root/radiance/ray/src/rt/rcontrib.c
Fri Feb 23 03:45:52 2024 UTC (3 months ago) by greg
Diff to previous 2.43 , to selected 2.12
perf: Added some list optimization to calcomp routines
Wed Nov 15 18:02:53 2023 UTC (6 months, 1 week ago) by greg
Changes since 2.42: +12 -8 lines
Diff to previous 2.42 , to selected 2.12
Mon Feb 6 22:40:21 2023 UTC (15 months, 2 weeks ago) by greg
Changes since 2.41: +2 -2 lines
Diff to previous 2.41 , to selected 2.12
Sun Feb 21 17:18:41 2021 UTC (3 years, 3 months ago) by greg
Changes since 2.40: +7 -5 lines
Diff to previous 2.40 , to selected 2.12
fix: repaired bug introduced in last change
Tue Feb 16 20:06:06 2021 UTC (3 years, 3 months ago) by greg
Changes since 2.39: +20 -18 lines
Diff to previous 2.39 , to selected 2.12
feat: removed upper limit on number of modifiers in rcontrib
Thu Sep 10 01:01:18 2020 UTC (3 years, 8 months ago) by greg
Changes since 2.38: +6 -5 lines
Diff to previous 2.38 , to selected 2.12
fix(rcontrib): Removed pointless initial report of 0% done after 0 hours
Thu Sep 10 00:45:01 2020 UTC (3 years, 8 months ago) by greg
Diff to previous 2.37 , to selected 2.12
fix(rcontrib): Forgot EOL in report for new -t option
Wed Sep 9 21:28:19 2020 UTC (3 years, 8 months ago) by greg
Changes since 2.36: +30 -3 lines
Diff to previous 2.36 , to selected 2.12
Mon Jul 20 15:54:29 2020 UTC (3 years, 10 months ago) by greg
Changes since 2.35: +3 -1 lines
Diff to previous 2.35 , to selected 2.12
fix(mkillum, rcontrib, rtrace, ranimove, rsensor): stall under macOS 10.15
due to broken flockfile() implementation -- workaround is better, anyway
Sun Apr 7 16:39:39 2019 UTC (5 years, 1 month ago) by greg
Diff to previous 2.34 , to selected 2.12
For consistency, reflected ray distance should be inf for diffuse surface
Tue Nov 13 19:58:33 2018 UTC (5 years, 6 months ago) by greg
Changes since 2.33: +2 -2 lines
Diff to previous 2.33 , to selected 2.12
Wed Jun 13 21:32:15 2018 UTC (5 years, 11 months ago) by greg
Diff to previous 2.32 , to selected 2.12
Cosmetic fix
Wed Jun 13 21:23:45 2018 UTC (5 years, 11 months ago) by greg
Changes since 2.31: +5 -3 lines
Diff to previous 2.31 , to selected 2.12
Fixed bug in rcontrib with virtual sources
Fri Feb 23 03:21:24 2018 UTC (6 years, 3 months ago) by greg
Diff to previous 2.30 , to selected 2.12
Corrected default setting, which is reset anyway
Tue Apr 11 17:52:40 2017 UTC (7 years, 1 month ago) by greg
Diff to previous 2.29 , to selected 2.12
Reduced specular sampling threshold, which should have never been so low!
Mon Sep 12 20:31:34 2016 UTC (7 years, 8 months ago) by greg
Changes since 2.28: +8 -4 lines
Diff to previous 2.28 , to selected 2.12
Wed Apr 27 21:11:32 2016 UTC (8 years ago) by greg
Changes since 2.27: +5 -5 lines
Diff to previous 2.27 , to selected 2.12
Future bug-proofing, should have no effect on behavior or performance
Mon Mar 21 19:06:08 2016 UTC (8 years, 2 months ago) by greg
Changes since 2.26: +12 -4 lines
Diff to previous 2.26 , to selected 2.12
Wed Jul 15 23:38:37 2015 UTC (8 years, 10 months ago) by greg
Changes since 2.25: +5 -1 lines
Diff to previous 2.25 , to selected 2.12
Added check for 'void' modifier in -m or -M option
Wed May 20 13:16:20 2015 UTC (9 years ago) by greg
Changes since 2.24: +1 -2 lines
Diff to previous 2.24 , to selected 2.12
Fixed include dependency
Wed May 20 12:58:31 2015 UTC (9 years ago) by greg
Changes since 2.23: +1 -47 lines
Diff to previous 2.23 , to selected 2.12
Added appropriate setting of ray parameters for bin rcontrib evaluation
Mon Aug 25 13:18:30 2014 UTC (9 years, 9 months ago) by greg
CVS Tags: rad4R2P1, rad4R2P2
Changes since 2.22: +3 -2 lines
Diff to previous 2.22 , to selected 2.12
Added bad bin number reporting
Sat Jul 19 20:03:03 2014 UTC (9 years, 10 months ago) by greg
CVS Tags: rad4R2
Changes since 2.21: +29 -24 lines
Diff to previous 2.21 , to selected 2.12
Fixed bug in parameter parser and added check during main arguments processing
Sat Jul 19 18:39:35 2014 UTC (9 years, 10 months ago) by greg
Changes since 2.20: +6 -5 lines
Diff to previous 2.20 , to selected 2.12
Added more careful checking of parameter setting string
Sat Jul 19 18:19:33 2014 UTC (9 years, 10 months ago) by greg
Changes since 2.19: +52 -7 lines
Diff to previous 2.19 , to selected 2.12
Sat Jul 19 00:07:03 2014 UTC (9 years, 10 months ago) by greg
Changes since 2.18: +5 -3 lines
Diff to previous 2.18 , to selected 2.12
Silently ignore negative bin values.
Thu Nov 15 19:41:03 2012 UTC (11 years, 6 months ago) by greg
Diff to previous 2.17 , to selected 2.12
Thu Nov 15 15:26:52 2012 UTC (11 years, 6 months ago) by greg
Changes since 2.16: +5 -4 lines
Fixed bug in handling of -c >1 with zero vectors -- trim pass to follow
Tue Aug 14 22:25:12 2012 UTC (11 years, 9 months ago) by greg
Added missing setting of rt
Fri Jul 13 05:07:06 2012 UTC (11 years, 10 months ago) by greg
Added missing assignment of ray intersection normal
Wed Jun 27 15:32:58 2012 UTC (11 years, 11 months ago) by greg
Changes since 2.13: +10 -4 lines
Added check for blocked shadow rays
Fri Jun 22 22:03:02 2012 UTC (11 years, 11 months ago) by greg
Changes since 2.12: +1 -5 lines
Diff to previous 2.12
Moved source initialization
Thu Jun 21 17:14:32 2012 UTC (11 years, 11 months ago) by greg
Changes since 2.11: +1 -2 lines
Accommodations for Windows
Tue Jun 19 01:27:13 2012 UTC (11 years, 11 months ago) by greg
Fixed reporting of broken pipe on completion with -c N
Tue Jun 19 00:12:08 2012 UTC (11 years, 11 months ago) by greg
Changes since 2.9: +3 -3 lines
Added quick-exit mode and fixed bug in recovery option with -c > 1
Sat Jun 16 17:30:13 2012 UTC (11 years, 11 months ago) by greg
Minor fixes
Sat Jun 16 17:09:49 2012 UTC (11 years, 11 months ago) by greg
Changes since 2.7: +10 -12 lines
Improved performance for -c 0 option
Fri Jun 15 21:32:11 2012 UTC (11 years, 11 months ago) by greg
Changes since 2.6: +25 -30 lines
Simplified immediate irradiance call
Fri Jun 15 00:57:40 2012 UTC (11 years, 11 months ago) by greg
Changes since 2.5: +4 -35 lines
Simplified modifier lookup
Wed Jun 13 00:16:42 2012 UTC (11 years, 11 months ago) by greg
Changes since 2.4: +13 -10 lines
Fixed problem with recovering many files
Tue Jun 12 17:20:44 2012 UTC (11 years, 11 months ago) by greg
Changes since 2.3: +6 -5 lines
Further efficiency improvements
Mon Jun 11 05:07:55 2012 UTC (11 years, 11 months ago) by greg
Changes since 2.2: +4 -24 lines
Fixed a number of bugs -- still testing
Sun Jun 10 05:25:42 2012 UTC (11 years, 11 months ago) by greg
Changes since 2.1: +12 -6 lines
Tweaks and bug fixes to new code
Sat Jun 9 07:16:47 2012 UTC (11 years, 11 months ago) by greg
Diff to selected 2.12
