root/radiance/ray/src/rt/rcontrib.c
Revision: 2.1
Committed: Sat Jun 9 07:16:47 2012 UTC (11 years, 11 months ago) by greg
5 * Accumulate ray contributions for a set of materials
6 * Initialization and calculation routines
7 */
8
9 #include "rcontrib.h"
10 #include "source.h"
11 #include "otypes.h"
12 #include "platform.h"
13
14 CUBE thescene; /* our scene */
15 OBJECT nsceneobjs; /* number of objects in our scene */
16
17 int dimlist[MAXDIM]; /* sampling dimensions */
18 int ndims = 0; /* number of sampling dimensions */
19 int samplendx = 0; /* index for this sample */
20
21 static void trace_contrib(RAY *r); /* our trace callback */
22 void (*trace)() = trace_contrib;
23
24 int do_irrad = 0; /* compute irradiance? */
25
26 int rand_samp = 0; /* pure Monte Carlo sampling? */
27
28 double dstrsrc = 0.0; /* square source distribution */
29 double shadthresh = .03; /* shadow threshold */
30 double shadcert = .75; /* shadow certainty */
31 int directrelay = 3; /* number of source relays */
32 int vspretest = 512; /* virtual source pretest density */
33 int directvis = 1; /* sources visible? */
34 double srcsizerat = .2; /* maximum ratio source size/dist. */
35
36 COLOR cextinction = BLKCOLOR; /* global extinction coefficient */
37 COLOR salbedo = BLKCOLOR; /* global scattering albedo */
38 double seccg = 0.; /* global scattering eccentricity */
39 double ssampdist = 0.; /* scatter sampling distance */
40
41 double specthresh = .15; /* specular sampling threshold */
42 double specjitter = 1.; /* specular sampling jitter */
43
44 int backvis = 1; /* back face visibility */
45
46 int maxdepth = 8; /* maximum recursion depth */
47 double minweight = 5e-4; /* minimum ray weight */
48
49 char *ambfile = NULL; /* ambient file name */
50 COLOR ambval = BLKCOLOR; /* ambient value */
51 int ambvwt = 0; /* initial weight for ambient value */
52 double ambacc = 0; /* ambient accuracy */
53 int ambres = 256; /* ambient resolution */
54 int ambdiv = 350; /* ambient divisions */
55 int ambssamp = 0; /* ambient super-samples */
56 int ambounce = 1; /* ambient bounces */
57 char *amblist[AMBLLEN+1]; /* ambient include/exclude list */
58 int ambincl = -1; /* include == 1, exclude == 0 */
59
60 int account; /* current accumulation count */
61 RNUMBER raysleft; /* number of rays left to trace */
62 long waitflush; /* how long until next flush */
63
64 int lastray = 0; /* last ray number sent */
65 int lastdone = 0; /* last ray output */
66
67 /* Close output stream and free record */
68 static void
69 closestream(void *p)
70 {
71 STREAMOUT *sop = (STREAMOUT *)p;
72 int status = 0;
73 if (sop->outpipe)
74 status = pclose(sop->ofp);
75 else if (sop->ofp != stdout)
76 status = fclose(sop->ofp);
77 if (status)
78 error(SYSTEM, "error closing output stream");
79 free(p);
80 }
81
82 LUTAB ofiletab = LU_SINIT(free,closestream); /* output file table */
83
84 #define OF_MODIFIER 01
85 #define OF_BIN 02
86
87 static void mcfree(void *p) { epfree((*(MODCONT *)p).binv); free(p); }
88
89 LUTAB modconttab = LU_SINIT(NULL,mcfree); /* modifier lookup table */
90
91 static OBJECT traset[MAXTSET+1]={0}; /* trace include set */
92
93 /************************** INITIALIZATION ROUTINES ***********************/
94
95 void
96 tranotify( /* record new modifier */
97 OBJECT obj
98 )
99 {
100 static int hitlimit = 0;
101 OBJREC *o = objptr(obj);
102 int i;
103
104 if (obj == OVOID) { /* starting over */
105 traset[0] = 0;
106 hitlimit = 0;
107 return;
108 }
109 if (hitlimit || !ismodifier(o->otype))
110 return;
111 for (i = nmods; i-- > 0; )
112 if (!strcmp(o->oname, modname[i])) {
113 if (traset[0] >= MAXTSET) {
114 error(WARNING, "too many same-named modifiers");
115 hitlimit++;
116 return; /* should this be fatal? */
117 }
118 insertelem(traset, obj);
119 break;
120 }
121 }
122
123
124 char *
125 formstr( /* return format identifier */
126 int f
127 )
128 {
129 switch (f) {
130 case 'a': return("ascii");
131 case 'f': return("float");
132 case 'd': return("double");
133 case 'c': return(COLRFMT);
134 }
135 return("unknown");
136 }
137
138
139 /* Add modifier to our list to track */
140 MODCONT *
141 addmodifier(char *modn, char *outf, char *binv, int bincnt)
142 {
143 LUENT *lep = lu_find(&modconttab,modn);
144 MODCONT *mp;
145 EPNODE *ebinv;
146 int i;
147
148 if (lep->data != NULL) {
149 sprintf(errmsg, "duplicate modifier '%s'", modn);
150 error(USER, errmsg);
151 }
152 if (nmods >= MAXMODLIST)
153 error(INTERNAL, "too many modifiers");
154 modname[nmods++] = modn; /* XXX assumes static string */
155 lep->key = modn; /* XXX assumes static string */
156 if (binv == NULL)
157 binv = "0"; /* use single bin if unspecified */
158 ebinv = eparse(binv);
159 if (ebinv->type == NUM) { /* check value if constant */
160 bincnt = (int)(evalue(ebinv) + 1.5);
161 if (bincnt != 1) {
162 sprintf(errmsg, "illegal non-zero constant for bin (%s)",
163 binv);
164 error(USER, errmsg);
165 }
166 } else if (bincnt <= 0) {
167 sprintf(errmsg,
168 "unspecified or illegal bin count for modifier '%s'",
169 modn);
170 error(USER, errmsg);
171 }
172 /* initialize results holder */
173 mp = (MODCONT *)malloc(sizeof(MODCONT)+sizeof(DCOLOR)*(bincnt-1));
174 if (mp == NULL)
175 error(SYSTEM, "out of memory in addmodifier");
176 mp->outspec = outf; /* XXX assumes static string */
177 mp->modname = modn; /* XXX assumes static string */
178 mp->binv = ebinv;
179 mp->nbins = bincnt;
180 memset(mp->cbin, 0, sizeof(DCOLOR)*bincnt);
181 /* allocate output streams */
182 for (i = bincnt; i-- > 0; )
183 getostream(mp->outspec, mp->modname, i, 1);
184 lep->data = (char *)mp;
185 return(mp);
186 }
187
188
189 /* add modifiers from a file list */
190 void
191 addmodfile(char *fname, char *outf, char *binv, int bincnt)
192 {
193 char *mname[MAXMODLIST];
194 int i;
195 /* find the file & store strings */
196 if (wordfile(mname, getpath(fname, getrlibpath(), R_OK)) < 0) {
197 sprintf(errmsg, "cannot find modifier file '%s'", fname);
198 error(SYSTEM, errmsg);
199 }
200 for (i = 0; mname[i]; i++) /* add each one */
201 addmodifier(mname[i], outf, binv, bincnt);
202 }
203
204
205 void
206 quit( /* quit program */
207 int code
208 )
209 {
210 if (nchild > 0) /* close children if any */
211 end_children();
212 exit(code);
213 }
214
215
216 /* Initialize our process(es) */
217 static void
218 rcinit()
219 {
220 int i;
221
222 if (nproc > MAXPROCESS)
223 sprintf(errmsg, "too many processes requested -- reducing to %d",
224 nproc = MAXPROCESS);
225
226 if ((nproc > 1) & (accumulate <= 0))
227 zero_record(0); /* prime our queue to accumulate */
228
229 if (recover) { /* recover previous output? */
230 if (accumulate <= 0) {
231 reload_output();
232 if ((nproc > 1) & (accumulate <= 0))
233 queue_modifiers();
234 } else
235 recover_output();
236 }
237 if (yres > 0) { /* set up flushing & ray counts */
238 if (xres > 0)
239 raysleft = (RNUMBER)xres*yres;
240 else
241 raysleft = yres;
242 } else
243 raysleft = 0;
244 if ((account = accumulate) > 1)
245 raysleft *= accumulate;
246 waitflush = (yres > 0) & (xres > 1) ? 0 : xres;
247 /* tracing to sources as well */
248 for (i = 0; i < nsources; i++)
249 source[i].sflags |= SFOLLOW;
250
251 if (nproc == 1 || in_rchild()) /* single process or child */
252 return; /* return to main processing loop */
253
254 parental_loop(); /* else run controller */
255 quit(0); /* parent musn't return! */
256 }
257
258 /************************** MAIN CALCULATION PROCESS ***********************/
259
260 /* Our trace call to sum contributions */
261 static void
262 trace_contrib(RAY *r)
263 {
264 MODCONT *mp;
265 int bn;
266 RREAL contr[3];
267
268 if (r->ro == NULL || !inset(traset, r->ro->omod))
269 return;
270
271 mp = (MODCONT *)lu_find(&modconttab,objptr(r->ro->omod)->oname)->data;
272
273 if (mp == NULL)
274 error(CONSISTENCY, "unexpected modifier in trace_contrib()");
275
276 worldfunc(RCCONTEXT, r); /* get bin number */
277 bn = (int)(evalue(mp->binv) + .5);
278 if ((bn < 0) | (bn >= mp->nbins)) {
279 error(WARNING, "bad bin number (ignored)");
280 return;
281 }
282 raycontrib(contr, r, PRIMARY);
283 if (contrib)
284 multcolor(contr, r->rcol);
285 addcolor(mp->cbin[bn], contr);
286 }
287
288
289 static void
290 rayirrad( /* compute irradiance rather than radiance */
291 RAY *r
292 )
293 {
294 r->rot = 1e-5; /* pretend we hit surface */
295 VSUM(r->rop, r->rorg, r->rdir, r->rot);
296 r->ron[0] = -r->rdir[0];
297 r->ron[1] = -r->rdir[1];
298 r->ron[2] = -r->rdir[2];
299 r->rod = 1.0;
300 /* compute result */
301 r->revf = raytrace;
302 (*ofun[Lamb.otype].funp)(&Lamb, r);
303 r->revf = rayirrad;
304 }
305
306
307 /* Evaluate ray contributions */
308 static void
309 eval_ray(FVECT org, FVECT dir, double dmax)
310 {
311 RAY thisray;
312 /* set up ray */
313 rayorigin(&thisray, PRIMARY, NULL, NULL);
314 if (imm_irrad) {
315 VSUM(thisray.rorg, org, dir, 1.1e-4);
316 thisray.rdir[0] = -dir[0];
317 thisray.rdir[1] = -dir[1];
318 thisray.rdir[2] = -dir[2];
319 thisray.rmax = 0.0;
320 thisray.revf = rayirrad;
321 } else {
322 VCOPY(thisray.rorg, org);
323 VCOPY(thisray.rdir, dir);
324 thisray.rmax = dmax;
325 }
326 samplendx++; /* call ray evaluation */
327 rayvalue(&thisray);
328 }
329
330
331 /* Accumulate and/or output ray contributions (child or only process) */
332 static void
333 done_contrib()
334 {
335 MODCONT *mp;
336 int i;
337
338 if (account <= 0 || --account)
339 return; /* not time yet */
340
341 for (i = 0; i < nmods; i++) { /* output records & clear */
342 mp = (MODCONT *)lu_find(&modconttab,modname[i])->data;
343 mod_output(mp);
344 memset(mp->cbin, 0, sizeof(DCOLOR)*mp->nbins);
345 }
346 end_record(); /* end lines & flush if time */
347
348 account = accumulate; /* reset accumulation counter */
349 }
350
351
352 /* Principal calculation loop (called by main) */
353 void
354 rcontrib()
355 {
356 static int ignore_warning_given = 0;
357 FVECT orig, direc;
358 double d;
359 /* initialize & fork */
360 rcinit();
361 /* load rays from stdin & process */
362 #ifdef getc_unlocked
363 flockfile(stdin); /* avoid lock/unlock overhead */
364 #endif
365 while (getvec(orig) == 0 && getvec(direc) == 0) {
366 d = normalize(direc);
367 if ((d == 0.0) & (accumulate != 1)) {
368 if (!ignore_warning_given++)
369 error(WARNING,
370 "dummy ray(s) ignored during accumulation\n");
371 continue;
372 }
373 if (lastray+1 < lastray)
374 lastray = lastdone = 0;
375 ++lastray;
376 if (d == 0.0) { /* zero ==> flush */
377 if ((yres <= 0) | (xres <= 0))
378 waitflush = 1; /* flush right after */
379 } else { /* else compute */
380 eval_ray(orig, direc, lim_dist ? d : 0.0);
381 }
382 done_contrib(); /* accumulate/output */
383 ++lastdone;
384 if (raysleft && !--raysleft)
385 break; /* preemptive EOI */
386 }
387 if (accumulate <= 0 || account < accumulate) {
388 if (account < accumulate) {
389 error(WARNING, "partial accumulation in final record");
390 accumulate -= account;
391 }
392 account = 1; /* output accumulated totals */
393 done_contrib();
394 }
395 if (raysleft)
396 error(USER, "unexpected EOF on input");
397 lu_done(&ofiletab); /* close output files */
398 }
