root/radiance/ray/src/rt/rcontrib.c
Revision: 2.26
Committed: Wed Jul 15 23:38:37 2015 UTC (9 years, 11 months ago) by greg
Changes since 2.25: +5 -1 lines
Added check for 'void' modifier in -m or -M option
2 static const char RCSid[] = "$Id: rcontrib.c,v 2.25 2015/05/20 13:16:20 greg Exp $";
5 * Accumulate ray contributions for a set of materials
6 * Initialization and calculation routines
7 */
8
9 #include "copyright.h"
10
11 #include "rcontrib.h"
12 #include "otypes.h"
13 #include "source.h"
14
15 char *shm_boundary = NULL; /* boundary of shared memory */
16
17 CUBE thescene; /* our scene */
18 OBJECT nsceneobjs; /* number of objects in our scene */
19
20 int dimlist[MAXDIM]; /* sampling dimensions */
21 int ndims = 0; /* number of sampling dimensions */
22 int samplendx = 0; /* index for this sample */
23
24 static void trace_contrib(RAY *r); /* our trace callback */
25 void (*trace)() = trace_contrib;
26
27 int do_irrad = 0; /* compute irradiance? */
28
29 int rand_samp = 1; /* pure Monte Carlo sampling? */
30
31 double dstrsrc = 0.9; /* square source distribution */
32 double shadthresh = .03; /* shadow threshold */
33 double shadcert = .75; /* shadow certainty */
34 int directrelay = 3; /* number of source relays */
35 int vspretest = 512; /* virtual source pretest density */
36 int directvis = 1; /* sources visible? */
37 double srcsizerat = .2; /* maximum ratio source size/dist. */
38
39 COLOR cextinction = BLKCOLOR; /* global extinction coefficient */
40 COLOR salbedo = BLKCOLOR; /* global scattering albedo */
41 double seccg = 0.; /* global scattering eccentricity */
42 double ssampdist = 0.; /* scatter sampling distance */
43
44 double specthresh = .15; /* specular sampling threshold */
45 double specjitter = 1.; /* specular sampling jitter */
46
47 int backvis = 1; /* back face visibility */
48
49 int maxdepth = -10; /* maximum recursion depth */
50 double minweight = 2e-3; /* minimum ray weight */
51
52 char *ambfile = NULL; /* ambient file name */
53 COLOR ambval = BLKCOLOR; /* ambient value */
54 int ambvwt = 0; /* initial weight for ambient value */
55 double ambacc = 0; /* ambient accuracy */
56 int ambres = 256; /* ambient resolution */
57 int ambdiv = 350; /* ambient divisions */
58 int ambssamp = 0; /* ambient super-samples */
59 int ambounce = 1; /* ambient bounces */
60 char *amblist[AMBLLEN+1]; /* ambient include/exclude list */
61 int ambincl = -1; /* include == 1, exclude == 0 */
62
63 int account; /* current accumulation count */
64 RNUMBER raysleft; /* number of rays left to trace */
65 long waitflush; /* how long until next flush */
66
67 RNUMBER lastray = 0; /* last ray number sent */
68 RNUMBER lastdone = 0; /* last ray output */
69
70 static void mcfree(void *p) { epfree((*(MODCONT *)p).binv); free(p); }
71
72 LUTAB modconttab = LU_SINIT(NULL,mcfree); /* modifier lookup table */
73
74 /************************** INITIALIZATION ROUTINES ***********************/
75
76 char *
77 formstr( /* return format identifier */
78 int f
79 )
80 {
81 switch (f) {
82 case 'a': return("ascii");
83 case 'f': return("float");
84 case 'd': return("double");
85 case 'c': return(COLRFMT);
86 }
87 return("unknown");
88 }
89
90
91 /* Add modifier to our list to track */
92 MODCONT *
93 addmodifier(char *modn, char *outf, char *prms, char *binv, int bincnt)
94 {
95 LUENT *lep = lu_find(&modconttab,modn);
96 MODCONT *mp;
97 EPNODE *ebinv;
98 int i;
99
100 if (lep->data != NULL) {
101 sprintf(errmsg, "duplicate modifier '%s'", modn);
102 error(USER, errmsg);
103 }
104 if (nmods >= MAXMODLIST)
105 error(INTERNAL, "too many modifiers");
106 if (!strcmp(modn, VOIDID)) {
107 sprintf(errmsg, "cannot track '%s' modifier", VOIDID);
108 error(USER, errmsg);
109 }
110 modname[nmods++] = modn; /* XXX assumes static string */
111 lep->key = modn; /* XXX assumes static string */
112 if (binv == NULL)
113 binv = "0"; /* use single bin if unspecified */
114 ebinv = eparse(binv);
115 if (ebinv->type == NUM) { /* check value if constant */
116 bincnt = (int)(evalue(ebinv) + 1.5);
117 if (bincnt != 1) {
118 sprintf(errmsg, "illegal non-zero constant for bin (%s)",
119 binv);
120 error(USER, errmsg);
121 }
122 } else if (bincnt <= 0) {
123 sprintf(errmsg,
124 "unspecified or illegal bin count for modifier '%s'",
125 modn);
126 error(USER, errmsg);
127 }
128 /* initialize results holder */
129 mp = (MODCONT *)malloc(sizeof(MODCONT)+sizeof(DCOLOR)*(bincnt-1));
130 if (mp == NULL)
131 error(SYSTEM, "out of memory in addmodifier");
132 mp->outspec = outf; /* XXX assumes static string */
133 mp->modname = modn; /* XXX assumes static string */
134 mp->params = prms;
135 mp->binv = ebinv;
136 mp->nbins = bincnt;
137 memset(mp->cbin, 0, sizeof(DCOLOR)*bincnt);
138 /* allocate output streams */
139 for (i = bincnt; i-- > 0; )
140 getostream(mp->outspec, mp->modname, i, 1);
141 lep->data = (char *)mp;
142 return(mp);
143 }
144
145
146 /* Add modifiers from a file list */
147 void
148 addmodfile(char *fname, char *outf, char *prms, char *binv, int bincnt)
149 {
150 char *mname[MAXMODLIST];
151 int i;
152 /* find the file & store strings */
153 if (wordfile(mname, getpath(fname, getrlibpath(), R_OK)) < 0) {
154 sprintf(errmsg, "cannot find modifier file '%s'", fname);
155 error(SYSTEM, errmsg);
156 }
157 for (i = 0; mname[i]; i++) /* add each one */
158 addmodifier(mname[i], outf, prms, binv, bincnt);
159 }
160
161
162 void
163 quit( /* quit program */
164 int code
165 )
166 {
167 if (nchild > 0) /* close children if any */
168 end_children(code != 0);
169 exit(code);
170 }
171
172
173 /* Initialize our process(es) */
174 static void
175 rcinit()
176 {
177 int i;
178
179 if (nproc > MAXPROCESS)
180 sprintf(errmsg, "too many processes requested -- reducing to %d",
181 nproc = MAXPROCESS);
182 if (nproc > 1) {
183 preload_objs(); /* preload auxiliary data */
184 /* set shared memory boundary */
185 shm_boundary = strcpy((char *)malloc(16), "SHM_BOUNDARY");
186 }
187 for (i = 0; i < nsources; i++) /* tracing to sources as well */
188 source[i].sflags |= SFOLLOW;
189 if (yres > 0) { /* set up flushing & ray counts */
190 if (xres > 0)
191 raysleft = (RNUMBER)xres*yres;
192 else
193 raysleft = yres;
194 } else
195 raysleft = 0;
196 if ((account = accumulate) > 1)
197 raysleft *= accumulate;
198 waitflush = (yres > 0) & (xres > 1) ? 0 : xres;
199
200 if (nproc > 1 && in_rchild()) /* forked child? */
201 return; /* return to main processing loop */
202
203 if (recover) { /* recover previous output? */
204 if (accumulate <= 0)
205 reload_output();
206 else
207 recover_output();
208 }
209 if (nproc == 1) /* single process? */
210 return;
211 /* else run appropriate controller */
212 if (accumulate <= 0)
213 feeder_loop();
214 else
215 parental_loop();
216 quit(0); /* parent musn't return! */
217 }
218
219 /************************** MAIN CALCULATION PROCESS ***********************/
220
221 /* Our trace call to sum contributions */
222 static void
223 trace_contrib(RAY *r)
224 {
225 MODCONT *mp;
226 double bval;
227 int bn;
228 RREAL contr[3];
229
230 if (r->ro == NULL || r->ro->omod == OVOID)
231 return;
232 /* shadow ray not on source? */
233 if (r->rsrc >= 0 && source[r->rsrc].so != r->ro)
234 return;
235
236 mp = (MODCONT *)lu_find(&modconttab,objptr(r->ro->omod)->oname)->data;
237
238 if (mp == NULL) /* not in our list? */
239 return;
240
241 worldfunc(RCCONTEXT, r); /* else set context */
242 set_eparams((char *)mp->params);
243 if ((bval = evalue(mp->binv)) <= -.5) /* and get bin number */
244 return; /* silently ignore negatives */
245 if ((bn = (int)(bval + .5)) >= mp->nbins) {
246 sprintf(errmsg, "bad bin number (%d ignored)", bn);
247 error(WARNING, errmsg);
248 return;
249 }
250 raycontrib(contr, r, PRIMARY); /* compute coefficient */
251 if (contrib)
252 multcolor(contr, r->rcol); /* -> contribution */
253 addcolor(mp->cbin[bn], contr);
254 }
255
256
257 /* Evaluate irradiance contributions */
258 static void
259 eval_irrad(FVECT org, FVECT dir)
260 {
261 RAY thisray;
262
263 VSUM(thisray.rorg, org, dir, 1.1e-4);
264 thisray.rdir[0] = -dir[0];
265 thisray.rdir[1] = -dir[1];
266 thisray.rdir[2] = -dir[2];
267 thisray.rmax = 0.0;
268 rayorigin(&thisray, PRIMARY, NULL, NULL);
269 /* pretend we hit surface */
270 thisray.rt = thisray.rot = 1e-5;
271 thisray.rod = 1.0;
272 VCOPY(thisray.ron, dir);
273 VSUM(thisray.rop, org, dir, 1e-4);
274 samplendx++; /* compute result */
275 (*ofun[Lamb.otype].funp)(&Lamb, &thisray);
276 }
277
278
279 /* Evaluate radiance contributions */
280 static void
281 eval_rad(FVECT org, FVECT dir, double dmax)
282 {
283 RAY thisray;
284 /* set up ray */
285 VCOPY(thisray.rorg, org);
286 VCOPY(thisray.rdir, dir);
287 thisray.rmax = dmax;
288 rayorigin(&thisray, PRIMARY, NULL, NULL);
289 samplendx++; /* call ray evaluation */
290 rayvalue(&thisray);
291 }
292
293
294 /* Accumulate and/or output ray contributions (child or only process) */
295 static void
296 done_contrib()
297 {
298 MODCONT *mp;
299 int i;
300
301 if (account <= 0 || --account)
302 return; /* not time yet */
303
304 for (i = 0; i < nmods; i++) { /* output records & clear */
305 mp = (MODCONT *)lu_find(&modconttab,modname[i])->data;
306 mod_output(mp);
307 memset(mp->cbin, 0, sizeof(DCOLOR)*mp->nbins);
308 }
309 end_record(); /* end lines & flush if time */
310
311 account = accumulate; /* reset accumulation counter */
312 }
313
314
315 /* Principal calculation loop (called by main) */
316 void
317 rcontrib()
318 {
319 static int ignore_warning_given = 0;
320 FVECT orig, direc;
321 double d;
322 /* initialize (& fork more of us) */
323 rcinit();
324 /* load rays from stdin & process */
325 #ifdef getc_unlocked
326 flockfile(stdin); /* avoid mutex overhead */
327 #endif
328 while (getvec(orig) == 0 && getvec(direc) == 0) {
329 d = normalize(direc);
330 if (nchild != -1 && (d == 0.0) & (accumulate == 0)) {
331 if (!ignore_warning_given++)
332 error(WARNING,
333 "dummy ray(s) ignored during accumulation\n");
334 continue;
335 }
336 if (lastray+1 < lastray)
337 lastray = lastdone = 0;
338 ++lastray;
339 if (d == 0.0) { /* zero ==> flush */
340 if ((yres <= 0) | (xres <= 1))
341 waitflush = 1; /* flush after */
342 if (nchild == -1)
343 account = 1;
344 } else if (imm_irrad) { /* else compute */
345 eval_irrad(orig, direc);
346 } else {
347 eval_rad(orig, direc, lim_dist ? d : 0.0);
348 }
349 done_contrib(); /* accumulate/output */
350 ++lastdone;
351 if (raysleft && !--raysleft)
352 break; /* preemptive EOI */
353 }
354 if (nchild != -1 && (accumulate <= 0) | (account < accumulate)) {
355 if (account < accumulate) {
356 error(WARNING, "partial accumulation in final record");
357 accumulate -= account;
358 }
359 account = 1; /* output accumulated totals */
360 done_contrib();
361 }
362 lu_done(&ofiletab); /* close output files */
363 if (raysleft)
364 error(USER, "unexpected EOF on input");
365 }
