root/radiance/ray/src/rt/rcmain.c
Thu Jan 18 19:43:43 2018 UTC (6 years, 5 months ago) by greg
CVS Tags: rad5R2, rad5R3
Diff to previous 2.17 , to selected 2.10
Changed context names to avoid collision with user-specified .cal file names
Thu Nov 30 23:31:34 2017 UTC (6 years, 6 months ago) by greg
Diff to previous 2.16 , to selected 2.10
Increased the limit on open files in rcontrib from 512 to 2048 under Windows
Wed Jun 1 03:00:06 2016 UTC (8 years ago) by greg
Diff to previous 2.15 , to selected 2.10
Added missing -c option in usage message
Thu Mar 10 18:25:46 2016 UTC (8 years, 3 months ago) by schorsch
Changes since 2.14: +10 -10 lines
newer C++ compilers have a standard type named "bool". rename macro to get rid of warnings.
Tue Feb 24 19:39:27 2015 UTC (9 years, 3 months ago) by greg
Changes since 2.13: +13 -2 lines
Sat Jul 19 20:03:03 2014 UTC (9 years, 11 months ago) by greg
Fixed bug in parameter parser and added check during main arguments processing
Sat Jul 19 18:19:33 2014 UTC (9 years, 11 months ago) by greg
Changes since 2.11: +9 -4 lines
Sun Aug 11 13:48:48 2013 UTC (10 years, 10 months ago) by greg
Added missing check for missing modifier
Wed Aug 7 05:10:09 2013 UTC (10 years, 10 months ago) by greg
Changes since 2.9: +2 -3 lines
Sat Aug 11 01:41:35 2012 UTC (11 years, 10 months ago) by greg
Shortened context name to "RC" from "RCONTRIB"
Wed Jun 27 15:32:58 2012 UTC (11 years, 11 months ago) by greg
Changes since 2.7: +1 -3 lines
Added check for blocked shadow rays
Fri Jun 22 22:03:02 2012 UTC (12 years ago) by greg
Moved source initialization
Fri Jun 22 21:58:45 2012 UTC (12 years ago) by greg
More portability fixes (missing headers)
Thu Jun 21 17:14:32 2012 UTC (12 years ago) by greg
Changes since 2.4: +1 -3 lines
Accommodations for Windows
Fri Jun 15 00:57:40 2012 UTC (12 years ago) by greg
Simplified modifier lookup
Mon Jun 11 05:07:55 2012 UTC (12 years ago) by greg
Changes since 2.2: +4 -1 lines
Fixed a number of bugs -- still testing
Sun Jun 10 05:25:42 2012 UTC (12 years ago) by greg
Changes since 2.1: +3 -10 lines
Tweaks and bug fixes to new code
Sat Jun 9 07:16:47 2012 UTC (12 years ago) by greg
Diff to selected 2.10
