root/radiance/ray/src/rt/rcontrib.h
Revision 2.15 - (view) (download) (annotate) - [selected]
Mon Sep 12 20:31:34 2016 UTC (7 years, 8 months ago) by greg
Diff to previous 2.14
Mon Mar 21 19:06:08 2016 UTC (8 years, 2 months ago) by greg
Diff to previous 2.13 , to selected 2.15
Diff to previous 2.12 , to selected 2.15
Wed May 20 12:58:31 2015 UTC (9 years ago) by greg
Diff to previous 2.11 , to selected 2.15
Added appropriate setting of ray parameters for bin rcontrib evaluation
Sat Jul 19 20:03:03 2014 UTC (9 years, 10 months ago) by greg
Diff to previous 2.10 , to selected 2.15
Fixed bug in parameter parser and added check during main arguments processing
Sat Jul 19 18:19:33 2014 UTC (9 years, 10 months ago) by greg
Diff to previous 2.9 , to selected 2.15
Wed Aug 7 05:10:09 2013 UTC (10 years, 9 months ago) by greg
Diff to previous 2.8 , to selected 2.15
Fri Jun 22 21:58:45 2012 UTC (11 years, 11 months ago) by greg
Diff to previous 2.7 , to selected 2.15
More portability fixes (missing headers)
Thu Jun 21 17:14:32 2012 UTC (11 years, 11 months ago) by greg
Diff to previous 2.6 , to selected 2.15
Accommodations for Windows
Tue Jun 19 00:12:08 2012 UTC (11 years, 11 months ago) by greg
Diff to previous 2.5 , to selected 2.15
Added quick-exit mode and fixed bug in recovery option with -c > 1
Sat Jun 16 17:09:49 2012 UTC (11 years, 11 months ago) by greg
Diff to previous 2.4 , to selected 2.15
Improved performance for -c 0 option
Fri Jun 15 00:57:40 2012 UTC (11 years, 11 months ago) by greg
Changes since 2.3: +1 -6 lines
Diff to previous 2.3 , to selected 2.15
Simplified modifier lookup
Tue Jun 12 17:20:44 2012 UTC (11 years, 11 months ago) by greg
Diff to previous 2.2 , to selected 2.15
Further efficiency improvements
Sun Jun 10 05:25:42 2012 UTC (11 years, 11 months ago) by greg
Diff to previous 2.1 , to selected 2.15
Tweaks and bug fixes to new code
Sat Jun 9 07:16:47 2012 UTC (11 years, 11 months ago) by greg
Diff to selected 2.15
