root/radiance/ray/src/rt/renderopts.c
Revision: 2.23
Committed: Fri Nov 17 20:02:07 2023 UTC (20 months, 2 weeks ago) by greg
Changes since 2.22: +24 -1 lines
2 static const char RCSid[] = "$Id: renderopts.c,v 2.22 2023/08/15 01:19:37 greg Exp $";
5 * renderopts.c - process common rendering options
6 *
7 * External symbols declared in ray.h
8 */
9
10 #include "copyright.h"
11
12 #include "ray.h"
13 #include "paths.h"
14 #include "pmapopt.h"
15
16 extern char *progname; /* global argv[0] */
17
18 char RFeatureList[2048] = /* newline-separated feature list */
19 "VirtualSources\nSecondarySources\nSourceSubsampling\n"
20 "SourceVisibility\nAmbientModifierSelection\n"
21 "PathTracing\nRussianRoulette\nLowDiscrepancySeq\n"
22 "SpecularSampling\nMaterialMixtures\nAntimatter\nBackFaceVisibility\n"
23 "ScatteringModels=WGMD,Ashikhmin-Shirley\n"
24 "TabulatedBSDFs=DataFile,KlemsXML,TensorTreeXML,+ViewPeakExtraction\n"
25 "Instancing=Octree,TriangleMesh\nAliases\n"
26 #if MAXCSAMP>3
27 "Hyperspectral\n"
28 #endif
29 #if !defined(SHADCACHE) || SHADCACHE > 0
30 "ShadowCache\n"
31 #endif
32 #ifdef DISPERSE
33 "DielectricDispersion\n"
34 #endif
35 /* PMAP_FEATURES XXX @Roland: need to define this in pmapopt.h */
36 ;
37
38
39 static char *
40 get_feature( /* find a specific feature (with optional sublist) */
41 const char *feat
42 )
43 {
44 char *cp = RFeatureList;
45 int n = 0;
46
47 while ((feat[n] != '\0') & (feat[n] != '='))
48 n++;
49 if (!n)
50 return(NULL);
51 while (*cp) {
52 if (!strncmp(cp, feat, n) && (cp[n] == '\n') | !feat[n] | (cp[n] == feat[n]))
53 return(cp);
54 while (*cp++ != '\n')
55 ;
56 }
57 return(NULL);
58 }
59
60
61 static int
62 match_subfeatures( /* check if subfeatures are supported */
63 char *mysublist,
64 char *reqs
65 )
66 {
67 if (mysublist)
68 mysublist = strchr(mysublist, '=');
69 if (!mysublist++ | !reqs)
70 return(0); /* not a feature list */
71 while (*reqs) { /* check each of their subfeature requests */
72 char subfeat[64];
73 char *cp = subfeat;
74 int n;
75 while (*reqs && (*cp = *reqs++) != ',')
76 cp++;
77 *cp = '\0';
78 n = cp - subfeat;
79 if (!(cp = strstr(mysublist, subfeat)) ||
80 (cp[-1] != ',') & (cp[-1] != '=') ||
81 (cp[n] != ',') & (cp[n] != '\n'))
82 return(0); /* missing this one! */
83 }
84 return(1); /* matched them all */
85 }
86
87
88 int
89 feature_status( /* report active feature list / check specifics */
90 int ac,
91 char *av[]
92 )
93 {
94 if (ac <= 0) /* report entire list? */
95 fputs(RFeatureList, stdout);
96
97 for ( ; ac-- > 0; av++) { /* check each argument */
98 char *cp;
99 if (!*av[0]) continue;
100 if ((cp = strchr(av[0], '=')) != NULL) {
101 if (!match_subfeatures(get_feature(av[0]), cp+1))
102 goto missing_feature;
103 } else if ((cp = get_feature(av[0])) != NULL) {
104 char *tp = strchr(cp, '=');
105 if (tp && tp < strchr(cp, '\n'))
106 do
107 fputc(*cp, stdout);
108 while (*cp++ != '\n');
109 } else
110 goto missing_feature;
111 }
112 return(0); /* return satisfactory status */
113 missing_feature: /* or report error */
114 fprintf(stderr, "%s: missing feature - %s\n", progname, av[0]);
115 return(1);
116 }
117
118
119 int
120 getrenderopt( /* get next render option */
121 int ac,
122 char *av[]
123 )
124 {
125 #define check(ol,al) if (av[0][ol] || \
126 badarg(ac-1,av+1,al)) \
127 return(-1)
128 #define check_bool(olen,var) switch (av[0][olen]) { \
129 case '\0': var = !var; break; \
130 case 'y': case 'Y': case 't': case 'T': \
131 case '+': case '1': var = 1; break; \
132 case 'n': case 'N': case 'f': case 'F': \
133 case '-': case '0': var = 0; break; \
134 default: return(-1); }
135 static char **amblp; /* pointer to build ambient list */
136 int rval;
137 /* is it even an option? */
138 if (ac < 1 || av[0] == NULL || av[0][0] != '-')
139 return(-1);
140 /* check if it's one we know */
141 switch (av[0][1]) {
142 case 'u': /* uncorrelated sampling */
143 check_bool(2,rand_samp);
144 return(0);
145 case 'b': /* back face vis. */
146 if (av[0][2] == 'v') {
147 check_bool(3,backvis);
148 return(0);
149 }
150 break;
151 case 'd': /* direct */
152 switch (av[0][2]) {
153 case 't': /* threshold */
154 check(3,"f");
155 shadthresh = atof(av[1]);
156 return(1);
157 case 'c': /* certainty */
158 check(3,"f");
159 shadcert = atof(av[1]);
160 return(1);
161 case 'j': /* jitter */
162 check(3,"f");
163 dstrsrc = atof(av[1]);
164 return(1);
165 case 'r': /* relays */
166 check(3,"i");
167 directrelay = atoi(av[1]);
168 return(1);
169 case 'p': /* pretest */
170 check(3,"i");
171 vspretest = atoi(av[1]);
172 return(1);
173 case 'v': /* visibility */
174 check_bool(3,directvis);
175 return(0);
176 case 's': /* size */
177 check(3,"f");
178 srcsizerat = atof(av[1]);
179 return(1);
180 }
181 break;
182 case 's': /* specular */
183 switch (av[0][2]) {
184 case 't': /* threshold */
185 check(3,"f");
186 specthresh = atof(av[1]);
187 return(1);
188 case 's': /* sampling */
189 check(3,"f");
190 specjitter = atof(av[1]);
191 return(1);
192 }
193 break;
194 case 'l': /* limit */
195 switch (av[0][2]) {
196 case 'r': /* recursion */
197 check(3,"i");
198 maxdepth = atoi(av[1]);
199 return(1);
200 case 'w': /* weight */
201 check(3,"f");
202 minweight = atof(av[1]);
203 return(1);
204 }
205 break;
206 case 'i': /* irradiance */
207 check_bool(2,do_irrad);
208 return(0);
209 case 'a': /* ambient */
210 switch (av[0][2]) {
211 case 'v': /* value */
212 check(3,"fff");
213 setcolor(ambval, atof(av[1]),
214 atof(av[2]),
215 atof(av[3]));
216 return(3);
217 case 'w': /* weight */
218 check(3,"i");
219 ambvwt = atoi(av[1]);
220 return(1);
221 case 'a': /* accuracy */
222 check(3,"f");
223 ambacc = atof(av[1]);
224 return(1);
225 case 'r': /* resolution */
226 check(3,"i");
227 ambres = atoi(av[1]);
228 return(1);
229 case 'd': /* divisions */
230 check(3,"i");
231 ambdiv = atoi(av[1]);
232 return(1);
233 case 's': /* super-samp */
234 check(3,"i");
235 ambssamp = atoi(av[1]);
236 return(1);
237 case 'b': /* bounces */
238 check(3,"i");
239 ambounce = atoi(av[1]);
240 return(1);
241 case 'i': /* include */
242 case 'I':
243 check(3,"s");
244 if (ambincl != 1) {
245 ambincl = 1;
246 amblp = amblist;
247 }
248 if (av[0][2] == 'I') { /* file */
249 rval = wordfile(amblp, AMBLLEN-(amblp-amblist),
250 getpath(av[1],getrlibpath(),R_OK));
251 if (rval < 0) {
252 sprintf(errmsg,
253 "cannot open ambient include file \"%s\"", av[1]);
254 error(SYSTEM, errmsg);
255 }
256 amblp += rval;
257 } else {
258 *amblp++ = savqstr(av[1]);
259 *amblp = NULL;
260 }
261 return(1);
262 case 'e': /* exclude */
263 case 'E':
264 check(3,"s");
265 if (ambincl != 0) {
266 ambincl = 0;
267 amblp = amblist;
268 }
269 if (av[0][2] == 'E') { /* file */
270 rval = wordfile(amblp, AMBLLEN-(amblp-amblist),
271 getpath(av[1],getrlibpath(),R_OK));
272 if (rval < 0) {
273 sprintf(errmsg,
274 "cannot open ambient exclude file \"%s\"", av[1]);
275 error(SYSTEM, errmsg);
276 }
277 amblp += rval;
278 } else {
279 *amblp++ = savqstr(av[1]);
280 *amblp = NULL;
281 }
282 return(1);
283 case 'f': /* file */
284 check(3,"s");
285 ambfile = savqstr(av[1]);
286 return(1);
287 }
288 break;
289 case 'm': /* medium */
290 switch (av[0][2]) {
291 case 'e': /* extinction */
292 check(3,"fff");
293 setcolor(cextinction, atof(av[1]),
294 atof(av[2]),
295 atof(av[3]));
296 return(3);
297 case 'a': /* albedo */
298 check(3,"fff");
299 setcolor(salbedo, atof(av[1]),
300 atof(av[2]),
301 atof(av[3]));
302 return(3);
303 case 'g': /* eccentr. */
304 check(3,"f");
305 seccg = atof(av[1]);
306 return(1);
307 case 's': /* sampling */
308 check(3,"f");
309 ssampdist = atof(av[1]);
310 return(1);
311 }
312 break;
313 #if MAXCSAMP>3
314 case 'c': /* spectral sampling */
315 switch (av[0][2]) {
316 case 's': /* spectral bin count */
317 check(3,"i");
318 NCSAMP = atoi(av[1]);
319 return(1);
320 case 'w': /* wavelength extrema */
321 check(3,"ff");
322 WLPART[0] = atof(av[1]);
323 WLPART[3] = atof(av[2]);
324 return(1);
325 }
326 break;
327 #endif
328 }
329
330 /* PMAP: Parse photon mapping options */
331 return(getPmapRenderOpt(ac, av));
332
333 /* return(-1); */ /* unknown option */
334
335 #undef check
336 #undef check_bool
337 }
338
339
340 void
341 print_rdefaults(void) /* print default render values to stdout */
342 {
343 printf(do_irrad ? "-i+\t\t\t\t# irradiance calculation on\n" :
344 "-i-\t\t\t\t# irradiance calculation off\n");
345 printf(rand_samp ? "-u+\t\t\t\t# uncorrelated Monte Carlo sampling\n" :
346 "-u-\t\t\t\t# correlated quasi-Monte Carlo sampling\n");
347 printf(backvis ? "-bv+\t\t\t\t# back face visibility on\n" :
348 "-bv-\t\t\t\t# back face visibility off\n");
349 printf("-dt %f\t\t\t# direct threshold\n", shadthresh);
350 printf("-dc %f\t\t\t# direct certainty\n", shadcert);
351 printf("-dj %f\t\t\t# direct jitter\n", dstrsrc);
352 printf("-ds %f\t\t\t# direct sampling\n", srcsizerat);
353 printf("-dr %-9d\t\t\t# direct relays\n", directrelay);
354 printf("-dp %-9d\t\t\t# direct pretest density\n", vspretest);
355 printf(directvis ? "-dv+\t\t\t\t# direct visibility on\n" :
356 "-dv-\t\t\t\t# direct visibility off\n");
357 printf("-ss %f\t\t\t# specular sampling\n", specjitter);
358 printf("-st %f\t\t\t# specular threshold\n", specthresh);
359 printf("-av %f %f %f\t# ambient value\n", colval(ambval,RED),
360 colval(ambval,GRN), colval(ambval, BLU));
361 printf("-aw %-9d\t\t\t# ambient value weight\n", ambvwt);
362 printf("-ab %-9d\t\t\t# ambient bounces\n", ambounce);
363 printf("-aa %f\t\t\t# ambient accuracy\n", ambacc);
364 printf("-ar %-9d\t\t\t# ambient resolution\n", ambres);
365 printf("-ad %-9d\t\t\t# ambient divisions\n", ambdiv);
366 printf("-as %-9d\t\t\t# ambient super-samples\n", ambssamp);
367 printf("-me %.2e %.2e %.2e\t# mist extinction coefficient\n",
368 colval(cextinction,RED),
369 colval(cextinction,GRN),
370 colval(cextinction,BLU));
371 printf("-ma %f %f %f\t# mist scattering albedo\n", colval(salbedo,RED),
372 colval(salbedo,GRN), colval(salbedo,BLU));
373 printf("-mg %f\t\t\t# mist scattering eccentricity\n", seccg);
374 printf("-ms %f\t\t\t# mist sampling distance\n", ssampdist);
375 if (NCSAMP > 3) {
376 printf("-cs %-2d\t\t\t\t# number of spectral bins\n", NCSAMP);
377 printf("-cw %3.0f %3.0f\t\t\t# wavelength limits (nm)\n",
378 WLPART[3], WLPART[0]);
379 }
380 printf("-lr %-9d\t\t\t# limit reflection%s\n", maxdepth,
381 maxdepth<=0 ? " (Russian roulette)" : "");
382 printf("-lw %.2e\t\t\t# limit weight\n", minweight);
383
384 /* PMAP: output photon map defaults */
385 printPmapDefaults();
386 }
