root/radiance/ray/src/rt/rcmain.c
Revision: 2.20
Committed: Tue Feb 16 20:06:06 2021 UTC (4 years, 5 months ago) by greg
Changes since 2.19: +4 -3 lines
feat: removed upper limit on number of modifiers in rcontrib
2 static const char RCSid[] = "$Id: rcmain.c,v 2.19 2020/09/09 21:28:19 greg Exp $";
5 * rcmain.c - main for rtcontrib ray contribution tracer
6 */
7
8 #include "copyright.h"
9
10 #include <signal.h>
11 #include <time.h>
12 #include "rcontrib.h"
13 #include "random.h"
14 #include "source.h"
15 #include "ambient.h"
16 #include "pmapray.h"
17 #include "pmapcontrib.h"
18
19 int gargc; /* global argc */
20 char **gargv; /* global argv */
21 char *octname; /* global octree name */
22 char *progname; /* global argv[0] */
23
24 char *sigerr[NSIG]; /* signal error messages */
25
26 int nproc = 1; /* number of processes requested */
27 int nchild = 0; /* number of children (-1 in child) */
28
29 int inpfmt = 'a'; /* input format */
30 int outfmt = 'a'; /* output format */
31
32 int header = 1; /* output header? */
33 int force_open = 0; /* truncate existing output? */
34 int recover = 0; /* recover previous output? */
35 int accumulate = 1; /* input rays per output record */
36 int contrib = 0; /* computing contributions? */
37
38 int xres = 0; /* horizontal (scan) size */
39 int yres = 0; /* vertical resolution */
40
41 int using_stdout = 0; /* are we using stdout? */
42
43 int imm_irrad = 0; /* compute immediate irradiance? */
44 int lim_dist = 0; /* limit distance? */
45
46 int report_intvl = 0; /* reporting interval (seconds) */
47
48 char **modname = NULL; /* ordered modifier name list */
49 int nmods = 0; /* number of modifiers */
50 int modasiz = 0; /* allocated modifier array size */
51
52 void (*addobjnotify[8])() = {ambnotify, NULL};
53
54 char RCCONTEXT[] = "RC."; /* our special evaluation context */
55
56
57 static void
58 printdefaults(void) /* print default values to stdout */
59 {
60 printf("-c %-5d\t\t\t# accumulated rays per record\n", accumulate);
61 printf("-V%c\t\t\t\t# output %s\n", contrib ? '+' : '-',
62 contrib ? "contributions" : "coefficients");
63 if (imm_irrad)
64 printf("-I+\t\t\t\t# immediate irradiance on\n");
65 printf("-n %-2d\t\t\t\t# number of rendering processes\n", nproc);
66 printf("-x %-9d\t\t\t# %s\n", xres,
67 yres && xres ? "x resolution" : "flush interval");
68 printf("-y %-9d\t\t\t# y resolution\n", yres);
69 printf(lim_dist ? "-ld+\t\t\t\t# limit distance on\n" :
70 "-ld-\t\t\t\t# limit distance off\n");
71 printf("-h%c\t\t\t\t# %s header\n", header ? '+' : '-',
72 header ? "output" : "no");
73 printf("-f%c%c\t\t\t\t# format input/output = %s/%s\n",
74 inpfmt, outfmt, formstr(inpfmt), formstr(outfmt));
75 printf(erract[WARNING].pf != NULL ?
76 "-w+\t\t\t\t# warning messages on\n" :
77 "-w-\t\t\t\t# warning messages off\n");
78 print_rdefaults();
79 }
80
81
82 static void
83 onsig( /* fatal signal */
84 int signo
85 )
86 {
87 static int gotsig = 0;
88
89 if (gotsig++) /* two signals and we're gone! */
90 _exit(signo);
91
92 #ifdef SIGALRM
93 alarm(15); /* allow 15 seconds to clean up */
94 signal(SIGALRM, SIG_DFL); /* make certain we do die */
95 #endif
96 eputs("signal - ");
97 eputs(sigerr[signo]);
98 eputs("\n");
99 quit(3);
100 }
101
102
103 static void
104 sigdie( /* set fatal signal */
105 int signo,
106 char *msg
107 )
108 {
109 if (signal(signo, onsig) == SIG_IGN)
110 signal(signo, SIG_IGN);
111 sigerr[signo] = msg;
112 }
113
114
115 /* set input/output format */
116 static void
117 setformat(const char *fmt)
118 {
119 switch (fmt[0]) {
120 case 'f':
121 case 'd':
122 SET_FILE_BINARY(stdin);
123 /* fall through */
124 case 'a':
125 inpfmt = fmt[0];
126 break;
127 default:
128 goto fmterr;
129 }
130 switch (fmt[1]) {
131 case '\0':
132 outfmt = inpfmt;
133 return;
134 case 'a':
135 case 'f':
136 case 'd':
137 case 'c':
138 outfmt = fmt[1];
139 break;
140 default:
141 goto fmterr;
142 }
143 if (!fmt[2])
144 return;
145 fmterr:
146 sprintf(errmsg, "Illegal i/o format: -f%s", fmt);
147 error(USER, errmsg);
148 }
149
150
151 /* Set overriding options */
152 static void
153 override_options(void)
154 {
155 shadthresh = 0;
156 ambssamp = 0;
157 ambacc = 0;
158 if (accumulate <= 0) /* no output flushing for single record */
159 xres = yres = 0;
160 }
161
162
163 int
164 main(int argc, char *argv[])
165 {
166 #define check(ol,al) if (argv[i][ol] || \
167 badarg(argc-i-1,argv+i+1,al)) \
168 goto badopt
169 #define check_bool(olen,var) switch (argv[i][olen]) { \
170 case '\0': var = !var; break; \
171 case 'y': case 'Y': case 't': case 'T': \
172 case '+': case '1': var = 1; break; \
173 case 'n': case 'N': case 'f': case 'F': \
174 case '-': case '0': var = 0; break; \
175 default: goto badopt; }
176 char *curout = NULL;
177 char *prms = NULL;
178 char *binval = NULL;
179 int bincnt = 0;
180 int rval;
181 int i;
182 /* global program name */
183 progname = argv[0] = fixargv0(argv[0]);
184 gargv = argv;
185 gargc = argc;
186 #if defined(_WIN32) || defined(_WIN64)
187 _setmaxstdio(2048); /* increase file limit to maximum */
188 #endif
189 /* initialize calcomp routines early */
190 initfunc();
191 setcontext(RCCONTEXT);
192 /* option city */
193 for (i = 1; i < argc; i++) {
194 /* expand arguments */
195 while ((rval = expandarg(&argc, &argv, i)) > 0)
196 ;
197 if (rval < 0) {
198 sprintf(errmsg, "cannot expand '%s'", argv[i]);
199 error(SYSTEM, errmsg);
200 }
201 if (argv[i] == NULL || argv[i][0] != '-')
202 break; /* break from options */
203 if (!strcmp(argv[i], "-version")) {
204 puts(VersionID);
205 quit(0);
206 }
207 if (!strcmp(argv[i], "-defaults") ||
208 !strcmp(argv[i], "-help")) {
209 override_options();
210 printdefaults();
211 quit(0);
212 }
213 rval = getrenderopt(argc-i, argv+i);
214 if (rval >= 0) {
215 i += rval;
216 continue;
217 }
218 switch (argv[i][1]) {
219 case 'n': /* number of cores */
220 check(2,"i");
221 nproc = atoi(argv[++i]);
222 if (nproc <= 0)
223 error(USER, "bad number of processes");
224 break;
225 case 'V': /* output contributions */
226 check_bool(2,contrib);
227 break;
228 case 'x': /* x resolution */
229 check(2,"i");
230 xres = atoi(argv[++i]);
231 break;
232 case 'y': /* y resolution */
233 check(2,"i");
234 yres = atoi(argv[++i]);
235 break;
236 case 'w': /* warnings */
237 rval = (erract[WARNING].pf != NULL);
238 check_bool(2,rval);
239 if (rval) erract[WARNING].pf = wputs;
240 else erract[WARNING].pf = NULL;
241 break;
242 case 'e': /* expression */
243 check(2,"s");
244 scompile(argv[++i], NULL, 0);
245 break;
246 case 'l': /* limit distance */
247 if (argv[i][2] != 'd')
248 goto badopt;
249 check_bool(3,lim_dist);
250 break;
251 case 'I': /* immed. irradiance */
252 check_bool(2,imm_irrad);
253 break;
254 case 'f': /* file or force or format */
255 if (!argv[i][2]) {
256 check(2,"s");
257 loadfunc(argv[++i]);
258 break;
259 }
260 if (argv[i][2] == 'o') {
261 check_bool(3,force_open);
262 break;
263 }
264 setformat(argv[i]+2);
265 break;
266 case 'o': /* output */
267 check(2,"s");
268 curout = argv[++i];
269 break;
270 case 'c': /* input rays per output */
271 check(2,"i");
272 accumulate = atoi(argv[++i]);
273 break;
274 case 'r': /* recover output */
275 check_bool(2,recover);
276 break;
277 case 'h': /* header output */
278 check_bool(2,header);
279 break;
280 case 'p': /* parameter setting(s) */
281 check(2,"s");
282 set_eparams(prms = argv[++i]);
283 break;
284 case 'b': /* bin expression/count */
285 if (argv[i][2] == 'n') {
286 check(3,"s");
287 bincnt = (int)(eval(argv[++i]) + .5);
288 break;
289 }
290 check(2,"s");
291 binval = argv[++i];
292 break;
293 case 'm': /* modifier name */
294 check(2,"s");
295 addmodifier(argv[++i], curout, prms, binval, bincnt);
296 break;
297 case 'M': /* modifier file */
298 check(2,"s");
299 addmodfile(argv[++i], curout, prms, binval, bincnt);
300 break;
301 case 't': /* reporting interval */
302 check(2,"i");
303 report_intvl = atoi(argv[++i]);
304 break;
305 default:
306 goto badopt;
307 }
308 }
309 if (nmods <= 0)
310 error(USER, "missing required modifier argument");
311 /* override some option settings */
312 override_options();
313 /* initialize object types */
314 initotypes();
315 /* initialize urand */
316 if (rand_samp) {
317 srandom((long)time(0));
318 initurand(0);
319 } else {
320 srandom(0L);
321 initurand(2048);
322 }
323 /* set up signal handling */
324 sigdie(SIGINT, "Interrupt");
325 #ifdef SIGHUP
326 sigdie(SIGHUP, "Hangup");
327 #endif
328 sigdie(SIGTERM, "Terminate");
329 #ifdef SIGPIPE
330 sigdie(SIGPIPE, "Broken pipe");
331 #endif
332 #ifdef SIGALRM
333 sigdie(SIGALRM, "Alarm clock");
334 #endif
335 #ifdef SIGXCPU
336 sigdie(SIGXCPU, "CPU limit exceeded");
337 sigdie(SIGXFSZ, "File size exceeded");
338 #endif
339 #ifdef NICE
340 nice(NICE); /* lower priority */
341 #endif
342 /* get octree */
343 if (i == argc)
344 octname = NULL;
345 else if (i == argc-1)
346 octname = argv[i];
347 else
348 goto badopt;
349 if (octname == NULL)
350 error(USER, "missing octree argument");
351
352 readoct(octname, ~(IO_FILES|IO_INFO), &thescene, NULL);
353 nsceneobjs = nobjects;
354
355 /* PMAP: set up & load photon maps */
356 ray_init_pmap();
357
358 marksources(); /* find and mark sources */
359
360 /* PMAP: init photon map for light source contributions */
361 initPmapContrib(&modconttab, nmods);
362
363 setambient(); /* initialize ambient calculation */
364
365 rcontrib(); /* trace ray contributions (loop) */
366
367 ambsync(); /* flush ambient file */
368
369 /* PMAP: free photon maps */
370 ray_done_pmap();
371
372 quit(0); /* exit clean */
373
374 badopt:
375 fprintf(stderr,
376 "Usage: %s [-n nprocs][-V][-c count][-r][-e expr][-f source][-o ospec][-p p1=V1,p2=V2][-b binv][-bn N] {-m mod | -M file} [rtrace options] octree\n",
377 progname);
378 sprintf(errmsg, "command line error at '%s'", argv[i]);
379 error(USER, errmsg);
380 return(1); /* pro forma return */
381
382 #undef check
383 #undef check_bool
384 }
385
386
387 void
388 wputs( /* warning output function */
389 char *s
390 )
391 {
392 int lasterrno = errno;
393 eputs(s);
394 errno = lasterrno;
395 }
396
397
398 void
399 eputs( /* put string to stderr */
400 char *s
401 )
402 {
403 static int midline = 0;
404
405 if (!*s)
406 return;
407 if (!midline++) {
408 fputs(progname, stderr);
409 fputs(": ", stderr);
410 }
411 fputs(s, stderr);
412 if (s[strlen(s)-1] == '\n') {
413 fflush(stderr);
414 midline = 0;
415 }
416 }
