root/radiance/ray/src/rt/rc3.c
Sun May 27 18:35:57 2018 UTC (7 years ago) by greg
CVS Tags: rad5R2, rad5R3
Changes since 2.22: +3 -1 lines
Diff to previous 2.22
Added internal error check
Thu Aug 18 00:52:48 2016 UTC (8 years, 9 months ago) by greg
Diff to previous 2.21
Fri Mar 4 02:48:14 2016 UTC (9 years, 3 months ago) by greg
Changes since 2.20: +35 -37 lines
Diff to previous 2.20
Made quitting rvu, rholo and rcontrib quicker with multiple processes on Unix
Sun Aug 23 00:17:12 2015 UTC (9 years, 9 months ago) by greg
Changes since 2.19: +6 -5 lines
Diff to previous 2.19
Minor tweaks & performance improvements for rcontrib file locking
Fri Aug 21 18:21:05 2015 UTC (9 years, 9 months ago) by greg
Diff to previous 2.18
Hopefull fix to deadlock issues under Mac OS X 10.10.x (Yosemite)
Thu Nov 15 19:41:03 2012 UTC (12 years, 6 months ago) by greg
Changes since 2.17: +20 -27 lines
Diff to previous 2.17
Thu Nov 15 15:26:52 2012 UTC (12 years, 6 months ago) by greg
Changes since 2.16: +21 -14 lines
Diff to previous 2.16
Fixed bug in handling of -c >1 with zero vectors -- trim pass to follow
Fri Jun 22 21:58:45 2012 UTC (12 years, 11 months ago) by greg
Changes since 2.15: +1 -2 lines
Diff to previous 2.15
More portability fixes (missing headers)
Thu Jun 21 17:14:32 2012 UTC (12 years, 11 months ago) by greg
Changes since 2.14: +3 -2 lines
Diff to previous 2.14
Accommodations for Windows
Wed Jun 20 21:36:34 2012 UTC (12 years, 11 months ago) by greg
Diff to previous 2.13
Added missing include file
Tue Jun 19 01:27:13 2012 UTC (12 years, 11 months ago) by greg
Diff to previous 2.12
Fixed reporting of broken pipe on completion with -c N
Tue Jun 19 00:12:08 2012 UTC (12 years, 11 months ago) by greg
Added quick-exit mode and fixed bug in recovery option with -c > 1
Sat Jun 16 17:30:13 2012 UTC (12 years, 11 months ago) by greg
Minor fixes
Sat Jun 16 17:09:49 2012 UTC (12 years, 11 months ago) by greg
Changes since 2.9: +111 -26 lines
Improved performance for -c 0 option
Thu Jun 14 05:13:25 2012 UTC (12 years, 11 months ago) by greg
Changes since 2.8: +15 -32 lines
Simplified creation of child process
Tue Jun 12 22:46:45 2012 UTC (12 years, 11 months ago) by greg
Fix for -ld+ option
Tue Jun 12 22:40:30 2012 UTC (12 years, 11 months ago) by greg
Bug fix in vector normalization
Tue Jun 12 17:20:44 2012 UTC (12 years, 11 months ago) by greg
Changes since 2.5: +90 -61 lines
Further efficiency improvements
Tue Jun 12 01:06:59 2012 UTC (12 years, 11 months ago) by greg
Changes since 2.4: +25 -22 lines
Minor efficiency improvements
Mon Jun 11 05:07:55 2012 UTC (12 years, 11 months ago) by greg
Changes since 2.3: +59 -23 lines
Fixed a number of bugs -- still testing
Sun Jun 10 05:25:42 2012 UTC (12 years, 11 months ago) by greg
Changes since 2.2: +33 -26 lines
Tweaks and bug fixes to new code
Sat Jun 9 16:47:27 2012 UTC (12 years, 11 months ago) by greg
Changes since 2.1: +64 -35 lines
Improved process queue handling
Sat Jun 9 07:16:47 2012 UTC (12 years, 11 months ago) by greg
