root/radiance/ray/src/rt/renderopts.c
Wed Apr 5 06:22:56 2006 UTC (18 years, 2 months ago) by greg
Made -u+ option truly random
Tue Jun 14 04:04:51 2005 UTC (19 years ago) by greg
Tue Jun 14 03:53:58 2005 UTC (19 years ago) by greg
Changed wording on -defaults output
Tue Jun 14 03:34:14 2005 UTC (19 years ago) by greg
Had to change new -R rendering option to -u to avoid conflict with rpiece
Mon Jun 13 20:07:56 2005 UTC (19 years ago) by greg
Changes since 2.8: +6 -1 lines
Fri Aug 20 20:03:00 2004 UTC (19 years, 10 months ago) by greg
Fixed error message for missing -aE and -aI files
Fri Aug 13 22:57:56 2004 UTC (19 years, 10 months ago) by greg
Added savqstr() calls on recorded strings, which might be on stack
Tue Mar 30 20:40:04 2004 UTC (20 years, 2 months ago) by greg
Changes since 2.3: +8 -9 lines
Tue May 13 17:58:33 2003 UTC (21 years, 1 month ago) by greg
Sat Feb 22 02:07:29 2003 UTC (21 years, 4 months ago) by greg
Diff to selected 2.11
