root/radiance/ray/src/rt/renderopts.c
Revision 2.15 - (view) (download) (annotate) - [selected]
Tue Jul 8 18:25:00 2014 UTC (9 years, 9 months ago) by greg
Changes since 2.14: +3 -3 lines
Diff to previous 2.14
Fri Oct 8 22:08:26 2010 UTC (13 years, 6 months ago) by greg
Diff to previous 2.13 , to selected 2.15
Wed Apr 5 06:22:56 2006 UTC (18 years, 1 month ago) by greg
Diff to previous 2.12 , to selected 2.15
Made -u+ option truly random
Tue Jun 14 04:04:51 2005 UTC (18 years, 10 months ago) by greg
Diff to previous 2.11 , to selected 2.15
Tue Jun 14 03:53:58 2005 UTC (18 years, 10 months ago) by greg
Diff to previous 2.10 , to selected 2.15
Changed wording on -defaults output
Tue Jun 14 03:34:14 2005 UTC (18 years, 10 months ago) by greg
Diff to previous 2.9 , to selected 2.15
Had to change new -R rendering option to -u to avoid conflict with rpiece
Mon Jun 13 20:07:56 2005 UTC (18 years, 10 months ago) by greg
Changes since 2.8: +6 -1 lines
Diff to previous 2.8 , to selected 2.15
Tue May 31 18:01:09 2005 UTC (18 years, 11 months ago) by greg
Diff to previous 2.7 , to selected 2.15
Fri Aug 20 20:03:00 2004 UTC (19 years, 8 months ago) by greg
Diff to previous 2.6 , to selected 2.15
Fixed error message for missing -aE and -aI files
Fri Aug 13 22:57:56 2004 UTC (19 years, 8 months ago) by greg
Diff to previous 2.5 , to selected 2.15
Added savqstr() calls on recorded strings, which might be on stack
Tue Mar 30 20:40:04 2004 UTC (20 years, 1 month ago) by greg
Diff to previous 2.4 , to selected 2.15
Changes since 2.3: +8 -9 lines
Diff to previous 2.3 , to selected 2.15
Tue May 13 17:58:33 2003 UTC (20 years, 11 months ago) by greg
Diff to previous 2.2 , to selected 2.15
Diff to previous 2.1 , to selected 2.15
Diff to selected 2.15
