root/Development/ray/src/rt/rcontrib.h
Sat Jun 7 05:09:46 2025 UTC (4 months, 3 weeks ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 2.19: +1 -2 lines
Diff to previous 2.19
Wed Nov 15 18:02:53 2023 UTC (23 months, 2 weeks ago) by greg
Changes since 2.18: +10 -5 lines
Diff to previous 2.18
Mon Feb 6 22:40:21 2023 UTC (2 years, 8 months ago) by greg
Changes since 2.17: +1 -3 lines
Diff to previous 2.17
Tue Feb 16 20:06:06 2021 UTC (4 years, 8 months ago) by greg
Changes since 2.16: +3 -6 lines
Diff to previous 2.16
feat: removed upper limit on number of modifiers in rcontrib
Wed Sep 9 21:28:19 2020 UTC (5 years, 1 month ago) by greg
Diff to previous 2.15
Mon Sep 12 20:31:34 2016 UTC (9 years, 1 month ago) by greg
Diff to previous 2.14
Mon Mar 21 19:06:08 2016 UTC (9 years, 7 months ago) by greg
Diff to previous 2.13
Sun Mar 6 01:13:18 2016 UTC (9 years, 8 months ago) by schorsch
Diff to previous 2.12
Wed May 20 12:58:31 2015 UTC (10 years, 5 months ago) by greg
Added appropriate setting of ray parameters for bin rcontrib evaluation
Sat Jul 19 20:03:03 2014 UTC (11 years, 3 months ago) by greg
Fixed bug in parameter parser and added check during main arguments processing
Sat Jul 19 18:19:33 2014 UTC (11 years, 3 months ago) by greg
Wed Aug 7 05:10:09 2013 UTC (12 years, 2 months ago) by greg
Fri Jun 22 21:58:45 2012 UTC (13 years, 4 months ago) by greg
More portability fixes (missing headers)
Thu Jun 21 17:14:32 2012 UTC (13 years, 4 months ago) by greg
Accommodations for Windows
Tue Jun 19 00:12:08 2012 UTC (13 years, 4 months ago) by greg
Added quick-exit mode and fixed bug in recovery option with -c > 1
Sat Jun 16 17:09:49 2012 UTC (13 years, 4 months ago) by greg
Improved performance for -c 0 option
Fri Jun 15 00:57:40 2012 UTC (13 years, 4 months ago) by greg
Changes since 2.3: +1 -6 lines
Simplified modifier lookup
Tue Jun 12 17:20:44 2012 UTC (13 years, 4 months ago) by greg
Further efficiency improvements
Sun Jun 10 05:25:42 2012 UTC (13 years, 4 months ago) by greg
Tweaks and bug fixes to new code
Sat Jun 9 07:16:47 2012 UTC (13 years, 4 months ago) by greg
