root/radiance/ray/src/rt/rcontrib.h
Revision: 2.18
Committed: Mon Feb 6 22:40:21 2023 UTC (2 years, 4 months ago) by greg
Changes since 2.17: +1 -3 lines
1 /* RCSid $Id: rcontrib.h,v 2.17 2021/02/16 20:06:06 greg Exp $ */
2
3 /*
4 * Header file for rcontrib modules
5 */
6
7 #include "platform.h"
8 #include "paths.h"
9 #include "rtprocess.h"
10 #include "ray.h"
11 #include "func.h"
12 #include "lookup.h"
13
14 extern int gargc; /* global argc */
15 extern char **gargv; /* global argv */
16 extern char *octname; /* global octree name */
17
18 extern int nproc; /* number of processes requested */
19 extern int nchild; /* number of children (-1 in child) */
20
21 extern int inpfmt; /* input format */
22 extern int outfmt; /* output format */
23
24 extern int header; /* output header? */
25 extern int force_open; /* truncate existing output? */
26 extern int recover; /* recover previous output? */
27 extern int accumulate; /* input rays per output record */
28 extern int contrib; /* computing contributions? */
29
30 extern int xres; /* horizontal (scan) size */
31 extern int yres; /* vertical resolution */
32
33 extern int using_stdout; /* are we using stdout? */
34
35 extern int imm_irrad; /* compute immediate irradiance? */
36 extern int lim_dist; /* limit distance? */
37
38 extern int account; /* current accumulation count */
39 extern RNUMBER raysleft; /* number of rays left to trace */
40 extern long waitflush; /* how long until next flush */
41
42 extern RNUMBER lastray; /* last ray number sent */
43 extern RNUMBER lastdone; /* last ray processed */
44
45 extern int report_intvl; /* reporting interval (seconds) */
46
47 typedef double DCOLOR[3]; /* double-precision color */
48
49 /*
50 * The MODCONT structure is used to accumulate ray contributions
51 * for a particular modifier, which may be subdivided into bins
52 * if binv evaluates > 0. If outspec contains a %s in it, this will
53 * be replaced with the modifier name. If outspec contains a %d in it,
54 * this will be used to create one output file per bin, otherwise all bins
55 * will be written to the same file, in order. If the global outfmt
56 * is 'c', then a 4-byte RGBE pixel will be output for each bin value
57 * and the file will conform to a RADIANCE image if xres & yres are set.
58 */
59 typedef struct {
60 const char *outspec; /* output file specification */
61 const char *modname; /* modifier name */
62 const char *params; /* parameter list */
63 EPNODE *binv; /* bin value expression */
64 int bin0; /* starting bin offset */
65 int nbins; /* number of contribution bins */
66 DCOLOR cbin[1]; /* contribution bins (extends struct) */
67 } MODCONT; /* modifier contribution */
68
69 extern LUTAB modconttab; /* modifier contribution table */
70
71 /*
72 * The STREAMOUT structure holds an open FILE pointer and a count of
73 * the number of RGB triplets per record, or 0 if unknown.
74 */
75 typedef struct {
76 FILE *ofp; /* output file pointer */
77 int outpipe; /* output is to a pipe */
78 int reclen; /* triplets/record */
79 int xr, yr; /* output resolution for picture */
80 } STREAMOUT;
81
82 extern LUTAB ofiletab; /* output stream table */
83
84 #ifndef MAXPROCESS
85 #if defined(_WIN32) || defined(_WIN64)
86 #define MAXPROCESS 1
87 #else
88 #define MAXPROCESS 128
89 #endif
90 #endif
91
92 extern char **modname; /* ordered modifier name list */
93 extern int nmods; /* number of modifiers */
94 extern int modasiz; /* allocated modifier array size */
95
96 extern char RCCONTEXT[]; /* special evaluation context */
97
98 extern void process_rcontrib(void); /* trace ray contributions */
99
100 extern STREAMOUT * getostream(const char *ospec, const char *mname,
101 int bn, int noopen);
102
103 extern void mod_output(MODCONT *mp);
104 extern void end_record(void);
105
106 extern MODCONT *addmodifier(char *modn, char *outf,
107 char *prms, char *binv, int bincnt);
108 extern void addmodfile(char *fname, char *outf,
109 char *prms, char *binv, int bincnt);
110
111 extern void reload_output(void);
112 extern void recover_output(void);
113
114 extern int getvec(FVECT vec);
115
116 extern int in_rchild(void);
117 extern void end_children(int immed);
118
119 extern void put_zero_record(int ndx);
120
121 extern int morays(void); /* reached end of input? */
122
123 extern void parental_loop(void); /* controlling process */
124
125 extern void feeder_loop(void); /* feeder process */
126
127 extern void rcontrib(void); /* main calculation loop */
