1 |
/* RCSid $Id: rcontrib.h,v 2.2 2012/06/10 05:25:42 greg Exp $ */ |
2 |
3 |
4 |
* Header file for rcontrib modules |
5 |
6 |
7 |
#include "ray.h" |
8 |
#include "func.h" |
9 |
#include "lookup.h" |
10 |
11 |
extern int gargc; /* global argc */ |
12 |
extern char **gargv; /* global argv */ |
13 |
extern char *octname; /* global octree name */ |
14 |
15 |
extern int nproc; /* number of processes requested */ |
16 |
extern int nchild; /* number of children (-1 in child) */ |
17 |
18 |
extern int inpfmt; /* input format */ |
19 |
extern int outfmt; /* output format */ |
20 |
21 |
extern int header; /* output header? */ |
22 |
extern int force_open; /* truncate existing output? */ |
23 |
extern int recover; /* recover previous output? */ |
24 |
extern int accumulate; /* input rays per output record */ |
25 |
extern int contrib; /* computing contributions? */ |
26 |
27 |
extern int xres; /* horizontal (scan) size */ |
28 |
extern int yres; /* vertical resolution */ |
29 |
30 |
extern int using_stdout; /* are we using stdout? */ |
31 |
32 |
extern int imm_irrad; /* compute immediate irradiance? */ |
33 |
extern int lim_dist; /* limit distance? */ |
34 |
35 |
extern int account; /* current accumulation count */ |
36 |
extern RNUMBER raysleft; /* number of rays left to trace */ |
37 |
extern long waitflush; /* how long until next flush */ |
38 |
39 |
extern RNUMBER lastray; /* last ray number sent */ |
40 |
extern RNUMBER lastdone; /* last ray processed */ |
41 |
42 |
typedef double DCOLOR[3]; /* double-precision color */ |
43 |
44 |
45 |
* The MODCONT structure is used to accumulate ray contributions |
46 |
* for a particular modifier, which may be subdivided into bins |
47 |
* if binv evaluates > 0. If outspec contains a %s in it, this will |
48 |
* be replaced with the modifier name. If outspec contains a %d in it, |
49 |
* this will be used to create one output file per bin, otherwise all bins |
50 |
* will be written to the same file, in order. If the global outfmt |
51 |
* is 'c', then a 4-byte RGBE pixel will be output for each bin value |
52 |
* and the file will conform to a RADIANCE image if xres & yres are set. |
53 |
54 |
typedef struct { |
55 |
const char *outspec; /* output file specification */ |
56 |
const char *modname; /* modifier name */ |
57 |
EPNODE *binv; /* bin value expression */ |
58 |
int nbins; /* number of contribution bins */ |
59 |
DCOLOR cbin[1]; /* contribution bins (extends struct) */ |
60 |
} MODCONT; /* modifier contribution */ |
61 |
62 |
extern LUTAB modconttab; /* modifier contribution table */ |
63 |
64 |
65 |
* The STREAMOUT structure holds an open FILE pointer and a count of |
66 |
* the number of RGB triplets per record, or 0 if unknown. |
67 |
68 |
typedef struct { |
69 |
FILE *ofp; /* output file pointer */ |
70 |
int outpipe; /* output is to a pipe */ |
71 |
int reclen; /* triplets/record */ |
72 |
int xr, yr; /* output resolution for picture */ |
73 |
} STREAMOUT; |
74 |
75 |
extern LUTAB ofiletab; /* output stream table */ |
76 |
77 |
#ifndef MAXPROCESS |
78 |
#ifdef _WIN32 |
79 |
#define MAXPROCESS 1 |
80 |
#else |
81 |
#define MAXPROCESS 128 |
82 |
#endif |
83 |
#endif |
84 |
85 |
#ifndef MAXMODLIST |
86 |
#define MAXMODLIST 2048 /* maximum modifiers we'll track */ |
87 |
#endif |
88 |
#ifndef MAXTSET |
89 |
#define MAXTSET 16383 /* maximum number in trace set */ |
90 |
#endif |
91 |
92 |
extern const char *modname[MAXMODLIST]; /* ordered modifier name list */ |
93 |
extern int nmods; /* number of modifiers */ |
94 |
95 |
extern char RCCONTEXT[]; /* special evaluation context */ |
96 |
97 |
extern void tranotify(OBJECT obj); /* new trace modifier */ |
98 |
99 |
extern char *formstr(int f); /* return format identifier */ |
100 |
101 |
extern void process_rcontrib(void); /* trace ray contributions */ |
102 |
103 |
extern STREAMOUT * getostream(const char *ospec, const char *mname, |
104 |
int bn, int noopen); |
105 |
106 |
extern void mod_output(MODCONT *mp); |
107 |
extern void end_record(void); |
108 |
109 |
extern MODCONT *addmodifier(char *modn, char *outf, |
110 |
char *binv, int bincnt); |
111 |
extern void addmodfile(char *fname, char *outf, |
112 |
113 |
114 |
extern void reload_output(void); |
115 |
extern void recover_output(void); |
116 |
117 |
extern int getvec(FVECT vec); |
118 |
119 |
extern int in_rchild(void); |
120 |
extern void end_children(void); |
121 |
122 |
extern void put_zero_record(int ndx); |
123 |
extern void queue_modifiers(void); |
124 |
125 |
extern void parental_loop(void); /* controlling process */ |
126 |
127 |
extern void rcontrib(void); /* main calculation loop */ |
