root/radiance/ray/src/rt/rmain.c
Revision: 2.47
Committed: Sat Feb 22 02:07:29 2003 UTC (22 years, 4 months ago) by greg
Changes since 2.46: +0 -0 lines
State: FILE REMOVED
1 /* Copyright (c) 1996 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * rmain.c - main for ray tracing programs
9 *
10 * 3/24/87
11 */
12
13 /* for flaky pre-processors */
14 #ifndef RPICT
15 #define RPICT 0
16 #endif
17 #ifndef RTRACE
18 #define RTRACE 0
19 #endif
20 #ifndef RVIEW
21 #define RVIEW 0
22 #endif
23
24 #include "ray.h"
25
26 #include "random.h"
27
28 #include "resolu.h"
29
30 #include "octree.h"
31
32 #include <sys/types.h>
33
34 #include <signal.h>
35
36 #include "view.h"
37
38 #include "paths.h"
39 /* persistent processes define */
40 #ifdef F_SETLKW
41 #if RPICT|RTRACE
42 #define PERSIST 1 /* normal persist */
43 #define PARALLEL 2 /* parallel persist */
44 #define PCHILD 3 /* child of normal persist */
45 #endif
46 #endif
47
48 char *progname; /* argv[0] */
49
50 char *octname; /* octree name */
51
52 char *getlibpath(); /* library directory list */
53
54 char *sigerr[NSIG]; /* signal error messages */
55
56 char *shm_boundary = NULL; /* boundary of shared memory */
57
58 extern char VersionID[]; /* version ID string */
59
60 int (*trace)() = NULL; /* trace call */
61 int do_irrad = 0; /* compute irradiance? */
62
63 char *errfile = NULL; /* error output file */
64
65 extern time_t time();
66 time_t tstart; /* start time */
67
68 extern int ambnotify(); /* new object notify functions */
69 #if RTRACE
70 extern int tranotify();
71 int (*addobjnotify[])() = {ambnotify, tranotify, NULL};
72 extern char *tralist[]; /* trace include/exclude list */
73 extern int traincl; /* include == 1, exclude == 0 */
74 #else
75 int (*addobjnotify[])() = {ambnotify, NULL};
76 #endif
77
78 CUBE thescene; /* our scene */
79 OBJECT nsceneobjs; /* number of objects in our scene */
80
81 extern unsigned long raynum, nrays; /* ray counts */
82
83 extern int imm_irrad; /* calculate immediate irradiance? */
84 extern int lim_dist; /* limit distance? */
85
86 extern int ralrm; /* seconds between reports */
87
88 extern int greyscale; /* map colors to brightness? */
89 extern char *devname; /* output device name */
90 extern double exposure; /* exposure compensation */
91
92 extern char *formstr(); /* string from format */
93 extern int inform; /* input format */
94 extern int outform; /* output format */
95 extern char *outvals; /* output values */
96
97 extern VIEW ourview; /* viewing parameters */
98
99 extern char rifname[]; /* rad input file name */
100
101 extern int hresolu; /* horizontal resolution */
102 extern int vresolu; /* vertical resolution */
103 extern double pixaspect; /* pixel aspect ratio */
104
105 extern int psample; /* pixel sample size */
106 extern double maxdiff; /* max. sample difference */
107 extern double dstrpix; /* square pixel distribution */
108
109 extern double mblur; /* motion blur parameter */
110
111 extern double dstrsrc; /* square source distribution */
112 extern double shadthresh; /* shadow threshold */
113 extern double shadcert; /* shadow testing certainty */
114 extern int directrelay; /* number of source relays */
115 extern int vspretest; /* virtual source pretest density */
116 extern int directvis; /* light sources visible to eye? */
117 extern double srcsizerat; /* maximum source size/dist. ratio */
118
119 extern double specthresh; /* specular sampling threshold */
120 extern double specjitter; /* specular sampling jitter */
121
122 extern COLOR cextinction; /* global extinction coefficient */
123 extern COLOR salbedo; /* global scattering albedo */
124 extern double seccg; /* global scattering eccentricity */
125 extern double ssampdist; /* scatter sampling distance */
126
127 extern int backvis; /* back face visibility */
128
129 extern int maxdepth; /* maximum recursion depth */
130 extern double minweight; /* minimum ray weight */
131
132 extern COLOR ambval; /* ambient value */
133 extern int ambvwt; /* initial weight for ambient value */
134 extern double ambacc; /* ambient accuracy */
135 extern int ambres; /* ambient resolution */
136 extern int ambdiv; /* ambient divisions */
137 extern int ambssamp; /* ambient super-samples */
138 extern int ambounce; /* ambient bounces */
139 extern char *amblist[]; /* ambient include/exclude list */
140 extern int ambincl; /* include == 1, exclude == 0 */
141
142
143 main(argc, argv)
144 int argc;
145 char *argv[];
146 {
147 #define check(ol,al) if (argv[i][ol] || \
148 badarg(argc-i-1,argv+i+1,al)) \
149 goto badopt
150 #define bool(olen,var) switch (argv[i][olen]) { \
151 case '\0': var = !var; break; \
152 case 'y': case 'Y': case 't': case 'T': \
153 case '+': case '1': var = 1; break; \
154 case 'n': case 'N': case 'f': case 'F': \
155 case '-': case '0': var = 0; break; \
156 default: goto badopt; }
157 char *err;
158 char *recover = NULL;
159 char *outfile = NULL;
160 char *zfile = NULL;
161 char *ambfile = NULL;
162 int loadflags = ~IO_FILES;
163 int seqstart = 0;
164 int persist = 0;
165 char **amblp;
166 char **tralp;
167 int duped1;
168 int rval;
169 int i;
170 /* record start time */
171 tstart = time((time_t *)NULL);
172 /* global program name */
173 progname = argv[0] = fixargv0(argv[0]);
174 /* initialize object types */
175 initotypes();
176 /* initialize urand */
177 initurand(2048);
178 /* option city */
179 for (i = 1; i < argc; i++) {
180 /* expand arguments */
181 while (rval = expandarg(&argc, &argv, i))
182 if (rval < 0) {
183 sprintf(errmsg, "cannot expand '%s'", argv[i]);
184 error(SYSTEM, errmsg);
185 }
186 if (argv[i] == NULL || argv[i][0] != '-')
187 break; /* break from options */
188 if (!strcmp(argv[i], "-version")) {
189 puts(VersionID);
190 quit(0);
191 }
192 if (!strcmp(argv[i], "-defaults") ||
193 !strcmp(argv[i], "-help")) {
194 printdefaults();
195 quit(0);
196 }
197 #if RVIEW
198 if (!strcmp(argv[i], "-devices")) {
199 printdevices();
200 quit(0);
201 }
202 #endif
203 #if RPICT|RVIEW
204 rval = getviewopt(&ourview, argc-i, argv+i);
205 if (rval >= 0) {
206 i += rval;
207 continue;
208 }
209 #endif
210 switch (argv[i][1]) {
211 #if RPICT|RVIEW
212 case 'v': /* view file */
213 if (argv[i][2] != 'f')
214 goto badopt;
215 check(3,"s");
216 rval = viewfile(argv[++i], &ourview, NULL);
217 if (rval < 0) {
218 sprintf(errmsg,
219 "cannot open view file \"%s\"",
220 argv[i]);
221 error(SYSTEM, errmsg);
222 } else if (rval == 0) {
223 sprintf(errmsg,
224 "bad view file \"%s\"",
225 argv[i]);
226 error(USER, errmsg);
227 }
228 break;
229 #endif
230 case 'b': /* back face vis. */
231 if (argv[i][2] == 'v') {
232 bool(3,backvis);
233 break;
234 }
235 #if RVIEW
236 bool(2,greyscale);
237 break;
238 #else
239 goto badopt;
240 #endif
241 case 'd': /* direct */
242 switch (argv[i][2]) {
243 case 't': /* threshold */
244 check(3,"f");
245 shadthresh = atof(argv[++i]);
246 break;
247 case 'c': /* certainty */
248 check(3,"f");
249 shadcert = atof(argv[++i]);
250 break;
251 case 'j': /* jitter */
252 check(3,"f");
253 dstrsrc = atof(argv[++i]);
254 break;
255 case 'r': /* relays */
256 check(3,"i");
257 directrelay = atoi(argv[++i]);
258 break;
259 case 'p': /* pretest */
260 check(3,"i");
261 vspretest = atoi(argv[++i]);
262 break;
263 case 'v': /* visibility */
264 bool(3,directvis);
265 break;
266 case 's': /* size */
267 check(3,"f");
268 srcsizerat = atof(argv[++i]);
269 break;
270 default:
271 goto badopt;
272 }
273 break;
274 case 's': /* specular */
275 switch (argv[i][2]) {
276 case 't': /* threshold */
277 check(3,"f");
278 specthresh = atof(argv[++i]);
279 break;
280 case 'j': /* jitter */
281 check(3,"f");
282 specjitter = atof(argv[++i]);
283 break;
284 default:
285 goto badopt;
286 }
287 break;
288 #if RPICT|RVIEW
289 case 'p': /* pixel */
290 switch (argv[i][2]) {
291 case 's': /* sample */
292 check(3,"i");
293 psample = atoi(argv[++i]);
294 break;
295 case 't': /* threshold */
296 check(3,"f");
297 maxdiff = atof(argv[++i]);
298 break;
299 #if RPICT
300 case 'j': /* jitter */
301 check(3,"f");
302 dstrpix = atof(argv[++i]);
303 break;
304 case 'a': /* aspect */
305 check(3,"f");
306 pixaspect = atof(argv[++i]);
307 break;
308 case 'm': /* motion */
309 check(3,"f");
310 mblur = atof(argv[++i]);
311 break;
312 #endif
313 #if RVIEW
314 case 'e': /* exposure */
315 check(3,"f");
316 exposure = atof(argv[++i]);
317 if (argv[i][0] == '+' || argv[i][0] == '-')
318 exposure = pow(2.0, exposure);
319 break;
320 #endif
321 default:
322 goto badopt;
323 }
324 break;
325 #endif
326 #if RPICT|RTRACE
327 case 'x': /* x resolution */
328 check(2,"i");
329 hresolu = atoi(argv[++i]);
330 break;
331 case 'y': /* y resolution */
332 check(2,"i");
333 vresolu = atoi(argv[++i]);
334 break;
335 #endif
336 case 'w': /* warnings */
337 rval = erract[WARNING].pf != NULL;
338 bool(2,rval);
339 if (rval) erract[WARNING].pf = wputs;
340 else erract[WARNING].pf = NULL;
341 break;
342 case 'e': /* error file */
343 check(2,"s");
344 errfile = argv[++i];
345 break;
346 case 'l': /* limit */
347 switch (argv[i][2]) {
348 case 'r': /* recursion */
349 check(3,"i");
350 maxdepth = atoi(argv[++i]);
351 break;
352 case 'w': /* weight */
353 check(3,"f");
354 minweight = atof(argv[++i]);
355 break;
356 #if RTRACE
357 case 'd': /* distance */
358 bool(3,lim_dist);
359 break;
360 #endif
361 default:
362 goto badopt;
363 }
364 break;
365 case 'i': /* irradiance */
366 bool(2,do_irrad);
367 break;
368 #if RPICT
369 case 'S': /* slave index */
370 check(2,"i");
371 seqstart = atoi(argv[++i]);
372 break;
373 case 'o': /* output file */
374 check(2,"s");
375 outfile = argv[++i];
376 break;
377 case 'z': /* z file */
378 check(2,"s");
379 zfile = argv[++i];
380 break;
381 case 'r': /* recover file */
382 if (argv[i][2] == 'o') { /* +output */
383 check(3,"s");
384 outfile = argv[i+1];
385 } else
386 check(2,"s");
387 recover = argv[++i];
388 break;
389 case 't': /* timer */
390 check(2,"i");
391 ralrm = atoi(argv[++i]);
392 break;
393 #endif
394 case 'a': /* ambient */
395 switch (argv[i][2]) {
396 case 'v': /* value */
397 check(3,"fff");
398 setcolor(ambval, atof(argv[i+1]),
399 atof(argv[i+2]),
400 atof(argv[i+3]));
401 i += 3;
402 break;
403 case 'w': /* weight */
404 check(3,"i");
405 ambvwt = atoi(argv[++i]);
406 break;
407 case 'a': /* accuracy */
408 check(3,"f");
409 ambacc = atof(argv[++i]);
410 break;
411 case 'r': /* resolution */
412 check(3,"i");
413 ambres = atoi(argv[++i]);
414 break;
415 case 'd': /* divisions */
416 check(3,"i");
417 ambdiv = atoi(argv[++i]);
418 break;
419 case 's': /* super-samp */
420 check(3,"i");
421 ambssamp = atoi(argv[++i]);
422 break;
423 case 'b': /* bounces */
424 check(3,"i");
425 ambounce = atoi(argv[++i]);
426 break;
427 case 'i': /* include */
428 case 'I':
429 check(3,"s");
430 if (ambincl != 1) {
431 ambincl = 1;
432 amblp = amblist;
433 }
434 if (argv[i][2] == 'I') { /* file */
435 rval = wordfile(amblp,
436 getpath(argv[++i],getlibpath(),R_OK));
437 if (rval < 0) {
438 sprintf(errmsg,
439 "cannot open ambient include file \"%s\"",
440 argv[i]);
441 error(SYSTEM, errmsg);
442 }
443 amblp += rval;
444 } else {
445 *amblp++ = argv[++i];
446 *amblp = NULL;
447 }
448 break;
449 case 'e': /* exclude */
450 case 'E':
451 check(3,"s");
452 if (ambincl != 0) {
453 ambincl = 0;
454 amblp = amblist;
455 }
456 if (argv[i][2] == 'E') { /* file */
457 rval = wordfile(amblp,
458 getpath(argv[++i],getlibpath(),R_OK));
459 if (rval < 0) {
460 sprintf(errmsg,
461 "cannot open ambient exclude file \"%s\"",
462 argv[i]);
463 error(SYSTEM, errmsg);
464 }
465 amblp += rval;
466 } else {
467 *amblp++ = argv[++i];
468 *amblp = NULL;
469 }
470 break;
471 case 'f': /* file */
472 check(3,"s");
473 ambfile= argv[++i];
474 break;
475 default:
476 goto badopt;
477 }
478 break;
479 case 'm': /* medium */
480 switch (argv[i][2]) {
481 case 'e': /* extinction */
482 check(3,"fff");
483 setcolor(cextinction, atof(argv[i+1]),
484 atof(argv[i+2]),
485 atof(argv[i+3]));
486 i += 3;
487 break;
488 case 'a': /* albedo */
489 check(3,"fff");
490 setcolor(salbedo, atof(argv[i+1]),
491 atof(argv[i+2]),
492 atof(argv[i+3]));
493 i += 3;
494 break;
495 case 'g': /* eccentr. */
496 check(3,"f");
497 seccg = atof(argv[++i]);
498 break;
499 case 's': /* sampling */
500 check(3,"f");
501 ssampdist = atof(argv[++i]);
502 break;
503 default:
504 goto badopt;
505 }
506 break;
507 #if RTRACE
508 case 'I': /* immed. irradiance */
509 bool(2,imm_irrad);
510 break;
511 case 'f': /* format i/o */
512 switch (argv[i][2]) {
513 case 'a': /* ascii */
514 case 'f': /* float */
515 case 'd': /* double */
516 inform = argv[i][2];
517 break;
518 default:
519 goto badopt;
520 }
521 switch (argv[i][3]) {
522 case '\0':
523 outform = inform;
524 break;
525 case 'a': /* ascii */
526 case 'f': /* float */
527 case 'd': /* double */
528 case 'c': /* color */
529 check(4,"");
530 outform = argv[i][3];
531 break;
532 default:
533 goto badopt;
534 }
535 break;
536 case 'o': /* output */
537 outvals = argv[i]+2;
538 break;
539 case 'h': /* header output */
540 rval = loadflags & IO_INFO;
541 bool(2,rval);
542 loadflags = rval ? loadflags | IO_INFO :
543 loadflags & ~IO_INFO;
544 break;
545 case 't': /* trace */
546 switch (argv[i][2]) {
547 case 'i': /* include */
548 case 'I':
549 check(3,"s");
550 if (traincl != 1) {
551 traincl = 1;
552 tralp = tralist;
553 }
554 if (argv[i][2] == 'I') { /* file */
555 rval = wordfile(tralp,
556 getpath(argv[++i],getlibpath(),R_OK));
557 if (rval < 0) {
558 sprintf(errmsg,
559 "cannot open trace include file \"%s\"",
560 argv[i]);
561 error(SYSTEM, errmsg);
562 }
563 tralp += rval;
564 } else {
565 *tralp++ = argv[++i];
566 *tralp = NULL;
567 }
568 break;
569 case 'e': /* exclude */
570 case 'E':
571 check(3,"s");
572 if (traincl != 0) {
573 traincl = 0;
574 tralp = tralist;
575 }
576 if (argv[i][2] == 'E') { /* file */
577 rval = wordfile(tralp,
578 getpath(argv[++i],getlibpath(),R_OK));
579 if (rval < 0) {
580 sprintf(errmsg,
581 "cannot open trace exclude file \"%s\"",
582 argv[i]);
583 error(SYSTEM, errmsg);
584 }
585 tralp += rval;
586 } else {
587 *tralp++ = argv[++i];
588 *tralp = NULL;
589 }
590 break;
591 default:
592 goto badopt;
593 }
594 break;
595 #endif
596 #if RVIEW
597 case 'o': /* output device */
598 check(2,"s");
599 devname = argv[++i];
600 break;
601 case 'R': /* render input file */
602 check(2,"s");
603 strcpy(rifname, argv[++i]);
604 break;
605 #endif
606 #ifdef PERSIST
607 case 'P': /* persist file */
608 if (argv[i][2] == 'P') {
609 check(3,"s");
610 persist = PARALLEL;
611 } else {
612 check(2,"s");
613 persist = PERSIST;
614 }
615 persistfile(argv[++i]);
616 break;
617 #endif
618 default:
619 goto badopt;
620 }
621 }
622 #if RPICT|RVIEW
623 err = setview(&ourview); /* set viewing parameters */
624 if (err != NULL)
625 error(USER, err);
626 #endif
627 /* set up signal handling */
628 sigdie(SIGINT, "Interrupt");
629 sigdie(SIGHUP, "Hangup");
630 sigdie(SIGTERM, "Terminate");
631 sigdie(SIGPIPE, "Broken pipe");
632 sigdie(SIGALRM, "Alarm clock");
633 #ifdef SIGXCPU
634 sigdie(SIGXCPU, "CPU limit exceeded");
635 sigdie(SIGXFSZ, "File size exceeded");
636 #endif
637 /* open error file */
638 if (errfile != NULL) {
639 if (freopen(errfile, "a", stderr) == NULL)
640 quit(2);
641 fprintf(stderr, "**************\n*** PID %5d: ",
642 getpid());
643 printargs(argc, argv, stderr);
644 putc('\n', stderr);
645 fflush(stderr);
646 }
647 #ifdef NICE
648 nice(NICE); /* lower priority */
649 #endif
650 /* get octree */
651 #if RVIEW
652 loadflags &= ~IO_INFO;
653 #endif
654 if (i == argc)
655 octname = NULL;
656 else if (i == argc-1)
657 octname = argv[i];
658 else
659 goto badopt;
660 if (
661 #if RPICT
662 seqstart > 0 &&
663 #endif
664 octname == NULL)
665 error(USER, "missing octree argument");
666 /* set up output */
667 #ifdef PERSIST
668 if (persist) {
669 #if RPICT
670 if (recover != NULL)
671 error(USER, "persist option used with recover file");
672 if (seqstart <= 0)
673 error(USER, "persist option only for sequences");
674 if (outfile == NULL)
675 #endif
676 duped1 = dup(fileno(stdout)); /* don't lose our output */
677 openheader();
678 }
679 #if RPICT
680 else
681 #endif
682 #endif
683 #if RPICT
684 if (outfile != NULL)
685 openheader();
686 #endif
687 #ifdef MSDOS
688 #if RTRACE
689 if (outform != 'a')
690 #endif
691 setmode(fileno(stdout), O_BINARY);
692 if (octname == NULL)
693 setmode(fileno(stdin), O_BINARY);
694 #endif
695 readoct(octname, loadflags, &thescene, NULL);
696 nsceneobjs = nobjects;
697
698 if (loadflags & IO_INFO) { /* print header */
699 printargs(i, argv, stdout);
700 printf("SOFTWARE= %s\n", VersionID);
701 #if RTRACE
702 fputformat(formstr(outform), stdout);
703 putchar('\n');
704 #endif
705 }
706
707 marksources(); /* find and mark sources */
708
709 setambient(ambfile); /* initialize ambient calculation */
710
711 #ifdef PERSIST
712 if (persist) {
713 fflush(stdout);
714 if (outfile == NULL) { /* reconnect stdout */
715 dup2(duped1, fileno(stdout));
716 close(duped1);
717 }
718 if (persist == PARALLEL) { /* multiprocessing */
719 preload_objs(); /* preload scene */
720 strcpy(shm_boundary=bmalloc(16), "SHM_BOUNDARY");
721 while ((rval=fork()) == 0) { /* keep on forkin' */
722 pflock(1);
723 pfhold();
724 tstart = time((time_t *)NULL);
725 }
726 if (rval < 0)
727 error(SYSTEM, "cannot fork child for persist function");
728 pfdetach(); /* parent exits */
729 }
730 }
731 runagain:
732 if (persist)
733 if (outfile == NULL) /* if out to stdout */
734 dupheader(); /* send header */
735 else /* if out to file */
736 duped1 = dup(fileno(stdout)); /* hang onto pipe */
737 #endif
738 #if RPICT
739 rpict(seqstart, outfile, zfile, recover);
740 #endif
741 #if RTRACE
742 rtrace(NULL);
743 #endif
744 #if RVIEW
745 rview();
746 #endif
747 ambsync(); /* flush ambient file */
748 #ifdef PERSIST
749 if (persist == PERSIST) { /* first run-through */
750 if ((rval=fork()) == 0) { /* child loops until killed */
751 pflock(1);
752 persist = PCHILD;
753 } else { /* original process exits */
754 if (rval < 0)
755 error(SYSTEM, "cannot fork child for persist function");
756 pfdetach(); /* parent exits */
757 }
758 }
759 if (persist == PCHILD) { /* wait for a signal then go again */
760 if (outfile != NULL)
761 close(duped1); /* release output handle */
762 pfhold();
763 tstart = time((time_t *)NULL); /* reinitialize */
764 raynum = nrays = 0;
765 goto runagain;
766 }
767 #endif
768 quit(0);
769
770 badopt:
771 sprintf(errmsg, "command line error at '%s'", argv[i]);
772 error(USER, errmsg);
773
774 #undef check
775 #undef bool
776 }
777
778
779 wputs(s) /* warning output function */
780 char *s;
781 {
782 int lasterrno = errno;
783 eputs(s);
784 errno = lasterrno;
785 }
786
787
788 eputs(s) /* put string to stderr */
789 register char *s;
790 {
791 static int midline = 0;
792
793 if (!*s)
794 return;
795 if (!midline++) {
796 fputs(progname, stderr);
797 fputs(": ", stderr);
798 }
799 fputs(s, stderr);
800 if (s[strlen(s)-1] == '\n') {
801 fflush(stderr);
802 midline = 0;
803 }
804 }
805
806
807 onsig(signo) /* fatal signal */
808 int signo;
809 {
810 static int gotsig = 0;
811
812 if (gotsig++) /* two signals and we're gone! */
813 _exit(signo);
814
815 alarm(15); /* allow 15 seconds to clean up */
816 signal(SIGALRM, SIG_DFL); /* make certain we do die */
817 eputs("signal - ");
818 eputs(sigerr[signo]);
819 eputs("\n");
820 quit(3);
821 }
822
823
824 sigdie(signo, msg) /* set fatal signal */
825 int signo;
826 char *msg;
827 {
828 if (signal(signo, onsig) == SIG_IGN)
829 signal(signo, SIG_IGN);
830 sigerr[signo] = msg;
831 }
832
833
834 printdefaults() /* print default values to stdout */
835 {
836 register char *cp;
837
838 #if RTRACE
839 if (imm_irrad)
840 printf("-I+\t\t\t\t# immediate irradiance on\n");
841 else
842 #endif
843 printf(do_irrad ? "-i+\t\t\t\t# irradiance calculation on\n" :
844 "-i-\t\t\t\t# irradiance calculation off\n");
845 #if RVIEW
846 printf(greyscale ? "-b+\t\t\t\t# greyscale on\n" :
847 "-b-\t\t\t\t# greyscale off\n");
848 #endif
849 #if RPICT|RVIEW
850 printf("-vt%c\t\t\t\t# view type %s\n", ourview.type,
851 ourview.type==VT_PER ? "perspective" :
852 ourview.type==VT_PAR ? "parallel" :
853 ourview.type==VT_HEM ? "hemispherical" :
854 ourview.type==VT_ANG ? "angular" :
855 ourview.type==VT_CYL ? "cylindrical" :
856 "unknown");
857 printf("-vp %f %f %f\t# view point\n",
858 ourview.vp[0], ourview.vp[1], ourview.vp[2]);
859 printf("-vd %f %f %f\t# view direction\n",
860 ourview.vdir[0], ourview.vdir[1], ourview.vdir[2]);
861 printf("-vu %f %f %f\t# view up\n",
862 ourview.vup[0], ourview.vup[1], ourview.vup[2]);
863 printf("-vh %f\t\t\t# view horizontal size\n", ourview.horiz);
864 printf("-vv %f\t\t\t# view vertical size\n", ourview.vert);
865 printf("-vo %f\t\t\t# view fore clipping plane\n", ourview.vfore);
866 printf("-va %f\t\t\t# view aft clipping plane\n", ourview.vaft);
867 printf("-vs %f\t\t\t# view shift\n", ourview.hoff);
868 printf("-vl %f\t\t\t# view lift\n", ourview.voff);
869 #endif
870 #if RPICT|RTRACE
871 printf("-x %-9d\t\t\t# x resolution\n", hresolu);
872 printf("-y %-9d\t\t\t# y resolution\n", vresolu);
873 #endif
874 #if RPICT
875 printf("-pa %f\t\t\t# pixel aspect ratio\n", pixaspect);
876 printf("-pj %f\t\t\t# pixel jitter\n", dstrpix);
877 printf("-pm %f\t\t\t# pixel motion\n", mblur);
878 #endif
879 #if RVIEW
880 printf("-pe %f\t\t\t# pixel exposure\n", exposure);
881 #endif
882 #if RPICT|RVIEW
883 printf("-ps %-9d\t\t\t# pixel sample\n", psample);
884 printf("-pt %f\t\t\t# pixel threshold\n", maxdiff);
885 #endif
886 printf(backvis ? "-bv+\t\t\t\t# back face visibility on\n" :
887 "-bv-\t\t\t\t# back face visibility off\n");
888 printf("-dt %f\t\t\t# direct threshold\n", shadthresh);
889 printf("-dc %f\t\t\t# direct certainty\n", shadcert);
890 printf("-dj %f\t\t\t# direct jitter\n", dstrsrc);
891 printf("-ds %f\t\t\t# direct sampling\n", srcsizerat);
892 printf("-dr %-9d\t\t\t# direct relays\n", directrelay);
893 printf("-dp %-9d\t\t\t# direct pretest density\n", vspretest);
894 printf(directvis ? "-dv+\t\t\t\t# direct visibility on\n" :
895 "-dv-\t\t\t\t# direct visibility off\n");
896 printf("-sj %f\t\t\t# specular jitter\n", specjitter);
897 printf("-st %f\t\t\t# specular threshold\n", specthresh);
898 printf("-av %f %f %f\t# ambient value\n", colval(ambval,RED),
899 colval(ambval,GRN), colval(ambval, BLU));
900 printf("-aw %-9d\t\t\t# ambient value weight\n", ambvwt);
901 printf("-ab %-9d\t\t\t# ambient bounces\n", ambounce);
902 printf("-aa %f\t\t\t# ambient accuracy\n", ambacc);
903 printf("-ar %-9d\t\t\t# ambient resolution\n", ambres);
904 printf("-ad %-9d\t\t\t# ambient divisions\n", ambdiv);
905 printf("-as %-9d\t\t\t# ambient super-samples\n", ambssamp);
906 printf("-me %.2e %.2e %.2e\t# mist extinction coefficient\n",
907 colval(cextinction,RED),
908 colval(cextinction,GRN),
909 colval(cextinction,BLU));
910 printf("-ma %f %f %f\t# mist scattering albedo\n", colval(salbedo,RED),
911 colval(salbedo,GRN), colval(salbedo,BLU));
912 printf("-mg %f\t\t\t# mist scattering eccentricity\n", seccg);
913 printf("-ms %f\t\t\t# mist sampling distance\n", ssampdist);
914 printf("-lr %-9d\t\t\t# limit reflection\n", maxdepth);
915 printf("-lw %f\t\t\t# limit weight\n", minweight);
916 #if RTRACE
917 printf(lim_dist ? "-ld+\t\t\t\t# limit distance on\n" :
918 "-ld-\t\t\t\t# limit distance off\n");
919 #endif
920 #if RPICT
921 printf("-t %-9d\t\t\t# time between reports\n", ralrm);
922 #endif
923 #if RVIEW
924 printf("-o %s\t\t\t\t# output device\n", devname);
925 #endif
926 #if RTRACE
927 printf("-f%c%c\t\t\t\t# format input/output = %s/%s\n",
928 inform, outform, formstr(inform), formstr(outform));
929 printf("-o%s\t\t\t\t# output", outvals);
930 for (cp = outvals; *cp; cp++)
931 switch (*cp) {
932 case 't': printf(" trace"); break;
933 case 'o': printf(" origin"); break;
934 case 'd': printf(" direction"); break;
935 case 'v': printf(" value"); break;
936 case 'l': printf(" length"); break;
937 case 'L': printf(" first_length"); break;
938 case 'p': printf(" point"); break;
939 case 'n': printf(" normal"); break;
940 case 'N': printf(" unperturbed_normal"); break;
941 case 's': printf(" surface"); break;
942 case 'w': printf(" weight"); break;
943 case 'm': printf(" modifier"); break;
944 }
945 putchar('\n');
946 #endif
947 printf(erract[WARNING].pf != NULL ?
948 "-w+\t\t\t\t# warning messages on\n" :
949 "-w-\t\t\t\t# warning messages off\n");
950 }
