root/radiance/ray/src/rt/rcontrib.c
Revision: 2.28
Committed: Wed Apr 27 21:11:32 2016 UTC (9 years, 1 month ago) by greg
Changes since 2.27: +5 -5 lines
Future bug-proofing, should have no effect on behavior or performance
2 static const char RCSid[] = "$Id: rcontrib.c,v 2.27 2016/03/21 19:06:08 greg Exp $";
5 * Accumulate ray contributions for a set of materials
6 * Initialization and calculation routines
7 */
8
9 #include "copyright.h"
10
11 #include "rcontrib.h"
12 #include "otypes.h"
13 #include "source.h"
14
15 char *shm_boundary = NULL; /* boundary of shared memory */
16
17 CUBE thescene; /* our scene */
18 OBJECT nsceneobjs; /* number of objects in our scene */
19
20 int dimlist[MAXDIM]; /* sampling dimensions */
21 int ndims = 0; /* number of sampling dimensions */
22 int samplendx = 0; /* index for this sample */
23
24 static void trace_contrib(RAY *r); /* our trace callback */
25 void (*trace)() = trace_contrib;
26
27 int do_irrad = 0; /* compute irradiance? */
28
29 int rand_samp = 1; /* pure Monte Carlo sampling? */
30
31 double dstrsrc = 0.9; /* square source distribution */
32 double shadthresh = .03; /* shadow threshold */
33 double shadcert = .75; /* shadow certainty */
34 int directrelay = 3; /* number of source relays */
35 int vspretest = 512; /* virtual source pretest density */
36 int directvis = 1; /* sources visible? */
37 double srcsizerat = .2; /* maximum ratio source size/dist. */
38
39 COLOR cextinction = BLKCOLOR; /* global extinction coefficient */
40 COLOR salbedo = BLKCOLOR; /* global scattering albedo */
41 double seccg = 0.; /* global scattering eccentricity */
42 double ssampdist = 0.; /* scatter sampling distance */
43
44 double specthresh = .15; /* specular sampling threshold */
45 double specjitter = 1.; /* specular sampling jitter */
46
47 int backvis = 1; /* back face visibility */
48
49 int maxdepth = -10; /* maximum recursion depth */
50 double minweight = 2e-3; /* minimum ray weight */
51
52 char *ambfile = NULL; /* ambient file name */
53 COLOR ambval = BLKCOLOR; /* ambient value */
54 int ambvwt = 0; /* initial weight for ambient value */
55 double ambacc = 0; /* ambient accuracy */
56 int ambres = 256; /* ambient resolution */
57 int ambdiv = 350; /* ambient divisions */
58 int ambssamp = 0; /* ambient super-samples */
59 int ambounce = 1; /* ambient bounces */
60 char *amblist[AMBLLEN+1]; /* ambient include/exclude list */
61 int ambincl = -1; /* include == 1, exclude == 0 */
62
63 int account; /* current accumulation count */
64 RNUMBER raysleft; /* number of rays left to trace */
65 long waitflush; /* how long until next flush */
66
67 RNUMBER lastray = 0; /* last ray number sent */
68 RNUMBER lastdone = 0; /* last ray output */
69
70 static void mcfree(void *p) { epfree((*(MODCONT *)p).binv); free(p); }
71
72 LUTAB modconttab = LU_SINIT(NULL,mcfree); /* modifier lookup table */
73
74 /************************** INITIALIZATION ROUTINES ***********************/
75
76 char *
77 formstr( /* return format identifier */
78 int f
79 )
80 {
81 switch (f) {
82 case 'a': return("ascii");
83 case 'f': return("float");
84 case 'd': return("double");
85 case 'c': return(COLRFMT);
86 }
87 return("unknown");
88 }
89
90
91 /* Add modifier to our list to track */
92 MODCONT *
93 addmodifier(char *modn, char *outf, char *prms, char *binv, int bincnt)
94 {
95 LUENT *lep = lu_find(&modconttab,modn);
96 MODCONT *mp;
97 EPNODE *ebinv;
98 int i;
99
100 if (lep->data != NULL) {
101 sprintf(errmsg, "duplicate modifier '%s'", modn);
102 error(USER, errmsg);
103 }
104 if (nmods >= MAXMODLIST) {
105 sprintf(errmsg, "too many modifiers (%d limit)", MAXMODLIST);
106 error(INTERNAL, errmsg);
107 }
108 if (!strcmp(modn, VOIDID)) {
109 sprintf(errmsg, "cannot track '%s' modifier", VOIDID);
110 error(USER, errmsg);
111 }
112 modname[nmods++] = modn; /* XXX assumes static string */
113 lep->key = modn; /* XXX assumes static string */
114 if (binv == NULL)
115 binv = "0"; /* use single bin if unspecified */
116 ebinv = eparse(binv);
117 if (ebinv->type == NUM) { /* check value if constant */
118 bincnt = (int)(evalue(ebinv) + 1.5);
119 if (bincnt != 1) {
120 sprintf(errmsg, "illegal non-zero constant for bin (%s)",
121 binv);
122 error(USER, errmsg);
123 }
124 } else if (bincnt <= 0) {
125 sprintf(errmsg,
126 "unspecified or illegal bin count for modifier '%s'",
127 modn);
128 error(USER, errmsg);
129 }
130 /* initialize results holder */
131 mp = (MODCONT *)malloc(sizeof(MODCONT)+sizeof(DCOLOR)*(bincnt-1));
132 if (mp == NULL)
133 error(SYSTEM, "out of memory in addmodifier");
134 mp->outspec = outf; /* XXX assumes static string */
135 mp->modname = modn; /* XXX assumes static string */
136 mp->params = prms; /* XXX assumes static string */
137 mp->binv = ebinv;
138 mp->nbins = bincnt;
139 memset(mp->cbin, 0, sizeof(DCOLOR)*bincnt);
140 /* allocate output streams */
141 for (i = bincnt; i-- > 0; )
142 getostream(mp->outspec, mp->modname, i, 1);
143 lep->data = (char *)mp;
144 return(mp);
145 }
146
147
148 /* Add modifiers from a file list */
149 void
150 addmodfile(char *fname, char *outf, char *prms, char *binv, int bincnt)
151 {
152 char *mname[MAXMODLIST];
153 int i;
154 /* find the file & store strings */
155 i = wordfile(mname, MAXMODLIST, getpath(fname, getrlibpath(), R_OK));
156 if (i < 0) {
157 sprintf(errmsg, "cannot find modifier file '%s'", fname);
158 error(SYSTEM, errmsg);
159 }
160 if (i >= MAXMODLIST-1) {
161 sprintf(errmsg, "too many modifiers (%d limit) in file '%s'",
162 MAXMODLIST-1, fname);
163 error(INTERNAL, errmsg);
164 }
165 for (i = 0; mname[i]; i++) /* add each one */
166 addmodifier(mname[i], outf, prms, binv, bincnt);
167 }
168
169
170 void
171 quit( /* quit program */
172 int code
173 )
174 {
175 if (nchild > 0) /* close children if any */
176 end_children(code != 0);
177 exit(code);
178 }
179
180
181 /* Initialize our process(es) */
182 static void
183 rcinit(void)
184 {
185 int i;
186
187 if (nproc > MAXPROCESS)
188 sprintf(errmsg, "too many processes requested -- reducing to %d",
189 nproc = MAXPROCESS);
190 if (nproc > 1) {
191 preload_objs(); /* preload auxiliary data */
192 /* set shared memory boundary */
193 shm_boundary = strcpy((char *)malloc(16), "SHM_BOUNDARY");
194 }
195 for (i = 0; i < nsources; i++) /* tracing to sources as well */
196 source[i].sflags |= SFOLLOW;
197 if (yres > 0) { /* set up flushing & ray counts */
198 if (xres > 0)
199 raysleft = (RNUMBER)xres*yres;
200 else
201 raysleft = yres;
202 } else
203 raysleft = 0;
204 if ((account = accumulate) > 1)
205 raysleft *= accumulate;
206 waitflush = (yres > 0) & (xres > 1) ? 0 : xres;
207
208 if (nproc > 1 && in_rchild()) /* forked child? */
209 return; /* return to main processing loop */
210
211 if (recover) { /* recover previous output? */
212 if (accumulate <= 0)
213 reload_output();
214 else
215 recover_output();
216 }
217 if (nproc == 1) /* single process? */
218 return;
219 /* else run appropriate controller */
220 if (accumulate <= 0)
221 feeder_loop();
222 else
223 parental_loop();
224 quit(0); /* parent musn't return! */
225 }
226
227 /************************** MAIN CALCULATION PROCESS ***********************/
228
229 /* Our trace call to sum contributions */
230 static void
231 trace_contrib(RAY *r)
232 {
233 MODCONT *mp;
234 double bval;
235 int bn;
236 RREAL contr[3];
237
238 if (r->ro == NULL || r->ro->omod == OVOID)
239 return;
240 /* shadow ray not on source? */
241 if (r->rsrc >= 0 && source[r->rsrc].so != r->ro)
242 return;
243
244 mp = (MODCONT *)lu_find(&modconttab,objptr(r->ro->omod)->oname)->data;
245
246 if (mp == NULL) /* not in our list? */
247 return;
248
249 worldfunc(RCCONTEXT, r); /* else set context */
250 set_eparams((char *)mp->params);
251 if ((bval = evalue(mp->binv)) <= -.5) /* and get bin number */
252 return; /* silently ignore negatives */
253 if ((bn = (int)(bval + .5)) >= mp->nbins) {
254 sprintf(errmsg, "bad bin number (%d ignored)", bn);
255 error(WARNING, errmsg);
256 return;
257 }
258 raycontrib(contr, r, PRIMARY); /* compute coefficient */
259 if (contrib)
260 multcolor(contr, r->rcol); /* -> contribution */
261 addcolor(mp->cbin[bn], contr);
262 }
263
264
265 /* Evaluate irradiance contributions */
266 static void
267 eval_irrad(FVECT org, FVECT dir)
268 {
269 RAY thisray;
270
271 VSUM(thisray.rorg, org, dir, 1.1e-4);
272 thisray.rdir[0] = -dir[0];
273 thisray.rdir[1] = -dir[1];
274 thisray.rdir[2] = -dir[2];
275 thisray.rmax = 0.0;
276 rayorigin(&thisray, PRIMARY, NULL, NULL);
277 /* pretend we hit surface */
278 thisray.rt = thisray.rot = 1e-5;
279 thisray.rod = 1.0;
280 VCOPY(thisray.ron, dir);
281 VSUM(thisray.rop, org, dir, 1e-4);
282 samplendx++; /* compute result */
283 (*ofun[Lamb.otype].funp)(&Lamb, &thisray);
284 }
285
286
287 /* Evaluate radiance contributions */
288 static void
289 eval_rad(FVECT org, FVECT dir, double dmax)
290 {
291 RAY thisray;
292 /* set up ray */
293 VCOPY(thisray.rorg, org);
294 VCOPY(thisray.rdir, dir);
295 thisray.rmax = dmax;
296 rayorigin(&thisray, PRIMARY, NULL, NULL);
297 samplendx++; /* call ray evaluation */
298 rayvalue(&thisray);
299 }
300
301
302 /* Accumulate and/or output ray contributions (child or only process) */
303 static void
304 done_contrib(void)
305 {
306 MODCONT *mp;
307 int i;
308
309 if (account <= 0 || --account)
310 return; /* not time yet */
311
312 for (i = 0; i < nmods; i++) { /* output records & clear */
313 mp = (MODCONT *)lu_find(&modconttab,modname[i])->data;
314 mod_output(mp);
315 memset(mp->cbin, 0, sizeof(DCOLOR)*mp->nbins);
316 }
317 end_record(); /* end lines & flush if time */
318
319 account = accumulate; /* reset accumulation counter */
320 }
321
322
323 /* Principal calculation loop (called by main) */
324 void
325 rcontrib(void)
326 {
327 static int ignore_warning_given = 0;
328 FVECT orig, direc;
329 double d;
330 /* initialize (& fork more of us) */
331 rcinit();
332 /* load rays from stdin & process */
333 #ifdef getc_unlocked
334 flockfile(stdin); /* avoid mutex overhead */
335 #endif
336 while (getvec(orig) == 0 && getvec(direc) == 0) {
337 d = normalize(direc);
338 if (nchild != -1 && (d == 0.0) & (accumulate == 0)) {
339 if (!ignore_warning_given++)
340 error(WARNING,
341 "dummy ray(s) ignored during accumulation\n");
342 continue;
343 }
344 if (lastray+1 < lastray)
345 lastray = lastdone = 0;
346 ++lastray;
347 if (d == 0.0) { /* zero ==> flush */
348 if ((yres <= 0) | (xres <= 1))
349 waitflush = 1; /* flush after */
350 if (nchild == -1)
351 account = 1;
352 } else if (imm_irrad) { /* else compute */
353 eval_irrad(orig, direc);
354 } else {
355 eval_rad(orig, direc, lim_dist ? d : 0.0);
356 }
357 done_contrib(); /* accumulate/output */
358 ++lastdone;
359 if (raysleft && !--raysleft)
360 break; /* preemptive EOI */
361 }
362 if (nchild != -1 && (accumulate <= 0) | (account < accumulate)) {
363 if (account < accumulate) {
364 error(WARNING, "partial accumulation in final record");
365 accumulate -= account;
366 }
367 account = 1; /* output accumulated totals */
368 done_contrib();
369 }
370 lu_done(&ofiletab); /* close output files */
371 if (raysleft)
372 error(USER, "unexpected EOF on input");
373 }
