root/radiance/ray/src/rt/renderopts.c
Tue Apr 22 18:08:48 2025 UTC (3 months, 2 weeks ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 2.27: +1 -5 lines
Diff to previous 2.27 , to selected 2.14
perf: Eliminated redundant tests
Tue Apr 22 17:12:25 2025 UTC (3 months, 2 weeks ago) by greg
Changes since 2.26: +16 -1 lines
Diff to previous 2.26 , to selected 2.14
Fri Apr 5 17:55:25 2024 UTC (16 months ago) by greg
Changes since 2.25: +3 -2 lines
Diff to previous 2.25 , to selected 2.14
fix: Added check for empty subfeature that could cause memory read-past-end
Fri Apr 5 17:52:20 2024 UTC (16 months ago) by greg
Changes since 2.24: +6 -4 lines
Diff to previous 2.24 , to selected 2.14
fix(rpict,rtrace,rcontrib,rvu): Fixed bug in feature sublist check
Sat Nov 18 18:14:26 2023 UTC (20 months, 2 weeks ago) by greg
Diff to previous 2.23 , to selected 2.14
fix(rpict,rtrace,others): Fixed parsing of '-cw' parameter
Fri Nov 17 20:02:07 2023 UTC (20 months, 2 weeks ago) by greg
Changes since 2.22: +24 -1 lines
Diff to previous 2.22 , to selected 2.14
Tue Aug 15 01:19:37 2023 UTC (23 months, 3 weeks ago) by greg
Diff to previous 2.21 , to selected 2.14
fix(rcontrib): Removed participating media from rcontrib -features
Mon Aug 14 23:45:41 2023 UTC (23 months, 3 weeks ago) by greg
Diff to previous 2.20 , to selected 2.14
fix: tighter requirements on subfeature list
Wed Oct 19 23:10:34 2022 UTC (2 years, 9 months ago) by greg
Diff to previous 2.19 , to selected 2.14
fix(rcontrib): removed AdaptiveShadowTesting from feature list (didn't belong)
Wed Oct 19 21:25:20 2022 UTC (2 years, 9 months ago) by greg
Changes since 2.18: +99 -1 lines
Diff to previous 2.18 , to selected 2.14
Mon Mar 21 19:06:08 2016 UTC (9 years, 4 months ago) by greg
Diff to previous 2.17 , to selected 2.14
Thu Mar 10 18:25:46 2016 UTC (9 years, 4 months ago) by schorsch
Diff to previous 2.16 , to selected 2.14
newer C++ compilers have a standard type named "bool". rename macro to get rid of warnings.
Tue Feb 24 19:39:27 2015 UTC (10 years, 5 months ago) by greg
Changes since 2.15: +10 -2 lines
Diff to previous 2.15 , to selected 2.14
Tue Jul 8 18:25:00 2014 UTC (11 years, 1 month ago) by greg
Changes since 2.14: +3 -3 lines
Diff to previous 2.14
Fri Oct 8 22:08:26 2010 UTC (14 years, 10 months ago) by greg
Diff to previous 2.13
Wed Apr 5 06:22:56 2006 UTC (19 years, 4 months ago) by greg
Made -u+ option truly random
Tue Jun 14 04:04:51 2005 UTC (20 years, 1 month ago) by greg
Tue Jun 14 03:53:58 2005 UTC (20 years, 1 month ago) by greg
Changed wording on -defaults output
Tue Jun 14 03:34:14 2005 UTC (20 years, 1 month ago) by greg
Had to change new -R rendering option to -u to avoid conflict with rpiece
Mon Jun 13 20:07:56 2005 UTC (20 years, 1 month ago) by greg
Changes since 2.8: +6 -1 lines
Tue May 31 18:01:09 2005 UTC (20 years, 2 months ago) by greg
Fri Aug 20 20:03:00 2004 UTC (20 years, 11 months ago) by greg
Fixed error message for missing -aE and -aI files
Fri Aug 13 22:57:56 2004 UTC (20 years, 11 months ago) by greg
Added savqstr() calls on recorded strings, which might be on stack
Tue Mar 30 20:40:04 2004 UTC (21 years, 4 months ago) by greg
Tue Mar 30 16:13:01 2004 UTC (21 years, 4 months ago) by schorsch
Changes since 2.3: +8 -9 lines
Tue May 13 17:58:33 2003 UTC (22 years, 3 months ago) by greg
Tue Feb 25 02:47:23 2003 UTC (22 years, 5 months ago) by greg
Sat Feb 22 02:07:29 2003 UTC (22 years, 5 months ago) by greg
Diff to selected 2.14
