root/radiance/ray/src/rt/rcontrib.c
Revision: 2.13
Committed: Fri Jun 22 22:03:02 2012 UTC (13 years, 1 month ago) by greg
Changes since 2.12: +1 -5 lines
Moved source initialization
2 static const char RCSid[] = "$Id: rcontrib.c,v 2.12 2012/06/21 17:14:32 greg Exp $";
5 * Accumulate ray contributions for a set of materials
6 * Initialization and calculation routines
7 */
8
9 #include "rcontrib.h"
10 #include "otypes.h"
11
12 char *shm_boundary = NULL; /* boundary of shared memory */
13
14 CUBE thescene; /* our scene */
15 OBJECT nsceneobjs; /* number of objects in our scene */
16
17 int dimlist[MAXDIM]; /* sampling dimensions */
18 int ndims = 0; /* number of sampling dimensions */
19 int samplendx = 0; /* index for this sample */
20
21 static void trace_contrib(RAY *r); /* our trace callback */
22 void (*trace)() = trace_contrib;
23
24 int do_irrad = 0; /* compute irradiance? */
25
26 int rand_samp = 1; /* pure Monte Carlo sampling? */
27
28 double dstrsrc = 0.9; /* square source distribution */
29 double shadthresh = .03; /* shadow threshold */
30 double shadcert = .75; /* shadow certainty */
31 int directrelay = 3; /* number of source relays */
32 int vspretest = 512; /* virtual source pretest density */
33 int directvis = 1; /* sources visible? */
34 double srcsizerat = .2; /* maximum ratio source size/dist. */
35
36 COLOR cextinction = BLKCOLOR; /* global extinction coefficient */
37 COLOR salbedo = BLKCOLOR; /* global scattering albedo */
38 double seccg = 0.; /* global scattering eccentricity */
39 double ssampdist = 0.; /* scatter sampling distance */
40
41 double specthresh = .15; /* specular sampling threshold */
42 double specjitter = 1.; /* specular sampling jitter */
43
44 int backvis = 1; /* back face visibility */
45
46 int maxdepth = -10; /* maximum recursion depth */
47 double minweight = 2e-3; /* minimum ray weight */
48
49 char *ambfile = NULL; /* ambient file name */
50 COLOR ambval = BLKCOLOR; /* ambient value */
51 int ambvwt = 0; /* initial weight for ambient value */
52 double ambacc = 0; /* ambient accuracy */
53 int ambres = 256; /* ambient resolution */
54 int ambdiv = 350; /* ambient divisions */
55 int ambssamp = 0; /* ambient super-samples */
56 int ambounce = 1; /* ambient bounces */
57 char *amblist[AMBLLEN+1]; /* ambient include/exclude list */
58 int ambincl = -1; /* include == 1, exclude == 0 */
59
60 int account; /* current accumulation count */
61 RNUMBER raysleft; /* number of rays left to trace */
62 long waitflush; /* how long until next flush */
63
64 RNUMBER lastray = 0; /* last ray number sent */
65 RNUMBER lastdone = 0; /* last ray output */
66
67 static void mcfree(void *p) { epfree((*(MODCONT *)p).binv); free(p); }
68
69 LUTAB modconttab = LU_SINIT(NULL,mcfree); /* modifier lookup table */
70
71 /************************** INITIALIZATION ROUTINES ***********************/
72
73 char *
74 formstr( /* return format identifier */
75 int f
76 )
77 {
78 switch (f) {
79 case 'a': return("ascii");
80 case 'f': return("float");
81 case 'd': return("double");
82 case 'c': return(COLRFMT);
83 }
84 return("unknown");
85 }
86
87
88 /* Add modifier to our list to track */
89 MODCONT *
90 addmodifier(char *modn, char *outf, char *binv, int bincnt)
91 {
92 LUENT *lep = lu_find(&modconttab,modn);
93 MODCONT *mp;
94 EPNODE *ebinv;
95 int i;
96
97 if (lep->data != NULL) {
98 sprintf(errmsg, "duplicate modifier '%s'", modn);
99 error(USER, errmsg);
100 }
101 if (nmods >= MAXMODLIST)
102 error(INTERNAL, "too many modifiers");
103 modname[nmods++] = modn; /* XXX assumes static string */
104 lep->key = modn; /* XXX assumes static string */
105 if (binv == NULL)
106 binv = "0"; /* use single bin if unspecified */
107 ebinv = eparse(binv);
108 if (ebinv->type == NUM) { /* check value if constant */
109 bincnt = (int)(evalue(ebinv) + 1.5);
110 if (bincnt != 1) {
111 sprintf(errmsg, "illegal non-zero constant for bin (%s)",
112 binv);
113 error(USER, errmsg);
114 }
115 } else if (bincnt <= 0) {
116 sprintf(errmsg,
117 "unspecified or illegal bin count for modifier '%s'",
118 modn);
119 error(USER, errmsg);
120 }
121 /* initialize results holder */
122 mp = (MODCONT *)malloc(sizeof(MODCONT)+sizeof(DCOLOR)*(bincnt-1));
123 if (mp == NULL)
124 error(SYSTEM, "out of memory in addmodifier");
125 mp->outspec = outf; /* XXX assumes static string */
126 mp->modname = modn; /* XXX assumes static string */
127 mp->binv = ebinv;
128 mp->nbins = bincnt;
129 memset(mp->cbin, 0, sizeof(DCOLOR)*bincnt);
130 /* allocate output streams */
131 for (i = bincnt; i-- > 0; )
132 getostream(mp->outspec, mp->modname, i, 1);
133 lep->data = (char *)mp;
134 return(mp);
135 }
136
137
138 /* Add modifiers from a file list */
139 void
140 addmodfile(char *fname, char *outf, char *binv, int bincnt)
141 {
142 char *mname[MAXMODLIST];
143 int i;
144 /* find the file & store strings */
145 if (wordfile(mname, getpath(fname, getrlibpath(), R_OK)) < 0) {
146 sprintf(errmsg, "cannot find modifier file '%s'", fname);
147 error(SYSTEM, errmsg);
148 }
149 for (i = 0; mname[i]; i++) /* add each one */
150 addmodifier(mname[i], outf, binv, bincnt);
151 }
152
153
154 void
155 quit( /* quit program */
156 int code
157 )
158 {
159 if (nchild > 0) /* close children if any */
160 end_children(code != 0);
161 exit(code);
162 }
163
164
165 /* Initialize our process(es) */
166 static void
167 rcinit()
168 {
169 int i;
170
171 if (nproc > MAXPROCESS)
172 sprintf(errmsg, "too many processes requested -- reducing to %d",
173 nproc = MAXPROCESS);
174 if (nproc > 1) {
175 preload_objs(); /* preload auxiliary data */
176 /* set shared memory boundary */
177 shm_boundary = strcpy((char *)malloc(16), "SHM_BOUNDARY");
178 }
179 if (yres > 0) { /* set up flushing & ray counts */
180 if (xres > 0)
181 raysleft = (RNUMBER)xres*yres;
182 else
183 raysleft = yres;
184 } else
185 raysleft = 0;
186 if ((account = accumulate) > 1)
187 raysleft *= accumulate;
188 waitflush = (yres > 0) & (xres > 1) ? 0 : xres;
189
190 if (nproc > 1 && in_rchild()) /* forked child? */
191 return; /* return to main processing loop */
192
193 if (recover) { /* recover previous output? */
194 if (accumulate <= 0)
195 reload_output();
196 else
197 recover_output();
198 }
199 if (nproc == 1) /* single process? */
200 return;
201 /* else run appropriate controller */
202 if (accumulate <= 0)
203 feeder_loop();
204 else
205 parental_loop();
206 quit(0); /* parent musn't return! */
207 }
208
209 /************************** MAIN CALCULATION PROCESS ***********************/
210
211 /* Our trace call to sum contributions */
212 static void
213 trace_contrib(RAY *r)
214 {
215 MODCONT *mp;
216 int bn;
217 RREAL contr[3];
218
219 if (r->ro == NULL || r->ro->omod == OVOID)
220 return;
221
222 mp = (MODCONT *)lu_find(&modconttab,objptr(r->ro->omod)->oname)->data;
223
224 if (mp == NULL) /* not in our list? */
225 return;
226
227 worldfunc(RCCONTEXT, r); /* get bin number */
228 bn = (int)(evalue(mp->binv) + .5);
229 if ((bn < 0) | (bn >= mp->nbins)) {
230 error(WARNING, "bad bin number (ignored)");
231 return;
232 }
233 raycontrib(contr, r, PRIMARY);
234 if (contrib)
235 multcolor(contr, r->rcol);
236 addcolor(mp->cbin[bn], contr);
237 }
238
239
240 /* Evaluate irradiance contributions */
241 static void
242 eval_irrad(FVECT org, FVECT dir)
243 {
244 RAY thisray;
245
246 VSUM(thisray.rorg, org, dir, 1.1e-4);
247 thisray.rdir[0] = -dir[0];
248 thisray.rdir[1] = -dir[1];
249 thisray.rdir[2] = -dir[2];
250 thisray.rmax = 0.0;
251 rayorigin(&thisray, PRIMARY, NULL, NULL);
252 thisray.rot = 1e-5; /* pretend we hit surface */
253 thisray.rod = 1.0;
254 VSUM(thisray.rop, org, dir, 1e-4);
255 samplendx++; /* compute result */
256 (*ofun[Lamb.otype].funp)(&Lamb, &thisray);
257 }
258
259
260 /* Evaluate radiance contributions */
261 static void
262 eval_rad(FVECT org, FVECT dir, double dmax)
263 {
264 RAY thisray;
265 /* set up ray */
266 VCOPY(thisray.rorg, org);
267 VCOPY(thisray.rdir, dir);
268 thisray.rmax = dmax;
269 rayorigin(&thisray, PRIMARY, NULL, NULL);
270 samplendx++; /* call ray evaluation */
271 rayvalue(&thisray);
272 }
273
274
275 /* Accumulate and/or output ray contributions (child or only process) */
276 static void
277 done_contrib()
278 {
279 MODCONT *mp;
280 int i;
281
282 if (account <= 0 || --account)
283 return; /* not time yet */
284
285 for (i = 0; i < nmods; i++) { /* output records & clear */
286 mp = (MODCONT *)lu_find(&modconttab,modname[i])->data;
287 mod_output(mp);
288 memset(mp->cbin, 0, sizeof(DCOLOR)*mp->nbins);
289 }
290 end_record(); /* end lines & flush if time */
291
292 account = accumulate; /* reset accumulation counter */
293 }
294
295
296 /* Principal calculation loop (called by main) */
297 void
298 rcontrib()
299 {
300 static int ignore_warning_given = 0;
301 FVECT orig, direc;
302 double d;
303 /* initialize (& fork more of us) */
304 rcinit();
305 /* load rays from stdin & process */
306 #ifdef getc_unlocked
307 flockfile(stdin); /* avoid mutex overhead */
308 #endif
309 while (getvec(orig) == 0 && getvec(direc) == 0) {
310 d = normalize(direc);
311 if (nchild != -1 && (d == 0.0) & (accumulate != 1)) {
312 if (!ignore_warning_given++)
313 error(WARNING,
314 "dummy ray(s) ignored during accumulation\n");
315 continue;
316 }
317 if (lastray+1 < lastray)
318 lastray = lastdone = 0;
319 ++lastray;
320 if (d == 0.0) { /* zero ==> flush */
321 if ((yres <= 0) | (xres <= 0))
322 waitflush = 1; /* flush right after */
323 account = 1;
324 } else if (imm_irrad) { /* else compute */
325 eval_irrad(orig, direc);
326 } else {
327 eval_rad(orig, direc, lim_dist ? d : 0.0);
328 }
329 done_contrib(); /* accumulate/output */
330 ++lastdone;
331 if (raysleft && !--raysleft)
332 break; /* preemptive EOI */
333 }
334 if (nchild != -1 && (accumulate <= 0) | (account < accumulate)) {
335 if (account < accumulate) {
336 error(WARNING, "partial accumulation in final record");
337 accumulate -= account;
338 }
339 account = 1; /* output accumulated totals */
340 done_contrib();
341 }
342 lu_done(&ofiletab); /* close output files */
343 if (raysleft)
344 error(USER, "unexpected EOF on input");
345 }
