| 1 |
/* RCSid $Id: rcontrib.h,v 2.5 2012/06/16 17:09:49 greg Exp $ */
| 2 |
| 3 |
| 4 |
* Header file for rcontrib modules
| 5 |
| 6 |
| 7 |
#include "ray.h"
| 8 |
#include "func.h"
| 9 |
#include "lookup.h"
| 10 |
| 11 |
extern int gargc; /* global argc */
| 12 |
extern char **gargv; /* global argv */
| 13 |
extern char *octname; /* global octree name */
| 14 |
| 15 |
extern int nproc; /* number of processes requested */
| 16 |
extern int nchild; /* number of children (-1 in child) */
| 17 |
| 18 |
extern int inpfmt; /* input format */
| 19 |
extern int outfmt; /* output format */
| 20 |
| 21 |
extern int header; /* output header? */
| 22 |
extern int force_open; /* truncate existing output? */
| 23 |
extern int recover; /* recover previous output? */
| 24 |
extern int accumulate; /* input rays per output record */
| 25 |
extern int contrib; /* computing contributions? */
| 26 |
| 27 |
extern int xres; /* horizontal (scan) size */
| 28 |
extern int yres; /* vertical resolution */
| 29 |
| 30 |
extern int using_stdout; /* are we using stdout? */
| 31 |
| 32 |
extern int imm_irrad; /* compute immediate irradiance? */
| 33 |
extern int lim_dist; /* limit distance? */
| 34 |
| 35 |
extern int account; /* current accumulation count */
| 36 |
extern RNUMBER raysleft; /* number of rays left to trace */
| 37 |
extern long waitflush; /* how long until next flush */
| 38 |
| 39 |
extern RNUMBER lastray; /* last ray number sent */
| 40 |
extern RNUMBER lastdone; /* last ray processed */
| 41 |
| 42 |
typedef double DCOLOR[3]; /* double-precision color */
| 43 |
| 44 |
| 45 |
* The MODCONT structure is used to accumulate ray contributions
| 46 |
* for a particular modifier, which may be subdivided into bins
| 47 |
* if binv evaluates > 0. If outspec contains a %s in it, this will
| 48 |
* be replaced with the modifier name. If outspec contains a %d in it,
| 49 |
* this will be used to create one output file per bin, otherwise all bins
| 50 |
* will be written to the same file, in order. If the global outfmt
| 51 |
* is 'c', then a 4-byte RGBE pixel will be output for each bin value
| 52 |
* and the file will conform to a RADIANCE image if xres & yres are set.
| 53 |
| 54 |
typedef struct {
| 55 |
const char *outspec; /* output file specification */
| 56 |
const char *modname; /* modifier name */
| 57 |
EPNODE *binv; /* bin value expression */
| 58 |
int nbins; /* number of contribution bins */
| 59 |
DCOLOR cbin[1]; /* contribution bins (extends struct) */
| 60 |
} MODCONT; /* modifier contribution */
| 61 |
| 62 |
extern LUTAB modconttab; /* modifier contribution table */
| 63 |
| 64 |
| 65 |
* The STREAMOUT structure holds an open FILE pointer and a count of
| 66 |
* the number of RGB triplets per record, or 0 if unknown.
| 67 |
| 68 |
typedef struct {
| 69 |
FILE *ofp; /* output file pointer */
| 70 |
int outpipe; /* output is to a pipe */
| 71 |
int reclen; /* triplets/record */
| 72 |
int xr, yr; /* output resolution for picture */
| 73 |
} STREAMOUT;
| 74 |
| 75 |
extern LUTAB ofiletab; /* output stream table */
| 76 |
| 77 |
#ifndef MAXPROCESS
| 78 |
#ifdef _WIN32
| 79 |
#define MAXPROCESS 1
| 80 |
#else
| 81 |
#define MAXPROCESS 128
| 82 |
#endif
| 83 |
#endif
| 84 |
| 85 |
#ifndef MAXMODLIST
| 86 |
#define MAXMODLIST 2048 /* maximum modifiers we'll track */
| 87 |
#endif
| 88 |
| 89 |
extern const char *modname[MAXMODLIST]; /* ordered modifier name list */
| 90 |
extern int nmods; /* number of modifiers */
| 91 |
| 92 |
extern char RCCONTEXT[]; /* special evaluation context */
| 93 |
| 94 |
extern char *formstr(int f); /* return format identifier */
| 95 |
| 96 |
extern void process_rcontrib(void); /* trace ray contributions */
| 97 |
| 98 |
extern STREAMOUT * getostream(const char *ospec, const char *mname,
| 99 |
int bn, int noopen);
| 100 |
| 101 |
extern void mod_output(MODCONT *mp);
| 102 |
extern void end_record(void);
| 103 |
| 104 |
extern MODCONT *addmodifier(char *modn, char *outf,
| 105 |
char *binv, int bincnt);
| 106 |
extern void addmodfile(char *fname, char *outf,
| 107 |
| 108 |
| 109 |
extern void reload_output(void);
| 110 |
extern void recover_output(void);
| 111 |
| 112 |
extern int getvec(FVECT vec);
| 113 |
| 114 |
extern int in_rchild(void);
| 115 |
extern void end_children(int immed);
| 116 |
| 117 |
extern void put_zero_record(int ndx);
| 118 |
| 119 |
extern void parental_loop(void); /* controlling process */
| 120 |
| 121 |
extern void rcontrib(void); /* main calculation loop */
