root/radiance/ray/src/rt/rcmain.c
Fri Apr 5 16:41:17 2024 UTC (6 weeks, 6 days ago) by greg
Changes since 2.35: +5 -3 lines
Diff to previous 2.35 , to selected 2.26
feat(rpict,rtrace,rcontrib): Added OutputCS to features list
Thu Jan 18 00:28:54 2024 UTC (4 months ago) by greg
Changes since 2.34: +2 -3 lines
Diff to previous 2.34 , to selected 2.26
fix(rcontrib, rpict, rvu): Better check for spectral sampling
Wed Jan 17 01:31:08 2024 UTC (4 months ago) by greg
Changes since 2.33: +5 -1 lines
Diff to previous 2.33 , to selected 2.26
fix(rpict,rvu,rcontrib): Fixed luminance estimate during spectral rendering
Fri Nov 17 20:02:07 2023 UTC (6 months ago) by greg
Changes since 2.32: +6 -28 lines
Diff to previous 2.32 , to selected 2.26
Wed Nov 15 18:02:53 2023 UTC (6 months, 1 week ago) by greg
Changes since 2.31: +31 -9 lines
Diff to previous 2.31 , to selected 2.26
Tue Aug 15 00:46:56 2023 UTC (9 months, 1 week ago) by greg
Changes since 2.30: +5 -3 lines
Diff to previous 2.30 , to selected 2.26
fix(rtrace,rcontrib): Added i/o format options to features list
Fri Apr 7 15:00:11 2023 UTC (13 months, 2 weeks ago) by greg
Diff to previous 2.29 , to selected 2.26
fix(rcontrib): Bug in new code to maximize open file descriptor limit
Sat Feb 25 16:17:11 2023 UTC (14 months, 3 weeks ago) by greg
Changes since 2.28: +1 -3 lines
Diff to previous 2.28 , to selected 2.26
fix: Stray #if statement
Fri Feb 24 18:25:36 2023 UTC (14 months, 4 weeks ago) by greg
Changes since 2.27: +6 -2 lines
Diff to previous 2.27 , to selected 2.26
perf(rcontrib): Increased open file limit under Windows (check for crashes?)
Mon Feb 6 22:40:21 2023 UTC (15 months, 2 weeks ago) by greg
Changes since 2.26: +3 -3 lines
Diff to previous 2.26
Revision 2.26 - (view) (download) (annotate) - [selected]
Mon Feb 6 20:37:06 2023 UTC (15 months, 2 weeks ago) by greg
Diff to previous 2.25
fix: Actually, need to allow -features to have arguments
Mon Feb 6 20:34:17 2023 UTC (15 months, 2 weeks ago) by greg
Diff to previous 2.24 , to selected 2.26
fix: fixed crash when executed with no arguments
Thu Oct 20 17:18:32 2022 UTC (19 months ago) by greg
Changes since 2.23: +5 -3 lines
Diff to previous 2.23 , to selected 2.26
feat(rpict,rtrace,rcontrib): Added Output= list to -features
Wed Oct 19 23:10:34 2022 UTC (19 months ago) by greg
Diff to previous 2.22 , to selected 2.26
fix(rcontrib): removed AdaptiveShadowTesting from feature list (didn't belong)
Wed Oct 19 21:25:20 2022 UTC (19 months ago) by greg
Changes since 2.21: +15 -1 lines
Diff to previous 2.21 , to selected 2.26
Wed Mar 30 16:00:56 2022 UTC (2 years, 1 month ago) by greg
Diff to previous 2.20 , to selected 2.26
fix: Renamed setcontext() to calcontext() to avoid obscure macOS naming conflict
Tue Feb 16 20:06:06 2021 UTC (3 years, 3 months ago) by greg
Changes since 2.19: +4 -3 lines
Diff to previous 2.19 , to selected 2.26
feat: removed upper limit on number of modifiers in rcontrib
Wed Sep 9 21:28:19 2020 UTC (3 years, 8 months ago) by greg
Changes since 2.18: +7 -1 lines
Diff to previous 2.18 , to selected 2.26
Thu Jan 18 19:43:43 2018 UTC (6 years, 4 months ago) by greg
CVS Tags: rad5R2, rad5R3
Diff to previous 2.17 , to selected 2.26
Changed context names to avoid collision with user-specified .cal file names
Thu Nov 30 23:31:34 2017 UTC (6 years, 5 months ago) by greg
Diff to previous 2.16 , to selected 2.26
Increased the limit on open files in rcontrib from 512 to 2048 under Windows
Wed Jun 1 03:00:06 2016 UTC (7 years, 11 months ago) by greg
Diff to previous 2.15 , to selected 2.26
Added missing -c option in usage message
Thu Mar 10 18:25:46 2016 UTC (8 years, 2 months ago) by schorsch
Changes since 2.14: +10 -10 lines
Diff to previous 2.14 , to selected 2.26
newer C++ compilers have a standard type named "bool". rename macro to get rid of warnings.
Tue Feb 24 19:39:27 2015 UTC (9 years, 2 months ago) by greg
Changes since 2.13: +13 -2 lines
Diff to previous 2.13 , to selected 2.26
Sat Jul 19 20:03:03 2014 UTC (9 years, 10 months ago) by greg
Diff to previous 2.12 , to selected 2.26
Fixed bug in parameter parser and added check during main arguments processing
Sat Jul 19 18:19:33 2014 UTC (9 years, 10 months ago) by greg
Changes since 2.11: +9 -4 lines
Diff to previous 2.11 , to selected 2.26
Sun Aug 11 13:48:48 2013 UTC (10 years, 9 months ago) by greg
Diff to previous 2.10 , to selected 2.26
Added missing check for missing modifier
Wed Aug 7 05:10:09 2013 UTC (10 years, 9 months ago) by greg
Changes since 2.9: +2 -3 lines
Diff to previous 2.9 , to selected 2.26
Sat Aug 11 01:41:35 2012 UTC (11 years, 9 months ago) by greg
Diff to previous 2.8 , to selected 2.26
Shortened context name to "RC" from "RCONTRIB"
Wed Jun 27 15:32:58 2012 UTC (11 years, 10 months ago) by greg
Changes since 2.7: +1 -3 lines
Diff to previous 2.7 , to selected 2.26
Added check for blocked shadow rays
Fri Jun 22 22:03:02 2012 UTC (11 years, 11 months ago) by greg
Diff to previous 2.6 , to selected 2.26
Moved source initialization
Fri Jun 22 21:58:45 2012 UTC (11 years, 11 months ago) by greg
Diff to previous 2.5 , to selected 2.26
More portability fixes (missing headers)
Thu Jun 21 17:14:32 2012 UTC (11 years, 11 months ago) by greg
Changes since 2.4: +1 -3 lines
Diff to previous 2.4 , to selected 2.26
Accommodations for Windows
Fri Jun 15 00:57:40 2012 UTC (11 years, 11 months ago) by greg
Diff to previous 2.3 , to selected 2.26
Simplified modifier lookup
Mon Jun 11 05:07:55 2012 UTC (11 years, 11 months ago) by greg
Changes since 2.2: +4 -1 lines
Diff to previous 2.2 , to selected 2.26
Fixed a number of bugs -- still testing
Sun Jun 10 05:25:42 2012 UTC (11 years, 11 months ago) by greg
Changes since 2.1: +3 -10 lines
Diff to previous 2.1 , to selected 2.26
Tweaks and bug fixes to new code
Sat Jun 9 07:16:47 2012 UTC (11 years, 11 months ago) by greg
Diff to selected 2.26
