root/radiance/ray/src/rt/rcontrib.c
Revision: 2.47
Committed: Fri Jun 20 03:43:17 2025 UTC (6 days, 13 hours ago) by greg
fix(rvu): Issue with live reset of -u boolean and consistency improvements
2 static const char RCSid[] = "$Id: rcontrib.c,v 2.46 2024/10/23 23:51:20 greg Exp $";
5 * Accumulate ray contributions for a set of materials
6 * Initialization and calculation routines
7 */
8
9 #include "copyright.h"
10
11 #include "rcontrib.h"
12 #include "otypes.h"
13 #include "source.h"
14
15 CUBE thescene; /* our scene */
16 OBJECT nsceneobjs; /* number of objects in our scene */
17
18 int dimlist[MAXDIM]; /* sampling dimensions */
19 int ndims = 0; /* number of sampling dimensions */
20 unsigned long samplendx = 0; /* index for this sample */
21
22 void (*trace)() = NULL; /* trace call (NULL before rcinit) */
23
24 int do_irrad = 0; /* compute irradiance? */
25
26 int rand_samp = 1; /* pure Monte Carlo sampling? */
27
28 double dstrsrc = 0.9; /* square source distribution */
29 double shadthresh = 0.; /* shadow threshold */
30 double shadcert = .75; /* shadow certainty */
31 int directrelay = 3; /* number of source relays */
32 int vspretest = 512; /* virtual source pretest density */
33 int directvis = 1; /* sources visible? */
34 double srcsizerat = .2; /* maximum ratio source size/dist. */
35
36 COLOR cextinction = BLKCOLOR; /* global extinction coefficient */
37 COLOR salbedo = BLKCOLOR; /* global scattering albedo */
38 double seccg = 0.; /* global scattering eccentricity */
39 double ssampdist = 0.; /* scatter sampling distance */
40
41 double specthresh = .02; /* specular sampling threshold */
42 double specjitter = 1.; /* specular sampling jitter */
43
44 int backvis = 1; /* back face visibility */
45
46 int maxdepth = -10; /* maximum recursion depth */
47 double minweight = 2e-3; /* minimum ray weight */
48
49 char *ambfile = NULL; /* ambient file name */
50 COLOR ambval = BLKCOLOR; /* ambient value */
51 int ambvwt = 0; /* initial weight for ambient value */
52 double ambacc = 0.; /* ambient accuracy */
53 int ambres = 256; /* ambient resolution */
54 int ambdiv = 350; /* ambient divisions */
55 int ambssamp = 0; /* ambient super-samples */
56 int ambounce = 1; /* ambient bounces */
57 char *amblist[AMBLLEN+1]; /* ambient include/exclude list */
58 int ambincl = -1; /* include == 1, exclude == 0 */
59
60 int account; /* current accumulation count */
61 RNUMBER raysleft; /* number of rays left to trace */
62 long waitflush; /* how long until next flush */
63
64 RNUMBER lastray = 0; /* last ray number sent */
65 RNUMBER lastdone = 0; /* last ray output */
66
67 static void trace_contrib(RAY *r); /* our trace callback */
68
69 static void mcfree(void *p) { epfree((*(MODCONT *)p).binv,1); free(p); }
70
71 LUTAB modconttab = LU_SINIT(NULL,mcfree); /* modifier lookup table */
72
73 /************************** INITIALIZATION ROUTINES ***********************/
74
75 const char *
76 formstr( /* return format identifier */
77 int f
78 )
79 {
80 switch (f) {
81 case 'a': return("ascii");
82 case 'f': return("float");
83 case 'd': return("double");
84 case 'c': return(NCSAMP==3 ? COLRFMT : SPECFMT);
85 }
86 return("unknown");
87 }
88
89
90 /* Add modifier to our list to track */
91 MODCONT *
92 addmodifier(char *modn, char *outf, char *prms, char *binv, int bincnt)
93 {
94 static int lastNCS = 0;
95 LUENT *lep = lu_find(&modconttab,modn);
96 MODCONT *mp;
97 EPNODE *ebinv;
98 int i;
99
100 if (!lastNCS)
101 lastNCS = NCSAMP;
102 else if (NCSAMP != lastNCS)
103 error(INTERNAL,
104 "number of spectral samples must be set before first modifier");
105 if (lep->data != NULL) {
106 sprintf(errmsg, "duplicate modifier '%s'", modn);
107 error(USER, errmsg);
108 }
109 if (!strcmp(modn, VOIDID)) {
110 sprintf(errmsg, "cannot track '%s' modifier", VOIDID);
111 error(USER, errmsg);
112 }
113 if (nmods >= modasiz) { /* need bigger modifier array */
114 modasiz += modasiz/2 + 64;
115 if (modname == NULL)
116 modname = (char **)malloc(modasiz*sizeof(char *));
117 else
118 modname = (char **)realloc(modname, modasiz*sizeof(char *));
119 if (modname == NULL)
120 error(SYSTEM, "out of memory in addmodifier()");
121 }
122 modname[nmods++] = modn; /* XXX assumes static string */
123 lep->key = modn; /* XXX assumes static string */
124 if (binv == NULL)
125 binv = "0"; /* use single bin if unspecified */
126 ebinv = eparse(binv);
127 if (ebinv->type == NUM) { /* check value if constant */
128 bincnt = (int)(evalue(ebinv) + 1.5);
129 if (bincnt != 1) {
130 sprintf(errmsg, "illegal non-zero constant for bin (%s)",
131 binv);
132 error(USER, errmsg);
133 }
134 } else if (bincnt <= 0) {
135 sprintf(errmsg,
136 "unspecified or illegal bin count for modifier '%s'",
137 modn);
138 error(USER, errmsg);
139 }
140 /* initialize results holder */
141 mp = (MODCONT *)malloc(mcsize(bincnt));
142 if (mp == NULL)
143 error(SYSTEM, "out of memory in addmodifier");
144 mp->outspec = outf; /* XXX assumes static string */
145 mp->modname = modn; /* XXX assumes static string */
146 mp->params = prms; /* XXX assumes static string */
147 mp->binv = ebinv;
148 mp->bin0 = 0;
149 mp->nbins = bincnt;
150 memset(mp->cbin, 0, DCOLORSIZ*bincnt);
151 /* figure out starting bin */
152 while (!getostream(mp->outspec, mp->modname, mp->bin0, 1))
153 mp->bin0++;
154 /* allocate other output streams */
155 for (i = 0; ++i < mp->nbins; )
156 getostream(mp->outspec, mp->modname, mp->bin0+i, 1);
157 lep->data = (char *)mp;
158 return(mp);
159 }
160
161
162 /* Add modifiers from a file list */
163 void
164 addmodfile(char *fname, char *outf, char *prms, char *binv, int bincnt)
165 {
166 char *path = getpath(fname, getrlibpath(), R_OK);
167 char mod[MAXSTR];
168 FILE *fp;
169
170 if (path == NULL || (fp = fopen(path, "r")) == NULL) {
171 if (path == NULL)
172 sprintf(errmsg, "cannot find modifier file '%s'", fname);
173 else
174 sprintf(errmsg, "cannot load modifier file '%s'", path);
175 error(SYSTEM, errmsg);
176 }
177 while (fgetword(mod, sizeof(mod), fp) != NULL)
178 addmodifier(savqstr(mod), outf, prms, binv, bincnt);
179 fclose(fp);
180 }
181
182
183 /* Check if we have any more rays left (and report progress) */
184 int
185 morays(void)
186 {
187 static RNUMBER total_rays;
188 static time_t tstart, last_report;
189 time_t tnow;
190
191 if (!raysleft)
192 return(1); /* unknown total, so nothing to do or say */
193
194 if (report_intvl > 0 && (tnow = time(0)) >= last_report+report_intvl) {
195 if (!total_rays) {
196 total_rays = raysleft;
197 tstart = tnow;
198 } else {
199 sprintf(errmsg, "%.2f%% done after %.3f hours\n",
200 100.-100.*raysleft/total_rays,
201 (1./3600.)*(tnow - tstart));
202 eputs(errmsg);
203 }
204 last_report = tnow;
205 }
206 return(--raysleft);
207 }
208
209
210 /* Quit program */
211 void
212 quit(
213 int code
214 )
215 {
216 if (nchild > 0) /* close children if any */
217 end_children(code != 0);
218 else if (nchild < 0)
219 _exit(code); /* avoid flush() in child */
220 exit(code);
221 }
222
223
224 /* Initialize our process(es) */
225 static void
226 rcinit(void)
227 {
228 int i;
229
230 if (nproc > MAXPROCESS)
231 sprintf(errmsg, "too many processes requested -- reducing to %d",
232 nproc = MAXPROCESS);
233 if (nproc > 1)
234 cow_memshare(); /* preload auxiliary data */
235 trace = trace_contrib; /* set up trace call-back */
236 for (i = 0; i < nsources; i++) /* tracing to sources as well */
237 source[i].sflags |= SFOLLOW;
238 if (yres > 0) { /* set up flushing & ray counts */
239 if (xres > 0)
240 raysleft = (RNUMBER)xres*yres;
241 else
242 raysleft = yres;
243 } else
244 raysleft = 0;
245 if ((account = accumulate) > 1)
246 raysleft *= accumulate;
247 waitflush = (yres > 0) & (xres > 1) ? 0 : xres;
248
249 if (nproc > 1 && in_rchild()) /* forked child? */
250 return; /* return to main processing loop */
251
252 if (recover) { /* recover previous output? */
253 if (accumulate <= 0)
254 reload_output();
255 else
256 recover_output();
257 }
258 if (nproc == 1) /* single process? */
259 return;
260 /* else run appropriate controller */
261 if (accumulate <= 0)
262 feeder_loop();
263 else
264 parental_loop();
265 quit(0); /* parent musn't return! */
266 }
267
268 /************************** MAIN CALCULATION PROCESS ***********************/
269
270 /* Our trace call to sum contributions */
271 static void
272 trace_contrib(RAY *r)
273 {
274 MODCONT *mp;
275 double bval;
276 int bn;
277 SCOLOR contr;
278 DCOLORV *dvp;
279 int i;
280
281 if (r->ro == NULL || r->ro->omod == OVOID)
282 return;
283 /* shadow ray not on source? */
284 if (r->rsrc >= 0 && source[r->rsrc].so != r->ro)
285 return;
286
287 mp = (MODCONT *)lu_find(&modconttab,objptr(r->ro->omod)->oname)->data;
288
289 if (mp == NULL) /* not in our list? */
290 return;
291
292 worldfunc(RCCONTEXT, r); /* else set context */
293 set_eparams((char *)mp->params);
294 if ((bval = evalue(mp->binv)) <= -.5) /* and get bin number */
295 return; /* silently ignore negatives */
296 if ((bn = (int)(bval + .5)) >= mp->nbins) {
297 sprintf(errmsg, "bad bin number (%d ignored)", bn);
298 error(WARNING, errmsg);
299 return;
300 }
301 raycontrib(contr, r, PRIMARY); /* compute coefficient */
302 if (contrib)
303 smultscolor(contr, r->rcol); /* -> contribution */
304 dvp = mcbin(mp, bn);
305 for (i = 0; i < NCSAMP; i++) /* add it in */
306 *dvp++ += contr[i];
307 }
308
309
310 /* Evaluate irradiance contributions */
311 static void
312 eval_irrad(FVECT org, FVECT dir)
313 {
314 RAY thisray;
315
316 VSUM(thisray.rorg, org, dir, 1.1e-4);
317 thisray.rdir[0] = -dir[0];
318 thisray.rdir[1] = -dir[1];
319 thisray.rdir[2] = -dir[2];
320 thisray.rmax = 0.0;
321 rayorigin(&thisray, PRIMARY, NULL, NULL);
322 /* pretend we hit surface */
323 thisray.rxt = thisray.rot = 1e-5;
324 thisray.rod = 1.0;
325 VCOPY(thisray.ron, dir);
326 VSUM(thisray.rop, org, dir, 1e-4);
327 samplendx++; /* compute result */
328 (*ofun[Lamb.otype].funp)(&Lamb, &thisray);
329 }
330
331
332 /* Evaluate radiance contributions */
333 static void
334 eval_rad(FVECT org, FVECT dir, double dmax)
335 {
336 RAY thisray;
337 /* set up ray */
338 VCOPY(thisray.rorg, org);
339 VCOPY(thisray.rdir, dir);
340 thisray.rmax = dmax;
341 rayorigin(&thisray, PRIMARY, NULL, NULL);
342 samplendx++; /* call ray evaluation */
343 rayvalue(&thisray);
344 }
345
346
347 /* Accumulate and/or output ray contributions (child or only process) */
348 static void
349 done_contrib(void)
350 {
351 MODCONT *mp;
352 int i;
353
354 if (account <= 0 || --account)
355 return; /* not time yet */
356
357 for (i = 0; i < nmods; i++) { /* output records & clear */
358 mp = (MODCONT *)lu_find(&modconttab,modname[i])->data;
359 mod_output(mp);
360 memset(mp->cbin, 0, DCOLORSIZ*mp->nbins);
361 }
362 end_record(); /* end lines & flush if time */
363
364 account = accumulate; /* reset accumulation counter */
365 }
366
367
368 /* Principal calculation loop (called by main) */
369 void
370 rcontrib(void)
371 {
372 static int ignore_warning_given = 0;
373 FVECT orig, direc;
374 double d;
375 /* initialize (& fork more of us) */
376 rcinit();
377 /* load rays from stdin & process */
378 #ifdef getc_unlocked
379 flockfile(stdin); /* avoid mutex overhead */
380 #endif
381 while (getvec(orig) == 0 && getvec(direc) == 0) {
382 d = normalize(direc);
383 if (nchild != -1 && (d == 0.0) & (accumulate == 0)) {
384 if (!ignore_warning_given++)
385 error(WARNING,
386 "dummy ray(s) ignored during accumulation\n");
387 continue;
388 }
389 if (lastray+1 < lastray)
390 lastray = lastdone = 0;
391 ++lastray;
392 if (d == 0.0) { /* zero ==> flush */
393 if ((yres <= 0) | (xres <= 1))
394 waitflush = 1; /* flush after */
395 if (nchild == -1)
396 account = 1;
397 } else if (imm_irrad) { /* else compute */
398 eval_irrad(orig, direc);
399 } else {
400 eval_rad(orig, direc, lim_dist ? d : 0.0);
401 }
402 done_contrib(); /* accumulate/output */
403 ++lastdone;
404 if (!morays())
405 break; /* preemptive EOI */
406 }
407 if (nchild != -1 && (accumulate <= 0) | (account < accumulate)) {
408 if (account < accumulate) {
409 error(WARNING, "partial accumulation in final record");
410 accumulate -= account;
411 }
412 account = 1; /* output accumulated totals */
413 done_contrib();
414 }
415 lu_done(&ofiletab); /* close output files */
416 if (raysleft)
417 error(USER, "unexpected EOF on input");
418 }
