1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: rc2.c,v 2.20 2016/09/16 04:49:15 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Accumulate ray contributions for a set of materials |
6 |
* File i/o and recovery |
7 |
8 |
9 |
#include <ctype.h> |
10 |
#include "platform.h" |
11 |
#include "rcontrib.h" |
12 |
#include "resolu.h" |
13 |
14 |
/* Close output stream and free record */ |
15 |
static void |
16 |
closestream(void *p) |
17 |
18 |
STREAMOUT *sop = (STREAMOUT *)p; |
19 |
20 |
if (sop->ofp != NULL) { |
21 |
int status = 0; |
22 |
if (sop->outpipe) |
23 |
status = pclose(sop->ofp); |
24 |
else if (sop->ofp != stdout) |
25 |
status = fclose(sop->ofp); |
26 |
if (status) |
27 |
error(SYSTEM, "error closing output stream"); |
28 |
29 |
free(p); |
30 |
31 |
32 |
LUTAB ofiletab = LU_SINIT(free,closestream); /* output file table */ |
33 |
34 |
#define OF_MODIFIER 01 |
35 |
#define OF_BIN 02 |
36 |
37 |
/************************** STREAM & FILE I/O ***************************/ |
38 |
39 |
/* Construct output file name and return flags whether modifier/bin present */ |
40 |
static int |
41 |
ofname(char *oname, const char *ospec, const char *mname, int bn) |
42 |
43 |
const char *mnp = NULL; |
44 |
const char *bnp = NULL; |
45 |
const char *cp; |
46 |
47 |
if (ospec == NULL) |
48 |
return(-1); |
49 |
for (cp = ospec; *cp; cp++) /* check format position(s) */ |
50 |
if (*cp == '%') { |
51 |
do |
52 |
++cp; |
53 |
while (isdigit(*cp)); |
54 |
switch (*cp) { |
55 |
case '%': |
56 |
break; |
57 |
case 's': |
58 |
if (mnp != NULL) |
59 |
return(-1); |
60 |
mnp = cp; |
61 |
break; |
62 |
case 'd': |
63 |
case 'i': |
64 |
case 'o': |
65 |
case 'x': |
66 |
case 'X': |
67 |
if (bnp != NULL) |
68 |
return(-1); |
69 |
bnp = cp; |
70 |
break; |
71 |
default: |
72 |
return(-1); |
73 |
74 |
75 |
if (mnp != NULL) { /* create file name */ |
76 |
if (bnp != NULL) { |
77 |
if (bnp > mnp) |
78 |
sprintf(oname, ospec, mname, bn); |
79 |
else |
80 |
sprintf(oname, ospec, bn, mname); |
81 |
return(OF_MODIFIER|OF_BIN); |
82 |
83 |
sprintf(oname, ospec, mname); |
84 |
return(OF_MODIFIER); |
85 |
86 |
87 |
sprintf(oname, ospec, bn); |
88 |
return(OF_BIN); |
89 |
90 |
strcpy(oname, ospec); |
91 |
return(0); |
92 |
93 |
94 |
95 |
/* Write header to the given output stream */ |
96 |
static void |
97 |
printheader(FILE *fout, const char *info) |
98 |
99 |
extern char VersionID[]; |
100 |
/* copy octree header */ |
101 |
if (octname[0] == '!') { |
102 |
newheader("RADIANCE", fout); |
103 |
fputs(octname+1, fout); |
104 |
if (octname[strlen(octname)-1] != '\n') |
105 |
fputc('\n', fout); |
106 |
} else { |
107 |
FILE *fin = fopen(octname, (outfmt=='a') ? "r" : "rb"); |
108 |
if (fin == NULL) |
109 |
quit(1); |
110 |
checkheader(fin, OCTFMT, fout); |
111 |
fclose(fin); |
112 |
113 |
printargs(gargc-1, gargv, fout); /* add our command */ |
114 |
fprintf(fout, "SOFTWARE= %s\n", VersionID); |
115 |
fputnow(fout); |
116 |
fputs("NCOMP=3\n", fout); /* always RGB */ |
117 |
if (info != NULL) /* add extra info if given */ |
118 |
fputs(info, fout); |
119 |
fputformat(formstr(outfmt), fout); |
120 |
fputc('\n', fout); /* empty line ends header */ |
121 |
122 |
123 |
124 |
/* Write resolution string to given output stream */ |
125 |
static void |
126 |
printresolu(FILE *fout, int xr, int yr) |
127 |
128 |
if ((xr > 0) & (yr > 0)) /* resolution string */ |
129 |
fprtresolu(xr, yr, fout); |
130 |
131 |
132 |
133 |
/* Get output stream pointer (open and write header if new and noopen==0) */ |
134 |
STREAMOUT * |
135 |
getostream(const char *ospec, const char *mname, int bn, int noopen) |
136 |
137 |
static STREAMOUT stdos; |
138 |
char info[1024]; |
139 |
int ofl; |
140 |
char oname[1024]; |
141 |
LUENT *lep; |
142 |
STREAMOUT *sop; |
143 |
char *cp; |
144 |
145 |
if (ospec == NULL) { /* use stdout? */ |
146 |
if (!noopen & !using_stdout) { |
147 |
if (outfmt != 'a') |
148 |
SET_FILE_BINARY(stdout); |
149 |
if (header) { |
150 |
cp = info; |
151 |
if (yres > 0) { |
152 |
sprintf(cp, "NROWS=%d\n", yres * |
153 |
(xres + !xres) ); |
154 |
while (*cp) ++cp; |
155 |
156 |
if ((xres <= 0) | (stdos.reclen > 1)) |
157 |
sprintf(cp, "NCOLS=%d\n", stdos.reclen); |
158 |
printheader(stdout, info); |
159 |
160 |
if (stdos.reclen == 1) |
161 |
printresolu(stdout, xres, yres); |
162 |
if (waitflush > 0) |
163 |
fflush(stdout); |
164 |
stdos.xr = xres; stdos.yr = yres; |
165 |
#ifdef getc_unlocked |
166 |
flockfile(stdout); /* avoid lock/unlock overhead */ |
167 |
#endif |
168 |
using_stdout = 1; |
169 |
170 |
stdos.ofp = stdout; |
171 |
stdos.reclen += noopen; |
172 |
return(&stdos); |
173 |
174 |
ofl = ofname(oname, ospec, mname, bn); /* get output name */ |
175 |
if (ofl < 0) { |
176 |
sprintf(errmsg, "bad output format '%s'", ospec); |
177 |
error(USER, errmsg); |
178 |
179 |
lep = lu_find(&ofiletab, oname); /* look it up */ |
180 |
if (lep->key == NULL) /* new entry */ |
181 |
lep->key = strcpy((char *)malloc(strlen(oname)+1), oname); |
182 |
sop = (STREAMOUT *)lep->data; |
183 |
if (sop == NULL) { /* allocate stream */ |
184 |
sop = (STREAMOUT *)malloc(sizeof(STREAMOUT)); |
185 |
if (sop == NULL) |
186 |
error(SYSTEM, "out of memory in getostream"); |
187 |
sop->outpipe = (oname[0] == '!'); |
188 |
sop->reclen = 0; |
189 |
sop->ofp = NULL; /* open iff noopen==0 */ |
190 |
sop->xr = xres; sop->yr = yres; |
191 |
lep->data = (char *)sop; |
192 |
if (!sop->outpipe & !force_open & !recover && |
193 |
access(oname, F_OK) == 0) { |
194 |
errno = EEXIST; /* file exists */ |
195 |
goto openerr; |
196 |
197 |
} else if (noopen && outfmt == 'c' && /* stream exists to picture? */ |
198 |
(sop->xr > 0) & (sop->yr > 0)) { |
199 |
if (ofl & OF_BIN) |
200 |
return(NULL); /* let caller offset bins */ |
201 |
sprintf(errmsg, "output '%s' not a valid picture", oname); |
202 |
error(WARNING, errmsg); |
203 |
204 |
if (!noopen && sop->ofp == NULL) { /* open output stream */ |
205 |
if (oname[0] == '!') /* output to command */ |
206 |
sop->ofp = popen(oname+1, "w"); |
207 |
else /* else open file */ |
208 |
sop->ofp = fopen(oname, "w"); |
209 |
if (sop->ofp == NULL) |
210 |
goto openerr; |
211 |
212 |
SET_FILE_BINARY(sop->ofp); |
213 |
214 |
flockfile(sop->ofp); /* avoid lock/unlock overhead */ |
215 |
#endif |
216 |
if (accumulate > 0) { /* global resolution */ |
217 |
218 |
219 |
if (header) { |
220 |
cp = info; |
221 |
if (ofl & OF_MODIFIER || sop->reclen == 1) { |
222 |
sprintf(cp, "MODIFIER=%s\n", mname); |
223 |
while (*cp) ++cp; |
224 |
225 |
if (ofl & OF_BIN) { |
226 |
sprintf(cp, "BIN=%d\n", bn); |
227 |
while (*cp) ++cp; |
228 |
229 |
if (sop->yr > 0) { |
230 |
sprintf(cp, "NROWS=%d\n", sop->yr * |
231 |
(sop->xr + !sop->xr) ); |
232 |
while (*cp) ++cp; |
233 |
234 |
if ((sop->xr <= 0) | (sop->reclen > 1)) |
235 |
sprintf(cp, "NCOLS=%d\n", sop->reclen); |
236 |
printheader(sop->ofp, info); |
237 |
238 |
if (sop->reclen == 1) |
239 |
printresolu(sop->ofp, sop->xr, sop->yr); |
240 |
241 |
fflush(sop->ofp); |
242 |
243 |
sop->reclen += noopen; /* add to length if noopen */ |
244 |
return(sop); /* return output stream */ |
245 |
openerr: |
246 |
sprintf(errmsg, "cannot open '%s' for writing", oname); |
247 |
error(SYSTEM, errmsg); |
248 |
return(NULL); /* pro forma return */ |
249 |
250 |
251 |
252 |
/* Get a vector from stdin */ |
253 |
int |
254 |
getvec(FVECT vec) |
255 |
256 |
float vf[3]; |
257 |
double vd[3]; |
258 |
char buf[32]; |
259 |
int i; |
260 |
261 |
switch (inpfmt) { |
262 |
case 'a': /* ascii */ |
263 |
for (i = 0; i < 3; i++) { |
264 |
if (fgetword(buf, sizeof(buf), stdin) == NULL || |
265 |
!isflt(buf)) |
266 |
return(-1); |
267 |
vec[i] = atof(buf); |
268 |
269 |
break; |
270 |
case 'f': /* binary float */ |
271 |
if (getbinary((char *)vf, sizeof(float), 3, stdin) != 3) |
272 |
return(-1); |
273 |
VCOPY(vec, vf); |
274 |
break; |
275 |
case 'd': /* binary double */ |
276 |
if (getbinary((char *)vd, sizeof(double), 3, stdin) != 3) |
277 |
return(-1); |
278 |
VCOPY(vec, vd); |
279 |
break; |
280 |
default: |
281 |
error(CONSISTENCY, "botched input format"); |
282 |
283 |
return(0); |
284 |
285 |
286 |
287 |
/* Put out ray contribution to file */ |
288 |
static void |
289 |
put_contrib(const DCOLOR cnt, FILE *fout) |
290 |
291 |
double sf = 1; |
292 |
COLOR fv; |
293 |
COLR cv; |
294 |
295 |
if (accumulate > 1) |
296 |
sf = 1./(double)accumulate; |
297 |
switch (outfmt) { |
298 |
case 'a': |
299 |
300 |
fprintf(fout, "%.6e\t%.6e\t%.6e\t", |
301 |
sf*cnt[0], sf*cnt[1], sf*cnt[2]); |
302 |
else |
303 |
304 |
cnt[0], cnt[1], cnt[2]); |
305 |
break; |
306 |
case 'f': |
307 |
if (accumulate > 1) { |
308 |
copycolor(fv, cnt); |
309 |
scalecolor(fv, sf); |
310 |
} else |
311 |
312 |
putbinary(fv, sizeof(float), 3, fout); |
313 |
break; |
314 |
case 'd': |
315 |
316 |
DCOLOR dv; |
317 |
copycolor(dv, cnt); |
318 |
scalecolor(dv, sf); |
319 |
putbinary(dv, sizeof(double), 3, fout); |
320 |
} else |
321 |
putbinary(cnt, sizeof(double), 3, fout); |
322 |
break; |
323 |
case 'c': |
324 |
325 |
setcolr(cv, sf*cnt[0], sf*cnt[1], sf*cnt[2]); |
326 |
else |
327 |
setcolr(cv, cnt[0], cnt[1], cnt[2]); |
328 |
putbinary(cv, sizeof(cv), 1, fout); |
329 |
break; |
330 |
default: |
331 |
error(INTERNAL, "botched output format"); |
332 |
333 |
334 |
335 |
336 |
/* Output modifier values to appropriate stream(s) */ |
337 |
void |
338 |
mod_output(MODCONT *mp) |
339 |
340 |
STREAMOUT *sop = getostream(mp->outspec, mp->modname, mp->bin0, 0); |
341 |
int j; |
342 |
343 |
put_contrib(mp->cbin[0], sop->ofp); |
344 |
if (mp->nbins > 3 && /* minor optimization */ |
345 |
sop == getostream(mp->outspec, mp->modname, mp->bin0+1, 0)) { |
346 |
for (j = 1; j < mp->nbins; j++) |
347 |
put_contrib(mp->cbin[j], sop->ofp); |
348 |
} else { |
349 |
for (j = 1; j < mp->nbins; j++) { |
350 |
sop = getostream(mp->outspec, mp->modname, mp->bin0+j, 0); |
351 |
352 |
353 |
354 |
355 |
356 |
357 |
/* callback to output newline to ASCII file and/or flush as requested */ |
358 |
static int |
359 |
puteol(const LUENT *e, void *p) |
360 |
361 |
STREAMOUT *sop = (STREAMOUT *)e->data; |
362 |
363 |
if (outfmt == 'a') |
364 |
putc('\n', sop->ofp); |
365 |
if (!waitflush) |
366 |
fflush(sop->ofp); |
367 |
if (ferror(sop->ofp)) { |
368 |
sprintf(errmsg, "write error on file '%s'", e->key); |
369 |
370 |
371 |
return(0); |
372 |
373 |
374 |
375 |
/* Terminate record output and flush if time */ |
376 |
void |
377 |
end_record() |
378 |
379 |
--waitflush; |
380 |
lu_doall(&ofiletab, &puteol, NULL); |
381 |
if (using_stdout & (outfmt == 'a')) |
382 |
putc('\n', stdout); |
383 |
if (!waitflush) { |
384 |
waitflush = (yres > 0) & (xres > 1) ? 0 : xres; |
385 |
if (using_stdout) |
386 |
fflush(stdout); |
387 |
388 |
389 |
390 |
/************************** PARTIAL RESULTS RECOVERY ***********************/ |
391 |
392 |
/* Get ray contribution from previous file */ |
393 |
static int |
394 |
get_contrib(DCOLOR cnt, FILE *finp) |
395 |
396 |
COLOR fv; |
397 |
COLR cv; |
398 |
399 |
switch (outfmt) { |
400 |
case 'a': |
401 |
return(fscanf(finp,"%lf %lf %lf",&cnt[0],&cnt[1],&cnt[2]) == 3); |
402 |
case 'f': |
403 |
if (getbinary(fv, sizeof(fv[0]), 3, finp) != 3) |
404 |
return(0); |
405 |
copycolor(cnt, fv); |
406 |
return(1); |
407 |
case 'd': |
408 |
return(getbinary(cnt, sizeof(cnt[0]), 3, finp) == 3); |
409 |
case 'c': |
410 |
if (getbinary(cv, sizeof(cv), 1, finp) != 1) |
411 |
return(0); |
412 |
colr_color(fv, cv); |
413 |
414 |
return(1); |
415 |
default: |
416 |
417 |
418 |
return(0); /* pro forma return */ |
419 |
420 |
421 |
422 |
/* Close output file opened for input */ |
423 |
static int |
424 |
myclose(const LUENT *e, void *p) |
425 |
426 |
427 |
428 |
429 |
return(0); |
430 |
fclose(sop->ofp); |
431 |
sop->ofp = NULL; |
432 |
return(0); |
433 |
434 |
435 |
436 |
/* Load previously accumulated values */ |
437 |
void |
438 |
reload_output() |
439 |
440 |
int i, j; |
441 |
MODCONT *mp; |
442 |
int ofl; |
443 |
char oname[1024]; |
444 |
char *fmode = "rb"; |
445 |
char *outvfmt; |
446 |
LUENT *oent; |
447 |
int xr, yr; |
448 |
STREAMOUT *sop; |
449 |
DCOLOR rgbv; |
450 |
451 |
452 |
fmode = "r"; |
453 |
outvfmt = formstr(outfmt); |
454 |
/* reload modifier values */ |
455 |
for (i = 0; i < nmods; i++) { |
456 |
mp = (MODCONT *)lu_find(&modconttab,modname[i])->data; |
457 |
if (mp->outspec == NULL) |
458 |
error(USER, "cannot reload from stdout"); |
459 |
if (mp->outspec[0] == '!') |
460 |
error(USER, "cannot reload from command"); |
461 |
for (j = 0; j < mp->nbins; j++) { /* load each modifier bin */ |
462 |
ofl = ofname(oname, mp->outspec, mp->modname, mp->bin0+j); |
463 |
if (ofl < 0) |
464 |
error(USER, "bad output file specification"); |
465 |
oent = lu_find(&ofiletab, oname); |
466 |
if (oent->data == NULL) |
467 |
error(INTERNAL, "unallocated stream in reload_output()"); |
468 |
sop = (STREAMOUT *)oent->data; |
469 |
if (sop->ofp == NULL) { /* open output as input */ |
470 |
sop->ofp = fopen(oname, fmode); |
471 |
if (sop->ofp == NULL) { |
472 |
sprintf(errmsg, "missing reload file '%s'", |
473 |
oname); |
474 |
475 |
break; |
476 |
477 |
478 |
flockfile(sop->ofp); |
479 |
#endif |
480 |
if (header && checkheader(sop->ofp, outvfmt, NULL) != 1) { |
481 |
sprintf(errmsg, "format mismatch for '%s'", |
482 |
oname); |
483 |
484 |
485 |
if ((sop->reclen == 1) & (sop->xr > 0) & (sop->yr > 0) && |
486 |
(!fscnresolu(&xr, &yr, sop->ofp) || |
487 |
(xr != sop->xr) | |
488 |
(yr != sop->yr))) { |
489 |
sprintf(errmsg, "resolution mismatch for '%s'", |
490 |
oname); |
491 |
492 |
493 |
494 |
/* read in RGB value */ |
495 |
if (!get_contrib(rgbv, sop->ofp)) { |
496 |
if (!j) { |
497 |
fclose(sop->ofp); |
498 |
break; /* ignore empty file */ |
499 |
500 |
if (j < mp->nbins) { |
501 |
sprintf(errmsg, "missing data in '%s'", |
502 |
oname); |
503 |
504 |
505 |
break; |
506 |
507 |
copycolor(mp->cbin[j], rgbv); |
508 |
509 |
510 |
lu_doall(&ofiletab, &myclose, NULL); /* close all files */ |
511 |
512 |
513 |
514 |
/* Seek on the given output file */ |
515 |
static int |
516 |
myseeko(const LUENT *e, void *p) |
517 |
518 |
519 |
off_t nbytes = *(off_t *)p; |
520 |
521 |
if (sop->reclen > 1) |
522 |
nbytes = nbytes * sop->reclen; |
523 |
if (fseeko(sop->ofp, nbytes, SEEK_CUR) < 0) { |
524 |
sprintf(errmsg, "seek error on file '%s'", e->key); |
525 |
526 |
527 |
return(0); |
528 |
529 |
530 |
531 |
/* Recover output if possible */ |
532 |
void |
533 |
recover_output() |
534 |
535 |
off_t lastout = -1; |
536 |
int outvsiz, recsiz; |
537 |
char *outvfmt; |
538 |
int i, j; |
539 |
MODCONT *mp; |
540 |
int ofl; |
541 |
char oname[1024]; |
542 |
LUENT *oent; |
543 |
STREAMOUT *sop; |
544 |
off_t nvals; |
545 |
int xr, yr; |
546 |
547 |
switch (outfmt) { |
548 |
case 'a': |
549 |
error(USER, "cannot recover ASCII output"); |
550 |
return; |
551 |
case 'f': |
552 |
outvsiz = sizeof(float)*3; |
553 |
break; |
554 |
case 'd': |
555 |
outvsiz = sizeof(double)*3; |
556 |
break; |
557 |
case 'c': |
558 |
outvsiz = sizeof(COLR); |
559 |
break; |
560 |
default: |
561 |
562 |
return; |
563 |
564 |
565 |
/* check modifier outputs */ |
566 |
567 |
568 |
569 |
error(USER, "cannot recover from stdout"); |
570 |
571 |
error(USER, "cannot recover from command"); |
572 |
for (j = 0; j < mp->nbins; j++) { /* check each bin's file */ |
573 |
574 |
if (ofl < 0) |
575 |
576 |
577 |
578 |
error(INTERNAL, "unallocated stream in recover_output()"); |
579 |
580 |
if (sop->ofp != NULL) { /* already open? */ |
581 |
if (ofl & OF_BIN) |
582 |
continue; |
583 |
break; |
584 |
585 |
/* open output */ |
586 |
sop->ofp = fopen(oname, "rb+"); |
587 |
588 |
sprintf(errmsg, "missing recover file '%s'", |
589 |
oname); |
590 |
591 |
lastout = 0; |
592 |
break; |
593 |
594 |
nvals = lseek(fileno(sop->ofp), 0, SEEK_END); |
595 |
if (nvals <= 0) { |
596 |
lastout = 0; /* empty output, quit here */ |
597 |
fclose(sop->ofp); |
598 |
break; |
599 |
600 |
recsiz = outvsiz * sop->reclen; |
601 |
602 |
lseek(fileno(sop->ofp), 0, SEEK_SET); |
603 |
604 |
605 |
oname); |
606 |
607 |
608 |
609 |
610 |
(xr != sop->xr) | |
611 |
612 |
613 |
oname); |
614 |
615 |
616 |
nvals = (nvals - (off_t)ftell(sop->ofp)) / recsiz; |
617 |
if ((lastout < 0) | (nvals < lastout)) |
618 |
lastout = nvals; |
619 |
if (!(ofl & OF_BIN)) |
620 |
break; /* no bin separation */ |
621 |
622 |
if (!lastout) { /* empty output */ |
623 |
error(WARNING, "no previous data to recover"); |
624 |
/* reclose all outputs */ |
625 |
lu_doall(&ofiletab, &myclose, NULL); |
626 |
return; |
627 |
628 |
629 |
if (lastout < 0) { |
630 |
error(WARNING, "no output files to recover"); |
631 |
return; |
632 |
633 |
if (raysleft && lastout >= raysleft/accumulate) { |
634 |
error(WARNING, "output appears to be complete"); |
635 |
/* XXX should read & discard input? */ |
636 |
quit(0); |
637 |
638 |
/* seek on all files */ |
639 |
nvals = lastout * outvsiz; |
640 |
lu_doall(&ofiletab, &myseeko, &nvals); |
641 |
/* skip repeated input */ |
642 |
lastout *= accumulate; |
643 |
for (nvals = 0; nvals < lastout; nvals++) { |
644 |
FVECT vdummy; |
645 |
if (getvec(vdummy) < 0 || getvec(vdummy) < 0) |
646 |
error(USER, "unexpected EOF on input"); |
647 |
648 |
lastray = lastdone = (RNUMBER)lastout; |
649 |
if (raysleft) |
650 |
raysleft -= lastray; |
651 |
