root/radiance/ray/src/rt/rcontrib.c
Revision: 2.31
Committed: Fri Feb 23 03:21:24 2018 UTC (7 years, 3 months ago) by greg
Corrected default setting, which is reset anyway
2 static const char RCSid[] = "$Id: rcontrib.c,v 2.30 2017/04/11 17:52:40 greg Exp $";
5 * Accumulate ray contributions for a set of materials
6 * Initialization and calculation routines
7 */
8
9 #include "copyright.h"
10
11 #include "rcontrib.h"
12 #include "otypes.h"
13 #include "source.h"
14
15 char *shm_boundary = NULL; /* boundary of shared memory */
16
17 CUBE thescene; /* our scene */
18 OBJECT nsceneobjs; /* number of objects in our scene */
19
20 int dimlist[MAXDIM]; /* sampling dimensions */
21 int ndims = 0; /* number of sampling dimensions */
22 int samplendx = 0; /* index for this sample */
23
24 static void trace_contrib(RAY *r); /* our trace callback */
25 void (*trace)() = trace_contrib;
26
27 int do_irrad = 0; /* compute irradiance? */
28
29 int rand_samp = 1; /* pure Monte Carlo sampling? */
30
31 double dstrsrc = 0.9; /* square source distribution */
32 double shadthresh = 0.; /* shadow threshold */
33 double shadcert = .75; /* shadow certainty */
34 int directrelay = 3; /* number of source relays */
35 int vspretest = 512; /* virtual source pretest density */
36 int directvis = 1; /* sources visible? */
37 double srcsizerat = .2; /* maximum ratio source size/dist. */
38
39 COLOR cextinction = BLKCOLOR; /* global extinction coefficient */
40 COLOR salbedo = BLKCOLOR; /* global scattering albedo */
41 double seccg = 0.; /* global scattering eccentricity */
42 double ssampdist = 0.; /* scatter sampling distance */
43
44 double specthresh = .02; /* specular sampling threshold */
45 double specjitter = 1.; /* specular sampling jitter */
46
47 int backvis = 1; /* back face visibility */
48
49 int maxdepth = -10; /* maximum recursion depth */
50 double minweight = 2e-3; /* minimum ray weight */
51
52 char *ambfile = NULL; /* ambient file name */
53 COLOR ambval = BLKCOLOR; /* ambient value */
54 int ambvwt = 0; /* initial weight for ambient value */
55 double ambacc = 0.; /* ambient accuracy */
56 int ambres = 256; /* ambient resolution */
57 int ambdiv = 350; /* ambient divisions */
58 int ambssamp = 0; /* ambient super-samples */
59 int ambounce = 1; /* ambient bounces */
60 char *amblist[AMBLLEN+1]; /* ambient include/exclude list */
61 int ambincl = -1; /* include == 1, exclude == 0 */
62
63 int account; /* current accumulation count */
64 RNUMBER raysleft; /* number of rays left to trace */
65 long waitflush; /* how long until next flush */
66
67 RNUMBER lastray = 0; /* last ray number sent */
68 RNUMBER lastdone = 0; /* last ray output */
69
70 static void mcfree(void *p) { epfree((*(MODCONT *)p).binv); free(p); }
71
72 LUTAB modconttab = LU_SINIT(NULL,mcfree); /* modifier lookup table */
73
74 /************************** INITIALIZATION ROUTINES ***********************/
75
76 char *
77 formstr( /* return format identifier */
78 int f
79 )
80 {
81 switch (f) {
82 case 'a': return("ascii");
83 case 'f': return("float");
84 case 'd': return("double");
85 case 'c': return(COLRFMT);
86 }
87 return("unknown");
88 }
89
90
91 /* Add modifier to our list to track */
92 MODCONT *
93 addmodifier(char *modn, char *outf, char *prms, char *binv, int bincnt)
94 {
95 LUENT *lep = lu_find(&modconttab,modn);
96 MODCONT *mp;
97 EPNODE *ebinv;
98 int i;
99
100 if (lep->data != NULL) {
101 sprintf(errmsg, "duplicate modifier '%s'", modn);
102 error(USER, errmsg);
103 }
104 if (nmods >= MAXMODLIST) {
105 sprintf(errmsg, "too many modifiers (%d limit)", MAXMODLIST);
106 error(INTERNAL, errmsg);
107 }
108 if (!strcmp(modn, VOIDID)) {
109 sprintf(errmsg, "cannot track '%s' modifier", VOIDID);
110 error(USER, errmsg);
111 }
112 modname[nmods++] = modn; /* XXX assumes static string */
113 lep->key = modn; /* XXX assumes static string */
114 if (binv == NULL)
115 binv = "0"; /* use single bin if unspecified */
116 ebinv = eparse(binv);
117 if (ebinv->type == NUM) { /* check value if constant */
118 bincnt = (int)(evalue(ebinv) + 1.5);
119 if (bincnt != 1) {
120 sprintf(errmsg, "illegal non-zero constant for bin (%s)",
121 binv);
122 error(USER, errmsg);
123 }
124 } else if (bincnt <= 0) {
125 sprintf(errmsg,
126 "unspecified or illegal bin count for modifier '%s'",
127 modn);
128 error(USER, errmsg);
129 }
130 /* initialize results holder */
131 mp = (MODCONT *)malloc(sizeof(MODCONT)+sizeof(DCOLOR)*(bincnt-1));
132 if (mp == NULL)
133 error(SYSTEM, "out of memory in addmodifier");
134 mp->outspec = outf; /* XXX assumes static string */
135 mp->modname = modn; /* XXX assumes static string */
136 mp->params = prms; /* XXX assumes static string */
137 mp->binv = ebinv;
138 mp->bin0 = 0;
139 mp->nbins = bincnt;
140 memset(mp->cbin, 0, sizeof(DCOLOR)*bincnt);
141 /* figure out starting bin */
142 while (!getostream(mp->outspec, mp->modname, mp->bin0, 1))
143 mp->bin0++;
144 /* allocate other output streams */
145 for (i = 0; ++i < mp->nbins; )
146 getostream(mp->outspec, mp->modname, mp->bin0+i, 1);
147 lep->data = (char *)mp;
148 return(mp);
149 }
150
151
152 /* Add modifiers from a file list */
153 void
154 addmodfile(char *fname, char *outf, char *prms, char *binv, int bincnt)
155 {
156 char *mname[MAXMODLIST];
157 int i;
158 /* find the file & store strings */
159 i = wordfile(mname, MAXMODLIST, getpath(fname, getrlibpath(), R_OK));
160 if (i < 0) {
161 sprintf(errmsg, "cannot find modifier file '%s'", fname);
162 error(SYSTEM, errmsg);
163 }
164 if (i >= MAXMODLIST-1) {
165 sprintf(errmsg, "too many modifiers (%d limit) in file '%s'",
166 MAXMODLIST-1, fname);
167 error(INTERNAL, errmsg);
168 }
169 for (i = 0; mname[i]; i++) /* add each one */
170 addmodifier(mname[i], outf, prms, binv, bincnt);
171 }
172
173
174 void
175 quit( /* quit program */
176 int code
177 )
178 {
179 if (nchild > 0) /* close children if any */
180 end_children(code != 0);
181 exit(code);
182 }
183
184
185 /* Initialize our process(es) */
186 static void
187 rcinit(void)
188 {
189 int i;
190
191 if (nproc > MAXPROCESS)
192 sprintf(errmsg, "too many processes requested -- reducing to %d",
193 nproc = MAXPROCESS);
194 if (nproc > 1) {
195 preload_objs(); /* preload auxiliary data */
196 /* set shared memory boundary */
197 shm_boundary = strcpy((char *)malloc(16), "SHM_BOUNDARY");
198 }
199 for (i = 0; i < nsources; i++) /* tracing to sources as well */
200 source[i].sflags |= SFOLLOW;
201 if (yres > 0) { /* set up flushing & ray counts */
202 if (xres > 0)
203 raysleft = (RNUMBER)xres*yres;
204 else
205 raysleft = yres;
206 } else
207 raysleft = 0;
208 if ((account = accumulate) > 1)
209 raysleft *= accumulate;
210 waitflush = (yres > 0) & (xres > 1) ? 0 : xres;
211
212 if (nproc > 1 && in_rchild()) /* forked child? */
213 return; /* return to main processing loop */
214
215 if (recover) { /* recover previous output? */
216 if (accumulate <= 0)
217 reload_output();
218 else
219 recover_output();
220 }
221 if (nproc == 1) /* single process? */
222 return;
223 /* else run appropriate controller */
224 if (accumulate <= 0)
225 feeder_loop();
226 else
227 parental_loop();
228 quit(0); /* parent musn't return! */
229 }
230
231 /************************** MAIN CALCULATION PROCESS ***********************/
232
233 /* Our trace call to sum contributions */
234 static void
235 trace_contrib(RAY *r)
236 {
237 MODCONT *mp;
238 double bval;
239 int bn;
240 RREAL contr[3];
241
242 if (r->ro == NULL || r->ro->omod == OVOID)
243 return;
244 /* shadow ray not on source? */
245 if (r->rsrc >= 0 && source[r->rsrc].so != r->ro)
246 return;
247
248 mp = (MODCONT *)lu_find(&modconttab,objptr(r->ro->omod)->oname)->data;
249
250 if (mp == NULL) /* not in our list? */
251 return;
252
253 worldfunc(RCCONTEXT, r); /* else set context */
254 set_eparams((char *)mp->params);
255 if ((bval = evalue(mp->binv)) <= -.5) /* and get bin number */
256 return; /* silently ignore negatives */
257 if ((bn = (int)(bval + .5)) >= mp->nbins) {
258 sprintf(errmsg, "bad bin number (%d ignored)", bn);
259 error(WARNING, errmsg);
260 return;
261 }
262 raycontrib(contr, r, PRIMARY); /* compute coefficient */
263 if (contrib)
264 multcolor(contr, r->rcol); /* -> contribution */
265 addcolor(mp->cbin[bn], contr);
266 }
267
268
269 /* Evaluate irradiance contributions */
270 static void
271 eval_irrad(FVECT org, FVECT dir)
272 {
273 RAY thisray;
274
275 VSUM(thisray.rorg, org, dir, 1.1e-4);
276 thisray.rdir[0] = -dir[0];
277 thisray.rdir[1] = -dir[1];
278 thisray.rdir[2] = -dir[2];
279 thisray.rmax = 0.0;
280 rayorigin(&thisray, PRIMARY, NULL, NULL);
281 /* pretend we hit surface */
282 thisray.rt = thisray.rot = 1e-5;
283 thisray.rod = 1.0;
284 VCOPY(thisray.ron, dir);
285 VSUM(thisray.rop, org, dir, 1e-4);
286 samplendx++; /* compute result */
287 (*ofun[Lamb.otype].funp)(&Lamb, &thisray);
288 }
289
290
291 /* Evaluate radiance contributions */
292 static void
293 eval_rad(FVECT org, FVECT dir, double dmax)
294 {
295 RAY thisray;
296 /* set up ray */
297 VCOPY(thisray.rorg, org);
298 VCOPY(thisray.rdir, dir);
299 thisray.rmax = dmax;
300 rayorigin(&thisray, PRIMARY, NULL, NULL);
301 samplendx++; /* call ray evaluation */
302 rayvalue(&thisray);
303 }
304
305
306 /* Accumulate and/or output ray contributions (child or only process) */
307 static void
308 done_contrib(void)
309 {
310 MODCONT *mp;
311 int i;
312
313 if (account <= 0 || --account)
314 return; /* not time yet */
315
316 for (i = 0; i < nmods; i++) { /* output records & clear */
317 mp = (MODCONT *)lu_find(&modconttab,modname[i])->data;
318 mod_output(mp);
319 memset(mp->cbin, 0, sizeof(DCOLOR)*mp->nbins);
320 }
321 end_record(); /* end lines & flush if time */
322
323 account = accumulate; /* reset accumulation counter */
324 }
325
326
327 /* Principal calculation loop (called by main) */
328 void
329 rcontrib(void)
330 {
331 static int ignore_warning_given = 0;
332 FVECT orig, direc;
333 double d;
334 /* initialize (& fork more of us) */
335 rcinit();
336 /* load rays from stdin & process */
337 #ifdef getc_unlocked
338 flockfile(stdin); /* avoid mutex overhead */
339 #endif
340 while (getvec(orig) == 0 && getvec(direc) == 0) {
341 d = normalize(direc);
342 if (nchild != -1 && (d == 0.0) & (accumulate == 0)) {
343 if (!ignore_warning_given++)
344 error(WARNING,
345 "dummy ray(s) ignored during accumulation\n");
346 continue;
347 }
348 if (lastray+1 < lastray)
349 lastray = lastdone = 0;
350 ++lastray;
351 if (d == 0.0) { /* zero ==> flush */
352 if ((yres <= 0) | (xres <= 1))
353 waitflush = 1; /* flush after */
354 if (nchild == -1)
355 account = 1;
356 } else if (imm_irrad) { /* else compute */
357 eval_irrad(orig, direc);
358 } else {
359 eval_rad(orig, direc, lim_dist ? d : 0.0);
360 }
361 done_contrib(); /* accumulate/output */
362 ++lastdone;
363 if (raysleft && !--raysleft)
364 break; /* preemptive EOI */
365 }
366 if (nchild != -1 && (accumulate <= 0) | (account < accumulate)) {
367 if (account < accumulate) {
368 error(WARNING, "partial accumulation in final record");
369 accumulate -= account;
370 }
371 account = 1; /* output accumulated totals */
372 done_contrib();
373 }
374 lu_done(&ofiletab); /* close output files */
375 if (raysleft)
376 error(USER, "unexpected EOF on input");
377 }
