root/radiance/ray/src/rt/rc2.c
Revision: 2.25
Committed: Fri Apr 7 00:03:26 2023 UTC (2 years, 1 month ago) by greg
fix(rcontrib): Fixed potential string overrun while printing header
2 static const char RCSid[] = "$Id: rc2.c,v 2.24 2019/09/04 20:19:51 greg Exp $";
5 * Accumulate ray contributions for a set of materials
6 * File i/o and recovery
7 */
8
9 #include <ctype.h>
10 #include "platform.h"
11 #include "rcontrib.h"
12 #include "resolu.h"
13
14 /* Close output stream and free record */
15 static void
16 closestream(void *p)
17 {
18 STREAMOUT *sop = (STREAMOUT *)p;
19
20 if (sop->ofp != NULL) {
21 int status = 0;
22 if (sop->outpipe)
23 status = pclose(sop->ofp);
24 else if (sop->ofp != stdout)
25 status = fclose(sop->ofp);
26 if (status)
27 error(SYSTEM, "error closing output stream");
28 }
29 free(p);
30 }
31
32 LUTAB ofiletab = LU_SINIT(free,closestream); /* output file table */
33
34 #define OF_MODIFIER 01
35 #define OF_BIN 02
36
37 /************************** STREAM & FILE I/O ***************************/
38
39 /* Construct output file name and return flags whether modifier/bin present */
40 static int
41 ofname(char *oname, const char *ospec, const char *mname, int bn)
42 {
43 const char *mnp = NULL;
44 const char *bnp = NULL;
45 const char *cp;
46
47 if (ospec == NULL)
48 return(-1);
49 for (cp = ospec; *cp; cp++) /* check format position(s) */
50 if (*cp == '%') {
51 do
52 ++cp;
53 while (isdigit(*cp));
54 switch (*cp) {
55 case '%':
56 break;
57 case 's':
58 if (mnp != NULL)
59 return(-1);
60 mnp = cp;
61 break;
62 case 'd':
63 case 'i':
64 case 'o':
65 case 'x':
66 case 'X':
67 if (bnp != NULL)
68 return(-1);
69 bnp = cp;
70 break;
71 default:
72 return(-1);
73 }
74 }
75 if (mnp != NULL) { /* create file name */
76 if (bnp != NULL) {
77 if (bnp > mnp)
78 sprintf(oname, ospec, mname, bn);
79 else
80 sprintf(oname, ospec, bn, mname);
81 return(OF_MODIFIER|OF_BIN);
82 }
83 sprintf(oname, ospec, mname);
84 return(OF_MODIFIER);
85 }
86 if (bnp != NULL) {
87 sprintf(oname, ospec, bn);
88 return(OF_BIN);
89 }
90 strcpy(oname, ospec);
91 return(0);
92 }
93
94
95 /* Write header to the given output stream */
96 static void
97 printheader(FILE *fout, const char *info)
98 {
99 extern char VersionID[];
100 /* copy octree header */
101 if (octname[0] == '!') {
102 newheader("RADIANCE", fout);
103 fputs(octname+1, fout);
104 if (octname[strlen(octname)-1] != '\n')
105 fputc('\n', fout);
106 } else {
107 FILE *fin = fopen(octname, (outfmt=='a') ? "r" : "rb");
108 if (fin == NULL)
109 quit(1);
110 checkheader(fin, OCTFMT, fout);
111 fclose(fin);
112 }
113 printargs(gargc-1, gargv, fout); /* add our command */
114 fprintf(fout, "SOFTWARE= %s\n", VersionID);
115 fputnow(fout);
116 fputs("NCOMP=3\n", fout); /* always RGB */
117 if (info != NULL) /* add extra info if given */
118 fputs(info, fout);
119 if ((outfmt == 'f') | (outfmt == 'd'))
120 fputendian(fout);
121 fputformat(formstr(outfmt), fout);
122 fputc('\n', fout); /* empty line ends header */
123 }
124
125
126 /* Write resolution string to given output stream */
127 static void
128 printresolu(FILE *fout, int xr, int yr)
129 {
130 if ((xr > 0) & (yr > 0)) /* resolution string */
131 fprtresolu(xr, yr, fout);
132 }
133
134
135 /* Get output stream pointer (open and write header if new and noopen==0) */
136 STREAMOUT *
137 getostream(const char *ospec, const char *mname, int bn, int noopen)
138 {
139 static STREAMOUT stdos;
140 char info[1024];
141 int ofl;
142 char oname[1024];
143 LUENT *lep;
144 STREAMOUT *sop;
145 char *cp;
146
147 info[0] = '\0';
148 if (ospec == NULL) { /* use stdout? */
149 if (!noopen & !using_stdout) {
150 if (outfmt != 'a')
151 SET_FILE_BINARY(stdout);
152 #ifdef getc_unlocked
153 flockfile(stdout); /* avoid lock/unlock overhead */
154 #endif
155 if (header) {
156 cp = info;
157 if (yres > 0) {
158 sprintf(cp, "NROWS=%d\n", yres *
159 (xres + !xres) );
160 while (*cp) ++cp;
161 }
162 if ((xres <= 0) | (stdos.reclen > 1))
163 sprintf(cp, "NCOLS=%d\n", stdos.reclen);
164 printheader(stdout, info);
165 }
166 if (stdos.reclen == 1)
167 printresolu(stdout, xres, yres);
168 if (waitflush > 0)
169 fflush(stdout);
170 stdos.xr = xres; stdos.yr = yres;
171 using_stdout = 1;
172 }
173 stdos.ofp = stdout;
174 stdos.reclen += noopen;
175 return(&stdos);
176 }
177 ofl = ofname(oname, ospec, mname, bn); /* get output name */
178 if (ofl < 0) {
179 sprintf(errmsg, "bad output format '%s'", ospec);
180 error(USER, errmsg);
181 }
182 lep = lu_find(&ofiletab, oname); /* look it up */
183 if (lep->key == NULL) /* new entry */
184 lep->key = strcpy((char *)malloc(strlen(oname)+1), oname);
185 sop = (STREAMOUT *)lep->data;
186 if (sop == NULL) { /* allocate stream */
187 sop = (STREAMOUT *)malloc(sizeof(STREAMOUT));
188 if (sop == NULL)
189 error(SYSTEM, "out of memory in getostream");
190 sop->outpipe = (oname[0] == '!');
191 sop->reclen = 0;
192 sop->ofp = NULL; /* open iff noopen==0 */
193 sop->xr = xres; sop->yr = yres;
194 lep->data = (char *)sop;
195 if (!sop->outpipe & !force_open & !recover &&
196 access(oname, F_OK) == 0) {
197 errno = EEXIST; /* file exists */
198 goto openerr;
199 }
200 } else if (noopen && outfmt == 'c' && /* stream exists to picture? */
201 (sop->xr > 0) & (sop->yr > 0)) {
202 if (ofl & OF_BIN)
203 return(NULL); /* let caller offset bins */
204 sprintf(errmsg, "output '%s' not a valid picture", oname);
205 error(WARNING, errmsg);
206 }
207 if (!noopen && sop->ofp == NULL) { /* open output stream */
208 if (oname[0] == '!') /* output to command */
209 sop->ofp = popen(oname+1, "w");
210 else /* else open file */
211 sop->ofp = fopen(oname, "w");
212 if (sop->ofp == NULL)
213 goto openerr;
214 if (outfmt != 'a')
215 SET_FILE_BINARY(sop->ofp);
216 #ifdef getc_unlocked
217 flockfile(sop->ofp); /* avoid lock/unlock overhead */
218 #endif
219 if (accumulate > 0) { /* global resolution */
220 sop->xr = xres; sop->yr = yres;
221 }
222 if (header) {
223 cp = info;
224 if (ofl & OF_MODIFIER || sop->reclen == 1) {
225 sprintf(cp, "MODIFIER=%s\n", mname);
226 while (*cp) ++cp;
227 }
228 if (ofl & OF_BIN) {
229 sprintf(cp, "BIN=%d\n", bn);
230 while (*cp) ++cp;
231 }
232 if (sop->yr > 0) {
233 sprintf(cp, "NROWS=%d\n", sop->yr *
234 (sop->xr + !sop->xr) );
235 while (*cp) ++cp;
236 }
237 if ((sop->xr <= 0) | (sop->reclen > 1))
238 sprintf(cp, "NCOLS=%d\n", sop->reclen);
239 printheader(sop->ofp, info);
240 }
241 if (sop->reclen == 1)
242 printresolu(sop->ofp, sop->xr, sop->yr);
243 if (waitflush > 0)
244 fflush(sop->ofp);
245 }
246 sop->reclen += noopen; /* add to length if noopen */
247 return(sop); /* return output stream */
248 openerr:
249 sprintf(errmsg, "cannot open '%s' for writing", oname);
250 error(SYSTEM, errmsg);
251 return(NULL); /* pro forma return */
252 }
253
254
255 /* Get a vector from stdin */
256 int
257 getvec(FVECT vec)
258 {
259 float vf[3];
260 double vd[3];
261 char buf[32];
262 int i;
263
264 switch (inpfmt) {
265 case 'a': /* ascii */
266 for (i = 0; i < 3; i++) {
267 if (fgetword(buf, sizeof(buf), stdin) == NULL ||
268 !isflt(buf))
269 return(-1);
270 vec[i] = atof(buf);
271 }
272 break;
273 case 'f': /* binary float */
274 if (getbinary((char *)vf, sizeof(float), 3, stdin) != 3)
275 return(-1);
276 VCOPY(vec, vf);
277 break;
278 case 'd': /* binary double */
279 if (getbinary((char *)vd, sizeof(double), 3, stdin) != 3)
280 return(-1);
281 VCOPY(vec, vd);
282 break;
283 default:
284 error(CONSISTENCY, "botched input format");
285 }
286 return(0);
287 }
288
289
290 /* Put out ray contribution to file */
291 static void
292 put_contrib(const DCOLOR cnt, FILE *fout)
293 {
294 double sf = 1;
295 COLOR fv;
296 COLR cv;
297
298 if (accumulate > 1)
299 sf = 1./(double)accumulate;
300 switch (outfmt) {
301 case 'a':
302 if (accumulate > 1)
303 fprintf(fout, "%.6e\t%.6e\t%.6e\t",
304 sf*cnt[0], sf*cnt[1], sf*cnt[2]);
305 else
306 fprintf(fout, "%.6e\t%.6e\t%.6e\t",
307 cnt[0], cnt[1], cnt[2]);
308 break;
309 case 'f':
310 if (accumulate > 1) {
311 copycolor(fv, cnt);
312 scalecolor(fv, sf);
313 } else
314 copycolor(fv, cnt);
315 putbinary(fv, sizeof(float), 3, fout);
316 break;
317 case 'd':
318 if (accumulate > 1) {
319 DCOLOR dv;
320 copycolor(dv, cnt);
321 scalecolor(dv, sf);
322 putbinary(dv, sizeof(double), 3, fout);
323 } else
324 putbinary(cnt, sizeof(double), 3, fout);
325 break;
326 case 'c':
327 if (accumulate > 1)
328 setcolr(cv, sf*cnt[0], sf*cnt[1], sf*cnt[2]);
329 else
330 setcolr(cv, cnt[0], cnt[1], cnt[2]);
331 putbinary(cv, sizeof(cv), 1, fout);
332 break;
333 default:
334 error(INTERNAL, "botched output format");
335 }
336 }
337
338
339 /* Output modifier values to appropriate stream(s) */
340 void
341 mod_output(MODCONT *mp)
342 {
343 STREAMOUT *sop = getostream(mp->outspec, mp->modname, mp->bin0, 0);
344 int j;
345
346 put_contrib(mp->cbin[0], sop->ofp);
347 if (mp->nbins > 3 && /* minor optimization */
348 sop == getostream(mp->outspec, mp->modname, mp->bin0+1, 0)) {
349 for (j = 1; j < mp->nbins; j++)
350 put_contrib(mp->cbin[j], sop->ofp);
351 } else {
352 for (j = 1; j < mp->nbins; j++) {
353 sop = getostream(mp->outspec, mp->modname, mp->bin0+j, 0);
354 put_contrib(mp->cbin[j], sop->ofp);
355 }
356 }
357 }
358
359
360 /* callback to output newline to ASCII file and/or flush as requested */
361 static int
362 puteol(const LUENT *e, void *p)
363 {
364 STREAMOUT *sop = (STREAMOUT *)e->data;
365
366 if (outfmt == 'a')
367 putc('\n', sop->ofp);
368 if (!waitflush)
369 fflush(sop->ofp);
370 if (ferror(sop->ofp)) {
371 sprintf(errmsg, "write error on file '%s'", e->key);
372 error(SYSTEM, errmsg);
373 }
374 return(0);
375 }
376
377
378 /* Terminate record output and flush if time */
379 void
380 end_record()
381 {
382 --waitflush;
383 lu_doall(&ofiletab, &puteol, NULL);
384 if (using_stdout & (outfmt == 'a'))
385 putc('\n', stdout);
386 if (!waitflush) {
387 waitflush = (yres > 0) & (xres > 1) ? 0 : xres;
388 if (using_stdout)
389 fflush(stdout);
390 }
391 }
392
393 /************************** PARTIAL RESULTS RECOVERY ***********************/
394
395 /* Get ray contribution from previous file */
396 static int
397 get_contrib(DCOLOR cnt, FILE *finp)
398 {
399 COLOR fv;
400 COLR cv;
401
402 switch (outfmt) {
403 case 'a':
404 return(fscanf(finp,"%lf %lf %lf",&cnt[0],&cnt[1],&cnt[2]) == 3);
405 case 'f':
406 if (getbinary(fv, sizeof(fv[0]), 3, finp) != 3)
407 return(0);
408 copycolor(cnt, fv);
409 return(1);
410 case 'd':
411 return(getbinary(cnt, sizeof(cnt[0]), 3, finp) == 3);
412 case 'c':
413 if (getbinary(cv, sizeof(cv), 1, finp) != 1)
414 return(0);
415 colr_color(fv, cv);
416 copycolor(cnt, fv);
417 return(1);
418 default:
419 error(INTERNAL, "botched output format");
420 }
421 return(0); /* pro forma return */
422 }
423
424
425 /* Close output file opened for input */
426 static int
427 myclose(const LUENT *e, void *p)
428 {
429 STREAMOUT *sop = (STREAMOUT *)e->data;
430
431 if (sop->ofp == NULL)
432 return(0);
433 fclose(sop->ofp);
434 sop->ofp = NULL;
435 return(0);
436 }
437
438
439 /* Load previously accumulated values */
440 void
441 reload_output()
442 {
443 int i, j;
444 MODCONT *mp;
445 int ofl;
446 char oname[1024];
447 char *fmode = "rb";
448 char *outvfmt;
449 LUENT *oent;
450 int xr, yr;
451 STREAMOUT *sop;
452 DCOLOR rgbv;
453
454 if (outfmt == 'a')
455 fmode = "r";
456 outvfmt = formstr(outfmt);
457 /* reload modifier values */
458 for (i = 0; i < nmods; i++) {
459 mp = (MODCONT *)lu_find(&modconttab,modname[i])->data;
460 if (mp->outspec == NULL)
461 error(USER, "cannot reload from stdout");
462 if (mp->outspec[0] == '!')
463 error(USER, "cannot reload from command");
464 for (j = 0; j < mp->nbins; j++) { /* load each modifier bin */
465 ofl = ofname(oname, mp->outspec, mp->modname, mp->bin0+j);
466 if (ofl < 0)
467 error(USER, "bad output file specification");
468 oent = lu_find(&ofiletab, oname);
469 if (oent->data == NULL)
470 error(INTERNAL, "unallocated stream in reload_output()");
471 sop = (STREAMOUT *)oent->data;
472 if (sop->ofp == NULL) { /* open output as input */
473 sop->ofp = fopen(oname, fmode);
474 if (sop->ofp == NULL) {
475 sprintf(errmsg, "missing reload file '%s'",
476 oname);
477 error(WARNING, errmsg);
478 break;
479 }
480 #ifdef getc_unlocked
481 flockfile(sop->ofp);
482 #endif
483 if (header && checkheader(sop->ofp, outvfmt, NULL) != 1) {
484 sprintf(errmsg, "format mismatch for '%s'",
485 oname);
486 error(USER, errmsg);
487 }
488 if ((sop->reclen == 1) & (sop->xr > 0) & (sop->yr > 0) &&
489 (!fscnresolu(&xr, &yr, sop->ofp) ||
490 (xr != sop->xr) |
491 (yr != sop->yr))) {
492 sprintf(errmsg, "resolution mismatch for '%s'",
493 oname);
494 error(USER, errmsg);
495 }
496 }
497 /* read in RGB value */
498 if (!get_contrib(rgbv, sop->ofp)) {
499 if (!j) {
500 fclose(sop->ofp);
501 break; /* ignore empty file */
502 }
503 if (j < mp->nbins) {
504 sprintf(errmsg, "missing data in '%s'",
505 oname);
506 error(USER, errmsg);
507 }
508 break;
509 }
510 copycolor(mp->cbin[j], rgbv);
511 }
512 }
513 lu_doall(&ofiletab, &myclose, NULL); /* close all files */
514 }
515
516
517 /* Seek on the given output file */
518 static int
519 myseeko(const LUENT *e, void *p)
520 {
521 STREAMOUT *sop = (STREAMOUT *)e->data;
522 off_t nbytes = *(off_t *)p;
523
524 if (sop->reclen > 1)
525 nbytes *= (off_t)sop->reclen;
526 if (fseeko(sop->ofp, nbytes, SEEK_CUR) < 0) {
527 sprintf(errmsg, "seek error on file '%s'", e->key);
528 error(SYSTEM, errmsg);
529 }
530 return(0);
531 }
532
533
534 /* Recover output if possible */
535 void
536 recover_output()
537 {
538 off_t lastout = -1;
539 int outvsiz, recsiz;
540 char *outvfmt;
541 int i, j;
542 MODCONT *mp;
543 int ofl;
544 char oname[1024];
545 LUENT *oent;
546 STREAMOUT *sop;
547 off_t nvals;
548 int xr, yr;
549
550 switch (outfmt) {
551 case 'a':
552 error(USER, "cannot recover ASCII output");
553 return;
554 case 'f':
555 outvsiz = sizeof(float)*3;
556 break;
557 case 'd':
558 outvsiz = sizeof(double)*3;
559 break;
560 case 'c':
561 outvsiz = sizeof(COLR);
562 break;
563 default:
564 error(INTERNAL, "botched output format");
565 return;
566 }
567 outvfmt = formstr(outfmt);
568 /* check modifier outputs */
569 for (i = 0; i < nmods; i++) {
570 mp = (MODCONT *)lu_find(&modconttab,modname[i])->data;
571 if (mp->outspec == NULL)
572 error(USER, "cannot recover from stdout");
573 if (mp->outspec[0] == '!')
574 error(USER, "cannot recover from command");
575 for (j = 0; j < mp->nbins; j++) { /* check each bin's file */
576 ofl = ofname(oname, mp->outspec, mp->modname, mp->bin0+j);
577 if (ofl < 0)
578 error(USER, "bad output file specification");
579 oent = lu_find(&ofiletab, oname);
580 if (oent->data == NULL)
581 error(INTERNAL, "unallocated stream in recover_output()");
582 sop = (STREAMOUT *)oent->data;
583 if (sop->ofp != NULL) { /* already open? */
584 if (ofl & OF_BIN)
585 continue;
586 break;
587 }
588 /* open output */
589 sop->ofp = fopen(oname, "rb+");
590 if (sop->ofp == NULL) {
591 sprintf(errmsg, "missing recover file '%s'",
592 oname);
593 error(WARNING, errmsg);
594 lastout = 0;
595 break;
596 }
597 nvals = lseek(fileno(sop->ofp), 0, SEEK_END);
598 if (nvals <= 0) {
599 lastout = 0; /* empty output, quit here */
600 fclose(sop->ofp);
601 break;
602 }
603 recsiz = outvsiz * sop->reclen;
604
605 lseek(fileno(sop->ofp), 0, SEEK_SET);
606 if (header && checkheader(sop->ofp, outvfmt, NULL) != 1) {
607 sprintf(errmsg, "format mismatch for '%s'",
608 oname);
609 error(USER, errmsg);
610 }
611 if ((sop->reclen == 1) & (sop->xr > 0) & (sop->yr > 0) &&
612 (!fscnresolu(&xr, &yr, sop->ofp) ||
613 (xr != sop->xr) |
614 (yr != sop->yr))) {
615 sprintf(errmsg, "resolution mismatch for '%s'",
616 oname);
617 error(USER, errmsg);
618 }
619 nvals = (nvals - (off_t)ftell(sop->ofp)) / recsiz;
620 if ((lastout < 0) | (nvals < lastout))
621 lastout = nvals;
622 if (!(ofl & OF_BIN))
623 break; /* no bin separation */
624 }
625 if (!lastout) { /* empty output */
626 error(WARNING, "no previous data to recover");
627 /* reclose all outputs */
628 lu_doall(&ofiletab, &myclose, NULL);
629 return;
630 }
631 }
632 if (lastout < 0) {
633 error(WARNING, "no output files to recover");
634 return;
635 }
636 if (raysleft && lastout >= raysleft/accumulate) {
637 error(WARNING, "output appears to be complete");
638 /* XXX should read & discard input? */
639 quit(0);
640 }
641 /* seek on all files */
642 nvals = lastout * outvsiz;
643 lu_doall(&ofiletab, &myseeko, &nvals);
644 /* skip repeated input */
645 lastout *= accumulate;
646 for (nvals = 0; nvals < lastout; nvals++) {
647 FVECT vdummy;
648 if (getvec(vdummy) < 0 || getvec(vdummy) < 0)
649 error(USER, "unexpected EOF on input");
650 }
651 lastray = lastdone = (RNUMBER)lastout;
652 if (raysleft)
653 raysleft -= lastray;
654 }
