root/radiance/ray/src/rt/rcmain.c
Revision: 2.11
Committed: Sun Aug 11 13:48:48 2013 UTC (11 years, 10 months ago) by greg
Added missing check for missing modifier
2 static const char RCSid[] = "$Id: rcmain.c,v 2.10 2013/08/07 05:10:09 greg Exp $";
5 * rcmain.c - main for rtcontrib ray contribution tracer
6 */
7
8 #include "copyright.h"
9
10 #include <signal.h>
11 #include <time.h>
12 #include "rcontrib.h"
13 #include "random.h"
14 #include "source.h"
15 #include "ambient.h"
16
17 int gargc; /* global argc */
18 char **gargv; /* global argv */
19 char *octname; /* global octree name */
20 char *progname; /* global argv[0] */
21
22 char *sigerr[NSIG]; /* signal error messages */
23
24 int nproc = 1; /* number of processes requested */
25 int nchild = 0; /* number of children (-1 in child) */
26
27 int inpfmt = 'a'; /* input format */
28 int outfmt = 'a'; /* output format */
29
30 int header = 1; /* output header? */
31 int force_open = 0; /* truncate existing output? */
32 int recover = 0; /* recover previous output? */
33 int accumulate = 1; /* input rays per output record */
34 int contrib = 0; /* computing contributions? */
35
36 int xres = 0; /* horizontal (scan) size */
37 int yres = 0; /* vertical resolution */
38
39 int using_stdout = 0; /* are we using stdout? */
40
41 int imm_irrad = 0; /* compute immediate irradiance? */
42 int lim_dist = 0; /* limit distance? */
43
44 const char *modname[MAXMODLIST]; /* ordered modifier name list */
45 int nmods = 0; /* number of modifiers */
46
47 void (*addobjnotify[8])() = {ambnotify, NULL};
48
49 char RCCONTEXT[] = "RC"; /* our special evaluation context */
50
51
52 static void
53 printdefaults(void) /* print default values to stdout */
54 {
55 printf("-c %-5d\t\t\t# accumulated rays per record\n", accumulate);
56 printf("-V%c\t\t\t\t# output %s\n", contrib ? '+' : '-',
57 contrib ? "contributions" : "coefficients");
58 if (imm_irrad)
59 printf("-I+\t\t\t\t# immediate irradiance on\n");
60 printf("-n %-2d\t\t\t\t# number of rendering processes\n", nproc);
61 printf("-x %-9d\t\t\t# %s\n", xres,
62 yres && xres ? "x resolution" : "flush interval");
63 printf("-y %-9d\t\t\t# y resolution\n", yres);
64 printf(lim_dist ? "-ld+\t\t\t\t# limit distance on\n" :
65 "-ld-\t\t\t\t# limit distance off\n");
66 printf("-h%c\t\t\t\t# %s header\n", header ? '+' : '-',
67 header ? "output" : "no");
68 printf("-f%c%c\t\t\t\t# format input/output = %s/%s\n",
69 inpfmt, outfmt, formstr(inpfmt), formstr(outfmt));
70 printf(erract[WARNING].pf != NULL ?
71 "-w+\t\t\t\t# warning messages on\n" :
72 "-w-\t\t\t\t# warning messages off\n");
73 print_rdefaults();
74 }
75
76
77 static void
78 onsig( /* fatal signal */
79 int signo
80 )
81 {
82 static int gotsig = 0;
83
84 if (gotsig++) /* two signals and we're gone! */
85 _exit(signo);
86
87 #ifdef SIGALRM
88 alarm(15); /* allow 15 seconds to clean up */
89 signal(SIGALRM, SIG_DFL); /* make certain we do die */
90 #endif
91 eputs("signal - ");
92 eputs(sigerr[signo]);
93 eputs("\n");
94 quit(3);
95 }
96
97
98 static void
99 sigdie( /* set fatal signal */
100 int signo,
101 char *msg
102 )
103 {
104 if (signal(signo, onsig) == SIG_IGN)
105 signal(signo, SIG_IGN);
106 sigerr[signo] = msg;
107 }
108
109
110 /* set input/output format */
111 static void
112 setformat(const char *fmt)
113 {
114 switch (fmt[0]) {
115 case 'f':
116 case 'd':
117 SET_FILE_BINARY(stdin);
118 /* fall through */
119 case 'a':
120 inpfmt = fmt[0];
121 break;
122 default:
123 goto fmterr;
124 }
125 switch (fmt[1]) {
126 case '\0':
127 outfmt = inpfmt;
128 return;
129 case 'a':
130 case 'f':
131 case 'd':
132 case 'c':
133 outfmt = fmt[1];
134 break;
135 default:
136 goto fmterr;
137 }
138 if (!fmt[2])
139 return;
140 fmterr:
141 sprintf(errmsg, "Illegal i/o format: -f%s", fmt);
142 error(USER, errmsg);
143 }
144
145
146 /* Set overriding options */
147 static void
148 override_options(void)
149 {
150 shadthresh = 0;
151 ambssamp = 0;
152 ambacc = 0;
153 if (accumulate <= 0) /* no output flushing for single record */
154 xres = yres = 0;
155 }
156
157
158 int
159 main(int argc, char *argv[])
160 {
161 #define check(ol,al) if (argv[i][ol] || \
162 badarg(argc-i-1,argv+i+1,al)) \
163 goto badopt
164 #define bool(olen,var) switch (argv[i][olen]) { \
165 case '\0': var = !var; break; \
166 case 'y': case 'Y': case 't': case 'T': \
167 case '+': case '1': var = 1; break; \
168 case 'n': case 'N': case 'f': case 'F': \
169 case '-': case '0': var = 0; break; \
170 default: goto badopt; }
171 char *curout = NULL;
172 char *binval = NULL;
173 int bincnt = 0;
174 int rval;
175 int i;
176 /* global program name */
177 progname = argv[0] = fixargv0(argv[0]);
178 gargv = argv;
179 gargc = argc;
180 /* initialize calcomp routines early */
181 initfunc();
182 setcontext(RCCONTEXT);
183 /* option city */
184 for (i = 1; i < argc; i++) {
185 /* expand arguments */
186 while ((rval = expandarg(&argc, &argv, i)) > 0)
187 ;
188 if (rval < 0) {
189 sprintf(errmsg, "cannot expand '%s'", argv[i]);
190 error(SYSTEM, errmsg);
191 }
192 if (argv[i] == NULL || argv[i][0] != '-')
193 break; /* break from options */
194 if (!strcmp(argv[i], "-version")) {
195 puts(VersionID);
196 quit(0);
197 }
198 if (!strcmp(argv[i], "-defaults") ||
199 !strcmp(argv[i], "-help")) {
200 override_options();
201 printdefaults();
202 quit(0);
203 }
204 rval = getrenderopt(argc-i, argv+i);
205 if (rval >= 0) {
206 i += rval;
207 continue;
208 }
209 switch (argv[i][1]) {
210 case 'n': /* number of cores */
211 check(2,"i");
212 nproc = atoi(argv[++i]);
213 if (nproc <= 0)
214 error(USER, "bad number of processes");
215 break;
216 case 'V': /* output contributions */
217 bool(2,contrib);
218 break;
219 case 'x': /* x resolution */
220 check(2,"i");
221 xres = atoi(argv[++i]);
222 break;
223 case 'y': /* y resolution */
224 check(2,"i");
225 yres = atoi(argv[++i]);
226 break;
227 case 'w': /* warnings */
228 rval = (erract[WARNING].pf != NULL);
229 bool(2,rval);
230 if (rval) erract[WARNING].pf = wputs;
231 else erract[WARNING].pf = NULL;
232 break;
233 case 'e': /* expression */
234 check(2,"s");
235 scompile(argv[++i], NULL, 0);
236 break;
237 case 'l': /* limit distance */
238 if (argv[i][2] != 'd')
239 goto badopt;
240 bool(3,lim_dist);
241 break;
242 case 'I': /* immed. irradiance */
243 bool(2,imm_irrad);
244 break;
245 case 'f': /* file or force or format */
246 if (!argv[i][2]) {
247 check(2,"s");
248 loadfunc(argv[++i]);
249 break;
250 }
251 if (argv[i][2] == 'o') {
252 bool(3,force_open);
253 break;
254 }
255 setformat(argv[i]+2);
256 break;
257 case 'o': /* output */
258 check(2,"s");
259 curout = argv[++i];
260 break;
261 case 'c': /* input rays per output */
262 check(2,"i");
263 accumulate = atoi(argv[++i]);
264 break;
265 case 'r': /* recover output */
266 bool(2,recover);
267 break;
268 case 'h': /* header output */
269 bool(2,header);
270 break;
271 case 'b': /* bin expression/count */
272 if (argv[i][2] == 'n') {
273 check(3,"s");
274 bincnt = (int)(eval(argv[++i]) + .5);
275 break;
276 }
277 check(2,"s");
278 binval = argv[++i];
279 break;
280 case 'm': /* modifier name */
281 check(2,"s");
282 addmodifier(argv[++i], curout, binval, bincnt);
283 break;
284 case 'M': /* modifier file */
285 check(2,"s");
286 addmodfile(argv[++i], curout, binval, bincnt);
287 break;
288 default:
289 goto badopt;
290 }
291 }
292 if (nmods <= 0)
293 error(USER, "missing required modifier argument");
294 /* override some option settings */
295 override_options();
296 /* initialize object types */
297 initotypes();
298 /* initialize urand */
299 if (rand_samp) {
300 srandom((long)time(0));
301 initurand(0);
302 } else {
303 srandom(0L);
304 initurand(2048);
305 }
306 /* set up signal handling */
307 sigdie(SIGINT, "Interrupt");
308 #ifdef SIGHUP
309 sigdie(SIGHUP, "Hangup");
310 #endif
311 sigdie(SIGTERM, "Terminate");
312 #ifdef SIGPIPE
313 sigdie(SIGPIPE, "Broken pipe");
314 #endif
315 #ifdef SIGALRM
316 sigdie(SIGALRM, "Alarm clock");
317 #endif
318 #ifdef SIGXCPU
319 sigdie(SIGXCPU, "CPU limit exceeded");
320 sigdie(SIGXFSZ, "File size exceeded");
321 #endif
322 #ifdef NICE
323 nice(NICE); /* lower priority */
324 #endif
325 /* get octree */
326 if (i == argc)
327 octname = NULL;
328 else if (i == argc-1)
329 octname = argv[i];
330 else
331 goto badopt;
332 if (octname == NULL)
333 error(USER, "missing octree argument");
334
335 readoct(octname, ~(IO_FILES|IO_INFO), &thescene, NULL);
336 nsceneobjs = nobjects;
337
338 marksources(); /* find and mark sources */
339
340 setambient(); /* initialize ambient calculation */
341
342 rcontrib(); /* trace ray contributions (loop) */
343
344 ambsync(); /* flush ambient file */
345
346 quit(0); /* exit clean */
347
348 badopt:
349 fprintf(stderr,
350 "Usage: %s [-n nprocs][-V][-r][-e expr][-f source][-o ospec][-b binv][-bn N] {-m mod | -M file} [rtrace options] octree\n",
351 progname);
352 sprintf(errmsg, "command line error at '%s'", argv[i]);
353 error(USER, errmsg);
354 return(1); /* pro forma return */
355
356 #undef check
357 #undef bool
358 }
359
360
361 void
362 wputs( /* warning output function */
363 char *s
364 )
365 {
366 int lasterrno = errno;
367 eputs(s);
368 errno = lasterrno;
369 }
370
371
372 void
373 eputs( /* put string to stderr */
374 char *s
375 )
376 {
377 static int midline = 0;
378
379 if (!*s)
380 return;
381 if (!midline++) {
382 fputs(progname, stderr);
383 fputs(": ", stderr);
384 }
385 fputs(s, stderr);
386 if (s[strlen(s)-1] == '\n') {
387 fflush(stderr);
388 midline = 0;
389 }
390 }
