root/radiance/ray/src/rt/rcmain.c
Revision: 2.42
Committed: Thu Jun 5 18:26:46 2025 UTC (3 weeks, 5 days ago) by greg
Changes since 2.41: +1 -2 lines
fix: Removed unnecessary or redundant progname declarations
2 static const char RCSid[] = "$Id: rcmain.c,v 2.41 2025/06/04 22:34:27 greg Exp $";
5 * rcmain.c - main for rtcontrib ray contribution tracer
6 */
7
8 #include "copyright.h"
9
10 #include <signal.h>
11 #include <time.h>
12 #include "rcontrib.h"
13 #include "random.h"
14 #include "source.h"
15 #include "ambient.h"
16 #include "pmapray.h"
17 #include "pmapcontrib.h"
18
19 int gargc; /* global argc */
20 char **gargv; /* global argv */
21 char *octname; /* global octree name */
22
23 char *sigerr[NSIG]; /* signal error messages */
24
25 int nproc = 1; /* number of processes requested */
26 int nchild = 0; /* number of children (-1 in child) */
27
28 int inpfmt = 'a'; /* input format */
29 int outfmt = 'a'; /* output format */
30
31 int header = 1; /* output header? */
32 int force_open = 0; /* truncate existing output? */
33 int recover = 0; /* recover previous output? */
34 int accumulate = 1; /* input rays per output record */
35 int contrib = 0; /* computing contributions? */
36
37 int xres = 0; /* horizontal (scan) size */
38 int yres = 0; /* vertical resolution */
39
40 int using_stdout = 0; /* are we using stdout? */
41
42 int imm_irrad = 0; /* compute immediate irradiance? */
43 int lim_dist = 0; /* limit distance? */
44
45 int report_intvl = 0; /* reporting interval (seconds) */
46
47 char **modname = NULL; /* ordered modifier name list */
48 int nmods = 0; /* number of modifiers */
49 int modasiz = 0; /* allocated modifier array size */
50
51 void (*addobjnotify[8])() = {ambnotify, NULL};
52
53 char RCCONTEXT[] = "RC."; /* our special evaluation context */
54
55 #if defined(_WIN32) || defined(_WIN64)
56 #define RCONTRIB_FEATURES "Accumulation\nSummation\nRecovery\n" \
57 "ImmediateIrradiance\n" \
58 "ProgressReporting\nDistanceLimiting\n" \
59 "InputFormats=a,f,d\nOutputFormats=a,f,d,c\n" \
60 "Outputs=V,W\n" \
61 "OutputCS=RGB,spec\n"
62 #else
63 #define RCONTRIB_FEATURES "Multiprocessing\n" \
64 "Accumulation\nSummation\nRecovery\n" \
65 "ImmediateIrradiance\n" \
66 "ProgressReporting\nDistanceLimiting\n" \
67 "InputFormats=a,f,d\nOutputFormats=a,f,d,c\n" \
68 "Outputs=V,W\n" \
69 "OutputCS=RGB,spec\n"
70 #endif
71
72 static void
73 printdefaults(void) /* print default values to stdout */
74 {
75 printf("-c %-5d\t\t\t# accumulated rays per record\n", accumulate);
76 printf("-V%c\t\t\t\t# output %s\n", contrib ? '+' : '-',
77 contrib ? "contributions" : "coefficients");
78 if (imm_irrad)
79 printf("-I+\t\t\t\t# immediate irradiance on\n");
80 printf("-n %-2d\t\t\t\t# number of rendering processes\n", nproc);
81 printf("-x %-9d\t\t\t# %s\n", xres,
82 yres && xres ? "x resolution" : "flush interval");
83 printf("-y %-9d\t\t\t# y resolution\n", yres);
84 printf(lim_dist ? "-ld+\t\t\t\t# limit distance on\n" :
85 "-ld-\t\t\t\t# limit distance off\n");
86 printf(header ? "-h+\t\t\t\t# output header\n" :
87 "-h-\t\t\t\t# no header\n");
88 printf("-f%c%c\t\t\t\t# format input/output = %s/%s\n",
89 inpfmt, outfmt, formstr(inpfmt), formstr(outfmt));
90 if (report_intvl > 0)
91 printf("-t %-9d\t\t\t# time between reports\n", report_intvl);
92 printf(erract[WARNING].pf != NULL ?
93 "-w+\t\t\t\t# warning messages on\n" :
94 "-w-\t\t\t\t# warning messages off\n");
95 print_rdefaults();
96 }
97
98
99 static void
100 onsig( /* fatal signal */
101 int signo
102 )
103 {
104 static int gotsig = 0;
105
106 if (gotsig++) /* two signals and we're gone! */
107 _exit(signo);
108
109 #ifdef SIGALRM
110 alarm(15); /* allow 15 seconds to clean up */
111 signal(SIGALRM, SIG_DFL); /* make certain we do die */
112 #endif
113 eputs("signal - ");
114 eputs(sigerr[signo]);
115 eputs("\n");
116 quit(3);
117 }
118
119
120 static void
121 sigdie( /* set fatal signal */
122 int signo,
123 char *msg
124 )
125 {
126 if (signal(signo, onsig) == SIG_IGN)
127 signal(signo, SIG_IGN);
128 sigerr[signo] = msg;
129 }
130
131
132 /* set input/output format */
133 static void
134 setformat(const char *fmt)
135 {
136 switch (fmt[0]) {
137 case 'f':
138 case 'd':
139 SET_FILE_BINARY(stdin);
140 /* fall through */
141 case 'a':
142 inpfmt = fmt[0];
143 break;
144 default:
145 goto fmterr;
146 }
147 switch (fmt[1]) {
148 case '\0':
149 outfmt = inpfmt;
150 return;
151 case 'a':
152 case 'f':
153 case 'd':
154 case 'c':
155 outfmt = fmt[1];
156 break;
157 default:
158 goto fmterr;
159 }
160 if (!fmt[2])
161 return;
162 fmterr:
163 sprintf(errmsg, "Illegal i/o format: -f%s", fmt);
164 error(USER, errmsg);
165 }
166
167
168 /* Set overriding options */
169 static void
170 override_options(void)
171 {
172 shadthresh = 0;
173 ambssamp = 0;
174 ambacc = 0;
175 if (accumulate <= 0) /* no output flushing for single record */
176 xres = yres = 0;
177 }
178
179
180 int
181 main(int argc, char *argv[])
182 {
183 #define check(ol,al) if (argv[i][ol] || \
184 badarg(argc-i-1,argv+i+1,al)) \
185 goto badopt
186 #define check_bool(olen,var) switch (argv[i][olen]) { \
187 case '\0': var = !var; break; \
188 case 'y': case 'Y': case 't': case 'T': \
189 case '+': case '1': var = 1; break; \
190 case 'n': case 'N': case 'f': case 'F': \
191 case '-': case '0': var = 0; break; \
192 default: goto badopt; }
193 char *curout = NULL;
194 char *prms = NULL;
195 char *binval = NULL;
196 int bincnt = 0;
197 int rval;
198 int i;
199 /* global program name */
200 argv[0] = fixargv0(argv[0]);
201 gargv = argv;
202 gargc = argc;
203 /* feature check only? */
204 strcat(RFeatureList, RCONTRIB_FEATURES);
205 if (argc > 1 && !strcmp(argv[1], "-features"))
206 return feature_status(argc-2, argv+2);
207 #if defined(_WIN32) || defined(_WIN64) /* increase file limit to maximum */
208 for (i = 8192; i > _IOB_ENTRIES; i >>= 1)
209 if (_setmaxstdio(i) == i)
210 break;
211 #endif
212 initfunc(); /* initialize calcomp routines */
213 calcontext(RCCONTEXT);
214 /* option city */
215 for (i = 1; i < argc; i++) {
216 /* expand arguments */
217 while ((rval = expandarg(&argc, &argv, i)) > 0)
218 ;
219 if (rval < 0) {
220 sprintf(errmsg, "cannot expand '%s'", argv[i]);
221 error(SYSTEM, errmsg);
222 }
223 if (argv[i] == NULL || argv[i][0] != '-')
224 break; /* break from options */
225 if (!strcmp(argv[i], "-version")) {
226 puts(VersionID);
227 quit(0);
228 }
229 if (!strcmp(argv[i], "-defaults") ||
230 !strcmp(argv[i], "-help")) {
231 override_options();
232 printdefaults();
233 quit(0);
234 }
235 rval = getrenderopt(argc-i, argv+i);
236 if (rval >= 0) {
237 i += rval;
238 continue;
239 }
240 switch (argv[i][1]) {
241 case 'n': /* number of cores */
242 check(2,"i");
243 nproc = atoi(argv[++i]);
244 if (nproc <= 0)
245 error(USER, "bad number of processes");
246 break;
247 case 'V': /* output contributions */
248 check_bool(2,contrib);
249 break;
250 case 'x': /* x resolution */
251 check(2,"i");
252 xres = atoi(argv[++i]);
253 break;
254 case 'y': /* y resolution */
255 check(2,"i");
256 yres = atoi(argv[++i]);
257 break;
258 case 'w': /* warnings */
259 rval = (erract[WARNING].pf != NULL);
260 check_bool(2,rval);
261 if (rval) erract[WARNING].pf = wputs;
262 else erract[WARNING].pf = NULL;
263 break;
264 case 'l': /* limit distance */
265 if (argv[i][2] != 'd')
266 goto badopt;
267 check_bool(3,lim_dist);
268 break;
269 case 'I': /* immed. irradiance */
270 check_bool(2,imm_irrad);
271 break;
272 case 'f': /* force or format */
273 if (argv[i][2] == 'o') {
274 check_bool(3,force_open);
275 break;
276 }
277 setformat(argv[i]+2);
278 break;
279 case 'o': /* output */
280 check(2,"s");
281 curout = argv[++i];
282 break;
283 case 'r': /* recover output */
284 check_bool(2,recover);
285 break;
286 case 'h': /* header output */
287 check_bool(2,header);
288 break;
289 case 'p': /* parameter setting(s) */
290 check(2,"s");
291 set_eparams(prms = argv[++i]);
292 break;
293 case 'c': /* sample count */
294 check(2,"i");
295 accumulate = atoi(argv[++i]);
296 break;
297 case 'b': /* bin expression/count */
298 if (argv[i][2] == 'n') {
299 check(3,"s");
300 bincnt = (int)(eval(argv[++i]) + .5);
301 break;
302 }
303 check(2,"s");
304 binval = argv[++i];
305 break;
306 case 'm': /* modifier name */
307 check(2,"s");
308 addmodifier(argv[++i], curout, prms, binval, bincnt);
309 break;
310 case 'M': /* modifier file */
311 check(2,"s");
312 addmodfile(argv[++i], curout, prms, binval, bincnt);
313 break;
314 case 't': /* reporting interval */
315 check(2,"i");
316 report_intvl = atoi(argv[++i]);
317 break;
318 default:
319 goto badopt;
320 }
321 }
322 if (nmods <= 0)
323 error(USER, "missing required modifier argument");
324 /* override some option settings */
325 override_options();
326 /* set/check spectral sampling */
327 if (setspectrsamp(CNDX, WLPART) < 0)
328 error(USER, "unsupported spectral sampling");
329 /* initialize object types */
330 initotypes();
331 /* initialize urand */
332 if (rand_samp) {
333 srandom((long)time(0));
334 initurand(0);
335 } else {
336 srandom(0L);
337 initurand(2048);
338 }
339 /* set up signal handling */
340 sigdie(SIGINT, "Interrupt");
341 #ifdef SIGHUP
342 sigdie(SIGHUP, "Hangup");
343 #endif
344 sigdie(SIGTERM, "Terminate");
345 #ifdef SIGPIPE
346 sigdie(SIGPIPE, "Broken pipe");
347 #endif
348 #ifdef SIGALRM
349 sigdie(SIGALRM, "Alarm clock");
350 #endif
351 #ifdef SIGXCPU
352 sigdie(SIGXCPU, "CPU limit exceeded");
353 sigdie(SIGXFSZ, "File size exceeded");
354 #endif
355 #ifdef NICE
356 nice(NICE); /* lower priority */
357 #endif
358 /* get octree */
359 if (i == argc)
360 octname = NULL;
361 else if (i == argc-1)
362 octname = argv[i];
363 else
364 goto badopt;
365 if (octname == NULL)
366 error(USER, "missing octree argument");
367
368 readoct(octname, ~(IO_FILES|IO_INFO), &thescene, NULL);
369 nsceneobjs = nobjects;
370
371 /* PMAP: set up & load photon maps */
372 ray_init_pmap();
373
374 marksources(); /* find and mark sources */
375
376 /* PMAP: init photon map for light source contributions */
377 initPmapContrib(&modconttab, nmods);
378
379 setambient(); /* initialize ambient calculation */
380
381 rcontrib(); /* trace ray contributions (loop) */
382
383 /* PMAP: free photon maps */
384 ray_done_pmap();
385
386 quit(0); /* exit clean */
387
388 badopt:
389 fprintf(stderr,
390 "Usage: %s [-n nprocs][-V][-c count][-r][-e expr][-f source][-o ospec][-p p1=V1,p2=V2][-b binv][-bn N] {-m mod | -M file} [rtrace options] octree\n",
391 progname);
392 sprintf(errmsg, "command line error at '%s'", argv[i]);
393 error(USER, errmsg);
394 return(1); /* pro forma return */
395
396 #undef check
397 #undef check_bool
398 }
399
400
401 void
402 wputs( /* warning output function */
403 const char *s
404 )
405 {
406 int lasterrno = errno;
407 if (erract[WARNING].pf == NULL)
408 return; /* called by calcomp or someone */
409 eputs(s);
410 errno = lasterrno;
411 }
412
413
414 void
415 eputs( /* put string to stderr */
416 const char *s
417 )
418 {
419 static int midline = 0;
420
421 if (!*s)
422 return;
423 if (!midline++) {
424 fputs(progname, stderr);
425 fputs(": ", stderr);
426 }
427 fputs(s, stderr);
428 if (s[strlen(s)-1] == '\n') {
429 fflush(stderr);
430 midline = 0;
431 }
432 }
