Cosmetic fix
Fixed bug in rcontrib with virtual sources
Corrected default setting, which is reset anyway
Reduced specular sampling threshold, which should have never been so low!
Future bug-proofing, should have no effect on behavior or performance
Added check for 'void' modifier in -m or -M option
Fixed include dependency
Added appropriate setting of ray parameters for bin rcontrib evaluation
Added bad bin number reporting
Fixed bug in parameter parser and added check during main arguments processing
Added more careful checking of parameter setting string
Silently ignore negative bin values.
Fixed bug in handling of -c >1 with zero vectors -- trim pass to follow
Added missing setting of rt
Added missing assignment of ray intersection normal
Added check for blocked shadow rays
Moved source initialization
Accommodations for Windows
Fixed reporting of broken pipe on completion with -c N
Added quick-exit mode and fixed bug in recovery option with -c > 1
Minor fixes
Improved performance for -c 0 option
Simplified immediate irradiance call
Simplified modifier lookup
Fixed problem with recovering many files
Further efficiency improvements
Fixed a number of bugs -- still testing
Tweaks and bug fixes to new code
