newer C++ compilers have a standard type named "bool". rename macro to get rid of warnings.
Made -u+ option truly random
Changed wording on -defaults output
Had to change new -R rendering option to -u to avoid conflict with rpiece
Fixed error message for missing -aE and -aI files
Added savqstr() calls on recorded strings, which might be on stack
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
