"i"); ambounce = atoi(argv[++i]); break; case 'i': /* include */ case 'I': check(3,"s"); if (ambincl != 1) { ambincl = 1; amblp = amblist; } if (argv[i][2] == 'I') { /* file */ rval = wordfile(amblp, getpath(argv[++i],libpath,R_OK)); if (rval < 0) { sprintf(errmsg, "cannot open ambient include file \"%s\"", argv[i]); error(SYSTEM, errmsg); } amblp += rval; } else { *amblp++ = argv[++i]; *amblp = NULL; } break; case 'e': /* exclude */ case 'E': check(3,"s"); if (ambincl != 0) { ambincl = 0; amblp = amblist; } if (argv[i][2] == 'E') { /* file */ rval = wordfile(amblp, getpath(argv[++i],libpath,R_OK)); if (rval < 0) { sprintf(errmsg, "cannot open ambient exclude file \"%s\"", argv[i]); error(SYSTEM, errmsg); } amblp += rval; } else { *amblp++ = argv[++i]; *amblp = NULL; } break; case 'f': /* file */ check(3,"s"); ambfile= argv[++i]; break; default: goto badopt; } break; #if RTRACE case 'I': /* immed. irradiance */ bool(2,imm_irrad); break; case 'f': /* format i/o */ switch (argv[i][2]) { case 'a': /* ascii */ case 'f': /* float */ case 'd': /* double */ inform = argv[i][2]; break; default: goto badopt; } switch (argv[i][3]) { case '\0': outform = inform; break; case 'a': /* ascii */ case 'f': /* float */ case 'd': /* double */ case 'c': /* color */ check(4,""); outform = argv[i][3]; break; default: goto badopt; } break; case 'o': /* output */ outvals = argv[i]+2; break; case 'h': /* header output */ rval = loadflags & IO_INFO; bool(2,rval); loadflags = rval ? loadflags | IO_INFO : loadflags & ~IO_INFO; break; case 't': /* trace */ switch (argv[i][2]) { case 'i': /* include */ case 'I': check(3,"s"); if (traincl != 1) { traincl = 1; tralp = tralist; } if (argv[i][2] == 'I') { /* file */ rval = wordfile(tralp, getpath(argv[++i],libpath,R_OK)); if (rval < 0) { sprintf(errmsg, "cannot open trace include file \"%s\"", argv[i]); error(SYSTEM, errmsg); } tralp += rval; } else { *tralp++ = argv[++i]; *tralp = NULL; } break; case 'e': /* exclude */ case 'E': check(3,"s"); if (traincl != 0) { traincl = 0; tralp = tralist; } if (argv[i][2] == 'E') { /* file */ rval = wordfile(tralp, getpath(argv[++i],libpath,R_OK)); if (rval < 0) { sprintf(errmsg, "cannot open trace exclude file \"%s\"", argv[i]); error(SYSTEM, errmsg); } tralp += rval; } else { *tralp++ = argv[++i]; *tralp = NULL; } break; default: goto badopt; } break; #endif #if RVIEW case 'b': /* black and white */ bool(2,greyscale); break; case 'o': /* output device */ check(2,"s"); devname = argv[++i]; break; case 'R': /* render input file */ check(2,"s"); strcpy(rifname, argv[++i]); break; #endif #ifdef PERSIST case 'P': /* persist file */ if (argv[i][2] == 'P') { check(3,"s"); persist = PARALLEL; } else { check(2,"s"); persist = PERSIST; } persistfile(argv[++i]); break; #endif default: goto badopt; } } #if RPICT|RVIEW err = setview(&ourview); /* set viewing parameters */ if (err != NULL) error(USER, err); #endif /* set up signal handling */ sigdie(SIGINT, "Interrupt"); sigdie(SIGHUP, "Hangup"); sigdie(SIGTERM, "Terminate"); sigdie(SIGPIPE, "Broken pipe"); sigdie(SIGALRM, "Alarm clock"); #ifdef SIGXCPU sigdie(SIGXCPU, "CPU limit exceeded"); sigdie(SIGXFSZ, "File size exceeded"); #endif /* open error file */ if (errfile != NULL) { if (freopen(errfile, "a", stderr) == NULL) quit(2); fprintf(stderr, "**************\n*** PID %5d: ", getpid()); printargs(argc, argv, stderr); putc('\n', stderr); fflush(stderr); } #ifdef NICE nice(NICE); /* lower priority */ #endif /* get octree */ #if RVIEW loadflags &= ~IO_INFO; #endif if (i == argc) octname = NULL; else if (i == argc-1) octname = argv[i]; else goto badopt; if ( #if RPICT seqstart > 0 && #endif octname == NULL) error(USER, "missing octree argument"); /* set up output */ #ifdef PERSIST if (persist) { #if RPICT if (recover != NULL) error(USER, "persist option used with recover file"); if (seqstart <= 0) error(USER, "persist option only for sequences"); if (outfile == NULL) #endif duped1 = dup(fileno(stdout)); /* don't lose our output */ openheader(); } #if RPICT else #endif #endif #if RPICT if (outfile != NULL) openheader(); #endif #ifdef MSDOS #if RTRACE if (outform != 'a') #endif setmode(fileno(stdout), O_BINARY); if (octname == NULL) setmode(fileno(stdin), O_BINARY); #endif readoct(octname, loadflags, &thescene, NULL); nsceneobjs = nobjects; if (loadflags & IO_INFO) { /* print header */ printargs(i, argv, stdout); printf("SOFTWARE= %s\n", VersionID); #if RTRACE fputformat(formstr(outform), stdout); putchar('\n'); #endif } marksources(); /* find and mark sources */ setambient(ambfile); /* initialize ambient calculation */ #ifdef PERSIST if (persist) { fflush(stdout); if (outfile == NULL) { /* reconnect stdout */ dup2(duped1, fileno(stdout)); close(duped1); } if (persist == PARALLEL) { /* multiprocessing */ preload_objs(); /* preload scene */ while ((rval=fork()) == 0) { /* keep on forkin' */ pflock(1); pfhold(); tstart = time((unsigned long *)NULL); } if (rval < 0) error(SYSTEM, "cannot fork child for persist function"); pfdetach(); /* parent exits */ } } runagain: if (persist) if (outfile == NULL) /* if out to stdout */ dupheader(); /* send header */ else /* if out to file */ duped1 = dup(fileno(stdout)); /* hang onto pipe */ #endif #if RPICT rpict(seqstart, outfile, zfile, recover); #endif #if RTRACE rtrace(NULL); #endif #if RVIEW rview(); #endif ambsync(); /* flush ambient file */ #ifdef PERSIST if (persist == PERSIST) { /* first run-through */ if ((rval=fork()) == 0) { /* child loops until killed */ pflock(1); persist = PCHILD; } else { /* original process exits */ if (rval < 0) error(SYSTEM, "cannot fork child for persist function"); pfdetach(); /* parent exits */ } } if (persist == PCHILD) { /* wait for a signal then go again */ if (outfile != NULL) close(duped1); /* release output handle */ pfhold(); tstart = time((unsigned long *)NULL); /* reinitialize */ raynum = nrays = 0; goto runagain; } #endif quit(0); badopt: sprintf(errmsg, "command line error at '%s'", argv[i]); error(USER, errmsg); #undef check #undef bool } eputs(s) /* error output */ char *s; { if (errvec != NULL) (*errvec)(s); } wputs(s) /* warning output */ char *s; { int lasterrno = errno; /* save errno */ if (wrnvec != NULL) (*wrnvec)(s); errno = lasterrno; } cputs(s) /* command error output */ char *s; { if (cmdvec != NULL) (*cmdvec)(s); } stderr_v(s) /* put string to stderr */ register char *s; { static int midline = 0; if (!*s) return; if (!midline++) { fputs(progname, stderr); fputs(": ", stderr); } fputs(s, stderr); if (s[strlen(s)-1] == '\n') { fflush(stderr); midline = 0; } } onsig(signo) /* fatal signal */ int signo; { static int gotsig = 0; if (gotsig++) /* two signals and we're gone! */ _exit(signo); alarm(15); /* allow 15 seconds to clean up */ signal(SIGALRM, SIG_DFL); /* make certain we do die */ eputs("signal - "); eputs(sigerr[signo]); eputs("\n"); quit(3); } sigdie(signo, msg) /* set fatal signal */ int signo; char *msg; { if (signal(signo, onsig) == SIG_IGN) signal(signo, SIG_IGN); sigerr[signo] = msg; } printdefaults() /* print default values to stdout */ { register char *cp; #if RTRACE if (imm_irrad) printf("-I+\t\t\t\t# immediate irradiance on\n"); else #endif printf(do_irrad ? "-i+\t\t\t\t# irradiance calculation on\n" : "-i-\t\t\t\t# irradiance calculation off\n"); #if RVIEW printf(greyscale ? "-b+\t\t\t\t# greyscale on\n" : "-b-\t\t\t\t# greyscale off\n"); #endif #if RPICT|RVIEW printf("-vt%c\t\t\t\t# view type %s\n", ourview.type, ourview.type==VT_PER ? "perspective" : ourview.type==VT_PAR ? "parallel" : ourview.type==VT_HEM ? "hemispherical" : ourview.type==VT_ANG ? "angular" : "unknown"); printf("-vp %f %f %f\t# view point\n", ourview.vp[0], ourview.vp[1], ourview.vp[2]); printf("-vd %f %f %f\t# view direction\n", ourview.vdir[0], ourview.vdir[1], ourview.vdir[2]); printf("-vu %f %f %f\t# view up\n", ourview.vup[0], ourview.vup[1], ourview.vup[2]); printf("-vh %f\t\t\t# view horizontal size\n", ourview.horiz); printf("-vv %f\t\t\t# view vertical size\n", ourview.vert); printf("-vs %f\t\t\t# view shift\n", ourview.hoff); printf("-vl %f\t\t\t# view lift\n", ourview.voff); #endif #if RPICT|RTRACE printf("-x %-9d\t\t\t# x resolution\n", hresolu); printf("-y %-9d\t\t\t# y resolution\n", vresolu); #endif #if RPICT printf("-pa %f\t\t\t# pixel aspect ratio\n", pixaspect); printf("-pj %f\t\t\t# pixel jitter\n", dstrpix); #endif #if RVIEW printf("-pe %f\t\t\t# pixel exposure\n", exposure); #endif #if RPICT|RVIEW printf("-ps %-9d\t\t\t# pixel sample\n", psample); printf("-pt %f\t\t\t# pixel threshold\n", maxdiff); #endif printf("-dt %f\t\t\t# direct threshold\n", shadthresh); printf("-dc %f\t\t\t# direct certainty\n", shadcert); printf("-dj %f\t\t\t# direct jitter\n", dstrsrc); printf("-ds %f\t\t\t# direct sampling\n", srcsizerat); printf("-dr %-9d\t\t\t# direct relays\n", directrelay); printf("-dp %-9d\t\t\t# direct pretest density\n", vspretest); printf(directvis ? "-dv+\t\t\t\t# direct visibility on\n" : "-dv-\t\t\t\t# direct visibility off\n"); printf("-sj %f\t\t\t# specular jitter\n", specjitter); printf("-st %f\t\t\t# specular threshold\n", specthresh); printf("-av %f %f %f\t# ambient value\n", colval(ambval,RED), colval(ambval,GRN), colval(ambval, BLU)); printf("-ab %-9d\t\t\t# ambient bounces\n", ambounce); printf("-aa %f\t\t\t# ambient accuracy\n", ambacc); printf("-ar %-9d\t\t\t# ambient resolution\n", ambres); printf("-ad %-9d\t\t\t# ambient divisions\n", ambdiv); printf("-as %-9d\t\t\t# ambient super-samples\n", ambssamp); printf("-lr %-9d\t\t\t# limit reflection\n", maxdepth); printf("-lw %f\t\t\t# limit weight\n", minweight); #if RPICT printf("-t %-9d\t\t\t# time between reports\n", ralrm); #endif #if RVIEW printf("-o %s\t\t\t\t# output device\n", devname); #endif #if RTRACE printf("-f%c%c\t\t\t\t# format input/output = %s/%s\n", inform, outform, formstr(inform), formstr(outform)); printf("-o%s\t\t\t\t# output", outvals); for (cp = outvals; *cp; cp++) switch (*cp) { case 't': printf(" trace"); break; case 'o': printf(" origin"); break; case 'd': printf(" direction"); break; case 'v': printf(" value"); break; case 'l': printf(" length"); break; case 'L': printf(" first_length"); break; case 'p': printf(" point"); break; case 'n': printf(" normal"); break; case 'N': printf(" unperturbed_normal"); break; case 's': printf(" surface"); break; case 'w': printf(" weight"); break; case 'm': printf(" modifier"); break; } putchar('\n'); #endif printf(wrnvec != NULL ? "-w+\t\t\t\t# warning messages on\n" : "-w-\t\t\t\t# warning messages off\n"); }
