root/Development/ray/src/rt/rcmain.c
Fri Jun 20 16:34:23 2025 UTC (4 months, 3 weeks ago) by greg
CVS Tags: HEAD, rad6R0
Diff to previous 2.42
fix: Avoid array bounds errors in dimlist[] in deep ray trees
Thu Jun 5 18:26:46 2025 UTC (5 months, 1 week ago) by greg
Changes since 2.41: +1 -2 lines
Diff to previous 2.41
fix: Removed unnecessary or redundant progname declarations
Wed Jun 4 22:34:27 2025 UTC (5 months, 1 week ago) by greg
Diff to previous 2.40
fix: Fixed reference to fixargv0()
Tue Apr 22 17:12:25 2025 UTC (6 months, 3 weeks ago) by greg
Changes since 2.39: +3 -13 lines
Diff to previous 2.39
Wed Oct 30 17:26:13 2024 UTC (12 months, 1 week ago) by greg
Changes since 2.38: +1 -3 lines
Diff to previous 2.38
fix(rcontrib,rxcontrib): reinstated .cal redefinition warnings
Wed Oct 30 02:22:23 2024 UTC (12 months, 1 week ago) by greg
Changes since 2.37: +5 -1 lines
Diff to previous 2.37
fix(rcontrib,rxcontrib): Eliminated spurious warning messages
Sun Oct 27 00:01:21 2024 UTC (12 months, 2 weeks ago) by greg
Changes since 2.36: +3 -3 lines
Diff to previous 2.36
feat: Added reporting interval to defaults output and removed unnecessary amb sync
Fri Apr 5 16:41:17 2024 UTC (19 months, 1 week ago) by greg
Changes since 2.35: +5 -3 lines
Diff to previous 2.35
feat(rpict,rtrace,rcontrib): Added OutputCS to features list
Thu Jan 18 00:28:54 2024 UTC (21 months, 3 weeks ago) by greg
Changes since 2.34: +2 -3 lines
Diff to previous 2.34
fix(rcontrib, rpict, rvu): Better check for spectral sampling
Wed Jan 17 01:31:08 2024 UTC (21 months, 3 weeks ago) by greg
Changes since 2.33: +5 -1 lines
Diff to previous 2.33
fix(rpict,rvu,rcontrib): Fixed luminance estimate during spectral rendering
Fri Nov 17 20:02:07 2023 UTC (23 months, 3 weeks ago) by greg
Changes since 2.32: +6 -28 lines
Diff to previous 2.32
Wed Nov 15 18:02:53 2023 UTC (23 months, 4 weeks ago) by greg
Changes since 2.31: +31 -9 lines
Diff to previous 2.31
Tue Aug 15 00:46:56 2023 UTC (2 years, 2 months ago) by greg
Changes since 2.30: +5 -3 lines
Diff to previous 2.30
fix(rtrace,rcontrib): Added i/o format options to features list
Fri Apr 7 15:00:11 2023 UTC (2 years, 7 months ago) by greg
Diff to previous 2.29
fix(rcontrib): Bug in new code to maximize open file descriptor limit
Sat Feb 25 16:17:11 2023 UTC (2 years, 8 months ago) by greg
Changes since 2.28: +1 -3 lines
Diff to previous 2.28
fix: Stray #if statement
Fri Feb 24 18:25:36 2023 UTC (2 years, 8 months ago) by greg
Changes since 2.27: +6 -2 lines
Diff to previous 2.27
perf(rcontrib): Increased open file limit under Windows (check for crashes?)
Mon Feb 6 22:40:21 2023 UTC (2 years, 9 months ago) by greg
Changes since 2.26: +3 -3 lines
Diff to previous 2.26
Mon Feb 6 20:37:06 2023 UTC (2 years, 9 months ago) by greg
Diff to previous 2.25
fix: Actually, need to allow -features to have arguments
Mon Feb 6 20:34:17 2023 UTC (2 years, 9 months ago) by greg
Diff to previous 2.24
fix: fixed crash when executed with no arguments
Thu Oct 20 17:18:32 2022 UTC (3 years ago) by greg
Changes since 2.23: +5 -3 lines
Diff to previous 2.23
feat(rpict,rtrace,rcontrib): Added Output= list to -features
Wed Oct 19 23:10:34 2022 UTC (3 years ago) by greg
Diff to previous 2.22
fix(rcontrib): removed AdaptiveShadowTesting from feature list (didn't belong)
Wed Oct 19 21:25:20 2022 UTC (3 years ago) by greg
Changes since 2.21: +15 -1 lines
Diff to previous 2.21
Wed Mar 30 16:00:56 2022 UTC (3 years, 7 months ago) by greg
Diff to previous 2.20
fix: Renamed setcontext() to calcontext() to avoid obscure macOS naming conflict
Tue Feb 16 20:06:06 2021 UTC (4 years, 8 months ago) by greg
Changes since 2.19: +4 -3 lines
Diff to previous 2.19
feat: removed upper limit on number of modifiers in rcontrib
Wed Sep 9 21:28:19 2020 UTC (5 years, 2 months ago) by greg
Changes since 2.18: +7 -1 lines
Diff to previous 2.18
Thu Jan 18 19:43:43 2018 UTC (7 years, 9 months ago) by greg
CVS Tags: rad5R2, rad5R3
Diff to previous 2.17
Changed context names to avoid collision with user-specified .cal file names
Thu Nov 30 23:31:34 2017 UTC (7 years, 11 months ago) by greg
Diff to previous 2.16
Increased the limit on open files in rcontrib from 512 to 2048 under Windows
Wed Jun 1 03:00:06 2016 UTC (9 years, 5 months ago) by greg
Diff to previous 2.15
Added missing -c option in usage message
Thu Mar 10 18:25:46 2016 UTC (9 years, 8 months ago) by schorsch
Changes since 2.14: +10 -10 lines
Diff to previous 2.14
newer C++ compilers have a standard type named "bool". rename macro to get rid of warnings.
Tue Feb 24 19:39:27 2015 UTC (10 years, 8 months ago) by greg
Changes since 2.13: +13 -2 lines
Diff to previous 2.13
Sat Jul 19 20:03:03 2014 UTC (11 years, 3 months ago) by greg
Diff to previous 2.12
Fixed bug in parameter parser and added check during main arguments processing
Sat Jul 19 18:19:33 2014 UTC (11 years, 3 months ago) by greg
Changes since 2.11: +9 -4 lines
Sun Aug 11 13:48:48 2013 UTC (12 years, 3 months ago) by greg
Added missing check for missing modifier
Wed Aug 7 05:10:09 2013 UTC (12 years, 3 months ago) by greg
Changes since 2.9: +2 -3 lines
Sat Aug 11 01:41:35 2012 UTC (13 years, 3 months ago) by greg
Shortened context name to "RC" from "RCONTRIB"
Wed Jun 27 15:32:58 2012 UTC (13 years, 4 months ago) by greg
Changes since 2.7: +1 -3 lines
Added check for blocked shadow rays
Fri Jun 22 22:03:02 2012 UTC (13 years, 4 months ago) by greg
Moved source initialization
Fri Jun 22 21:58:45 2012 UTC (13 years, 4 months ago) by greg
More portability fixes (missing headers)
Thu Jun 21 17:14:32 2012 UTC (13 years, 4 months ago) by greg
Changes since 2.4: +1 -3 lines
Accommodations for Windows
Fri Jun 15 00:57:40 2012 UTC (13 years, 5 months ago) by greg
Simplified modifier lookup
Mon Jun 11 05:07:55 2012 UTC (13 years, 5 months ago) by greg
Changes since 2.2: +4 -1 lines
Fixed a number of bugs -- still testing
Sun Jun 10 05:25:42 2012 UTC (13 years, 5 months ago) by greg
Changes since 2.1: +3 -10 lines
Tweaks and bug fixes to new code
Sat Jun 9 07:16:47 2012 UTC (13 years, 5 months ago) by greg
