root/radiance/ray/src/rt/renderopts.c
Revision: 2.3
Committed: Tue May 13 17:58:33 2003 UTC (22 years, 3 months ago) by greg
5 * renderopts.c - process common rendering options
6 *
7 * External symbols declared in ray.h
8 */
9
10 #include "copyright.h"
11
12 #include "ray.h"
13
14
15 int
16 getrenderopt(ac, av) /* get next render option */
17 int ac;
18 char *av[];
19 {
20 #define check(ol,al) if (av[0][ol] || \
21 badarg(ac-1,av+1,al)) \
22 return(-1)
23 #define bool(olen,var) switch (av[0][olen]) { \
24 case '\0': var = !var; break; \
25 case 'y': case 'Y': case 't': case 'T': \
26 case '+': case '1': var = 1; break; \
27 case 'n': case 'N': case 'f': case 'F': \
28 case '-': case '0': var = 0; break; \
29 default: return(-1); }
30 static char **amblp; /* pointer to build ambient list */
31 int rval;
32 /* is it even an option? */
33 if (ac < 1 || av[0] == NULL || av[0][0] != '-')
34 return(-1);
35 /* check if it's one we know */
36 switch (av[0][1]) {
37 case 'b': /* back face vis. */
38 if (av[0][2] == 'v') {
39 bool(3,backvis);
40 return(0);
41 }
42 break;
43 case 'd': /* direct */
44 switch (av[0][2]) {
45 case 't': /* threshold */
46 check(3,"f");
47 shadthresh = atof(av[1]);
48 return(1);
49 case 'c': /* certainty */
50 check(3,"f");
51 shadcert = atof(av[1]);
52 return(1);
53 case 'j': /* jitter */
54 check(3,"f");
55 dstrsrc = atof(av[1]);
56 return(1);
57 case 'r': /* relays */
58 check(3,"i");
59 directrelay = atoi(av[1]);
60 return(1);
61 case 'p': /* pretest */
62 check(3,"i");
63 vspretest = atoi(av[1]);
64 return(1);
65 case 'v': /* visibility */
66 bool(3,directvis);
67 return(0);
68 case 's': /* size */
69 check(3,"f");
70 srcsizerat = atof(av[1]);
71 return(1);
72 }
73 break;
74 case 's': /* specular */
75 switch (av[0][2]) {
76 case 't': /* threshold */
77 check(3,"f");
78 specthresh = atof(av[1]);
79 return(1);
80 case 'j': /* jitter */
81 check(3,"f");
82 specjitter = atof(av[1]);
83 return(1);
84 }
85 break;
86 case 'l': /* limit */
87 switch (av[0][2]) {
88 case 'r': /* recursion */
89 check(3,"i");
90 maxdepth = atoi(av[1]);
91 return(1);
92 case 'w': /* weight */
93 check(3,"f");
94 minweight = atof(av[1]);
95 return(1);
96 }
97 break;
98 case 'i': /* irradiance */
99 bool(2,do_irrad);
100 return(0);
101 case 'a': /* ambient */
102 switch (av[0][2]) {
103 case 'v': /* value */
104 check(3,"fff");
105 setcolor(ambval, atof(av[1]),
106 atof(av[2]),
107 atof(av[3]));
108 return(3);
109 case 'w': /* weight */
110 check(3,"i");
111 ambvwt = atoi(av[1]);
112 return(1);
113 case 'a': /* accuracy */
114 check(3,"f");
115 ambacc = atof(av[1]);
116 return(1);
117 case 'r': /* resolution */
118 check(3,"i");
119 ambres = atoi(av[1]);
120 return(1);
121 case 'd': /* divisions */
122 check(3,"i");
123 ambdiv = atoi(av[1]);
124 return(1);
125 case 's': /* super-samp */
126 check(3,"i");
127 ambssamp = atoi(av[1]);
128 return(1);
129 case 'b': /* bounces */
130 check(3,"i");
131 ambounce = atoi(av[1]);
132 return(1);
133 case 'i': /* include */
134 case 'I':
135 check(3,"s");
136 if (ambincl != 1) {
137 ambincl = 1;
138 amblp = amblist;
139 }
140 if (av[0][2] == 'I') { /* file */
141 rval = wordfile(amblp,
142 getpath(av[1],getrlibpath(),R_OK));
143 if (rval < 0) {
144 sprintf(errmsg,
145 "cannot open ambient include file \"%s\"", av[0]);
146 error(SYSTEM, errmsg);
147 }
148 amblp += rval;
149 } else {
150 *amblp++ = av[1];
151 *amblp = NULL;
152 }
153 return(1);
154 case 'e': /* exclude */
155 case 'E':
156 check(3,"s");
157 if (ambincl != 0) {
158 ambincl = 0;
159 amblp = amblist;
160 }
161 if (av[0][2] == 'E') { /* file */
162 rval = wordfile(amblp,
163 getpath(av[1],getrlibpath(),R_OK));
164 if (rval < 0) {
165 sprintf(errmsg,
166 "cannot open ambient exclude file \"%s\"", av[0]);
167 error(SYSTEM, errmsg);
168 }
169 amblp += rval;
170 } else {
171 *amblp++ = av[1];
172 *amblp = NULL;
173 }
174 return(1);
175 case 'f': /* file */
176 check(3,"s");
177 ambfile= av[1];
178 return(1);
179 }
180 break;
181 case 'm': /* medium */
182 switch (av[0][2]) {
183 case 'e': /* extinction */
184 check(3,"fff");
185 setcolor(cextinction, atof(av[1]),
186 atof(av[2]),
187 atof(av[3]));
188 return(3);
189 case 'a': /* albedo */
190 check(3,"fff");
191 setcolor(salbedo, atof(av[1]),
192 atof(av[2]),
193 atof(av[3]));
194 return(3);
195 case 'g': /* eccentr. */
196 check(3,"f");
197 seccg = atof(av[1]);
198 return(1);
199 case 's': /* sampling */
200 check(3,"f");
201 ssampdist = atof(av[1]);
202 return(1);
203 }
204 break;
205 }
206 return(-1); /* unknown option */
207
208 #undef check
209 #undef bool
210 }
211
212
213 void
214 print_rdefaults() /* print default render values to stdout */
215 {
216 register char *cp;
217
218 printf(do_irrad ? "-i+\t\t\t\t# irradiance calculation on\n" :
219 "-i-\t\t\t\t# irradiance calculation off\n");
220 printf(backvis ? "-bv+\t\t\t\t# back face visibility on\n" :
221 "-bv-\t\t\t\t# back face visibility off\n");
222 printf("-dt %f\t\t\t# direct threshold\n", shadthresh);
223 printf("-dc %f\t\t\t# direct certainty\n", shadcert);
224 printf("-dj %f\t\t\t# direct jitter\n", dstrsrc);
225 printf("-ds %f\t\t\t# direct sampling\n", srcsizerat);
226 printf("-dr %-9d\t\t\t# direct relays\n", directrelay);
227 printf("-dp %-9d\t\t\t# direct pretest density\n", vspretest);
228 printf(directvis ? "-dv+\t\t\t\t# direct visibility on\n" :
229 "-dv-\t\t\t\t# direct visibility off\n");
230 printf("-sj %f\t\t\t# specular jitter\n", specjitter);
231 printf("-st %f\t\t\t# specular threshold\n", specthresh);
232 printf("-av %f %f %f\t# ambient value\n", colval(ambval,RED),
233 colval(ambval,GRN), colval(ambval, BLU));
234 printf("-aw %-9d\t\t\t# ambient value weight\n", ambvwt);
235 printf("-ab %-9d\t\t\t# ambient bounces\n", ambounce);
236 printf("-aa %f\t\t\t# ambient accuracy\n", ambacc);
237 printf("-ar %-9d\t\t\t# ambient resolution\n", ambres);
238 printf("-ad %-9d\t\t\t# ambient divisions\n", ambdiv);
239 printf("-as %-9d\t\t\t# ambient super-samples\n", ambssamp);
240 printf("-me %.2e %.2e %.2e\t# mist extinction coefficient\n",
241 colval(cextinction,RED),
242 colval(cextinction,GRN),
243 colval(cextinction,BLU));
244 printf("-ma %f %f %f\t# mist scattering albedo\n", colval(salbedo,RED),
245 colval(salbedo,GRN), colval(salbedo,BLU));
246 printf("-mg %f\t\t\t# mist scattering eccentricity\n", seccg);
247 printf("-ms %f\t\t\t# mist sampling distance\n", ssampdist);
248 printf("-lr %-9d\t\t\t# limit reflection\n", maxdepth);
249 printf("-lw %f\t\t\t# limit weight\n", minweight);
250 }
