root/radiance/ray/src/rt/rcmain.c
Revision: 2.26
Committed: Mon Feb 6 20:37:06 2023 UTC (16 months, 1 week ago) by greg
fix: Actually, need to allow -features to have arguments
2 static const char RCSid[] = "$Id: rcmain.c,v 2.25 2023/02/06 20:34:17 greg Exp $";
5 * rcmain.c - main for rtcontrib ray contribution tracer
6 */
7
8 #include "copyright.h"
9
10 #include <signal.h>
11 #include <time.h>
12 #include "rcontrib.h"
13 #include "random.h"
14 #include "source.h"
15 #include "ambient.h"
16 #include "pmapray.h"
17 #include "pmapcontrib.h"
18
19 int gargc; /* global argc */
20 char **gargv; /* global argv */
21 char *octname; /* global octree name */
22 char *progname; /* global argv[0] */
23
24 char *sigerr[NSIG]; /* signal error messages */
25
26 int nproc = 1; /* number of processes requested */
27 int nchild = 0; /* number of children (-1 in child) */
28
29 int inpfmt = 'a'; /* input format */
30 int outfmt = 'a'; /* output format */
31
32 int header = 1; /* output header? */
33 int force_open = 0; /* truncate existing output? */
34 int recover = 0; /* recover previous output? */
35 int accumulate = 1; /* input rays per output record */
36 int contrib = 0; /* computing contributions? */
37
38 int xres = 0; /* horizontal (scan) size */
39 int yres = 0; /* vertical resolution */
40
41 int using_stdout = 0; /* are we using stdout? */
42
43 int imm_irrad = 0; /* compute immediate irradiance? */
44 int lim_dist = 0; /* limit distance? */
45
46 int report_intvl = 0; /* reporting interval (seconds) */
47
48 char **modname = NULL; /* ordered modifier name list */
49 int nmods = 0; /* number of modifiers */
50 int modasiz = 0; /* allocated modifier array size */
51
52 void (*addobjnotify[8])() = {ambnotify, NULL};
53
54 char RCCONTEXT[] = "RC."; /* our special evaluation context */
55
56 #if defined(_WIN32) || defined(_WIN64)
57 #define RCONTRIB_FEATURES "Accumulation\nSummation\nRecovery\n" \
58 "ValueContribution\nImmediateIrradiance\n" \
59 "ProgressReporting\nDistanceLimiting\n" \
60 "Outputs=V,W\n"
61 #else
62 #define RCONTRIB_FEATURES "Multiprocessing\n" \
63 "Accumulation\nSummation\nRecovery\n" \
64 "ValueContribution\nImmediateIrradiance\n" \
65 "ProgressReporting\nDistanceLimiting\n" \
66 "Outputs=V,W\n"
67 #endif
68
69 static void
70 printdefaults(void) /* print default values to stdout */
71 {
72 printf("-c %-5d\t\t\t# accumulated rays per record\n", accumulate);
73 printf("-V%c\t\t\t\t# output %s\n", contrib ? '+' : '-',
74 contrib ? "contributions" : "coefficients");
75 if (imm_irrad)
76 printf("-I+\t\t\t\t# immediate irradiance on\n");
77 printf("-n %-2d\t\t\t\t# number of rendering processes\n", nproc);
78 printf("-x %-9d\t\t\t# %s\n", xres,
79 yres && xres ? "x resolution" : "flush interval");
80 printf("-y %-9d\t\t\t# y resolution\n", yres);
81 printf(lim_dist ? "-ld+\t\t\t\t# limit distance on\n" :
82 "-ld-\t\t\t\t# limit distance off\n");
83 printf("-h%c\t\t\t\t# %s header\n", header ? '+' : '-',
84 header ? "output" : "no");
85 printf("-f%c%c\t\t\t\t# format input/output = %s/%s\n",
86 inpfmt, outfmt, formstr(inpfmt), formstr(outfmt));
87 printf(erract[WARNING].pf != NULL ?
88 "-w+\t\t\t\t# warning messages on\n" :
89 "-w-\t\t\t\t# warning messages off\n");
90 print_rdefaults();
91 }
92
93
94 static void
95 onsig( /* fatal signal */
96 int signo
97 )
98 {
99 static int gotsig = 0;
100
101 if (gotsig++) /* two signals and we're gone! */
102 _exit(signo);
103
104 #ifdef SIGALRM
105 alarm(15); /* allow 15 seconds to clean up */
106 signal(SIGALRM, SIG_DFL); /* make certain we do die */
107 #endif
108 eputs("signal - ");
109 eputs(sigerr[signo]);
110 eputs("\n");
111 quit(3);
112 }
113
114
115 static void
116 sigdie( /* set fatal signal */
117 int signo,
118 char *msg
119 )
120 {
121 if (signal(signo, onsig) == SIG_IGN)
122 signal(signo, SIG_IGN);
123 sigerr[signo] = msg;
124 }
125
126
127 /* set input/output format */
128 static void
129 setformat(const char *fmt)
130 {
131 switch (fmt[0]) {
132 case 'f':
133 case 'd':
134 SET_FILE_BINARY(stdin);
135 /* fall through */
136 case 'a':
137 inpfmt = fmt[0];
138 break;
139 default:
140 goto fmterr;
141 }
142 switch (fmt[1]) {
143 case '\0':
144 outfmt = inpfmt;
145 return;
146 case 'a':
147 case 'f':
148 case 'd':
149 case 'c':
150 outfmt = fmt[1];
151 break;
152 default:
153 goto fmterr;
154 }
155 if (!fmt[2])
156 return;
157 fmterr:
158 sprintf(errmsg, "Illegal i/o format: -f%s", fmt);
159 error(USER, errmsg);
160 }
161
162
163 /* Set overriding options */
164 static void
165 override_options(void)
166 {
167 shadthresh = 0;
168 ambssamp = 0;
169 ambacc = 0;
170 if (accumulate <= 0) /* no output flushing for single record */
171 xres = yres = 0;
172 }
173
174
175 int
176 main(int argc, char *argv[])
177 {
178 #define check(ol,al) if (argv[i][ol] || \
179 badarg(argc-i-1,argv+i+1,al)) \
180 goto badopt
181 #define check_bool(olen,var) switch (argv[i][olen]) { \
182 case '\0': var = !var; break; \
183 case 'y': case 'Y': case 't': case 'T': \
184 case '+': case '1': var = 1; break; \
185 case 'n': case 'N': case 'f': case 'F': \
186 case '-': case '0': var = 0; break; \
187 default: goto badopt; }
188 char *curout = NULL;
189 char *prms = NULL;
190 char *binval = NULL;
191 int bincnt = 0;
192 int rval;
193 int i;
194 /* global program name */
195 progname = argv[0] = fixargv0(argv[0]);
196 gargv = argv;
197 gargc = argc;
198 /* feature check only? */
199 strcat(RFeatureList, RCONTRIB_FEATURES);
200 if (argc > 1 && !strcmp(argv[1], "-features"))
201 return feature_status(argc-2, argv+2);
202 #if defined(_WIN32) || defined(_WIN64)
203 _setmaxstdio(2048); /* increase file limit to maximum */
204 #endif
205 /* initialize calcomp routines early */
206 initfunc();
207 calcontext(RCCONTEXT);
208 /* option city */
209 for (i = 1; i < argc; i++) {
210 /* expand arguments */
211 while ((rval = expandarg(&argc, &argv, i)) > 0)
212 ;
213 if (rval < 0) {
214 sprintf(errmsg, "cannot expand '%s'", argv[i]);
215 error(SYSTEM, errmsg);
216 }
217 if (argv[i] == NULL || argv[i][0] != '-')
218 break; /* break from options */
219 if (!strcmp(argv[i], "-version")) {
220 puts(VersionID);
221 quit(0);
222 }
223 if (!strcmp(argv[i], "-defaults") ||
224 !strcmp(argv[i], "-help")) {
225 override_options();
226 printdefaults();
227 quit(0);
228 }
229 rval = getrenderopt(argc-i, argv+i);
230 if (rval >= 0) {
231 i += rval;
232 continue;
233 }
234 switch (argv[i][1]) {
235 case 'n': /* number of cores */
236 check(2,"i");
237 nproc = atoi(argv[++i]);
238 if (nproc <= 0)
239 error(USER, "bad number of processes");
240 break;
241 case 'V': /* output contributions */
242 check_bool(2,contrib);
243 break;
244 case 'x': /* x resolution */
245 check(2,"i");
246 xres = atoi(argv[++i]);
247 break;
248 case 'y': /* y resolution */
249 check(2,"i");
250 yres = atoi(argv[++i]);
251 break;
252 case 'w': /* warnings */
253 rval = (erract[WARNING].pf != NULL);
254 check_bool(2,rval);
255 if (rval) erract[WARNING].pf = wputs;
256 else erract[WARNING].pf = NULL;
257 break;
258 case 'e': /* expression */
259 check(2,"s");
260 scompile(argv[++i], NULL, 0);
261 break;
262 case 'l': /* limit distance */
263 if (argv[i][2] != 'd')
264 goto badopt;
265 check_bool(3,lim_dist);
266 break;
267 case 'I': /* immed. irradiance */
268 check_bool(2,imm_irrad);
269 break;
270 case 'f': /* file or force or format */
271 if (!argv[i][2]) {
272 check(2,"s");
273 loadfunc(argv[++i]);
274 break;
275 }
276 if (argv[i][2] == 'o') {
277 check_bool(3,force_open);
278 break;
279 }
280 setformat(argv[i]+2);
281 break;
282 case 'o': /* output */
283 check(2,"s");
284 curout = argv[++i];
285 break;
286 case 'c': /* input rays per output */
287 check(2,"i");
288 accumulate = atoi(argv[++i]);
289 break;
290 case 'r': /* recover output */
291 check_bool(2,recover);
292 break;
293 case 'h': /* header output */
294 check_bool(2,header);
295 break;
296 case 'p': /* parameter setting(s) */
297 check(2,"s");
298 set_eparams(prms = argv[++i]);
299 break;
300 case 'b': /* bin expression/count */
301 if (argv[i][2] == 'n') {
302 check(3,"s");
303 bincnt = (int)(eval(argv[++i]) + .5);
304 break;
305 }
306 check(2,"s");
307 binval = argv[++i];
308 break;
309 case 'm': /* modifier name */
310 check(2,"s");
311 addmodifier(argv[++i], curout, prms, binval, bincnt);
312 break;
313 case 'M': /* modifier file */
314 check(2,"s");
315 addmodfile(argv[++i], curout, prms, binval, bincnt);
316 break;
317 case 't': /* reporting interval */
318 check(2,"i");
319 report_intvl = atoi(argv[++i]);
320 break;
321 default:
322 goto badopt;
323 }
324 }
325 if (nmods <= 0)
326 error(USER, "missing required modifier argument");
327 /* override some option settings */
328 override_options();
329 /* initialize object types */
330 initotypes();
331 /* initialize urand */
332 if (rand_samp) {
333 srandom((long)time(0));
334 initurand(0);
335 } else {
336 srandom(0L);
337 initurand(2048);
338 }
339 /* set up signal handling */
340 sigdie(SIGINT, "Interrupt");
341 #ifdef SIGHUP
342 sigdie(SIGHUP, "Hangup");
343 #endif
344 sigdie(SIGTERM, "Terminate");
345 #ifdef SIGPIPE
346 sigdie(SIGPIPE, "Broken pipe");
347 #endif
348 #ifdef SIGALRM
349 sigdie(SIGALRM, "Alarm clock");
350 #endif
351 #ifdef SIGXCPU
352 sigdie(SIGXCPU, "CPU limit exceeded");
353 sigdie(SIGXFSZ, "File size exceeded");
354 #endif
355 #ifdef NICE
356 nice(NICE); /* lower priority */
357 #endif
358 /* get octree */
359 if (i == argc)
360 octname = NULL;
361 else if (i == argc-1)
362 octname = argv[i];
363 else
364 goto badopt;
365 if (octname == NULL)
366 error(USER, "missing octree argument");
367
368 readoct(octname, ~(IO_FILES|IO_INFO), &thescene, NULL);
369 nsceneobjs = nobjects;
370
371 /* PMAP: set up & load photon maps */
372 ray_init_pmap();
373
374 marksources(); /* find and mark sources */
375
376 /* PMAP: init photon map for light source contributions */
377 initPmapContrib(&modconttab, nmods);
378
379 setambient(); /* initialize ambient calculation */
380
381 rcontrib(); /* trace ray contributions (loop) */
382
383 ambsync(); /* flush ambient file */
384
385 /* PMAP: free photon maps */
386 ray_done_pmap();
387
388 quit(0); /* exit clean */
389
390 badopt:
391 fprintf(stderr,
392 "Usage: %s [-n nprocs][-V][-c count][-r][-e expr][-f source][-o ospec][-p p1=V1,p2=V2][-b binv][-bn N] {-m mod | -M file} [rtrace options] octree\n",
393 progname);
394 sprintf(errmsg, "command line error at '%s'", argv[i]);
395 error(USER, errmsg);
396 return(1); /* pro forma return */
397
398 #undef check
399 #undef check_bool
400 }
401
402
403 void
404 wputs( /* warning output function */
405 char *s
406 )
407 {
408 int lasterrno = errno;
409 eputs(s);
410 errno = lasterrno;
411 }
412
413
414 void
415 eputs( /* put string to stderr */
416 char *s
417 )
418 {
419 static int midline = 0;
420
421 if (!*s)
422 return;
423 if (!midline++) {
424 fputs(progname, stderr);
425 fputs(": ", stderr);
426 }
427 fputs(s, stderr);
428 if (s[strlen(s)-1] == '\n') {
429 fflush(stderr);
430 midline = 0;
431 }
432 }
