fix: Avoid array bounds errors in dimlist[] in deep ray trees
fix: Removed unnecessary or redundant progname declarations
fix: Fixed reference to fixargv0()
fix(rcontrib,rxcontrib): reinstated .cal redefinition warnings
fix(rcontrib,rxcontrib): Eliminated spurious warning messages
feat: Added reporting interval to defaults output and removed unnecessary amb sync
feat(rpict,rtrace,rcontrib): Added OutputCS to features list
fix(rcontrib, rpict, rvu): Better check for spectral sampling
fix(rpict,rvu,rcontrib): Fixed luminance estimate during spectral rendering
fix(rtrace,rcontrib): Added i/o format options to features list
fix(rcontrib): Bug in new code to maximize open file descriptor limit
fix: Stray #if statement
perf(rcontrib): Increased open file limit under Windows (check for crashes?)
fix: Actually, need to allow -features to have arguments
fix: fixed crash when executed with no arguments
feat(rpict,rtrace,rcontrib): Added Output= list to -features
fix(rcontrib): removed AdaptiveShadowTesting from feature list (didn't belong)
fix: Renamed setcontext() to calcontext() to avoid obscure macOS naming conflict
feat: removed upper limit on number of modifiers in rcontrib
Changed context names to avoid collision with user-specified .cal file names
Increased the limit on open files in rcontrib from 512 to 2048 under Windows
Added missing -c option in usage message
newer C++ compilers have a standard type named "bool". rename macro to get rid of warnings.
Fixed bug in parameter parser and added check during main arguments processing
Added missing check for missing modifier
Shortened context name to "RC" from "RCONTRIB"
Added check for blocked shadow rays
Moved source initialization
More portability fixes (missing headers)
Accommodations for Windows
Simplified modifier lookup
Fixed a number of bugs -- still testing
Tweaks and bug fixes to new code
