root/radiance/ray/src/rt/rcontrib.c
Revision: 2.25
Committed: Wed May 20 13:16:20 2015 UTC (10 years, 1 month ago) by greg
Changes since 2.24: +1 -2 lines
Fixed include dependency
2 static const char RCSid[] = "$Id: rcontrib.c,v 2.24 2015/05/20 12:58:31 greg Exp $";
5 * Accumulate ray contributions for a set of materials
6 * Initialization and calculation routines
7 */
8
9 #include "copyright.h"
10
11 #include "rcontrib.h"
12 #include "otypes.h"
13 #include "source.h"
14
15 char *shm_boundary = NULL; /* boundary of shared memory */
16
17 CUBE thescene; /* our scene */
18 OBJECT nsceneobjs; /* number of objects in our scene */
19
20 int dimlist[MAXDIM]; /* sampling dimensions */
21 int ndims = 0; /* number of sampling dimensions */
22 int samplendx = 0; /* index for this sample */
23
24 static void trace_contrib(RAY *r); /* our trace callback */
25 void (*trace)() = trace_contrib;
26
27 int do_irrad = 0; /* compute irradiance? */
28
29 int rand_samp = 1; /* pure Monte Carlo sampling? */
30
31 double dstrsrc = 0.9; /* square source distribution */
32 double shadthresh = .03; /* shadow threshold */
33 double shadcert = .75; /* shadow certainty */
34 int directrelay = 3; /* number of source relays */
35 int vspretest = 512; /* virtual source pretest density */
36 int directvis = 1; /* sources visible? */
37 double srcsizerat = .2; /* maximum ratio source size/dist. */
38
39 COLOR cextinction = BLKCOLOR; /* global extinction coefficient */
40 COLOR salbedo = BLKCOLOR; /* global scattering albedo */
41 double seccg = 0.; /* global scattering eccentricity */
42 double ssampdist = 0.; /* scatter sampling distance */
43
44 double specthresh = .15; /* specular sampling threshold */
45 double specjitter = 1.; /* specular sampling jitter */
46
47 int backvis = 1; /* back face visibility */
48
49 int maxdepth = -10; /* maximum recursion depth */
50 double minweight = 2e-3; /* minimum ray weight */
51
52 char *ambfile = NULL; /* ambient file name */
53 COLOR ambval = BLKCOLOR; /* ambient value */
54 int ambvwt = 0; /* initial weight for ambient value */
55 double ambacc = 0; /* ambient accuracy */
56 int ambres = 256; /* ambient resolution */
57 int ambdiv = 350; /* ambient divisions */
58 int ambssamp = 0; /* ambient super-samples */
59 int ambounce = 1; /* ambient bounces */
60 char *amblist[AMBLLEN+1]; /* ambient include/exclude list */
61 int ambincl = -1; /* include == 1, exclude == 0 */
62
63 int account; /* current accumulation count */
64 RNUMBER raysleft; /* number of rays left to trace */
65 long waitflush; /* how long until next flush */
66
67 RNUMBER lastray = 0; /* last ray number sent */
68 RNUMBER lastdone = 0; /* last ray output */
69
70 static void mcfree(void *p) { epfree((*(MODCONT *)p).binv); free(p); }
71
72 LUTAB modconttab = LU_SINIT(NULL,mcfree); /* modifier lookup table */
73
74 /************************** INITIALIZATION ROUTINES ***********************/
75
76 char *
77 formstr( /* return format identifier */
78 int f
79 )
80 {
81 switch (f) {
82 case 'a': return("ascii");
83 case 'f': return("float");
84 case 'd': return("double");
85 case 'c': return(COLRFMT);
86 }
87 return("unknown");
88 }
89
90
91 /* Add modifier to our list to track */
92 MODCONT *
93 addmodifier(char *modn, char *outf, char *prms, char *binv, int bincnt)
94 {
95 LUENT *lep = lu_find(&modconttab,modn);
96 MODCONT *mp;
97 EPNODE *ebinv;
98 int i;
99
100 if (lep->data != NULL) {
101 sprintf(errmsg, "duplicate modifier '%s'", modn);
102 error(USER, errmsg);
103 }
104 if (nmods >= MAXMODLIST)
105 error(INTERNAL, "too many modifiers");
106 modname[nmods++] = modn; /* XXX assumes static string */
107 lep->key = modn; /* XXX assumes static string */
108 if (binv == NULL)
109 binv = "0"; /* use single bin if unspecified */
110 ebinv = eparse(binv);
111 if (ebinv->type == NUM) { /* check value if constant */
112 bincnt = (int)(evalue(ebinv) + 1.5);
113 if (bincnt != 1) {
114 sprintf(errmsg, "illegal non-zero constant for bin (%s)",
115 binv);
116 error(USER, errmsg);
117 }
118 } else if (bincnt <= 0) {
119 sprintf(errmsg,
120 "unspecified or illegal bin count for modifier '%s'",
121 modn);
122 error(USER, errmsg);
123 }
124 /* initialize results holder */
125 mp = (MODCONT *)malloc(sizeof(MODCONT)+sizeof(DCOLOR)*(bincnt-1));
126 if (mp == NULL)
127 error(SYSTEM, "out of memory in addmodifier");
128 mp->outspec = outf; /* XXX assumes static string */
129 mp->modname = modn; /* XXX assumes static string */
130 mp->params = prms;
131 mp->binv = ebinv;
132 mp->nbins = bincnt;
133 memset(mp->cbin, 0, sizeof(DCOLOR)*bincnt);
134 /* allocate output streams */
135 for (i = bincnt; i-- > 0; )
136 getostream(mp->outspec, mp->modname, i, 1);
137 lep->data = (char *)mp;
138 return(mp);
139 }
140
141
142 /* Add modifiers from a file list */
143 void
144 addmodfile(char *fname, char *outf, char *prms, char *binv, int bincnt)
145 {
146 char *mname[MAXMODLIST];
147 int i;
148 /* find the file & store strings */
149 if (wordfile(mname, getpath(fname, getrlibpath(), R_OK)) < 0) {
150 sprintf(errmsg, "cannot find modifier file '%s'", fname);
151 error(SYSTEM, errmsg);
152 }
153 for (i = 0; mname[i]; i++) /* add each one */
154 addmodifier(mname[i], outf, prms, binv, bincnt);
155 }
156
157
158 void
159 quit( /* quit program */
160 int code
161 )
162 {
163 if (nchild > 0) /* close children if any */
164 end_children(code != 0);
165 exit(code);
166 }
167
168
169 /* Initialize our process(es) */
170 static void
171 rcinit()
172 {
173 int i;
174
175 if (nproc > MAXPROCESS)
176 sprintf(errmsg, "too many processes requested -- reducing to %d",
177 nproc = MAXPROCESS);
178 if (nproc > 1) {
179 preload_objs(); /* preload auxiliary data */
180 /* set shared memory boundary */
181 shm_boundary = strcpy((char *)malloc(16), "SHM_BOUNDARY");
182 }
183 for (i = 0; i < nsources; i++) /* tracing to sources as well */
184 source[i].sflags |= SFOLLOW;
185 if (yres > 0) { /* set up flushing & ray counts */
186 if (xres > 0)
187 raysleft = (RNUMBER)xres*yres;
188 else
189 raysleft = yres;
190 } else
191 raysleft = 0;
192 if ((account = accumulate) > 1)
193 raysleft *= accumulate;
194 waitflush = (yres > 0) & (xres > 1) ? 0 : xres;
195
196 if (nproc > 1 && in_rchild()) /* forked child? */
197 return; /* return to main processing loop */
198
199 if (recover) { /* recover previous output? */
200 if (accumulate <= 0)
201 reload_output();
202 else
203 recover_output();
204 }
205 if (nproc == 1) /* single process? */
206 return;
207 /* else run appropriate controller */
208 if (accumulate <= 0)
209 feeder_loop();
210 else
211 parental_loop();
212 quit(0); /* parent musn't return! */
213 }
214
215 /************************** MAIN CALCULATION PROCESS ***********************/
216
217 /* Our trace call to sum contributions */
218 static void
219 trace_contrib(RAY *r)
220 {
221 MODCONT *mp;
222 double bval;
223 int bn;
224 RREAL contr[3];
225
226 if (r->ro == NULL || r->ro->omod == OVOID)
227 return;
228 /* shadow ray not on source? */
229 if (r->rsrc >= 0 && source[r->rsrc].so != r->ro)
230 return;
231
232 mp = (MODCONT *)lu_find(&modconttab,objptr(r->ro->omod)->oname)->data;
233
234 if (mp == NULL) /* not in our list? */
235 return;
236
237 worldfunc(RCCONTEXT, r); /* else set context */
238 set_eparams((char *)mp->params);
239 if ((bval = evalue(mp->binv)) <= -.5) /* and get bin number */
240 return; /* silently ignore negatives */
241 if ((bn = (int)(bval + .5)) >= mp->nbins) {
242 sprintf(errmsg, "bad bin number (%d ignored)", bn);
243 error(WARNING, errmsg);
244 return;
245 }
246 raycontrib(contr, r, PRIMARY); /* compute coefficient */
247 if (contrib)
248 multcolor(contr, r->rcol); /* -> contribution */
249 addcolor(mp->cbin[bn], contr);
250 }
251
252
253 /* Evaluate irradiance contributions */
254 static void
255 eval_irrad(FVECT org, FVECT dir)
256 {
257 RAY thisray;
258
259 VSUM(thisray.rorg, org, dir, 1.1e-4);
260 thisray.rdir[0] = -dir[0];
261 thisray.rdir[1] = -dir[1];
262 thisray.rdir[2] = -dir[2];
263 thisray.rmax = 0.0;
264 rayorigin(&thisray, PRIMARY, NULL, NULL);
265 /* pretend we hit surface */
266 thisray.rt = thisray.rot = 1e-5;
267 thisray.rod = 1.0;
268 VCOPY(thisray.ron, dir);
269 VSUM(thisray.rop, org, dir, 1e-4);
270 samplendx++; /* compute result */
271 (*ofun[Lamb.otype].funp)(&Lamb, &thisray);
272 }
273
274
275 /* Evaluate radiance contributions */
276 static void
277 eval_rad(FVECT org, FVECT dir, double dmax)
278 {
279 RAY thisray;
280 /* set up ray */
281 VCOPY(thisray.rorg, org);
282 VCOPY(thisray.rdir, dir);
283 thisray.rmax = dmax;
284 rayorigin(&thisray, PRIMARY, NULL, NULL);
285 samplendx++; /* call ray evaluation */
286 rayvalue(&thisray);
287 }
288
289
290 /* Accumulate and/or output ray contributions (child or only process) */
291 static void
292 done_contrib()
293 {
294 MODCONT *mp;
295 int i;
296
297 if (account <= 0 || --account)
298 return; /* not time yet */
299
300 for (i = 0; i < nmods; i++) { /* output records & clear */
301 mp = (MODCONT *)lu_find(&modconttab,modname[i])->data;
302 mod_output(mp);
303 memset(mp->cbin, 0, sizeof(DCOLOR)*mp->nbins);
304 }
305 end_record(); /* end lines & flush if time */
306
307 account = accumulate; /* reset accumulation counter */
308 }
309
310
311 /* Principal calculation loop (called by main) */
312 void
313 rcontrib()
314 {
315 static int ignore_warning_given = 0;
316 FVECT orig, direc;
317 double d;
318 /* initialize (& fork more of us) */
319 rcinit();
320 /* load rays from stdin & process */
321 #ifdef getc_unlocked
322 flockfile(stdin); /* avoid mutex overhead */
323 #endif
324 while (getvec(orig) == 0 && getvec(direc) == 0) {
325 d = normalize(direc);
326 if (nchild != -1 && (d == 0.0) & (accumulate == 0)) {
327 if (!ignore_warning_given++)
328 error(WARNING,
329 "dummy ray(s) ignored during accumulation\n");
330 continue;
331 }
332 if (lastray+1 < lastray)
333 lastray = lastdone = 0;
334 ++lastray;
335 if (d == 0.0) { /* zero ==> flush */
336 if ((yres <= 0) | (xres <= 1))
337 waitflush = 1; /* flush after */
338 if (nchild == -1)
339 account = 1;
340 } else if (imm_irrad) { /* else compute */
341 eval_irrad(orig, direc);
342 } else {
343 eval_rad(orig, direc, lim_dist ? d : 0.0);
344 }
345 done_contrib(); /* accumulate/output */
346 ++lastdone;
347 if (raysleft && !--raysleft)
348 break; /* preemptive EOI */
349 }
350 if (nchild != -1 && (accumulate <= 0) | (account < accumulate)) {
351 if (account < accumulate) {
352 error(WARNING, "partial accumulation in final record");
353 accumulate -= account;
354 }
355 account = 1; /* output accumulated totals */
356 done_contrib();
357 }
358 lu_done(&ofiletab); /* close output files */
359 if (raysleft)
360 error(USER, "unexpected EOF on input");
361 }
