root/radiance/ray/src/rt/rcmain.c
Revision: 2.36
Committed: Fri Apr 5 16:41:17 2024 UTC (7 weeks, 1 day ago) by greg
Changes since 2.35: +5 -3 lines
feat(rpict,rtrace,rcontrib): Added OutputCS to features list
2 static const char RCSid[] = "$Id: rcmain.c,v 2.35 2024/01/18 00:28:54 greg Exp $";
5 * rcmain.c - main for rtcontrib ray contribution tracer
6 */
7
8 #include "copyright.h"
9
10 #include <signal.h>
11 #include <time.h>
12 #include "rcontrib.h"
13 #include "random.h"
14 #include "source.h"
15 #include "ambient.h"
16 #include "pmapray.h"
17 #include "pmapcontrib.h"
18
19 int gargc; /* global argc */
20 char **gargv; /* global argv */
21 char *octname; /* global octree name */
22 char *progname; /* global argv[0] */
23
24 char *sigerr[NSIG]; /* signal error messages */
25
26 int nproc = 1; /* number of processes requested */
27 int nchild = 0; /* number of children (-1 in child) */
28
29 int inpfmt = 'a'; /* input format */
30 int outfmt = 'a'; /* output format */
31
32 int header = 1; /* output header? */
33 int force_open = 0; /* truncate existing output? */
34 int recover = 0; /* recover previous output? */
35 int accumulate = 1; /* input rays per output record */
36 int contrib = 0; /* computing contributions? */
37
38 int xres = 0; /* horizontal (scan) size */
39 int yres = 0; /* vertical resolution */
40
41 int using_stdout = 0; /* are we using stdout? */
42
43 int imm_irrad = 0; /* compute immediate irradiance? */
44 int lim_dist = 0; /* limit distance? */
45
46 int report_intvl = 0; /* reporting interval (seconds) */
47
48 char **modname = NULL; /* ordered modifier name list */
49 int nmods = 0; /* number of modifiers */
50 int modasiz = 0; /* allocated modifier array size */
51
52 void (*addobjnotify[8])() = {ambnotify, NULL};
53
54 char RCCONTEXT[] = "RC."; /* our special evaluation context */
55
56 #if defined(_WIN32) || defined(_WIN64)
57 #define RCONTRIB_FEATURES "Accumulation\nSummation\nRecovery\n" \
58 "ImmediateIrradiance\n" \
59 "ProgressReporting\nDistanceLimiting\n" \
60 "InputFormats=a,f,d\nOutputFormats=a,f,d,c\n" \
61 "Outputs=V,W\n" \
62 "OutputCS=RGB,spec\n"
63 #else
64 #define RCONTRIB_FEATURES "Multiprocessing\n" \
65 "Accumulation\nSummation\nRecovery\n" \
66 "ImmediateIrradiance\n" \
67 "ProgressReporting\nDistanceLimiting\n" \
68 "InputFormats=a,f,d\nOutputFormats=a,f,d,c\n" \
69 "Outputs=V,W\n" \
70 "OutputCS=RGB,spec\n"
71 #endif
72
73 static void
74 printdefaults(void) /* print default values to stdout */
75 {
76 printf("-c %-5d\t\t\t# accumulated rays per record\n", accumulate);
77 printf("-V%c\t\t\t\t# output %s\n", contrib ? '+' : '-',
78 contrib ? "contributions" : "coefficients");
79 if (imm_irrad)
80 printf("-I+\t\t\t\t# immediate irradiance on\n");
81 printf("-n %-2d\t\t\t\t# number of rendering processes\n", nproc);
82 printf("-x %-9d\t\t\t# %s\n", xres,
83 yres && xres ? "x resolution" : "flush interval");
84 printf("-y %-9d\t\t\t# y resolution\n", yres);
85 printf(lim_dist ? "-ld+\t\t\t\t# limit distance on\n" :
86 "-ld-\t\t\t\t# limit distance off\n");
87 printf(header ? "-h+\t\t\t\t# output header\n" :
88 "-h-\t\t\t\t# no header\n");
89 printf("-f%c%c\t\t\t\t# format input/output = %s/%s\n",
90 inpfmt, outfmt, formstr(inpfmt), formstr(outfmt));
91 printf(erract[WARNING].pf != NULL ?
92 "-w+\t\t\t\t# warning messages on\n" :
93 "-w-\t\t\t\t# warning messages off\n");
94 print_rdefaults();
95 }
96
97
98 static void
99 onsig( /* fatal signal */
100 int signo
101 )
102 {
103 static int gotsig = 0;
104
105 if (gotsig++) /* two signals and we're gone! */
106 _exit(signo);
107
108 #ifdef SIGALRM
109 alarm(15); /* allow 15 seconds to clean up */
110 signal(SIGALRM, SIG_DFL); /* make certain we do die */
111 #endif
112 eputs("signal - ");
113 eputs(sigerr[signo]);
114 eputs("\n");
115 quit(3);
116 }
117
118
119 static void
120 sigdie( /* set fatal signal */
121 int signo,
122 char *msg
123 )
124 {
125 if (signal(signo, onsig) == SIG_IGN)
126 signal(signo, SIG_IGN);
127 sigerr[signo] = msg;
128 }
129
130
131 /* set input/output format */
132 static void
133 setformat(const char *fmt)
134 {
135 switch (fmt[0]) {
136 case 'f':
137 case 'd':
138 SET_FILE_BINARY(stdin);
139 /* fall through */
140 case 'a':
141 inpfmt = fmt[0];
142 break;
143 default:
144 goto fmterr;
145 }
146 switch (fmt[1]) {
147 case '\0':
148 outfmt = inpfmt;
149 return;
150 case 'a':
151 case 'f':
152 case 'd':
153 case 'c':
154 outfmt = fmt[1];
155 break;
156 default:
157 goto fmterr;
158 }
159 if (!fmt[2])
160 return;
161 fmterr:
162 sprintf(errmsg, "Illegal i/o format: -f%s", fmt);
163 error(USER, errmsg);
164 }
165
166
167 /* Set overriding options */
168 static void
169 override_options(void)
170 {
171 shadthresh = 0;
172 ambssamp = 0;
173 ambacc = 0;
174 if (accumulate <= 0) /* no output flushing for single record */
175 xres = yres = 0;
176 }
177
178
179 int
180 main(int argc, char *argv[])
181 {
182 #define check(ol,al) if (argv[i][ol] || \
183 badarg(argc-i-1,argv+i+1,al)) \
184 goto badopt
185 #define check_bool(olen,var) switch (argv[i][olen]) { \
186 case '\0': var = !var; break; \
187 case 'y': case 'Y': case 't': case 'T': \
188 case '+': case '1': var = 1; break; \
189 case 'n': case 'N': case 'f': case 'F': \
190 case '-': case '0': var = 0; break; \
191 default: goto badopt; }
192 char *curout = NULL;
193 char *prms = NULL;
194 char *binval = NULL;
195 int bincnt = 0;
196 int rval;
197 int i;
198 /* global program name */
199 progname = argv[0] = fixargv0(argv[0]);
200 gargv = argv;
201 gargc = argc;
202 /* feature check only? */
203 strcat(RFeatureList, RCONTRIB_FEATURES);
204 if (argc > 1 && !strcmp(argv[1], "-features"))
205 return feature_status(argc-2, argv+2);
206 #if defined(_WIN32) || defined(_WIN64) /* increase file limit to maximum */
207 for (i = 8192; i > _IOB_ENTRIES; i >>= 1)
208 if (_setmaxstdio(i) == i)
209 break;
210 #endif
211 /* initialize calcomp routines early */
212 initfunc();
213 calcontext(RCCONTEXT);
214 /* option city */
215 for (i = 1; i < argc; i++) {
216 /* expand arguments */
217 while ((rval = expandarg(&argc, &argv, i)) > 0)
218 ;
219 if (rval < 0) {
220 sprintf(errmsg, "cannot expand '%s'", argv[i]);
221 error(SYSTEM, errmsg);
222 }
223 if (argv[i] == NULL || argv[i][0] != '-')
224 break; /* break from options */
225 if (!strcmp(argv[i], "-version")) {
226 puts(VersionID);
227 quit(0);
228 }
229 if (!strcmp(argv[i], "-defaults") ||
230 !strcmp(argv[i], "-help")) {
231 override_options();
232 printdefaults();
233 quit(0);
234 }
235 rval = getrenderopt(argc-i, argv+i);
236 if (rval >= 0) {
237 i += rval;
238 continue;
239 }
240 switch (argv[i][1]) {
241 case 'n': /* number of cores */
242 check(2,"i");
243 nproc = atoi(argv[++i]);
244 if (nproc <= 0)
245 error(USER, "bad number of processes");
246 break;
247 case 'V': /* output contributions */
248 check_bool(2,contrib);
249 break;
250 case 'x': /* x resolution */
251 check(2,"i");
252 xres = atoi(argv[++i]);
253 break;
254 case 'y': /* y resolution */
255 check(2,"i");
256 yres = atoi(argv[++i]);
257 break;
258 case 'w': /* warnings */
259 rval = (erract[WARNING].pf != NULL);
260 check_bool(2,rval);
261 if (rval) erract[WARNING].pf = wputs;
262 else erract[WARNING].pf = NULL;
263 break;
264 case 'e': /* expression */
265 check(2,"s");
266 scompile(argv[++i], NULL, 0);
267 break;
268 case 'l': /* limit distance */
269 if (argv[i][2] != 'd')
270 goto badopt;
271 check_bool(3,lim_dist);
272 break;
273 case 'I': /* immed. irradiance */
274 check_bool(2,imm_irrad);
275 break;
276 case 'f': /* file or force or format */
277 if (!argv[i][2]) {
278 check(2,"s");
279 loadfunc(argv[++i]);
280 break;
281 }
282 if (argv[i][2] == 'o') {
283 check_bool(3,force_open);
284 break;
285 }
286 setformat(argv[i]+2);
287 break;
288 case 'o': /* output */
289 check(2,"s");
290 curout = argv[++i];
291 break;
292 case 'r': /* recover output */
293 check_bool(2,recover);
294 break;
295 case 'h': /* header output */
296 check_bool(2,header);
297 break;
298 case 'p': /* parameter setting(s) */
299 check(2,"s");
300 set_eparams(prms = argv[++i]);
301 break;
302 case 'c': /* sample count */
303 check(2,"i");
304 accumulate = atoi(argv[++i]);
305 break;
306 case 'b': /* bin expression/count */
307 if (argv[i][2] == 'n') {
308 check(3,"s");
309 bincnt = (int)(eval(argv[++i]) + .5);
310 break;
311 }
312 check(2,"s");
313 binval = argv[++i];
314 break;
315 case 'm': /* modifier name */
316 check(2,"s");
317 addmodifier(argv[++i], curout, prms, binval, bincnt);
318 break;
319 case 'M': /* modifier file */
320 check(2,"s");
321 addmodfile(argv[++i], curout, prms, binval, bincnt);
322 break;
323 case 't': /* reporting interval */
324 check(2,"i");
325 report_intvl = atoi(argv[++i]);
326 break;
327 default:
328 goto badopt;
329 }
330 }
331 if (nmods <= 0)
332 error(USER, "missing required modifier argument");
333 /* override some option settings */
334 override_options();
335 /* set/check spectral sampling */
336 if (setspectrsamp(CNDX, WLPART) < 0)
337 error(USER, "unsupported spectral sampling");
338 /* initialize object types */
339 initotypes();
340 /* initialize urand */
341 if (rand_samp) {
342 srandom((long)time(0));
343 initurand(0);
344 } else {
345 srandom(0L);
346 initurand(2048);
347 }
348 /* set up signal handling */
349 sigdie(SIGINT, "Interrupt");
350 #ifdef SIGHUP
351 sigdie(SIGHUP, "Hangup");
352 #endif
353 sigdie(SIGTERM, "Terminate");
354 #ifdef SIGPIPE
355 sigdie(SIGPIPE, "Broken pipe");
356 #endif
357 #ifdef SIGALRM
358 sigdie(SIGALRM, "Alarm clock");
359 #endif
360 #ifdef SIGXCPU
361 sigdie(SIGXCPU, "CPU limit exceeded");
362 sigdie(SIGXFSZ, "File size exceeded");
363 #endif
364 #ifdef NICE
365 nice(NICE); /* lower priority */
366 #endif
367 /* get octree */
368 if (i == argc)
369 octname = NULL;
370 else if (i == argc-1)
371 octname = argv[i];
372 else
373 goto badopt;
374 if (octname == NULL)
375 error(USER, "missing octree argument");
376
377 readoct(octname, ~(IO_FILES|IO_INFO), &thescene, NULL);
378 nsceneobjs = nobjects;
379
380 /* PMAP: set up & load photon maps */
381 ray_init_pmap();
382
383 marksources(); /* find and mark sources */
384
385 /* PMAP: init photon map for light source contributions */
386 initPmapContrib(&modconttab, nmods);
387
388 setambient(); /* initialize ambient calculation */
389
390 rcontrib(); /* trace ray contributions (loop) */
391
392 ambsync(); /* flush ambient file */
393
394 /* PMAP: free photon maps */
395 ray_done_pmap();
396
397 quit(0); /* exit clean */
398
399 badopt:
400 fprintf(stderr,
401 "Usage: %s [-n nprocs][-V][-c count][-r][-e expr][-f source][-o ospec][-p p1=V1,p2=V2][-b binv][-bn N] {-m mod | -M file} [rtrace options] octree\n",
402 progname);
403 sprintf(errmsg, "command line error at '%s'", argv[i]);
404 error(USER, errmsg);
405 return(1); /* pro forma return */
406
407 #undef check
408 #undef check_bool
409 }
410
411
412 void
413 wputs( /* warning output function */
414 const char *s
415 )
416 {
417 int lasterrno = errno;
418 eputs(s);
419 errno = lasterrno;
420 }
421
422
423 void
424 eputs( /* put string to stderr */
425 const char *s
426 )
427 {
428 static int midline = 0;
429
430 if (!*s)
431 return;
432 if (!midline++) {
433 fputs(progname, stderr);
434 fputs(": ", stderr);
435 }
436 fputs(s, stderr);
437 if (s[strlen(s)-1] == '\n') {
438 fflush(stderr);
439 midline = 0;
440 }
441 }
