root/Development/ray/src/rt/rcmain.c
Revision: 2.43
Committed: Fri Jun 20 16:34:23 2025 UTC (4 months, 2 weeks ago) by greg
CVS Tags: rad6R0, HEAD
fix: Avoid array bounds errors in dimlist[] in deep ray trees
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.43 static const char RCSid[] = "$Id: rcmain.c,v 2.42 2025/06/05 18:26:46 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * rcmain.c - main for rtcontrib ray contribution tracer
6     */
7
8     #include "copyright.h"
9
10     #include <signal.h>
11 greg 2.10 #include <time.h>
12 greg 2.1 #include "rcontrib.h"
13 greg 2.6 #include "random.h"
14 greg 2.1 #include "source.h"
15     #include "ambient.h"
16 greg 2.14 #include "pmapray.h"
17     #include "pmapcontrib.h"
18 greg 2.1
19     int gargc; /* global argc */
20     char **gargv; /* global argv */
21     char *octname; /* global octree name */
22
23     char *sigerr[NSIG]; /* signal error messages */
24
25     int nproc = 1; /* number of processes requested */
26     int nchild = 0; /* number of children (-1 in child) */
27
28     int inpfmt = 'a'; /* input format */
29     int outfmt = 'a'; /* output format */
30
31     int header = 1; /* output header? */
32     int force_open = 0; /* truncate existing output? */
33     int recover = 0; /* recover previous output? */
34     int accumulate = 1; /* input rays per output record */
35     int contrib = 0; /* computing contributions? */
36
37     int xres = 0; /* horizontal (scan) size */
38     int yres = 0; /* vertical resolution */
39
40     int using_stdout = 0; /* are we using stdout? */
41
42     int imm_irrad = 0; /* compute immediate irradiance? */
43     int lim_dist = 0; /* limit distance? */
44
45 greg 2.19 int report_intvl = 0; /* reporting interval (seconds) */
46
47 greg 2.20 char **modname = NULL; /* ordered modifier name list */
48     int nmods = 0; /* number of modifiers */
49     int modasiz = 0; /* allocated modifier array size */
50 greg 2.1
51 greg 2.43 void (*addobjnotify[])() = {ambnotify, NULL};
52 greg 2.4
53 greg 2.18 char RCCONTEXT[] = "RC."; /* our special evaluation context */
54 greg 2.1
55 greg 2.22 #if defined(_WIN32) || defined(_WIN64)
56 greg 2.23 #define RCONTRIB_FEATURES "Accumulation\nSummation\nRecovery\n" \
57 greg 2.33 "ImmediateIrradiance\n" \
58 greg 2.24 "ProgressReporting\nDistanceLimiting\n" \
59 greg 2.31 "InputFormats=a,f,d\nOutputFormats=a,f,d,c\n" \
60 greg 2.36 "Outputs=V,W\n" \
61     "OutputCS=RGB,spec\n"
62 greg 2.22 #else
63     #define RCONTRIB_FEATURES "Multiprocessing\n" \
64 greg 2.23 "Accumulation\nSummation\nRecovery\n" \
65 greg 2.33 "ImmediateIrradiance\n" \
66 greg 2.24 "ProgressReporting\nDistanceLimiting\n" \
67 greg 2.31 "InputFormats=a,f,d\nOutputFormats=a,f,d,c\n" \
68 greg 2.36 "Outputs=V,W\n" \
69     "OutputCS=RGB,spec\n"
70 greg 2.22 #endif
71 greg 2.1
72     static void
73     printdefaults(void) /* print default values to stdout */
74     {
75 greg 2.3 printf("-c %-5d\t\t\t# accumulated rays per record\n", accumulate);
76     printf("-V%c\t\t\t\t# output %s\n", contrib ? '+' : '-',
77     contrib ? "contributions" : "coefficients");
78 greg 2.1 if (imm_irrad)
79     printf("-I+\t\t\t\t# immediate irradiance on\n");
80     printf("-n %-2d\t\t\t\t# number of rendering processes\n", nproc);
81     printf("-x %-9d\t\t\t# %s\n", xres,
82     yres && xres ? "x resolution" : "flush interval");
83     printf("-y %-9d\t\t\t# y resolution\n", yres);
84     printf(lim_dist ? "-ld+\t\t\t\t# limit distance on\n" :
85     "-ld-\t\t\t\t# limit distance off\n");
86 greg 2.32 printf(header ? "-h+\t\t\t\t# output header\n" :
87     "-h-\t\t\t\t# no header\n");
88 greg 2.1 printf("-f%c%c\t\t\t\t# format input/output = %s/%s\n",
89     inpfmt, outfmt, formstr(inpfmt), formstr(outfmt));
90 greg 2.37 if (report_intvl > 0)
91     printf("-t %-9d\t\t\t# time between reports\n", report_intvl);
92 greg 2.1 printf(erract[WARNING].pf != NULL ?
93     "-w+\t\t\t\t# warning messages on\n" :
94     "-w-\t\t\t\t# warning messages off\n");
95     print_rdefaults();
96     }
97
98
99     static void
100     onsig( /* fatal signal */
101     int signo
102     )
103     {
104     static int gotsig = 0;
105
106     if (gotsig++) /* two signals and we're gone! */
107     _exit(signo);
108
109     #ifdef SIGALRM
110     alarm(15); /* allow 15 seconds to clean up */
111     signal(SIGALRM, SIG_DFL); /* make certain we do die */
112     #endif
113     eputs("signal - ");
114     eputs(sigerr[signo]);
115     eputs("\n");
116     quit(3);
117     }
118
119
120     static void
121     sigdie( /* set fatal signal */
122     int signo,
123     char *msg
124     )
125     {
126     if (signal(signo, onsig) == SIG_IGN)
127     signal(signo, SIG_IGN);
128     sigerr[signo] = msg;
129     }
130
131
132     /* set input/output format */
133     static void
134     setformat(const char *fmt)
135     {
136     switch (fmt[0]) {
137     case 'f':
138     case 'd':
139     SET_FILE_BINARY(stdin);
140     /* fall through */
141     case 'a':
142     inpfmt = fmt[0];
143     break;
144     default:
145     goto fmterr;
146     }
147     switch (fmt[1]) {
148     case '\0':
149     outfmt = inpfmt;
150     return;
151     case 'a':
152     case 'f':
153     case 'd':
154     case 'c':
155     outfmt = fmt[1];
156     break;
157     default:
158     goto fmterr;
159     }
160     if (!fmt[2])
161     return;
162     fmterr:
163     sprintf(errmsg, "Illegal i/o format: -f%s", fmt);
164     error(USER, errmsg);
165     }
166
167
168     /* Set overriding options */
169     static void
170     override_options(void)
171     {
172     shadthresh = 0;
173     ambssamp = 0;
174     ambacc = 0;
175     if (accumulate <= 0) /* no output flushing for single record */
176     xres = yres = 0;
177     }
178
179
180     int
181     main(int argc, char *argv[])
182     {
183     #define check(ol,al) if (argv[i][ol] || \
184     badarg(argc-i-1,argv+i+1,al)) \
185     goto badopt
186 schorsch 2.15 #define check_bool(olen,var) switch (argv[i][olen]) { \
187 greg 2.1 case '\0': var = !var; break; \
188     case 'y': case 'Y': case 't': case 'T': \
189     case '+': case '1': var = 1; break; \
190     case 'n': case 'N': case 'f': case 'F': \
191     case '-': case '0': var = 0; break; \
192     default: goto badopt; }
193     char *curout = NULL;
194 greg 2.12 char *prms = NULL;
195 greg 2.1 char *binval = NULL;
196     int bincnt = 0;
197     int rval;
198     int i;
199     /* global program name */
200 greg 2.41 argv[0] = fixargv0(argv[0]);
201 greg 2.1 gargv = argv;
202     gargc = argc;
203 greg 2.22 /* feature check only? */
204     strcat(RFeatureList, RCONTRIB_FEATURES);
205 greg 2.26 if (argc > 1 && !strcmp(argv[1], "-features"))
206 greg 2.22 return feature_status(argc-2, argv+2);
207 greg 2.28 #if defined(_WIN32) || defined(_WIN64) /* increase file limit to maximum */
208     for (i = 8192; i > _IOB_ENTRIES; i >>= 1)
209 greg 2.30 if (_setmaxstdio(i) == i)
210 greg 2.28 break;
211 greg 2.17 #endif
212 greg 2.40 initfunc(); /* initialize calcomp routines */
213 greg 2.21 calcontext(RCCONTEXT);
214 greg 2.1 /* option city */
215     for (i = 1; i < argc; i++) {
216     /* expand arguments */
217     while ((rval = expandarg(&argc, &argv, i)) > 0)
218     ;
219     if (rval < 0) {
220     sprintf(errmsg, "cannot expand '%s'", argv[i]);
221     error(SYSTEM, errmsg);
222     }
223     if (argv[i] == NULL || argv[i][0] != '-')
224     break; /* break from options */
225     if (!strcmp(argv[i], "-version")) {
226     puts(VersionID);
227     quit(0);
228     }
229     if (!strcmp(argv[i], "-defaults") ||
230     !strcmp(argv[i], "-help")) {
231     override_options();
232     printdefaults();
233     quit(0);
234     }
235     rval = getrenderopt(argc-i, argv+i);
236     if (rval >= 0) {
237     i += rval;
238     continue;
239     }
240     switch (argv[i][1]) {
241     case 'n': /* number of cores */
242     check(2,"i");
243     nproc = atoi(argv[++i]);
244     if (nproc <= 0)
245     error(USER, "bad number of processes");
246     break;
247     case 'V': /* output contributions */
248 schorsch 2.15 check_bool(2,contrib);
249 greg 2.1 break;
250     case 'x': /* x resolution */
251     check(2,"i");
252     xres = atoi(argv[++i]);
253     break;
254     case 'y': /* y resolution */
255     check(2,"i");
256     yres = atoi(argv[++i]);
257     break;
258     case 'w': /* warnings */
259 greg 2.2 rval = (erract[WARNING].pf != NULL);
260 schorsch 2.15 check_bool(2,rval);
261 greg 2.1 if (rval) erract[WARNING].pf = wputs;
262     else erract[WARNING].pf = NULL;
263     break;
264     case 'l': /* limit distance */
265     if (argv[i][2] != 'd')
266     goto badopt;
267 schorsch 2.15 check_bool(3,lim_dist);
268 greg 2.1 break;
269     case 'I': /* immed. irradiance */
270 schorsch 2.15 check_bool(2,imm_irrad);
271 greg 2.1 break;
272 greg 2.40 case 'f': /* force or format */
273 greg 2.1 if (argv[i][2] == 'o') {
274 schorsch 2.15 check_bool(3,force_open);
275 greg 2.1 break;
276     }
277     setformat(argv[i]+2);
278     break;
279     case 'o': /* output */
280     check(2,"s");
281     curout = argv[++i];
282     break;
283     case 'r': /* recover output */
284 schorsch 2.15 check_bool(2,recover);
285 greg 2.1 break;
286     case 'h': /* header output */
287 schorsch 2.15 check_bool(2,header);
288 greg 2.1 break;
289 greg 2.12 case 'p': /* parameter setting(s) */
290     check(2,"s");
291 greg 2.13 set_eparams(prms = argv[++i]);
292 greg 2.12 break;
293 greg 2.33 case 'c': /* sample count */
294     check(2,"i");
295     accumulate = atoi(argv[++i]);
296 greg 2.32 break;
297 greg 2.1 case 'b': /* bin expression/count */
298     if (argv[i][2] == 'n') {
299     check(3,"s");
300     bincnt = (int)(eval(argv[++i]) + .5);
301     break;
302     }
303     check(2,"s");
304     binval = argv[++i];
305     break;
306     case 'm': /* modifier name */
307     check(2,"s");
308 greg 2.12 addmodifier(argv[++i], curout, prms, binval, bincnt);
309 greg 2.1 break;
310     case 'M': /* modifier file */
311     check(2,"s");
312 greg 2.12 addmodfile(argv[++i], curout, prms, binval, bincnt);
313 greg 2.1 break;
314 greg 2.19 case 't': /* reporting interval */
315     check(2,"i");
316     report_intvl = atoi(argv[++i]);
317     break;
318 greg 2.1 default:
319     goto badopt;
320     }
321     }
322 greg 2.11 if (nmods <= 0)
323     error(USER, "missing required modifier argument");
324 greg 2.1 /* override some option settings */
325     override_options();
326 greg 2.34 /* set/check spectral sampling */
327 greg 2.35 if (setspectrsamp(CNDX, WLPART) < 0)
328 greg 2.34 error(USER, "unsupported spectral sampling");
329 greg 2.1 /* initialize object types */
330     initotypes();
331     /* initialize urand */
332     if (rand_samp) {
333     srandom((long)time(0));
334     initurand(0);
335     } else {
336     srandom(0L);
337     initurand(2048);
338     }
339     /* set up signal handling */
340     sigdie(SIGINT, "Interrupt");
341     #ifdef SIGHUP
342     sigdie(SIGHUP, "Hangup");
343     #endif
344     sigdie(SIGTERM, "Terminate");
345     #ifdef SIGPIPE
346     sigdie(SIGPIPE, "Broken pipe");
347     #endif
348     #ifdef SIGALRM
349     sigdie(SIGALRM, "Alarm clock");
350     #endif
351     #ifdef SIGXCPU
352     sigdie(SIGXCPU, "CPU limit exceeded");
353     sigdie(SIGXFSZ, "File size exceeded");
354     #endif
355     #ifdef NICE
356     nice(NICE); /* lower priority */
357     #endif
358     /* get octree */
359     if (i == argc)
360     octname = NULL;
361     else if (i == argc-1)
362     octname = argv[i];
363     else
364     goto badopt;
365     if (octname == NULL)
366     error(USER, "missing octree argument");
367
368     readoct(octname, ~(IO_FILES|IO_INFO), &thescene, NULL);
369     nsceneobjs = nobjects;
370
371 greg 2.14 /* PMAP: set up & load photon maps */
372     ray_init_pmap();
373
374 greg 2.1 marksources(); /* find and mark sources */
375 greg 2.14
376     /* PMAP: init photon map for light source contributions */
377     initPmapContrib(&modconttab, nmods);
378 greg 2.1
379     setambient(); /* initialize ambient calculation */
380 greg 2.14
381 greg 2.2 rcontrib(); /* trace ray contributions (loop) */
382 greg 2.1
383 greg 2.14 /* PMAP: free photon maps */
384     ray_done_pmap();
385
386 greg 2.1 quit(0); /* exit clean */
387
388     badopt:
389     fprintf(stderr,
390 greg 2.16 "Usage: %s [-n nprocs][-V][-c count][-r][-e expr][-f source][-o ospec][-p p1=V1,p2=V2][-b binv][-bn N] {-m mod | -M file} [rtrace options] octree\n",
391 greg 2.1 progname);
392     sprintf(errmsg, "command line error at '%s'", argv[i]);
393     error(USER, errmsg);
394     return(1); /* pro forma return */
395
396     #undef check
397 schorsch 2.15 #undef check_bool
398 greg 2.1 }
399
400
401     void
402     wputs( /* warning output function */
403 greg 2.27 const char *s
404 greg 2.1 )
405     {
406     int lasterrno = errno;
407 greg 2.38 if (erract[WARNING].pf == NULL)
408     return; /* called by calcomp or someone */
409 greg 2.1 eputs(s);
410     errno = lasterrno;
411     }
412
413
414     void
415     eputs( /* put string to stderr */
416 greg 2.27 const char *s
417 greg 2.1 )
418     {
419     static int midline = 0;
420
421     if (!*s)
422     return;
423     if (!midline++) {
424     fputs(progname, stderr);
425     fputs(": ", stderr);
426     }
427     fputs(s, stderr);
428     if (s[strlen(s)-1] == '\n') {
429     fflush(stderr);
430     midline = 0;
431     }
432     }
