root/radiance/ray/src/rt/rcontrib.h
Revision: 2.5
Committed: Sat Jun 16 17:09:49 2012 UTC (11 years, 11 months ago) by greg
Improved performance for -c 0 option
1 /* RCSid $Id: rcontrib.h,v 2.4 2012/06/15 00:57:40 greg Exp $ */
2
3 /*
4 * Header file for rcontrib modules
5 */
6
7 #include "ray.h"
8 #include "func.h"
9 #include "lookup.h"
10
11 extern int gargc; /* global argc */
12 extern char **gargv; /* global argv */
13 extern char *octname; /* global octree name */
14
15 extern int nproc; /* number of processes requested */
16 extern int nchild; /* number of children (-1 in child) */
17
18 extern int inpfmt; /* input format */
19 extern int outfmt; /* output format */
20
21 extern int header; /* output header? */
22 extern int force_open; /* truncate existing output? */
23 extern int recover; /* recover previous output? */
24 extern int accumulate; /* input rays per output record */
25 extern int contrib; /* computing contributions? */
26
27 extern int xres; /* horizontal (scan) size */
28 extern int yres; /* vertical resolution */
29
30 extern int using_stdout; /* are we using stdout? */
31
32 extern int imm_irrad; /* compute immediate irradiance? */
33 extern int lim_dist; /* limit distance? */
34
35 extern int account; /* current accumulation count */
36 extern RNUMBER raysleft; /* number of rays left to trace */
37 extern long waitflush; /* how long until next flush */
38
39 extern RNUMBER lastray; /* last ray number sent */
40 extern RNUMBER lastdone; /* last ray processed */
41
42 typedef double DCOLOR[3]; /* double-precision color */
43
44 /*
45 * The MODCONT structure is used to accumulate ray contributions
46 * for a particular modifier, which may be subdivided into bins
47 * if binv evaluates > 0. If outspec contains a %s in it, this will
48 * be replaced with the modifier name. If outspec contains a %d in it,
49 * this will be used to create one output file per bin, otherwise all bins
50 * will be written to the same file, in order. If the global outfmt
51 * is 'c', then a 4-byte RGBE pixel will be output for each bin value
52 * and the file will conform to a RADIANCE image if xres & yres are set.
53 */
54 typedef struct {
55 const char *outspec; /* output file specification */
56 const char *modname; /* modifier name */
57 EPNODE *binv; /* bin value expression */
58 int nbins; /* number of contribution bins */
59 DCOLOR cbin[1]; /* contribution bins (extends struct) */
60 } MODCONT; /* modifier contribution */
61
62 extern LUTAB modconttab; /* modifier contribution table */
63
64 /*
65 * The STREAMOUT structure holds an open FILE pointer and a count of
66 * the number of RGB triplets per record, or 0 if unknown.
67 */
68 typedef struct {
69 FILE *ofp; /* output file pointer */
70 int outpipe; /* output is to a pipe */
71 int reclen; /* triplets/record */
72 int xr, yr; /* output resolution for picture */
73 } STREAMOUT;
74
75 extern LUTAB ofiletab; /* output stream table */
76
77 #ifndef MAXPROCESS
78 #ifdef _WIN32
79 #define MAXPROCESS 1
80 #else
81 #define MAXPROCESS 128
82 #endif
83 #endif
84
85 #ifndef MAXMODLIST
86 #define MAXMODLIST 2048 /* maximum modifiers we'll track */
87 #endif
88
89 extern const char *modname[MAXMODLIST]; /* ordered modifier name list */
90 extern int nmods; /* number of modifiers */
91
92 extern char RCCONTEXT[]; /* special evaluation context */
93
94 extern char *formstr(int f); /* return format identifier */
95
96 extern void process_rcontrib(void); /* trace ray contributions */
97
98 extern STREAMOUT * getostream(const char *ospec, const char *mname,
99 int bn, int noopen);
100
101 extern void mod_output(MODCONT *mp);
102 extern void end_record(void);
103
104 extern MODCONT *addmodifier(char *modn, char *outf,
105 char *binv, int bincnt);
106 extern void addmodfile(char *fname, char *outf,
107 char *binv, int bincnt);
108
109 extern void reload_output(void);
110 extern void recover_output(void);
111
112 extern int getvec(FVECT vec);
113
114 extern int in_rchild(void);
115 extern void end_children(void);
116
117 extern void put_zero_record(int ndx);
118
119 extern void parental_loop(void); /* controlling process */
120
121 extern void rcontrib(void); /* main calculation loop */
