| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: rc2.c,v 2.10 2014/05/30 16:05:52 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Accumulate ray contributions for a set of materials
| 6 |
* File i/o and recovery
| 7 |
| 8 |
| 9 |
#include "rcontrib.h"
| 10 |
#include "resolu.h"
| 11 |
#include <ctype.h>
| 12 |
| 13 |
/* Close output stream and free record */
| 14 |
static void
| 15 |
closestream(void *p)
| 16 |
| 17 |
STREAMOUT *sop = (STREAMOUT *)p;
| 18 |
| 19 |
if (sop->ofp != NULL) {
| 20 |
int status = 0;
| 21 |
if (sop->outpipe)
| 22 |
status = pclose(sop->ofp);
| 23 |
else if (sop->ofp != stdout)
| 24 |
status = fclose(sop->ofp);
| 25 |
if (status)
| 26 |
error(SYSTEM, "error closing output stream");
| 27 |
| 28 |
free(p);
| 29 |
| 30 |
| 31 |
LUTAB ofiletab = LU_SINIT(free,closestream); /* output file table */
| 32 |
| 33 |
#define OF_MODIFIER 01
| 34 |
#define OF_BIN 02
| 35 |
| 36 |
/************************** STREAM & FILE I/O ***************************/
| 37 |
| 38 |
/* Construct output file name and return flags whether modifier/bin present */
| 39 |
static int
| 40 |
ofname(char *oname, const char *ospec, const char *mname, int bn)
| 41 |
| 42 |
const char *mnp = NULL;
| 43 |
const char *bnp = NULL;
| 44 |
const char *cp;
| 45 |
| 46 |
if (ospec == NULL)
| 47 |
return(-1);
| 48 |
for (cp = ospec; *cp; cp++) /* check format position(s) */
| 49 |
if (*cp == '%') {
| 50 |
do
| 51 |
++cp;
| 52 |
while (isdigit(*cp));
| 53 |
switch (*cp) {
| 54 |
case '%':
| 55 |
break;
| 56 |
case 's':
| 57 |
if (mnp != NULL)
| 58 |
return(-1);
| 59 |
mnp = cp;
| 60 |
break;
| 61 |
case 'd':
| 62 |
case 'i':
| 63 |
case 'o':
| 64 |
case 'x':
| 65 |
case 'X':
| 66 |
if (bnp != NULL)
| 67 |
return(-1);
| 68 |
bnp = cp;
| 69 |
break;
| 70 |
default:
| 71 |
return(-1);
| 72 |
| 73 |
| 74 |
if (mnp != NULL) { /* create file name */
| 75 |
if (bnp != NULL) {
| 76 |
if (bnp > mnp)
| 77 |
sprintf(oname, ospec, mname, bn);
| 78 |
else
| 79 |
sprintf(oname, ospec, bn, mname);
| 80 |
return(OF_MODIFIER|OF_BIN);
| 81 |
| 82 |
sprintf(oname, ospec, mname);
| 83 |
return(OF_MODIFIER);
| 84 |
| 85 |
if (bnp != NULL) {
| 86 |
sprintf(oname, ospec, bn);
| 87 |
return(OF_BIN);
| 88 |
| 89 |
strcpy(oname, ospec);
| 90 |
return(0);
| 91 |
| 92 |
| 93 |
| 94 |
/* Write header to the given output stream */
| 95 |
static void
| 96 |
printheader(FILE *fout, const char *info)
| 97 |
| 98 |
extern char VersionID[];
| 99 |
/* copy octree header */
| 100 |
if (octname[0] == '!') {
| 101 |
newheader("RADIANCE", fout);
| 102 |
fputs(octname+1, fout);
| 103 |
if (octname[strlen(octname)-1] != '\n')
| 104 |
fputc('\n', fout);
| 105 |
} else {
| 106 |
FILE *fin = fopen(octname, (outfmt=='a') ? "r" : "rb");
| 107 |
if (fin == NULL)
| 108 |
quit(1);
| 109 |
checkheader(fin, OCTFMT, fout);
| 110 |
fclose(fin);
| 111 |
| 112 |
printargs(gargc-1, gargv, fout); /* add our command */
| 113 |
fprintf(fout, "SOFTWARE= %s\n", VersionID);
| 114 |
fputnow(fout);
| 115 |
fputs("NCOMP=3\n", fout); /* always RGB */
| 116 |
if (info != NULL) /* add extra info if given */
| 117 |
fputs(info, fout);
| 118 |
fputformat(formstr(outfmt), fout);
| 119 |
fputc('\n', fout); /* empty line ends header */
| 120 |
| 121 |
| 122 |
| 123 |
/* Write resolution string to given output stream */
| 124 |
static void
| 125 |
printresolu(FILE *fout, int xr, int yr)
| 126 |
| 127 |
if ((xr > 0) & (yr > 0)) /* resolution string */
| 128 |
fprtresolu(xr, yr, fout);
| 129 |
| 130 |
| 131 |
| 132 |
/* Get output stream pointer (open and write header if new and noopen==0) */
| 133 |
STREAMOUT *
| 134 |
getostream(const char *ospec, const char *mname, int bn, int noopen)
| 135 |
| 136 |
static STREAMOUT stdos;
| 137 |
char info[1024];
| 138 |
int ofl;
| 139 |
char oname[1024];
| 140 |
LUENT *lep;
| 141 |
STREAMOUT *sop;
| 142 |
char *cp;
| 143 |
| 144 |
if (ospec == NULL) { /* use stdout? */
| 145 |
if (!noopen & !using_stdout) {
| 146 |
if (outfmt != 'a')
| 147 |
SET_FILE_BINARY(stdout);
| 148 |
if (header) {
| 149 |
cp = info;
| 150 |
if (yres > 0) {
| 151 |
sprintf(cp, "NROWS=%d\n", yres *
| 152 |
(xres + !xres) );
| 153 |
while (*cp) ++cp;
| 154 |
| 155 |
sprintf(cp, "NCOLS=%d\nNCOMP=3\n",
| 156 |
stdos.reclen);
| 157 |
printheader(stdout, info);
| 158 |
| 159 |
printresolu(stdout, xres, yres);
| 160 |
if (waitflush > 0)
| 161 |
fflush(stdout);
| 162 |
stdos.xr = xres; stdos.yr = yres;
| 163 |
#ifdef getc_unlocked
| 164 |
flockfile(stdout); /* avoid lock/unlock overhead */
| 165 |
#endif
| 166 |
using_stdout = 1;
| 167 |
| 168 |
stdos.ofp = stdout;
| 169 |
stdos.reclen += noopen;
| 170 |
return(&stdos);
| 171 |
| 172 |
ofl = ofname(oname, ospec, mname, bn); /* get output name */
| 173 |
if (ofl < 0) {
| 174 |
sprintf(errmsg, "bad output format '%s'", ospec);
| 175 |
error(USER, errmsg);
| 176 |
| 177 |
lep = lu_find(&ofiletab, oname); /* look it up */
| 178 |
if (lep->key == NULL) /* new entry */
| 179 |
lep->key = strcpy((char *)malloc(strlen(oname)+1), oname);
| 180 |
sop = (STREAMOUT *)lep->data;
| 181 |
if (sop == NULL) { /* allocate stream */
| 182 |
sop = (STREAMOUT *)malloc(sizeof(STREAMOUT));
| 183 |
if (sop == NULL)
| 184 |
error(SYSTEM, "out of memory in getostream");
| 185 |
sop->outpipe = oname[0] == '!';
| 186 |
sop->reclen = 0;
| 187 |
sop->ofp = NULL; /* open iff noopen==0 */
| 188 |
sop->xr = xres; sop->yr = yres;
| 189 |
lep->data = (char *)sop;
| 190 |
if (!sop->outpipe & !force_open & !recover &&
| 191 |
access(oname, F_OK) == 0) {
| 192 |
errno = EEXIST; /* file exists */
| 193 |
goto openerr;
| 194 |
| 195 |
| 196 |
if (!noopen && sop->ofp == NULL) { /* open output stream */
| 197 |
if (oname[0] == '!') /* output to command */
| 198 |
sop->ofp = popen(oname+1, "w");
| 199 |
else /* else open file */
| 200 |
sop->ofp = fopen(oname, "w");
| 201 |
if (sop->ofp == NULL)
| 202 |
goto openerr;
| 203 |
if (outfmt != 'a')
| 204 |
SET_FILE_BINARY(sop->ofp);
| 205 |
| 206 |
flockfile(sop->ofp); /* avoid lock/unlock overhead */
| 207 |
#endif
| 208 |
if (accumulate > 0) { /* global resolution */
| 209 |
| 210 |
| 211 |
if (header) {
| 212 |
cp = info;
| 213 |
if (ofl & OF_MODIFIER || sop->reclen == 1) {
| 214 |
sprintf(cp, "MODIFIER=%s\n", mname);
| 215 |
while (*cp) ++cp;
| 216 |
| 217 |
if (ofl & OF_BIN) {
| 218 |
sprintf(cp, "BIN=%d\n", bn);
| 219 |
while (*cp) ++cp;
| 220 |
| 221 |
if (sop->yr > 0) {
| 222 |
sprintf(cp, "NROWS=%d\n", sop->yr *
| 223 |
(sop->xr + !sop->xr) );
| 224 |
while (*cp) ++cp;
| 225 |
| 226 |
sprintf(cp, "NCOLS=%d\nNCOMP=3\n", sop->reclen);
| 227 |
printheader(sop->ofp, info);
| 228 |
| 229 |
printresolu(sop->ofp, sop->xr, sop->yr);
| 230 |
if (waitflush > 0)
| 231 |
fflush(sop->ofp);
| 232 |
| 233 |
sop->reclen += noopen; /* add to length if noopen */
| 234 |
return(sop); /* return output stream */
| 235 |
openerr:
| 236 |
sprintf(errmsg, "cannot open '%s' for writing", oname);
| 237 |
error(SYSTEM, errmsg);
| 238 |
return(NULL); /* pro forma return */
| 239 |
| 240 |
| 241 |
| 242 |
/* Get a vector from stdin */
| 243 |
int
| 244 |
getvec(FVECT vec)
| 245 |
| 246 |
float vf[3];
| 247 |
double vd[3];
| 248 |
char buf[32];
| 249 |
int i;
| 250 |
| 251 |
switch (inpfmt) {
| 252 |
case 'a': /* ascii */
| 253 |
for (i = 0; i < 3; i++) {
| 254 |
if (fgetword(buf, sizeof(buf), stdin) == NULL ||
| 255 |
!isflt(buf))
| 256 |
return(-1);
| 257 |
vec[i] = atof(buf);
| 258 |
| 259 |
break;
| 260 |
case 'f': /* binary float */
| 261 |
if (fread((char *)vf, sizeof(float), 3, stdin) != 3)
| 262 |
return(-1);
| 263 |
VCOPY(vec, vf);
| 264 |
break;
| 265 |
case 'd': /* binary double */
| 266 |
if (fread((char *)vd, sizeof(double), 3, stdin) != 3)
| 267 |
return(-1);
| 268 |
VCOPY(vec, vd);
| 269 |
break;
| 270 |
default:
| 271 |
error(CONSISTENCY, "botched input format");
| 272 |
| 273 |
return(0);
| 274 |
| 275 |
| 276 |
| 277 |
/* Put out ray contribution to file */
| 278 |
static void
| 279 |
put_contrib(const DCOLOR cnt, FILE *fout)
| 280 |
| 281 |
double sf = 1;
| 282 |
COLOR fv;
| 283 |
COLR cv;
| 284 |
| 285 |
if (accumulate > 1)
| 286 |
sf = 1./(double)accumulate;
| 287 |
switch (outfmt) {
| 288 |
case 'a':
| 289 |
if (accumulate > 1)
| 290 |
fprintf(fout, "%.6e\t%.6e\t%.6e\t",
| 291 |
sf*cnt[0], sf*cnt[1], sf*cnt[2]);
| 292 |
else
| 293 |
| 294 |
cnt[0], cnt[1], cnt[2]);
| 295 |
break;
| 296 |
case 'f':
| 297 |
if (accumulate > 1) {
| 298 |
copycolor(fv, cnt);
| 299 |
scalecolor(fv, sf);
| 300 |
} else
| 301 |
copycolor(fv, cnt);
| 302 |
fwrite(fv, sizeof(float), 3, fout);
| 303 |
break;
| 304 |
case 'd':
| 305 |
| 306 |
DCOLOR dv;
| 307 |
copycolor(dv, cnt);
| 308 |
scalecolor(dv, sf);
| 309 |
fwrite(dv, sizeof(double), 3, fout);
| 310 |
} else
| 311 |
fwrite(cnt, sizeof(double), 3, fout);
| 312 |
break;
| 313 |
case 'c':
| 314 |
if (accumulate > 1)
| 315 |
setcolr(cv, sf*cnt[0], sf*cnt[1], sf*cnt[2]);
| 316 |
else
| 317 |
setcolr(cv, cnt[0], cnt[1], cnt[2]);
| 318 |
fwrite(cv, sizeof(cv), 1, fout);
| 319 |
break;
| 320 |
default:
| 321 |
error(INTERNAL, "botched output format");
| 322 |
| 323 |
| 324 |
| 325 |
| 326 |
/* Output modifier values to appropriate stream(s) */
| 327 |
void
| 328 |
mod_output(MODCONT *mp)
| 329 |
| 330 |
STREAMOUT *sop = getostream(mp->outspec, mp->modname, 0, 0);
| 331 |
int j;
| 332 |
| 333 |
put_contrib(mp->cbin[0], sop->ofp);
| 334 |
if (mp->nbins > 3 && /* minor optimization */
| 335 |
sop == getostream(mp->outspec, mp->modname, 1, 0)) {
| 336 |
for (j = 1; j < mp->nbins; j++)
| 337 |
put_contrib(mp->cbin[j], sop->ofp);
| 338 |
} else {
| 339 |
for (j = 1; j < mp->nbins; j++) {
| 340 |
sop = getostream(mp->outspec, mp->modname, j, 0);
| 341 |
| 342 |
| 343 |
| 344 |
| 345 |
| 346 |
| 347 |
/* callback to output newline to ASCII file and/or flush as requested */
| 348 |
static int
| 349 |
puteol(const LUENT *e, void *p)
| 350 |
| 351 |
STREAMOUT *sop = (STREAMOUT *)e->data;
| 352 |
| 353 |
if (outfmt == 'a')
| 354 |
putc('\n', sop->ofp);
| 355 |
if (!waitflush)
| 356 |
fflush(sop->ofp);
| 357 |
if (ferror(sop->ofp)) {
| 358 |
sprintf(errmsg, "write error on file '%s'", e->key);
| 359 |
| 360 |
| 361 |
return(0);
| 362 |
| 363 |
| 364 |
| 365 |
/* Terminate record output and flush if time */
| 366 |
void
| 367 |
end_record()
| 368 |
| 369 |
--waitflush;
| 370 |
lu_doall(&ofiletab, &puteol, NULL);
| 371 |
if (using_stdout & (outfmt == 'a'))
| 372 |
putc('\n', stdout);
| 373 |
if (!waitflush) {
| 374 |
waitflush = (yres > 0) & (xres > 1) ? 0 : xres;
| 375 |
if (using_stdout)
| 376 |
fflush(stdout);
| 377 |
| 378 |
| 379 |
| 380 |
/************************** PARTIAL RESULTS RECOVERY ***********************/
| 381 |
| 382 |
/* Get ray contribution from previous file */
| 383 |
static int
| 384 |
get_contrib(DCOLOR cnt, FILE *finp)
| 385 |
| 386 |
COLOR fv;
| 387 |
COLR cv;
| 388 |
| 389 |
switch (outfmt) {
| 390 |
case 'a':
| 391 |
return(fscanf(finp,"%lf %lf %lf",&cnt[0],&cnt[1],&cnt[2]) == 3);
| 392 |
case 'f':
| 393 |
if (fread(fv, sizeof(fv[0]), 3, finp) != 3)
| 394 |
return(0);
| 395 |
copycolor(cnt, fv);
| 396 |
return(1);
| 397 |
case 'd':
| 398 |
return(fread(cnt, sizeof(cnt[0]), 3, finp) == 3);
| 399 |
case 'c':
| 400 |
if (fread(cv, sizeof(cv), 1, finp) != 1)
| 401 |
return(0);
| 402 |
colr_color(fv, cv);
| 403 |
copycolor(cnt, fv);
| 404 |
return(1);
| 405 |
default:
| 406 |
| 407 |
| 408 |
return(0); /* pro forma return */
| 409 |
| 410 |
| 411 |
| 412 |
/* Close output file opened for input */
| 413 |
static int
| 414 |
myclose(const LUENT *e, void *p)
| 415 |
| 416 |
| 417 |
| 418 |
| 419 |
return(0);
| 420 |
fclose(sop->ofp);
| 421 |
sop->ofp = NULL;
| 422 |
return(0);
| 423 |
| 424 |
| 425 |
| 426 |
/* Load previously accumulated values */
| 427 |
void
| 428 |
reload_output()
| 429 |
| 430 |
int i, j;
| 431 |
MODCONT *mp;
| 432 |
int ofl;
| 433 |
char oname[1024];
| 434 |
char *fmode = "rb";
| 435 |
char *outvfmt;
| 436 |
LUENT *oent;
| 437 |
int xr, yr;
| 438 |
STREAMOUT sout;
| 439 |
DCOLOR rgbv;
| 440 |
| 441 |
if (outfmt == 'a')
| 442 |
fmode = "r";
| 443 |
outvfmt = formstr(outfmt);
| 444 |
/* reload modifier values */
| 445 |
for (i = 0; i < nmods; i++) {
| 446 |
mp = (MODCONT *)lu_find(&modconttab,modname[i])->data;
| 447 |
if (mp->outspec == NULL)
| 448 |
error(USER, "cannot reload from stdout");
| 449 |
if (mp->outspec[0] == '!')
| 450 |
error(USER, "cannot reload from command");
| 451 |
for (j = 0; ; j++) { /* load each modifier bin */
| 452 |
ofl = ofname(oname, mp->outspec, mp->modname, j);
| 453 |
if (ofl < 0)
| 454 |
error(USER, "bad output file specification");
| 455 |
oent = lu_find(&ofiletab, oname);
| 456 |
if (oent->data != NULL) {
| 457 |
sout = *(STREAMOUT *)oent->data;
| 458 |
} else {
| 459 |
sout.reclen = 0;
| 460 |
sout.outpipe = 0;
| 461 |
sout.xr = xres; sout.yr = yres;
| 462 |
sout.ofp = NULL;
| 463 |
| 464 |
if (sout.ofp == NULL) { /* open output as input */
| 465 |
sout.ofp = fopen(oname, fmode);
| 466 |
| 467 |
if (j == mp->nbins)
| 468 |
break; /* assume end of modifier */
| 469 |
sprintf(errmsg, "missing reload file '%s'",
| 470 |
oname);
| 471 |
error(WARNING, errmsg);
| 472 |
break;
| 473 |
| 474 |
| 475 |
flockfile(sout.ofp);
| 476 |
#endif
| 477 |
if (header && checkheader(sout.ofp, outvfmt, NULL) != 1) {
| 478 |
sprintf(errmsg, "format mismatch for '%s'",
| 479 |
oname);
| 480 |
| 481 |
| 482 |
if ((sout.xr > 0) & (sout.yr > 0) &&
| 483 |
(!fscnresolu(&xr, &yr, sout.ofp) ||
| 484 |
(xr != sout.xr) |
| 485 |
(yr != sout.yr))) {
| 486 |
sprintf(errmsg, "resolution mismatch for '%s'",
| 487 |
oname);
| 488 |
| 489 |
| 490 |
| 491 |
/* read in RGB value */
| 492 |
if (!get_contrib(rgbv, sout.ofp)) {
| 493 |
if (!j) {
| 494 |
fclose(sout.ofp);
| 495 |
break; /* ignore empty file */
| 496 |
| 497 |
if (j < mp->nbins) {
| 498 |
sprintf(errmsg, "missing data in '%s'",
| 499 |
oname);
| 500 |
| 501 |
| 502 |
break;
| 503 |
| 504 |
if (j >= mp->nbins) { /* check modifier size */
| 505 |
sprintf(errmsg,
| 506 |
"mismatched -bn setting for reloading '%s'",
| 507 |
modname[i]);
| 508 |
| 509 |
| 510 |
| 511 |
copycolor(mp->cbin[j], rgbv);
| 512 |
if (oent->key == NULL) /* new file entry */
| 513 |
oent->key = strcpy((char *)
| 514 |
| 515 |
if (oent->data == NULL)
| 516 |
oent->data = (char *)malloc(sizeof(STREAMOUT));
| 517 |
*(STREAMOUT *)oent->data = sout;
| 518 |
| 519 |
| 520 |
lu_doall(&ofiletab, &myclose, NULL); /* close all files */
| 521 |
| 522 |
| 523 |
| 524 |
/* Seek on the given output file */
| 525 |
static int
| 526 |
myseeko(const LUENT *e, void *p)
| 527 |
| 528 |
| 529 |
off_t nbytes = *(off_t *)p;
| 530 |
| 531 |
if (sop->reclen > 1)
| 532 |
nbytes = nbytes * sop->reclen;
| 533 |
if (fseeko(sop->ofp, nbytes, SEEK_CUR) < 0) {
| 534 |
sprintf(errmsg, "seek error on file '%s'", e->key);
| 535 |
| 536 |
| 537 |
return(0);
| 538 |
| 539 |
| 540 |
| 541 |
/* Recover output if possible */
| 542 |
void
| 543 |
recover_output()
| 544 |
| 545 |
off_t lastout = -1;
| 546 |
int outvsiz, recsiz;
| 547 |
char *outvfmt;
| 548 |
int i, j;
| 549 |
MODCONT *mp;
| 550 |
int ofl;
| 551 |
char oname[1024];
| 552 |
LUENT *oent;
| 553 |
STREAMOUT sout;
| 554 |
off_t nvals;
| 555 |
int xr, yr;
| 556 |
| 557 |
switch (outfmt) {
| 558 |
case 'a':
| 559 |
error(USER, "cannot recover ASCII output");
| 560 |
return;
| 561 |
case 'f':
| 562 |
outvsiz = sizeof(float)*3;
| 563 |
break;
| 564 |
case 'd':
| 565 |
outvsiz = sizeof(double)*3;
| 566 |
break;
| 567 |
case 'c':
| 568 |
outvsiz = sizeof(COLR);
| 569 |
break;
| 570 |
default:
| 571 |
| 572 |
return;
| 573 |
| 574 |
| 575 |
/* check modifier outputs */
| 576 |
| 577 |
| 578 |
| 579 |
error(USER, "cannot recover from stdout");
| 580 |
| 581 |
error(USER, "cannot recover from command");
| 582 |
for (j = 0; ; j++) { /* check each bin's file */
| 583 |
| 584 |
if (ofl < 0)
| 585 |
| 586 |
| 587 |
| 588 |
| 589 |
} else {
| 590 |
sout.reclen = 0;
| 591 |
sout.outpipe = 0;
| 592 |
sout.ofp = NULL;
| 593 |
| 594 |
if (sout.ofp != NULL) { /* already open? */
| 595 |
if (ofl & OF_BIN)
| 596 |
continue;
| 597 |
break;
| 598 |
| 599 |
/* open output */
| 600 |
sout.ofp = fopen(oname, "rb+");
| 601 |
| 602 |
if (j == mp->nbins)
| 603 |
| 604 |
sprintf(errmsg, "missing recover file '%s'",
| 605 |
oname);
| 606 |
| 607 |
break;
| 608 |
| 609 |
nvals = lseek(fileno(sout.ofp), 0, SEEK_END);
| 610 |
if (nvals <= 0) {
| 611 |
lastout = 0; /* empty output, quit here */
| 612 |
fclose(sout.ofp);
| 613 |
break;
| 614 |
| 615 |
if (!sout.reclen) {
| 616 |
if (!(ofl & OF_BIN)) {
| 617 |
sprintf(errmsg,
| 618 |
"need -bn to recover file '%s'",
| 619 |
oname);
| 620 |
| 621 |
| 622 |
recsiz = outvsiz;
| 623 |
} else
| 624 |
recsiz = outvsiz * sout.reclen;
| 625 |
| 626 |
lseek(fileno(sout.ofp), 0, SEEK_SET);
| 627 |
| 628 |
| 629 |
oname);
| 630 |
| 631 |
| 632 |
| 633 |
| 634 |
| 635 |
(xr != sout.xr) |
| 636 |
(yr != sout.yr))) {
| 637 |
| 638 |
oname);
| 639 |
| 640 |
| 641 |
nvals = (nvals - (off_t)ftell(sout.ofp)) / recsiz;
| 642 |
if ((lastout < 0) | (nvals < lastout))
| 643 |
lastout = nvals;
| 644 |
if (oent->key == NULL) /* new entry */
| 645 |
| 646 |
| 647 |
| 648 |
| 649 |
| 650 |
| 651 |
break; /* no bin separation */
| 652 |
| 653 |
if (!lastout) { /* empty output */
| 654 |
error(WARNING, "no previous data to recover");
| 655 |
lu_done(&ofiletab); /* reclose all outputs */
| 656 |
return;
| 657 |
| 658 |
if (j > mp->nbins) { /* check modifier size */
| 659 |
sprintf(errmsg,
| 660 |
"mismatched -bn setting for recovering '%s'",
| 661 |
modname[i]);
| 662 |
| 663 |
| 664 |
| 665 |
if (lastout < 0) {
| 666 |
error(WARNING, "no output files to recover");
| 667 |
return;
| 668 |
| 669 |
if (raysleft && lastout >= raysleft/accumulate) {
| 670 |
error(WARNING, "output appears to be complete");
| 671 |
/* XXX should read & discard input? */
| 672 |
quit(0);
| 673 |
| 674 |
/* seek on all files */
| 675 |
nvals = lastout * outvsiz;
| 676 |
lu_doall(&ofiletab, &myseeko, &nvals);
| 677 |
/* skip repeated input */
| 678 |
lastout *= accumulate;
| 679 |
for (nvals = 0; nvals < lastout; nvals++) {
| 680 |
FVECT vdummy;
| 681 |
if (getvec(vdummy) < 0 || getvec(vdummy) < 0)
| 682 |
error(USER, "unexpected EOF on input");
| 683 |
| 684 |
lastray = lastdone = (RNUMBER)lastout;
| 685 |
if (raysleft)
| 686 |
raysleft -= lastray;
| 687 |
