root/radiance/ray/src/rt/renderopts.c
Revision: 2.16
Committed: Tue Feb 24 19:39:27 2015 UTC (10 years, 2 months ago) by greg
Changes since 2.15: +10 -2 lines
2 static const char RCSid[] = "$Id: renderopts.c,v 1.1 2014/08/26 15:19:26 taschreg Exp taschreg $";
5 * renderopts.c - process common rendering options
6 *
7 * External symbols declared in ray.h
8 */
9
10 #include "copyright.h"
11
12 #include "ray.h"
13 #include "paths.h"
14 #include "pmapopt.h"
15
16
17 int
18 getrenderopt( /* get next render option */
19 int ac,
20 char *av[]
21 )
22 {
23 #define check(ol,al) if (av[0][ol] || \
24 badarg(ac-1,av+1,al)) \
25 return(-1)
26 #define bool(olen,var) switch (av[0][olen]) { \
27 case '\0': var = !var; break; \
28 case 'y': case 'Y': case 't': case 'T': \
29 case '+': case '1': var = 1; break; \
30 case 'n': case 'N': case 'f': case 'F': \
31 case '-': case '0': var = 0; break; \
32 default: return(-1); }
33 static char **amblp; /* pointer to build ambient list */
34 int rval;
35 /* is it even an option? */
36 if (ac < 1 || av[0] == NULL || av[0][0] != '-')
37 return(-1);
38 /* check if it's one we know */
39 switch (av[0][1]) {
40 case 'u': /* uncorrelated sampling */
41 bool(2,rand_samp);
42 return(0);
43 case 'b': /* back face vis. */
44 if (av[0][2] == 'v') {
45 bool(3,backvis);
46 return(0);
47 }
48 break;
49 case 'd': /* direct */
50 switch (av[0][2]) {
51 case 't': /* threshold */
52 check(3,"f");
53 shadthresh = atof(av[1]);
54 return(1);
55 case 'c': /* certainty */
56 check(3,"f");
57 shadcert = atof(av[1]);
58 return(1);
59 case 'j': /* jitter */
60 check(3,"f");
61 dstrsrc = atof(av[1]);
62 return(1);
63 case 'r': /* relays */
64 check(3,"i");
65 directrelay = atoi(av[1]);
66 return(1);
67 case 'p': /* pretest */
68 check(3,"i");
69 vspretest = atoi(av[1]);
70 return(1);
71 case 'v': /* visibility */
72 bool(3,directvis);
73 return(0);
74 case 's': /* size */
75 check(3,"f");
76 srcsizerat = atof(av[1]);
77 return(1);
78 }
79 break;
80 case 's': /* specular */
81 switch (av[0][2]) {
82 case 't': /* threshold */
83 check(3,"f");
84 specthresh = atof(av[1]);
85 return(1);
86 case 's': /* sampling */
87 check(3,"f");
88 specjitter = atof(av[1]);
89 return(1);
90 }
91 break;
92 case 'l': /* limit */
93 switch (av[0][2]) {
94 case 'r': /* recursion */
95 check(3,"i");
96 maxdepth = atoi(av[1]);
97 return(1);
98 case 'w': /* weight */
99 check(3,"f");
100 minweight = atof(av[1]);
101 return(1);
102 }
103 break;
104 case 'i': /* irradiance */
105 bool(2,do_irrad);
106 return(0);
107 case 'a': /* ambient */
108 switch (av[0][2]) {
109 case 'v': /* value */
110 check(3,"fff");
111 setcolor(ambval, atof(av[1]),
112 atof(av[2]),
113 atof(av[3]));
114 return(3);
115 case 'w': /* weight */
116 check(3,"i");
117 ambvwt = atoi(av[1]);
118 return(1);
119 case 'a': /* accuracy */
120 check(3,"f");
121 ambacc = atof(av[1]);
122 return(1);
123 case 'r': /* resolution */
124 check(3,"i");
125 ambres = atoi(av[1]);
126 return(1);
127 case 'd': /* divisions */
128 check(3,"i");
129 ambdiv = atoi(av[1]);
130 return(1);
131 case 's': /* super-samp */
132 check(3,"i");
133 ambssamp = atoi(av[1]);
134 return(1);
135 case 'b': /* bounces */
136 check(3,"i");
137 ambounce = atoi(av[1]);
138 return(1);
139 case 'i': /* include */
140 case 'I':
141 check(3,"s");
142 if (ambincl != 1) {
143 ambincl = 1;
144 amblp = amblist;
145 }
146 if (av[0][2] == 'I') { /* file */
147 rval = wordfile(amblp,
148 getpath(av[1],getrlibpath(),R_OK));
149 if (rval < 0) {
150 sprintf(errmsg,
151 "cannot open ambient include file \"%s\"", av[1]);
152 error(SYSTEM, errmsg);
153 }
154 amblp += rval;
155 } else {
156 *amblp++ = savqstr(av[1]);
157 *amblp = NULL;
158 }
159 return(1);
160 case 'e': /* exclude */
161 case 'E':
162 check(3,"s");
163 if (ambincl != 0) {
164 ambincl = 0;
165 amblp = amblist;
166 }
167 if (av[0][2] == 'E') { /* file */
168 rval = wordfile(amblp,
169 getpath(av[1],getrlibpath(),R_OK));
170 if (rval < 0) {
171 sprintf(errmsg,
172 "cannot open ambient exclude file \"%s\"", av[1]);
173 error(SYSTEM, errmsg);
174 }
175 amblp += rval;
176 } else {
177 *amblp++ = savqstr(av[1]);
178 *amblp = NULL;
179 }
180 return(1);
181 case 'f': /* file */
182 check(3,"s");
183 ambfile = savqstr(av[1]);
184 return(1);
185 }
186 break;
187 case 'm': /* medium */
188 switch (av[0][2]) {
189 case 'e': /* extinction */
190 check(3,"fff");
191 setcolor(cextinction, atof(av[1]),
192 atof(av[2]),
193 atof(av[3]));
194 return(3);
195 case 'a': /* albedo */
196 check(3,"fff");
197 setcolor(salbedo, atof(av[1]),
198 atof(av[2]),
199 atof(av[3]));
200 return(3);
201 case 'g': /* eccentr. */
202 check(3,"f");
203 seccg = atof(av[1]);
204 return(1);
205 case 's': /* sampling */
206 check(3,"f");
207 ssampdist = atof(av[1]);
208 return(1);
209 }
210 break;
211 }
212
213 /* PMAP: Parse photon mapping options */
214 return(getPmapRenderOpt(ac, av));
215
216 /* return(-1); */ /* unknown option */
217
218 #undef check
219 #undef bool
220 }
221
222
223 void
224 print_rdefaults(void) /* print default render values to stdout */
225 {
226 printf(do_irrad ? "-i+\t\t\t\t# irradiance calculation on\n" :
227 "-i-\t\t\t\t# irradiance calculation off\n");
228 printf(rand_samp ? "-u+\t\t\t\t# uncorrelated Monte Carlo sampling\n" :
229 "-u-\t\t\t\t# correlated quasi-Monte Carlo sampling\n");
230 printf(backvis ? "-bv+\t\t\t\t# back face visibility on\n" :
231 "-bv-\t\t\t\t# back face visibility off\n");
232 printf("-dt %f\t\t\t# direct threshold\n", shadthresh);
233 printf("-dc %f\t\t\t# direct certainty\n", shadcert);
234 printf("-dj %f\t\t\t# direct jitter\n", dstrsrc);
235 printf("-ds %f\t\t\t# direct sampling\n", srcsizerat);
236 printf("-dr %-9d\t\t\t# direct relays\n", directrelay);
237 printf("-dp %-9d\t\t\t# direct pretest density\n", vspretest);
238 printf(directvis ? "-dv+\t\t\t\t# direct visibility on\n" :
239 "-dv-\t\t\t\t# direct visibility off\n");
240 printf("-ss %f\t\t\t# specular sampling\n", specjitter);
241 printf("-st %f\t\t\t# specular threshold\n", specthresh);
242 printf("-av %f %f %f\t# ambient value\n", colval(ambval,RED),
243 colval(ambval,GRN), colval(ambval, BLU));
244 printf("-aw %-9d\t\t\t# ambient value weight\n", ambvwt);
245 printf("-ab %-9d\t\t\t# ambient bounces\n", ambounce);
246 printf("-aa %f\t\t\t# ambient accuracy\n", ambacc);
247 printf("-ar %-9d\t\t\t# ambient resolution\n", ambres);
248 printf("-ad %-9d\t\t\t# ambient divisions\n", ambdiv);
249 printf("-as %-9d\t\t\t# ambient super-samples\n", ambssamp);
250 printf("-me %.2e %.2e %.2e\t# mist extinction coefficient\n",
251 colval(cextinction,RED),
252 colval(cextinction,GRN),
253 colval(cextinction,BLU));
254 printf("-ma %f %f %f\t# mist scattering albedo\n", colval(salbedo,RED),
255 colval(salbedo,GRN), colval(salbedo,BLU));
256 printf("-mg %f\t\t\t# mist scattering eccentricity\n", seccg);
257 printf("-ms %f\t\t\t# mist sampling distance\n", ssampdist);
258 printf("-lr %-9d\t\t\t# limit reflection%s\n", maxdepth,
259 maxdepth<=0 ? " (Russian roulette)" : "");
260 printf("-lw %.2e\t\t\t# limit weight\n", minweight);
261
262 /* PMAP: output photon map defaults */
263 printPmapDefaults();
264 }
