root/Development/ray/src/rt/renderopts.c
Tue Jul 8 18:25:00 2014 UTC (11 years, 3 months ago) by greg
Changes since 2.14: +3 -3 lines
Diff to previous 2.14
Fri Oct 8 22:08:26 2010 UTC (15 years ago) by greg
Diff to previous 2.13
Wed Apr 5 06:22:56 2006 UTC (19 years, 6 months ago) by greg
Diff to previous 2.12
Made -u+ option truly random
Tue Jun 14 04:04:51 2005 UTC (20 years, 4 months ago) by greg
Tue Jun 14 03:53:58 2005 UTC (20 years, 4 months ago) by greg
Changed wording on -defaults output
Tue Jun 14 03:34:14 2005 UTC (20 years, 4 months ago) by greg
Had to change new -R rendering option to -u to avoid conflict with rpiece
Mon Jun 13 20:07:56 2005 UTC (20 years, 4 months ago) by greg
Changes since 2.8: +6 -1 lines
Tue May 31 18:01:09 2005 UTC (20 years, 5 months ago) by greg
Fri Aug 20 20:03:00 2004 UTC (21 years, 2 months ago) by greg
Fixed error message for missing -aE and -aI files
Fri Aug 13 22:57:56 2004 UTC (21 years, 2 months ago) by greg
Added savqstr() calls on recorded strings, which might be on stack
Tue Mar 30 20:40:04 2004 UTC (21 years, 7 months ago) by greg
Tue Mar 30 16:13:01 2004 UTC (21 years, 7 months ago) by schorsch
Changes since 2.3: +8 -9 lines
Tue May 13 17:58:33 2003 UTC (22 years, 5 months ago) by greg
Tue Feb 25 02:47:23 2003 UTC (22 years, 8 months ago) by greg
Sat Feb 22 02:07:29 2003 UTC (22 years, 8 months ago) by greg
