root/radiance/ray/src/rt/rcontrib.c
Tue Apr 11 17:52:40 2017 UTC (7 years, 1 month ago) by greg
Diff to previous 2.29 , to selected 2.28
Reduced specular sampling threshold, which should have never been so low!
Mon Sep 12 20:31:34 2016 UTC (7 years, 8 months ago) by greg
Changes since 2.28: +8 -4 lines
Diff to previous 2.28
Revision 2.28 - (view) (download) (annotate) - [selected]
Wed Apr 27 21:11:32 2016 UTC (8 years, 1 month ago) by greg
Changes since 2.27: +5 -5 lines
Diff to previous 2.27
Future bug-proofing, should have no effect on behavior or performance
Mon Mar 21 19:06:08 2016 UTC (8 years, 2 months ago) by greg
Changes since 2.26: +12 -4 lines
Diff to previous 2.26 , to selected 2.28
Wed Jul 15 23:38:37 2015 UTC (8 years, 10 months ago) by greg
Changes since 2.25: +5 -1 lines
Diff to previous 2.25 , to selected 2.28
Added check for 'void' modifier in -m or -M option
Wed May 20 13:16:20 2015 UTC (9 years ago) by greg
Changes since 2.24: +1 -2 lines
Diff to previous 2.24 , to selected 2.28
Fixed include dependency
Wed May 20 12:58:31 2015 UTC (9 years ago) by greg
Changes since 2.23: +1 -47 lines
Diff to previous 2.23 , to selected 2.28
Added appropriate setting of ray parameters for bin rcontrib evaluation
Mon Aug 25 13:18:30 2014 UTC (9 years, 9 months ago) by greg
CVS Tags: rad4R2P1, rad4R2P2
Changes since 2.22: +3 -2 lines
Diff to previous 2.22 , to selected 2.28
Added bad bin number reporting
Sat Jul 19 20:03:03 2014 UTC (9 years, 10 months ago) by greg
CVS Tags: rad4R2
Changes since 2.21: +29 -24 lines
Diff to previous 2.21 , to selected 2.28
Fixed bug in parameter parser and added check during main arguments processing
Sat Jul 19 18:39:35 2014 UTC (9 years, 10 months ago) by greg
Changes since 2.20: +6 -5 lines
Diff to previous 2.20 , to selected 2.28
Added more careful checking of parameter setting string
Sat Jul 19 18:19:33 2014 UTC (9 years, 10 months ago) by greg
Changes since 2.19: +52 -7 lines
Diff to previous 2.19 , to selected 2.28
Sat Jul 19 00:07:03 2014 UTC (9 years, 10 months ago) by greg
Changes since 2.18: +5 -3 lines
Diff to previous 2.18 , to selected 2.28
Silently ignore negative bin values.
Thu Nov 15 19:41:03 2012 UTC (11 years, 6 months ago) by greg
Diff to previous 2.17 , to selected 2.28
Thu Nov 15 15:26:52 2012 UTC (11 years, 6 months ago) by greg
Changes since 2.16: +5 -4 lines
Diff to previous 2.16 , to selected 2.28
Fixed bug in handling of -c >1 with zero vectors -- trim pass to follow
Tue Aug 14 22:25:12 2012 UTC (11 years, 9 months ago) by greg
Diff to previous 2.15 , to selected 2.28
Added missing setting of rt
Fri Jul 13 05:07:06 2012 UTC (11 years, 10 months ago) by greg
Diff to previous 2.14 , to selected 2.28
Added missing assignment of ray intersection normal
Wed Jun 27 15:32:58 2012 UTC (11 years, 11 months ago) by greg
Changes since 2.13: +10 -4 lines
Diff to previous 2.13 , to selected 2.28
Added check for blocked shadow rays
Fri Jun 22 22:03:02 2012 UTC (11 years, 11 months ago) by greg
Changes since 2.12: +1 -5 lines
Diff to previous 2.12 , to selected 2.28
Moved source initialization
Thu Jun 21 17:14:32 2012 UTC (11 years, 11 months ago) by greg
Changes since 2.11: +1 -2 lines
Diff to previous 2.11 , to selected 2.28
Accommodations for Windows
Tue Jun 19 01:27:13 2012 UTC (11 years, 11 months ago) by greg
Diff to previous 2.10 , to selected 2.28
Fixed reporting of broken pipe on completion with -c N
Tue Jun 19 00:12:08 2012 UTC (11 years, 11 months ago) by greg
Changes since 2.9: +3 -3 lines
Diff to previous 2.9 , to selected 2.28
Added quick-exit mode and fixed bug in recovery option with -c > 1
Sat Jun 16 17:30:13 2012 UTC (11 years, 11 months ago) by greg
Diff to previous 2.8 , to selected 2.28
Minor fixes
Sat Jun 16 17:09:49 2012 UTC (11 years, 11 months ago) by greg
Changes since 2.7: +10 -12 lines
Diff to previous 2.7 , to selected 2.28
Improved performance for -c 0 option
Fri Jun 15 21:32:11 2012 UTC (11 years, 11 months ago) by greg
Changes since 2.6: +25 -30 lines
Diff to previous 2.6 , to selected 2.28
Simplified immediate irradiance call
Fri Jun 15 00:57:40 2012 UTC (11 years, 11 months ago) by greg
Changes since 2.5: +4 -35 lines
Diff to previous 2.5 , to selected 2.28
Simplified modifier lookup
Wed Jun 13 00:16:42 2012 UTC (11 years, 11 months ago) by greg
Changes since 2.4: +13 -10 lines
Diff to previous 2.4 , to selected 2.28
Fixed problem with recovering many files
Tue Jun 12 17:20:44 2012 UTC (11 years, 11 months ago) by greg
Changes since 2.3: +6 -5 lines
Diff to previous 2.3 , to selected 2.28
Further efficiency improvements
Mon Jun 11 05:07:55 2012 UTC (11 years, 11 months ago) by greg
Changes since 2.2: +4 -24 lines
Diff to previous 2.2 , to selected 2.28
Fixed a number of bugs -- still testing
Sun Jun 10 05:25:42 2012 UTC (11 years, 11 months ago) by greg
Changes since 2.1: +12 -6 lines
Diff to previous 2.1 , to selected 2.28
Tweaks and bug fixes to new code
Sat Jun 9 07:16:47 2012 UTC (11 years, 11 months ago) by greg
Diff to selected 2.28
