root/radiance/ray/src/rt/renderopts.c
Mon Mar 21 19:06:08 2016 UTC (9 years, 1 month ago) by greg
Diff to previous 2.17 , to selected 2.3
Thu Mar 10 18:25:46 2016 UTC (9 years, 1 month ago) by schorsch
Diff to previous 2.16 , to selected 2.3
newer C++ compilers have a standard type named "bool". rename macro to get rid of warnings.
Tue Feb 24 19:39:27 2015 UTC (10 years, 2 months ago) by greg
Changes since 2.15: +10 -2 lines
Diff to previous 2.15 , to selected 2.3
Tue Jul 8 18:25:00 2014 UTC (10 years, 9 months ago) by greg
Changes since 2.14: +3 -3 lines
Diff to previous 2.14 , to selected 2.3
Fri Oct 8 22:08:26 2010 UTC (14 years, 6 months ago) by greg
Diff to previous 2.13 , to selected 2.3
Wed Apr 5 06:22:56 2006 UTC (19 years, 1 month ago) by greg
Diff to previous 2.12 , to selected 2.3
Made -u+ option truly random
Tue Jun 14 04:04:51 2005 UTC (19 years, 10 months ago) by greg
Diff to previous 2.11 , to selected 2.3
Tue Jun 14 03:53:58 2005 UTC (19 years, 10 months ago) by greg
Diff to previous 2.10 , to selected 2.3
Changed wording on -defaults output
Tue Jun 14 03:34:14 2005 UTC (19 years, 10 months ago) by greg
Diff to previous 2.9 , to selected 2.3
Had to change new -R rendering option to -u to avoid conflict with rpiece
Mon Jun 13 20:07:56 2005 UTC (19 years, 10 months ago) by greg
Changes since 2.8: +6 -1 lines
Tue May 31 18:01:09 2005 UTC (19 years, 11 months ago) by greg
Fri Aug 20 20:03:00 2004 UTC (20 years, 8 months ago) by greg
Fixed error message for missing -aE and -aI files
Fri Aug 13 22:57:56 2004 UTC (20 years, 8 months ago) by greg
Added savqstr() calls on recorded strings, which might be on stack
Tue Mar 30 20:40:04 2004 UTC (21 years, 1 month ago) by greg
Changes since 2.3: +8 -9 lines
Tue May 13 17:58:33 2003 UTC (21 years, 11 months ago) by greg
Tue Feb 25 02:47:23 2003 UTC (22 years, 2 months ago) by greg
Diff to selected 2.3
