| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: rc2.c,v 2.18 2016/08/18 00:52:48 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Accumulate ray contributions for a set of materials
| 6 |
* File i/o and recovery
| 7 |
| 8 |
| 9 |
#include <ctype.h>
| 10 |
#include "platform.h"
| 11 |
#include "rcontrib.h"
| 12 |
#include "resolu.h"
| 13 |
| 14 |
/* Close output stream and free record */
| 15 |
static void
| 16 |
closestream(void *p)
| 17 |
| 18 |
STREAMOUT *sop = (STREAMOUT *)p;
| 19 |
| 20 |
if (sop->ofp != NULL) {
| 21 |
int status = 0;
| 22 |
if (sop->outpipe)
| 23 |
status = pclose(sop->ofp);
| 24 |
else if (sop->ofp != stdout)
| 25 |
status = fclose(sop->ofp);
| 26 |
if (status)
| 27 |
error(SYSTEM, "error closing output stream");
| 28 |
| 29 |
free(p);
| 30 |
| 31 |
| 32 |
LUTAB ofiletab = LU_SINIT(free,closestream); /* output file table */
| 33 |
| 34 |
#define OF_MODIFIER 01
| 35 |
#define OF_BIN 02
| 36 |
| 37 |
/************************** STREAM & FILE I/O ***************************/
| 38 |
| 39 |
/* Construct output file name and return flags whether modifier/bin present */
| 40 |
static int
| 41 |
ofname(char *oname, const char *ospec, const char *mname, int bn)
| 42 |
| 43 |
const char *mnp = NULL;
| 44 |
const char *bnp = NULL;
| 45 |
const char *cp;
| 46 |
| 47 |
if (ospec == NULL)
| 48 |
return(-1);
| 49 |
for (cp = ospec; *cp; cp++) /* check format position(s) */
| 50 |
if (*cp == '%') {
| 51 |
do
| 52 |
++cp;
| 53 |
while (isdigit(*cp));
| 54 |
switch (*cp) {
| 55 |
case '%':
| 56 |
break;
| 57 |
case 's':
| 58 |
if (mnp != NULL)
| 59 |
return(-1);
| 60 |
mnp = cp;
| 61 |
break;
| 62 |
case 'd':
| 63 |
case 'i':
| 64 |
case 'o':
| 65 |
case 'x':
| 66 |
case 'X':
| 67 |
if (bnp != NULL)
| 68 |
return(-1);
| 69 |
bnp = cp;
| 70 |
break;
| 71 |
default:
| 72 |
return(-1);
| 73 |
| 74 |
| 75 |
if (mnp != NULL) { /* create file name */
| 76 |
if (bnp != NULL) {
| 77 |
if (bnp > mnp)
| 78 |
sprintf(oname, ospec, mname, bn);
| 79 |
else
| 80 |
sprintf(oname, ospec, bn, mname);
| 81 |
return(OF_MODIFIER|OF_BIN);
| 82 |
| 83 |
sprintf(oname, ospec, mname);
| 84 |
return(OF_MODIFIER);
| 85 |
| 86 |
if (bnp != NULL) {
| 87 |
sprintf(oname, ospec, bn);
| 88 |
return(OF_BIN);
| 89 |
| 90 |
strcpy(oname, ospec);
| 91 |
return(0);
| 92 |
| 93 |
| 94 |
| 95 |
/* Write header to the given output stream */
| 96 |
static void
| 97 |
printheader(FILE *fout, const char *info)
| 98 |
| 99 |
extern char VersionID[];
| 100 |
/* copy octree header */
| 101 |
if (octname[0] == '!') {
| 102 |
newheader("RADIANCE", fout);
| 103 |
fputs(octname+1, fout);
| 104 |
if (octname[strlen(octname)-1] != '\n')
| 105 |
fputc('\n', fout);
| 106 |
} else {
| 107 |
FILE *fin = fopen(octname, (outfmt=='a') ? "r" : "rb");
| 108 |
if (fin == NULL)
| 109 |
quit(1);
| 110 |
checkheader(fin, OCTFMT, fout);
| 111 |
fclose(fin);
| 112 |
| 113 |
printargs(gargc-1, gargv, fout); /* add our command */
| 114 |
fprintf(fout, "SOFTWARE= %s\n", VersionID);
| 115 |
fputnow(fout);
| 116 |
fputs("NCOMP=3\n", fout); /* always RGB */
| 117 |
if (info != NULL) /* add extra info if given */
| 118 |
fputs(info, fout);
| 119 |
fputformat(formstr(outfmt), fout);
| 120 |
fputc('\n', fout); /* empty line ends header */
| 121 |
| 122 |
| 123 |
| 124 |
/* Write resolution string to given output stream */
| 125 |
static void
| 126 |
printresolu(FILE *fout, int xr, int yr)
| 127 |
| 128 |
if ((xr > 0) & (yr > 0)) /* resolution string */
| 129 |
fprtresolu(xr, yr, fout);
| 130 |
| 131 |
| 132 |
| 133 |
/* Get output stream pointer (open and write header if new and noopen==0) */
| 134 |
STREAMOUT *
| 135 |
getostream(const char *ospec, const char *mname, int bn, int noopen)
| 136 |
| 137 |
static STREAMOUT stdos;
| 138 |
char info[1024];
| 139 |
int ofl;
| 140 |
char oname[1024];
| 141 |
LUENT *lep;
| 142 |
STREAMOUT *sop;
| 143 |
char *cp;
| 144 |
| 145 |
if (ospec == NULL) { /* use stdout? */
| 146 |
if (!noopen & !using_stdout) {
| 147 |
if (outfmt != 'a')
| 148 |
SET_FILE_BINARY(stdout);
| 149 |
if (header) {
| 150 |
cp = info;
| 151 |
if (yres > 0) {
| 152 |
sprintf(cp, "NROWS=%d\n", yres *
| 153 |
(xres + !xres) );
| 154 |
while (*cp) ++cp;
| 155 |
| 156 |
if ((xres <= 0) | (stdos.reclen > 1))
| 157 |
sprintf(cp, "NCOLS=%d\n", stdos.reclen);
| 158 |
printheader(stdout, info);
| 159 |
| 160 |
if (stdos.reclen == 1)
| 161 |
printresolu(stdout, xres, yres);
| 162 |
if (waitflush > 0)
| 163 |
fflush(stdout);
| 164 |
stdos.xr = xres; stdos.yr = yres;
| 165 |
#ifdef getc_unlocked
| 166 |
flockfile(stdout); /* avoid lock/unlock overhead */
| 167 |
#endif
| 168 |
using_stdout = 1;
| 169 |
| 170 |
stdos.ofp = stdout;
| 171 |
stdos.reclen += noopen;
| 172 |
return(&stdos);
| 173 |
| 174 |
ofl = ofname(oname, ospec, mname, bn); /* get output name */
| 175 |
if (ofl < 0) {
| 176 |
sprintf(errmsg, "bad output format '%s'", ospec);
| 177 |
error(USER, errmsg);
| 178 |
| 179 |
lep = lu_find(&ofiletab, oname); /* look it up */
| 180 |
if (lep->key == NULL) /* new entry */
| 181 |
lep->key = strcpy((char *)malloc(strlen(oname)+1), oname);
| 182 |
sop = (STREAMOUT *)lep->data;
| 183 |
if (sop == NULL) { /* allocate stream */
| 184 |
sop = (STREAMOUT *)malloc(sizeof(STREAMOUT));
| 185 |
if (sop == NULL)
| 186 |
error(SYSTEM, "out of memory in getostream");
| 187 |
sop->outpipe = (oname[0] == '!');
| 188 |
sop->reclen = 0;
| 189 |
sop->ofp = NULL; /* open iff noopen==0 */
| 190 |
sop->xr = xres; sop->yr = yres;
| 191 |
lep->data = (char *)sop;
| 192 |
if (!sop->outpipe & !force_open & !recover &&
| 193 |
access(oname, F_OK) == 0) {
| 194 |
errno = EEXIST; /* file exists */
| 195 |
goto openerr;
| 196 |
| 197 |
} else if (noopen && outfmt == 'c' && /* stream exists to picture? */
| 198 |
(sop->xr > 0) & (sop->yr > 0)) {
| 199 |
if (ofl & OF_BIN)
| 200 |
return(NULL); /* let caller offset bins */
| 201 |
sprintf(errmsg, "output '%s' not a valid picture", oname);
| 202 |
error(WARNING, errmsg);
| 203 |
| 204 |
if (!noopen && sop->ofp == NULL) { /* open output stream */
| 205 |
if (oname[0] == '!') /* output to command */
| 206 |
sop->ofp = popen(oname+1, "w");
| 207 |
else /* else open file */
| 208 |
sop->ofp = fopen(oname, "w");
| 209 |
if (sop->ofp == NULL)
| 210 |
goto openerr;
| 211 |
if (outfmt != 'a')
| 212 |
SET_FILE_BINARY(sop->ofp);
| 213 |
| 214 |
flockfile(sop->ofp); /* avoid lock/unlock overhead */
| 215 |
#endif
| 216 |
if (accumulate > 0) { /* global resolution */
| 217 |
| 218 |
| 219 |
if (header) {
| 220 |
cp = info;
| 221 |
if (ofl & OF_MODIFIER || sop->reclen == 1) {
| 222 |
sprintf(cp, "MODIFIER=%s\n", mname);
| 223 |
while (*cp) ++cp;
| 224 |
| 225 |
if (ofl & OF_BIN) {
| 226 |
sprintf(cp, "BIN=%d\n", bn);
| 227 |
while (*cp) ++cp;
| 228 |
| 229 |
if (sop->yr > 0) {
| 230 |
sprintf(cp, "NROWS=%d\n", sop->yr *
| 231 |
(sop->xr + !sop->xr) );
| 232 |
while (*cp) ++cp;
| 233 |
| 234 |
if ((sop->xr <= 0) | (sop->reclen > 1))
| 235 |
sprintf(cp, "NCOLS=%d\n", sop->reclen);
| 236 |
printheader(sop->ofp, info);
| 237 |
| 238 |
if (sop->reclen == 1)
| 239 |
printresolu(sop->ofp, sop->xr, sop->yr);
| 240 |
if (waitflush > 0)
| 241 |
fflush(sop->ofp);
| 242 |
| 243 |
sop->reclen += noopen; /* add to length if noopen */
| 244 |
return(sop); /* return output stream */
| 245 |
openerr:
| 246 |
sprintf(errmsg, "cannot open '%s' for writing", oname);
| 247 |
error(SYSTEM, errmsg);
| 248 |
return(NULL); /* pro forma return */
| 249 |
| 250 |
| 251 |
| 252 |
/* Get a vector from stdin */
| 253 |
int
| 254 |
getvec(FVECT vec)
| 255 |
| 256 |
float vf[3];
| 257 |
double vd[3];
| 258 |
char buf[32];
| 259 |
int i;
| 260 |
| 261 |
switch (inpfmt) {
| 262 |
case 'a': /* ascii */
| 263 |
for (i = 0; i < 3; i++) {
| 264 |
if (fgetword(buf, sizeof(buf), stdin) == NULL ||
| 265 |
!isflt(buf))
| 266 |
return(-1);
| 267 |
vec[i] = atof(buf);
| 268 |
| 269 |
break;
| 270 |
case 'f': /* binary float */
| 271 |
if (getbinary((char *)vf, sizeof(float), 3, stdin) != 3)
| 272 |
return(-1);
| 273 |
VCOPY(vec, vf);
| 274 |
break;
| 275 |
case 'd': /* binary double */
| 276 |
if (getbinary((char *)vd, sizeof(double), 3, stdin) != 3)
| 277 |
return(-1);
| 278 |
VCOPY(vec, vd);
| 279 |
break;
| 280 |
default:
| 281 |
error(CONSISTENCY, "botched input format");
| 282 |
| 283 |
return(0);
| 284 |
| 285 |
| 286 |
| 287 |
/* Put out ray contribution to file */
| 288 |
static void
| 289 |
put_contrib(const DCOLOR cnt, FILE *fout)
| 290 |
| 291 |
double sf = 1;
| 292 |
COLOR fv;
| 293 |
COLR cv;
| 294 |
| 295 |
if (accumulate > 1)
| 296 |
sf = 1./(double)accumulate;
| 297 |
switch (outfmt) {
| 298 |
case 'a':
| 299 |
if (accumulate > 1)
| 300 |
fprintf(fout, "%.6e\t%.6e\t%.6e\t",
| 301 |
sf*cnt[0], sf*cnt[1], sf*cnt[2]);
| 302 |
else
| 303 |
| 304 |
cnt[0], cnt[1], cnt[2]);
| 305 |
break;
| 306 |
case 'f':
| 307 |
if (accumulate > 1) {
| 308 |
copycolor(fv, cnt);
| 309 |
scalecolor(fv, sf);
| 310 |
} else
| 311 |
copycolor(fv, cnt);
| 312 |
putbinary(fv, sizeof(float), 3, fout);
| 313 |
break;
| 314 |
case 'd':
| 315 |
| 316 |
DCOLOR dv;
| 317 |
copycolor(dv, cnt);
| 318 |
scalecolor(dv, sf);
| 319 |
putbinary(dv, sizeof(double), 3, fout);
| 320 |
} else
| 321 |
putbinary(cnt, sizeof(double), 3, fout);
| 322 |
break;
| 323 |
case 'c':
| 324 |
if (accumulate > 1)
| 325 |
setcolr(cv, sf*cnt[0], sf*cnt[1], sf*cnt[2]);
| 326 |
else
| 327 |
setcolr(cv, cnt[0], cnt[1], cnt[2]);
| 328 |
putbinary(cv, sizeof(cv), 1, fout);
| 329 |
break;
| 330 |
default:
| 331 |
error(INTERNAL, "botched output format");
| 332 |
| 333 |
| 334 |
| 335 |
| 336 |
/* Output modifier values to appropriate stream(s) */
| 337 |
void
| 338 |
mod_output(MODCONT *mp)
| 339 |
| 340 |
STREAMOUT *sop = getostream(mp->outspec, mp->modname, mp->bin0, 0);
| 341 |
int j;
| 342 |
| 343 |
put_contrib(mp->cbin[0], sop->ofp);
| 344 |
if (mp->nbins > 3 && /* minor optimization */
| 345 |
sop == getostream(mp->outspec, mp->modname, mp->bin0+1, 0)) {
| 346 |
for (j = 1; j < mp->nbins; j++)
| 347 |
put_contrib(mp->cbin[j], sop->ofp);
| 348 |
} else {
| 349 |
for (j = 1; j < mp->nbins; j++) {
| 350 |
sop = getostream(mp->outspec, mp->modname, mp->bin0+j, 0);
| 351 |
| 352 |
| 353 |
| 354 |
| 355 |
| 356 |
| 357 |
/* callback to output newline to ASCII file and/or flush as requested */
| 358 |
static int
| 359 |
puteol(const LUENT *e, void *p)
| 360 |
| 361 |
STREAMOUT *sop = (STREAMOUT *)e->data;
| 362 |
| 363 |
if (outfmt == 'a')
| 364 |
putc('\n', sop->ofp);
| 365 |
if (!waitflush)
| 366 |
fflush(sop->ofp);
| 367 |
if (ferror(sop->ofp)) {
| 368 |
sprintf(errmsg, "write error on file '%s'", e->key);
| 369 |
| 370 |
| 371 |
return(0);
| 372 |
| 373 |
| 374 |
| 375 |
/* Terminate record output and flush if time */
| 376 |
void
| 377 |
end_record()
| 378 |
| 379 |
--waitflush;
| 380 |
lu_doall(&ofiletab, &puteol, NULL);
| 381 |
if (using_stdout & (outfmt == 'a'))
| 382 |
putc('\n', stdout);
| 383 |
if (!waitflush) {
| 384 |
waitflush = (yres > 0) & (xres > 1) ? 0 : xres;
| 385 |
if (using_stdout)
| 386 |
fflush(stdout);
| 387 |
| 388 |
| 389 |
| 390 |
/************************** PARTIAL RESULTS RECOVERY ***********************/
| 391 |
| 392 |
/* Get ray contribution from previous file */
| 393 |
static int
| 394 |
get_contrib(DCOLOR cnt, FILE *finp)
| 395 |
| 396 |
COLOR fv;
| 397 |
COLR cv;
| 398 |
| 399 |
switch (outfmt) {
| 400 |
case 'a':
| 401 |
return(fscanf(finp,"%lf %lf %lf",&cnt[0],&cnt[1],&cnt[2]) == 3);
| 402 |
case 'f':
| 403 |
if (getbinary(fv, sizeof(fv[0]), 3, finp) != 3)
| 404 |
return(0);
| 405 |
copycolor(cnt, fv);
| 406 |
return(1);
| 407 |
case 'd':
| 408 |
return(getbinary(cnt, sizeof(cnt[0]), 3, finp) == 3);
| 409 |
case 'c':
| 410 |
if (getbinary(cv, sizeof(cv), 1, finp) != 1)
| 411 |
return(0);
| 412 |
colr_color(fv, cv);
| 413 |
copycolor(cnt, fv);
| 414 |
return(1);
| 415 |
default:
| 416 |
| 417 |
| 418 |
return(0); /* pro forma return */
| 419 |
| 420 |
| 421 |
| 422 |
/* Close output file opened for input */
| 423 |
static int
| 424 |
myclose(const LUENT *e, void *p)
| 425 |
| 426 |
| 427 |
| 428 |
| 429 |
return(0);
| 430 |
fclose(sop->ofp);
| 431 |
sop->ofp = NULL;
| 432 |
return(0);
| 433 |
| 434 |
| 435 |
| 436 |
/* Load previously accumulated values */
| 437 |
void
| 438 |
reload_output()
| 439 |
| 440 |
int i, j;
| 441 |
MODCONT *mp;
| 442 |
int ofl;
| 443 |
char oname[1024];
| 444 |
char *fmode = "rb";
| 445 |
char *outvfmt;
| 446 |
LUENT *oent;
| 447 |
int xr, yr;
| 448 |
STREAMOUT sout;
| 449 |
DCOLOR rgbv;
| 450 |
| 451 |
if (outfmt == 'a')
| 452 |
fmode = "r";
| 453 |
outvfmt = formstr(outfmt);
| 454 |
/* reload modifier values */
| 455 |
for (i = 0; i < nmods; i++) {
| 456 |
mp = (MODCONT *)lu_find(&modconttab,modname[i])->data;
| 457 |
if (mp->outspec == NULL)
| 458 |
error(USER, "cannot reload from stdout");
| 459 |
if (mp->outspec[0] == '!')
| 460 |
error(USER, "cannot reload from command");
| 461 |
for (j = 0; ; j++) { /* load each modifier bin */
| 462 |
ofl = ofname(oname, mp->outspec, mp->modname, j);
| 463 |
if (ofl < 0)
| 464 |
error(USER, "bad output file specification");
| 465 |
oent = lu_find(&ofiletab, oname);
| 466 |
if (oent->data != NULL) {
| 467 |
sout = *(STREAMOUT *)oent->data;
| 468 |
} else {
| 469 |
sout.reclen = 0;
| 470 |
sout.outpipe = 0;
| 471 |
sout.xr = xres; sout.yr = yres;
| 472 |
sout.ofp = NULL;
| 473 |
| 474 |
if (sout.ofp == NULL) { /* open output as input */
| 475 |
sout.ofp = fopen(oname, fmode);
| 476 |
| 477 |
if (j == mp->nbins)
| 478 |
break; /* assume end of modifier */
| 479 |
sprintf(errmsg, "missing reload file '%s'",
| 480 |
oname);
| 481 |
| 482 |
break;
| 483 |
| 484 |
| 485 |
flockfile(sout.ofp);
| 486 |
#endif
| 487 |
if (header && checkheader(sout.ofp, outvfmt, NULL) != 1) {
| 488 |
sprintf(errmsg, "format mismatch for '%s'",
| 489 |
oname);
| 490 |
| 491 |
| 492 |
if ((sout.reclen == 1) & (sout.xr > 0) & (sout.yr > 0) &&
| 493 |
(!fscnresolu(&xr, &yr, sout.ofp) ||
| 494 |
(xr != sout.xr) |
| 495 |
(yr != sout.yr))) {
| 496 |
sprintf(errmsg, "resolution mismatch for '%s'",
| 497 |
oname);
| 498 |
| 499 |
| 500 |
| 501 |
/* read in RGB value */
| 502 |
if (!get_contrib(rgbv, sout.ofp)) {
| 503 |
if (!j) {
| 504 |
fclose(sout.ofp);
| 505 |
break; /* ignore empty file */
| 506 |
| 507 |
if (j < mp->nbins) {
| 508 |
sprintf(errmsg, "missing data in '%s'",
| 509 |
oname);
| 510 |
| 511 |
| 512 |
break;
| 513 |
| 514 |
if (j >= mp->nbins) { /* check modifier size */
| 515 |
sprintf(errmsg,
| 516 |
"mismatched -bn setting for reloading '%s'",
| 517 |
modname[i]);
| 518 |
| 519 |
| 520 |
| 521 |
copycolor(mp->cbin[j], rgbv);
| 522 |
if (oent->key == NULL) /* new file entry */
| 523 |
oent->key = strcpy((char *)
| 524 |
| 525 |
if (oent->data == NULL)
| 526 |
oent->data = (char *)malloc(sizeof(STREAMOUT));
| 527 |
*(STREAMOUT *)oent->data = sout;
| 528 |
| 529 |
| 530 |
lu_doall(&ofiletab, &myclose, NULL); /* close all files */
| 531 |
| 532 |
| 533 |
| 534 |
/* Seek on the given output file */
| 535 |
static int
| 536 |
myseeko(const LUENT *e, void *p)
| 537 |
| 538 |
| 539 |
off_t nbytes = *(off_t *)p;
| 540 |
| 541 |
if (sop->reclen > 1)
| 542 |
nbytes = nbytes * sop->reclen;
| 543 |
if (fseeko(sop->ofp, nbytes, SEEK_CUR) < 0) {
| 544 |
sprintf(errmsg, "seek error on file '%s'", e->key);
| 545 |
| 546 |
| 547 |
return(0);
| 548 |
| 549 |
| 550 |
| 551 |
/* Recover output if possible */
| 552 |
void
| 553 |
recover_output()
| 554 |
| 555 |
off_t lastout = -1;
| 556 |
int outvsiz, recsiz;
| 557 |
char *outvfmt;
| 558 |
int i, j;
| 559 |
MODCONT *mp;
| 560 |
int ofl;
| 561 |
char oname[1024];
| 562 |
LUENT *oent;
| 563 |
STREAMOUT sout;
| 564 |
off_t nvals;
| 565 |
int xr, yr;
| 566 |
| 567 |
switch (outfmt) {
| 568 |
case 'a':
| 569 |
error(USER, "cannot recover ASCII output");
| 570 |
return;
| 571 |
case 'f':
| 572 |
outvsiz = sizeof(float)*3;
| 573 |
break;
| 574 |
case 'd':
| 575 |
outvsiz = sizeof(double)*3;
| 576 |
break;
| 577 |
case 'c':
| 578 |
outvsiz = sizeof(COLR);
| 579 |
break;
| 580 |
default:
| 581 |
| 582 |
return;
| 583 |
| 584 |
| 585 |
/* check modifier outputs */
| 586 |
| 587 |
| 588 |
| 589 |
error(USER, "cannot recover from stdout");
| 590 |
| 591 |
error(USER, "cannot recover from command");
| 592 |
for (j = 0; ; j++) { /* check each bin's file */
| 593 |
| 594 |
if (ofl < 0)
| 595 |
| 596 |
| 597 |
| 598 |
| 599 |
} else {
| 600 |
sout.reclen = 0;
| 601 |
sout.outpipe = 0;
| 602 |
sout.xr = xres;
| 603 |
sout.yr = yres;
| 604 |
sout.ofp = NULL;
| 605 |
| 606 |
if (sout.ofp != NULL) { /* already open? */
| 607 |
if (ofl & OF_BIN)
| 608 |
continue;
| 609 |
break;
| 610 |
| 611 |
/* open output */
| 612 |
sout.ofp = fopen(oname, "rb+");
| 613 |
| 614 |
if (j == mp->nbins)
| 615 |
| 616 |
sprintf(errmsg, "missing recover file '%s'",
| 617 |
oname);
| 618 |
| 619 |
break;
| 620 |
| 621 |
nvals = lseek(fileno(sout.ofp), 0, SEEK_END);
| 622 |
if (nvals <= 0) {
| 623 |
lastout = 0; /* empty output, quit here */
| 624 |
fclose(sout.ofp);
| 625 |
break;
| 626 |
| 627 |
if (!sout.reclen) {
| 628 |
if (!(ofl & OF_BIN)) {
| 629 |
sprintf(errmsg,
| 630 |
"need -bn to recover file '%s'",
| 631 |
oname);
| 632 |
| 633 |
| 634 |
recsiz = outvsiz;
| 635 |
} else
| 636 |
recsiz = outvsiz * sout.reclen;
| 637 |
| 638 |
lseek(fileno(sout.ofp), 0, SEEK_SET);
| 639 |
| 640 |
| 641 |
oname);
| 642 |
| 643 |
| 644 |
| 645 |
| 646 |
(xr != sout.xr) |
| 647 |
(yr != sout.yr))) {
| 648 |
| 649 |
oname);
| 650 |
| 651 |
| 652 |
nvals = (nvals - (off_t)ftell(sout.ofp)) / recsiz;
| 653 |
if ((lastout < 0) | (nvals < lastout))
| 654 |
lastout = nvals;
| 655 |
if (oent->key == NULL) /* new entry */
| 656 |
| 657 |
| 658 |
| 659 |
| 660 |
| 661 |
| 662 |
break; /* no bin separation */
| 663 |
| 664 |
if (!lastout) { /* empty output */
| 665 |
error(WARNING, "no previous data to recover");
| 666 |
lu_done(&ofiletab); /* reclose all outputs */
| 667 |
return;
| 668 |
| 669 |
if (j > mp->nbins) { /* check modifier size */
| 670 |
sprintf(errmsg,
| 671 |
"mismatched -bn setting for recovering '%s'",
| 672 |
modname[i]);
| 673 |
| 674 |
| 675 |
| 676 |
if (lastout < 0) {
| 677 |
error(WARNING, "no output files to recover");
| 678 |
return;
| 679 |
| 680 |
if (raysleft && lastout >= raysleft/accumulate) {
| 681 |
error(WARNING, "output appears to be complete");
| 682 |
/* XXX should read & discard input? */
| 683 |
quit(0);
| 684 |
| 685 |
/* seek on all files */
| 686 |
nvals = lastout * outvsiz;
| 687 |
lu_doall(&ofiletab, &myseeko, &nvals);
| 688 |
/* skip repeated input */
| 689 |
lastout *= accumulate;
| 690 |
for (nvals = 0; nvals < lastout; nvals++) {
| 691 |
FVECT vdummy;
| 692 |
if (getvec(vdummy) < 0 || getvec(vdummy) < 0)
| 693 |
error(USER, "unexpected EOF on input");
| 694 |
| 695 |
lastray = lastdone = (RNUMBER)lastout;
| 696 |
if (raysleft)
| 697 |
raysleft -= lastray;
| 698 |
