root/radiance/ray/src/rt/rcontrib.c
Revision: 2.6
Committed: Fri Jun 15 00:57:40 2012 UTC (12 years, 11 months ago) by greg
Changes since 2.5: +4 -35 lines
Simplified modifier lookup
2 static const char RCSid[] = "$Id: rcontrib.c,v 2.5 2012/06/13 00:16:42 greg Exp $";
5 * Accumulate ray contributions for a set of materials
6 * Initialization and calculation routines
7 */
8
9 #include "rcontrib.h"
10 #include "source.h"
11 #include "otypes.h"
12 #include "platform.h"
13
14 char *shm_boundary = NULL; /* boundary of shared memory */
15
16 CUBE thescene; /* our scene */
17 OBJECT nsceneobjs; /* number of objects in our scene */
18
19 int dimlist[MAXDIM]; /* sampling dimensions */
20 int ndims = 0; /* number of sampling dimensions */
21 int samplendx = 0; /* index for this sample */
22
23 static void trace_contrib(RAY *r); /* our trace callback */
24 void (*trace)() = trace_contrib;
25
26 int do_irrad = 0; /* compute irradiance? */
27
28 int rand_samp = 1; /* pure Monte Carlo sampling? */
29
30 double dstrsrc = 0.0; /* square source distribution */
31 double shadthresh = .03; /* shadow threshold */
32 double shadcert = .75; /* shadow certainty */
33 int directrelay = 3; /* number of source relays */
34 int vspretest = 512; /* virtual source pretest density */
35 int directvis = 1; /* sources visible? */
36 double srcsizerat = .2; /* maximum ratio source size/dist. */
37
38 COLOR cextinction = BLKCOLOR; /* global extinction coefficient */
39 COLOR salbedo = BLKCOLOR; /* global scattering albedo */
40 double seccg = 0.; /* global scattering eccentricity */
41 double ssampdist = 0.; /* scatter sampling distance */
42
43 double specthresh = .15; /* specular sampling threshold */
44 double specjitter = 1.; /* specular sampling jitter */
45
46 int backvis = 1; /* back face visibility */
47
48 int maxdepth = -10; /* maximum recursion depth */
49 double minweight = 2e-3; /* minimum ray weight */
50
51 char *ambfile = NULL; /* ambient file name */
52 COLOR ambval = BLKCOLOR; /* ambient value */
53 int ambvwt = 0; /* initial weight for ambient value */
54 double ambacc = 0; /* ambient accuracy */
55 int ambres = 256; /* ambient resolution */
56 int ambdiv = 350; /* ambient divisions */
57 int ambssamp = 0; /* ambient super-samples */
58 int ambounce = 1; /* ambient bounces */
59 char *amblist[AMBLLEN+1]; /* ambient include/exclude list */
60 int ambincl = -1; /* include == 1, exclude == 0 */
61
62 int account; /* current accumulation count */
63 RNUMBER raysleft; /* number of rays left to trace */
64 long waitflush; /* how long until next flush */
65
66 RNUMBER lastray = 0; /* last ray number sent */
67 RNUMBER lastdone = 0; /* last ray output */
68
69 static void mcfree(void *p) { epfree((*(MODCONT *)p).binv); free(p); }
70
71 LUTAB modconttab = LU_SINIT(NULL,mcfree); /* modifier lookup table */
72
73 /************************** INITIALIZATION ROUTINES ***********************/
74
75 char *
76 formstr( /* return format identifier */
77 int f
78 )
79 {
80 switch (f) {
81 case 'a': return("ascii");
82 case 'f': return("float");
83 case 'd': return("double");
84 case 'c': return(COLRFMT);
85 }
86 return("unknown");
87 }
88
89
90 /* Add modifier to our list to track */
91 MODCONT *
92 addmodifier(char *modn, char *outf, char *binv, int bincnt)
93 {
94 LUENT *lep = lu_find(&modconttab,modn);
95 MODCONT *mp;
96 EPNODE *ebinv;
97 int i;
98
99 if (lep->data != NULL) {
100 sprintf(errmsg, "duplicate modifier '%s'", modn);
101 error(USER, errmsg);
102 }
103 if (nmods >= MAXMODLIST)
104 error(INTERNAL, "too many modifiers");
105 modname[nmods++] = modn; /* XXX assumes static string */
106 lep->key = modn; /* XXX assumes static string */
107 if (binv == NULL)
108 binv = "0"; /* use single bin if unspecified */
109 ebinv = eparse(binv);
110 if (ebinv->type == NUM) { /* check value if constant */
111 bincnt = (int)(evalue(ebinv) + 1.5);
112 if (bincnt != 1) {
113 sprintf(errmsg, "illegal non-zero constant for bin (%s)",
114 binv);
115 error(USER, errmsg);
116 }
117 } else if (bincnt <= 0) {
118 sprintf(errmsg,
119 "unspecified or illegal bin count for modifier '%s'",
120 modn);
121 error(USER, errmsg);
122 }
123 /* initialize results holder */
124 mp = (MODCONT *)malloc(sizeof(MODCONT)+sizeof(DCOLOR)*(bincnt-1));
125 if (mp == NULL)
126 error(SYSTEM, "out of memory in addmodifier");
127 mp->outspec = outf; /* XXX assumes static string */
128 mp->modname = modn; /* XXX assumes static string */
129 mp->binv = ebinv;
130 mp->nbins = bincnt;
131 memset(mp->cbin, 0, sizeof(DCOLOR)*bincnt);
132 /* allocate output streams */
133 for (i = bincnt; i-- > 0; )
134 getostream(mp->outspec, mp->modname, i, 1);
135 lep->data = (char *)mp;
136 return(mp);
137 }
138
139
140 /* add modifiers from a file list */
141 void
142 addmodfile(char *fname, char *outf, char *binv, int bincnt)
143 {
144 char *mname[MAXMODLIST];
145 int i;
146 /* find the file & store strings */
147 if (wordfile(mname, getpath(fname, getrlibpath(), R_OK)) < 0) {
148 sprintf(errmsg, "cannot find modifier file '%s'", fname);
149 error(SYSTEM, errmsg);
150 }
151 for (i = 0; mname[i]; i++) /* add each one */
152 addmodifier(mname[i], outf, binv, bincnt);
153 }
154
155
156 void
157 quit( /* quit program */
158 int code
159 )
160 {
161 if (nchild > 0) /* close children if any */
162 end_children();
163 exit(code);
164 }
165
166
167 /* Initialize our process(es) */
168 static void
169 rcinit()
170 {
171 int i;
172
173 if (nproc > MAXPROCESS)
174 sprintf(errmsg, "too many processes requested -- reducing to %d",
175 nproc = MAXPROCESS);
176 if (nproc > 1) {
177 preload_objs(); /* preload auxiliary data */
178 /* set shared memory boundary */
179 shm_boundary = strcpy((char *)malloc(16), "SHM_BOUNDARY");
180 }
181 if ((nproc > 1) & (accumulate <= 0))
182 put_zero_record(0); /* prime our queue to accumulate */
183
184 if (yres > 0) { /* set up flushing & ray counts */
185 if (xres > 0)
186 raysleft = (RNUMBER)xres*yres;
187 else
188 raysleft = yres;
189 } else
190 raysleft = 0;
191 if ((account = accumulate) > 1)
192 raysleft *= accumulate;
193 waitflush = (yres > 0) & (xres > 1) ? 0 : xres;
194 /* tracing to sources as well */
195 for (i = 0; i < nsources; i++)
196 source[i].sflags |= SFOLLOW;
197
198 if (nproc > 1 && in_rchild()) /* forked child? */
199 return; /* return to main processing loop */
200
201 if (recover) { /* recover previous output? */
202 if (accumulate <= 0) {
203 reload_output();
204 if (nproc > 1)
205 queue_modifiers();
206 } else
207 recover_output();
208 }
209 if (nproc == 1) /* single process? */
210 return;
211
212 parental_loop(); /* else run controller */
213 quit(0); /* parent musn't return! */
214 }
215
216 /************************** MAIN CALCULATION PROCESS ***********************/
217
218 /* Our trace call to sum contributions */
219 static void
220 trace_contrib(RAY *r)
221 {
222 MODCONT *mp;
223 int bn;
224 RREAL contr[3];
225
226 if (r->ro == NULL || r->ro->omod == OVOID)
227 return;
228
229 mp = (MODCONT *)lu_find(&modconttab,objptr(r->ro->omod)->oname)->data;
230
231 if (mp == NULL) /* not in our list? */
232 return;
233
234 worldfunc(RCCONTEXT, r); /* get bin number */
235 bn = (int)(evalue(mp->binv) + .5);
236 if ((bn < 0) | (bn >= mp->nbins)) {
237 error(WARNING, "bad bin number (ignored)");
238 return;
239 }
240 raycontrib(contr, r, PRIMARY);
241 if (contrib)
242 multcolor(contr, r->rcol);
243 addcolor(mp->cbin[bn], contr);
244 }
245
246
247 static void
248 rayirrad( /* compute irradiance rather than radiance */
249 RAY *r
250 )
251 {
252 r->rot = 1e-5; /* pretend we hit surface */
253 VSUM(r->rop, r->rorg, r->rdir, r->rot);
254 r->ron[0] = -r->rdir[0];
255 r->ron[1] = -r->rdir[1];
256 r->ron[2] = -r->rdir[2];
257 r->rod = 1.0;
258 /* compute result */
259 r->revf = raytrace;
260 (*ofun[Lamb.otype].funp)(&Lamb, r);
261 r->revf = rayirrad;
262 }
263
264
265 /* Evaluate ray contributions */
266 static void
267 eval_ray(FVECT org, FVECT dir, double dmax)
268 {
269 RAY thisray;
270 /* set up ray */
271 rayorigin(&thisray, PRIMARY, NULL, NULL);
272 if (imm_irrad) {
273 VSUM(thisray.rorg, org, dir, 1.1e-4);
274 thisray.rdir[0] = -dir[0];
275 thisray.rdir[1] = -dir[1];
276 thisray.rdir[2] = -dir[2];
277 thisray.rmax = 0.0;
278 thisray.revf = rayirrad;
279 } else {
280 VCOPY(thisray.rorg, org);
281 VCOPY(thisray.rdir, dir);
282 thisray.rmax = dmax;
283 }
284 samplendx++; /* call ray evaluation */
285 rayvalue(&thisray);
286 }
287
288
289 /* Accumulate and/or output ray contributions (child or only process) */
290 static void
291 done_contrib()
292 {
293 MODCONT *mp;
294 int i;
295
296 if (account <= 0 || --account)
297 return; /* not time yet */
298
299 for (i = 0; i < nmods; i++) { /* output records & clear */
300 mp = (MODCONT *)lu_find(&modconttab,modname[i])->data;
301 mod_output(mp);
302 memset(mp->cbin, 0, sizeof(DCOLOR)*mp->nbins);
303 }
304 end_record(); /* end lines & flush if time */
305
306 account = accumulate; /* reset accumulation counter */
307 }
308
309
310 /* Principal calculation loop (called by main) */
311 void
312 rcontrib()
313 {
314 static int ignore_warning_given = 0;
315 FVECT orig, direc;
316 double d;
317 /* initialize (& fork more of us) */
318 rcinit();
319 /* load rays from stdin & process */
320 #ifdef getc_unlocked
321 flockfile(stdin); /* avoid mutex overhead */
322 #endif
323 while (getvec(orig) == 0 && getvec(direc) == 0) {
324 d = normalize(direc);
325 if (nchild != -1 && (d == 0.0) & (accumulate != 1)) {
326 if (!ignore_warning_given++)
327 error(WARNING,
328 "dummy ray(s) ignored during accumulation\n");
329 continue;
330 }
331 if (lastray+1 < lastray)
332 lastray = lastdone = 0;
333 ++lastray;
334 if (d == 0.0) { /* zero ==> flush */
335 if ((yres <= 0) | (xres <= 0))
336 waitflush = 1; /* flush right after */
337 account = 1;
338 } else { /* else compute */
339 eval_ray(orig, direc, lim_dist ? d : 0.0);
340 }
341 done_contrib(); /* accumulate/output */
342 ++lastdone;
343 if (raysleft && !--raysleft)
344 break; /* preemptive EOI */
345 }
346 if (nchild != -1 && (accumulate <= 0) | (account < accumulate)) {
347 if (account < accumulate) {
348 error(WARNING, "partial accumulation in final record");
349 accumulate -= account;
350 }
351 account = 1; /* output accumulated totals */
352 done_contrib();
353 }
354 if (raysleft)
355 error(USER, "unexpected EOF on input");
356 lu_done(&ofiletab); /* close output files */
357 }
