--- ray/src/rt/rcmain.c 2018/01/18 19:43:43 2.18 +++ ray/src/rt/rcmain.c 2024/04/05 16:41:17 2.36 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rcmain.c,v 2.18 2018/01/18 19:43:43 greg Exp $"; +static const char RCSid[] = "$Id: rcmain.c,v 2.36 2024/04/05 16:41:17 greg Exp $"; #endif /* * rcmain.c - main for rtcontrib ray contribution tracer @@ -43,13 +43,32 @@ int using_stdout = 0; /* are we using stdout? */ int imm_irrad = 0; /* compute immediate irradiance? */ int lim_dist = 0; /* limit distance? */ -const char *modname[MAXMODLIST]; /* ordered modifier name list */ -int nmods = 0; /* number of modifiers */ +int report_intvl = 0; /* reporting interval (seconds) */ +char **modname = NULL; /* ordered modifier name list */ +int nmods = 0; /* number of modifiers */ +int modasiz = 0; /* allocated modifier array size */ + void (*addobjnotify[8])() = {ambnotify, NULL}; char RCCONTEXT[] = "RC."; /* our special evaluation context */ +#if defined(_WIN32) || defined(_WIN64) +#define RCONTRIB_FEATURES "Accumulation\nSummation\nRecovery\n" \ + "ImmediateIrradiance\n" \ + "ProgressReporting\nDistanceLimiting\n" \ + "InputFormats=a,f,d\nOutputFormats=a,f,d,c\n" \ + "Outputs=V,W\n" \ + "OutputCS=RGB,spec\n" +#else +#define RCONTRIB_FEATURES "Multiprocessing\n" \ + "Accumulation\nSummation\nRecovery\n" \ + "ImmediateIrradiance\n" \ + "ProgressReporting\nDistanceLimiting\n" \ + "InputFormats=a,f,d\nOutputFormats=a,f,d,c\n" \ + "Outputs=V,W\n" \ + "OutputCS=RGB,spec\n" +#endif static void printdefaults(void) /* print default values to stdout */ @@ -65,8 +84,8 @@ printdefaults(void) /* print default values to stdou printf("-y %-9d\t\t\t# y resolution\n", yres); printf(lim_dist ? "-ld+\t\t\t\t# limit distance on\n" : "-ld-\t\t\t\t# limit distance off\n"); - printf("-h%c\t\t\t\t# %s header\n", header ? '+' : '-', - header ? "output" : "no"); + printf(header ? "-h+\t\t\t\t# output header\n" : + "-h-\t\t\t\t# no header\n"); printf("-f%c%c\t\t\t\t# format input/output = %s/%s\n", inpfmt, outfmt, formstr(inpfmt), formstr(outfmt)); printf(erract[WARNING].pf != NULL ? @@ -180,12 +199,18 @@ main(int argc, char *argv[]) progname = argv[0] = fixargv0(argv[0]); gargv = argv; gargc = argc; -#if defined(_WIN32) || defined(_WIN64) - _setmaxstdio(2048); /* increase file limit to maximum */ + /* feature check only? */ + strcat(RFeatureList, RCONTRIB_FEATURES); + if (argc > 1 && !strcmp(argv[1], "-features")) + return feature_status(argc-2, argv+2); +#if defined(_WIN32) || defined(_WIN64) /* increase file limit to maximum */ + for (i = 8192; i > _IOB_ENTRIES; i >>= 1) + if (_setmaxstdio(i) == i) + break; #endif /* initialize calcomp routines early */ initfunc(); - setcontext(RCCONTEXT); + calcontext(RCCONTEXT); /* option city */ for (i = 1; i < argc; i++) { /* expand arguments */ @@ -264,10 +289,6 @@ main(int argc, char *argv[]) check(2,"s"); curout = argv[++i]; break; - case 'c': /* input rays per output */ - check(2,"i"); - accumulate = atoi(argv[++i]); - break; case 'r': /* recover output */ check_bool(2,recover); break; @@ -278,6 +299,10 @@ main(int argc, char *argv[]) check(2,"s"); set_eparams(prms = argv[++i]); break; + case 'c': /* sample count */ + check(2,"i"); + accumulate = atoi(argv[++i]); + break; case 'b': /* bin expression/count */ if (argv[i][2] == 'n') { check(3,"s"); @@ -295,6 +320,10 @@ main(int argc, char *argv[]) check(2,"s"); addmodfile(argv[++i], curout, prms, binval, bincnt); break; + case 't': /* reporting interval */ + check(2,"i"); + report_intvl = atoi(argv[++i]); + break; default: goto badopt; } @@ -303,6 +332,9 @@ main(int argc, char *argv[]) error(USER, "missing required modifier argument"); /* override some option settings */ override_options(); + /* set/check spectral sampling */ + if (setspectrsamp(CNDX, WLPART) < 0) + error(USER, "unsupported spectral sampling"); /* initialize object types */ initotypes(); /* initialize urand */ @@ -379,7 +411,7 @@ badopt: void wputs( /* warning output function */ - char *s + const char *s ) { int lasterrno = errno; @@ -390,7 +422,7 @@ wputs( /* warning output function */ void eputs( /* put string to stderr */ - char *s + const char *s ) { static int midline = 0;
