root/radiance/ray/src/rt/rcontrib.h
Revision: 2.7
Committed: Thu Jun 21 17:14:32 2012 UTC (11 years, 11 months ago) by greg
Accommodations for Windows
1 /* RCSid $Id: rcontrib.h,v 2.6 2012/06/19 00:12:08 greg Exp $ */
2
3 /*
4 * Header file for rcontrib modules
5 */
6
7 #include "platform.h"
8 #include "paths.h"
9 #include "ray.h"
10 #include "func.h"
11 #include "lookup.h"
12
13 extern int gargc; /* global argc */
14 extern char **gargv; /* global argv */
15 extern char *octname; /* global octree name */
16
17 extern int nproc; /* number of processes requested */
18 extern int nchild; /* number of children (-1 in child) */
19
20 extern int inpfmt; /* input format */
21 extern int outfmt; /* output format */
22
23 extern int header; /* output header? */
24 extern int force_open; /* truncate existing output? */
25 extern int recover; /* recover previous output? */
26 extern int accumulate; /* input rays per output record */
27 extern int contrib; /* computing contributions? */
28
29 extern int xres; /* horizontal (scan) size */
30 extern int yres; /* vertical resolution */
31
32 extern int using_stdout; /* are we using stdout? */
33
34 extern int imm_irrad; /* compute immediate irradiance? */
35 extern int lim_dist; /* limit distance? */
36
37 extern int account; /* current accumulation count */
38 extern RNUMBER raysleft; /* number of rays left to trace */
39 extern long waitflush; /* how long until next flush */
40
41 extern RNUMBER lastray; /* last ray number sent */
42 extern RNUMBER lastdone; /* last ray processed */
43
44 typedef double DCOLOR[3]; /* double-precision color */
45
46 /*
47 * The MODCONT structure is used to accumulate ray contributions
48 * for a particular modifier, which may be subdivided into bins
49 * if binv evaluates > 0. If outspec contains a %s in it, this will
50 * be replaced with the modifier name. If outspec contains a %d in it,
51 * this will be used to create one output file per bin, otherwise all bins
52 * will be written to the same file, in order. If the global outfmt
53 * is 'c', then a 4-byte RGBE pixel will be output for each bin value
54 * and the file will conform to a RADIANCE image if xres & yres are set.
55 */
56 typedef struct {
57 const char *outspec; /* output file specification */
58 const char *modname; /* modifier name */
59 EPNODE *binv; /* bin value expression */
60 int nbins; /* number of contribution bins */
61 DCOLOR cbin[1]; /* contribution bins (extends struct) */
62 } MODCONT; /* modifier contribution */
63
64 extern LUTAB modconttab; /* modifier contribution table */
65
66 /*
67 * The STREAMOUT structure holds an open FILE pointer and a count of
68 * the number of RGB triplets per record, or 0 if unknown.
69 */
70 typedef struct {
71 FILE *ofp; /* output file pointer */
72 int outpipe; /* output is to a pipe */
73 int reclen; /* triplets/record */
74 int xr, yr; /* output resolution for picture */
75 } STREAMOUT;
76
77 extern LUTAB ofiletab; /* output stream table */
78
79 #ifndef MAXPROCESS
80 #ifdef _WIN32
81 #define MAXPROCESS 1
82 #else
83 #define MAXPROCESS 128
84 #endif
85 #endif
86
87 #ifndef MAXMODLIST
88 #define MAXMODLIST 2048 /* maximum modifiers we'll track */
89 #endif
90
91 extern const char *modname[MAXMODLIST]; /* ordered modifier name list */
92 extern int nmods; /* number of modifiers */
93
94 extern char RCCONTEXT[]; /* special evaluation context */
95
96 extern char *formstr(int f); /* return format identifier */
97
98 extern void process_rcontrib(void); /* trace ray contributions */
99
100 extern STREAMOUT * getostream(const char *ospec, const char *mname,
101 int bn, int noopen);
102
103 extern void mod_output(MODCONT *mp);
104 extern void end_record(void);
105
106 extern MODCONT *addmodifier(char *modn, char *outf,
107 char *binv, int bincnt);
108 extern void addmodfile(char *fname, char *outf,
109 char *binv, int bincnt);
110
111 extern void reload_output(void);
112 extern void recover_output(void);
113
114 extern int getvec(FVECT vec);
115
116 extern int in_rchild(void);
117 extern void end_children(int immed);
118
119 extern void put_zero_record(int ndx);
120
121 extern void parental_loop(void); /* controlling process */
122
123 extern void rcontrib(void); /* main calculation loop */
